PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Forum
  2. Spektrum and Carbon Fiber
  3. Spektrum Failsafe
  4. JR Rx service needed
  5. singal voltage
  6. AR 9100
  7. 9303 and AR 9000 receiver programming
  8. Lost an Aircraft - DX7 & AR7000
  9. Question on the 'hold' condition
  10. QuickConnect update and RX Giveaway time?
  11. Spektrum Air & Ground compatability
  12. 12x Multiple Servos-In-Line
  13. Spektrum and Optic 6
  14. No Antenna for Buddy Box?
  15. Warranty
  16. Pilot RX blinks
  17. Spektrum DX6 fuse
  18. P-LINK MODE , WHAT XMTRS HAVE IT ?
  19. RX giveaway clarification
  20. R610M and R610UL broken antenna
  21. Jr Dsx-9
  22. replacement antenna for DX6, available?
  23. 9303 setup for Scale Sailplane
  24. 10x fuse bypassing
  25. JR 9303 2.4 Range check
  26. JR 9303 2.4 Dual Channel Problem
  27. Need help with failsafe issue
  28. Dumb question but here goes!!
  29. DELTA WING & DX7
  30. Non-technical manufacturer question!!
  31. Having trouble setting up the flaps on the X9303
  32. DX6i and AR 6000's
  33. ey
  34. Kill Switch for DX7??
  35. DX-7 use with emocoteh
  36. binding DX7
  37. jr 820g servo.
  38. x9303 programming help
  39. Maximum receiver voltage
  40. R921
  41. G770 3D / 8900G voltage
  42. 9 channel Spektrum transmitter
  43. ARE FIRMWARE UPGRADED AR7000s NOW DATA(FLIGHT LOG) CAPABLE???
  44. DX7 and Ultra Stick Programming
  45. x9303 and DX7 Throttle Trim
  46. JR x9303-2,4Gh Graupner compability!!!
  47. JR and Telementry
  48. R921 battery ports
  49. Binding Spektrum DX6i
  50. SPM6200 Rx & 9303 Tx compatability
  51. .
  52. Servo lead mounting near AR7000?
  53. Can I cycle the batteries in my Spektrum DX6i Radio?
  54. DX7 to DX6 Trainer Mode- How To
  55. Flaps
  56. Danny, when was "QuickConnect" started.
  57. Which radio's have pc connection?
  58. R921, R1291 and AR9000
  59. Spektrum Tx module blinking LED
  60. Different Config. Latency
  61. DX6i mode change menu
  62. Why is it................
  63. Where to Buy a DSM2 System with Q.C.
  64. LEDs on the JR R921 Receiver
  65. Running the flaps on two separate channels
  66. 9303 tx only?
  67. jr reciver being wierd
  68. JR XP6102 Transmitter Problem
  69. JR791 Retract Servo power- 6V ok?
  70. Warranty Spectrum Return Form for defective Spectrum Servo?
  71. snap