View Full Version : Glow Engines
- CEN NT-16 - Which Way Round ?
- Tower Hobbies .75 Air Leak?
- fantom .15
- Reduced propeller diameter
- Top Flite Cessna and the Saito 1.50?
- ASP Four Strokes
- Engine Question
- 46 size evolution
- need a 90 degree header for OS engine
- YS140 Prop Choice?
- Royal .40 ABC Engine questions
- 15x8 3 blade on a 1.20
- Motor cuts after 5 secs
- damaged my saito 180..need spares
- New OS FL-70
- OS FS-40S-CX
- Tuned Pipe Keeps Burning Plugs???
- Power Panel ?
- Nipples
- MVVS 1.60
- Crankshaft, bearings on Magnum 91 4 stroke
- Which glow plug for YS 63 works better?
- Problem??
- Zenoah G23 Glow instruction manual
- Norvel .061 prop thread
- Moki 2.10 running lean when pointed up
- y.s. ac 1.20 fuel delivery diagram?
- My airplane is shaking like crazy with DuBro soft mounts
- Saito 1.20, max rpm, black oil?
- Four cycle engines vs. two cycles
- How long is a long term storage for using after run storage??
- The weight of a Saito .91
- switching throttle arm saito 56 [2002]
- How is this for a fuel delivery system
- Frozen Tower 40
- Webra P5 91 Aero
- Help Needed Identifying Piston/Sleeve combos
- YS 63 and Tru Turn Spinner
- Gettin' a "clickin" sound from my OS 46AX when starting up? Don't like it..
- New Engine Break-in
- starter for os 160 and break in procedure?
- universal engine mount?
- evolution motors
- Irvine 46 cutting out
- How does MVVS rate
- fuel filter question
- Any Norvel new AX40 Engine Owners Out There?
- mouse can muffler for 46fx?
- engine tuning help needed
- New Enya 155
- Mouse can question on header length?
- Can you Identify this engine for me?
- thunder tiger 54 four stroke
- magnum four stroke
- 4 strokes & ignitions
- Magnum 120 muffler
- 2 Blade To 3 Blade Prop
- Smoke
- GMS 1.20 BB Ringed
- 4 Stroke Tank - Pressure? yes/no?
- ultra stick 40 w/ saito 80 mount ?'s
- SAITO 182TD or 170Radial Selection
- Thunder Tiger Pro 90???
- Not the usual 91FX problem FIXED
- OS 120 Fuel Pump Connections
- carb for saito 120
- reliable and powerful .45-.50
- Looking for piston ring for HB .61 PDP
- Egas II
- K&B .65 sportster
- Saito 150 w/ C&H ignition problem
- wasp .26
- Small Four Stroke Wanted
- O.S. 40 LA "3D" prop?
- What can we use to soak engine cases clean?
- EVO .46 Please help????
- os 50sx or os 61fx
- TT .91 Faceplant
- 3 Blade Prop on an OS.52 4 stroke
- I measured a YS 63's actual weight
- VMAX Engine
- OS .50 SX, Props, RPM's....
- How hard is hovering on a 2 stroke engine?
- 4 stroke orientation ? (sideways, etc)
- k/b motor
- O.S. FS-91 II Surpass
- Swapping Carburetors - Advice needed !!
- Saito 72 rpm?
- Tower Hobbies .46 problem----------in---->
- OS 46AX what % of nitro?
- Help OS FP .15 Locking Up?
- OS 91 FX rpm question
- Moki 2.10 Exhaust Extension
- Interesting.....
- OS Ultimate 70 Surpass
- What do you have your YS 1.10 mounted to and how does it perform?
- YS tuning etc
- YS .63 or Saito .72?
- saito 65 on 40 stick
- HELP, Saito 100 inverted problems
- Help with OS 91 FX
- YS 63 spinner question - aluminum a must?
- super tiger engine
- Need Engine Weights
- Perry Pump Spring
- K&B
- os or magnum piston, ring and liner
- A helping hand
- My GMS.25 is JUNK !!!
- Fuel economy between OS and Saito
- OS 61 RF pumped engine
- Moki 150
- Are YS Engines Really Worth The Extra Cost
- Saito 90 Radial
- Irvine Engines
- K&B screamin .48 ????????
- Robert Eiermann's Webpage Address
- Saito .45 Mk II - Need Manual
- Best size fuel line for engines
- TT91FS
- Thunder Tiger service
- MECOA 46
- OS .91 Surpass... crankshaft woes.
- Detonation problem in surpass
- TT Thunder Tiger .46 Fuel
- TT ST TH or Magnum .46
- NovaMega S12 Specs? in my NTC3
- Saito 100 - Preignition
- HB engine
- siato 130 ft/tuning question
- Help Identify Older Super Tigre .75?
- pinging
- RCV engines-overheating
- Glow plug specs.
- New RMX engines!
- is this a good engine
- Magnum .91 Four-Stroke Inverted?
- what is tappet adjustment and how do you do it?
- Fox 15 fuel pressure ?
- Webra .50 idle setting
- OS 70 ULTIMATE 4ST
- Magnum XLS 52A
- new ys .63fz?
- Good deal on new ST2300 engines
- Saito 100 prop choice
- Fuel usage....OS .10
- MDS .61 Ruff Runnin'
- Magnum .15 XL Crank Replacement
- Exhaust routing idea
- Moki 2.10 Compression
- OS 52 surpass problems
- SALE on Magnum 91XLS!!
- 10% vs 30%
- OS 1.60 fuel line ?
- perfect engine rpm?
- .75 2 stroke?
- satio 100 big 3 blade
- Two 12 oz fuel tanks to work as one?
- Perry pump setup/adjustment
- Fuel Injection question.
- K&B 7.5 DF
- KLOTZ- Is there a substitute?
- Engine soaked..
- V- twins
- Magnum .52fs HELP
- Is a 4 stroke to much for a novice?
- 4 stroke without a muffler
- 4 stroke without muffler
- Saito .45 parts source?
- 52 Surpass = 70 Surpass
- Magnum 46XL carb?
- Saito 150 flying time on 12 oz fuel?
- TT46 -Drill out mounting holes
- Please help - MDS engine
- Thunder Tiger PRO 46 Manuel
- H.B. .40 engine questions...
- YS 63 shaft size
- Horse Power
- SAITO .91 HELP!
- .61 Thunder Tiger and 14x4 zinger would that work?
- Tuned pipe--no pressure nipple?
- OS Max engines- the sad demise.
- Fox 15 Question
- Saito 300 smoke mufler
- am i being cheap or what?
- Thunder Tiger .46 inlet position
- Can't decide
- YS 91 FZ fuel line set up?
- How about an O.S. 200+ series?
- Is it worth it?
- Macs muffler and OS LA25
- Fuel piping for Saito 91 on Funtana
- RCV 58 engine question
- 4*40 engine size
- ASP91 fuel consumption
- Saito 1.80 Prop
- Irvine 40?
- OS 120 111 P
- HB .40 PDP
- GMS Engines
- Check out this engine
- mvvs,enya or webra for twin setup
- Help me identify this pipe
- Header for Norvel .15 for tuned pipe
- YS 1.4 DZ verses Saito 1.8
- Pics of Perry Pump internals
- New OS 46 AX?
- HELP! Who made this motor mount?
- Engine dies when vertical help.
- What 3-bladed prop for a OS 52 FS
- Saito 100 prop. shaft.
- Super Tigre G51 bore size?
- Trouble with ys63
- OS 160 FX
- YS FZ 63 S
- anyone have a vid of a 5cyl radial running?
- Exhaust redirectors -- Pros -- Cons -- please
- Outside diameter of ASP radial?
- 4-Stroke spinner Nut question
- OS 1.08 BX-1 engine
- Most fuel efficient in the .40-.46 range?
- tuned pipes
- Magnum .61 casting leaking
- Magnum 40 carb
- couple of ??'s
- Hey guys.., lets talk about an..... O.S. FS 120S-SP ...... surpass SUPERCHARGED ENGINE
- IRVINE 61 Owner Manual
- Plz Help....Carb got Sliced!!!!
- Need OS Engine Help
- saito 100
- GMS .47 Help a new guy
- Help with Muffler_Assembly_Screw for TT46
- SAITO 91 Bearing change
- Saito .91 Idling Question
- Ys 91 fz engine questions
- O.S. CZ ??? Help me please
- runaway engine - what next?
- Mccoy engine 098
- prop size?
- Thunder Tiger .46 Carb
- OS FX 61
- prop 2 or 3 blades?
- Engine for 60 Ultra stick?
- ENYA 46-4C
- Webra 1.20 unverted
- g4500 wont fire?
- YS 91 A/C
- THUNDER TIGER PRO 120 ABC BB
- O.S. FS 120
- break in OS 46 AX
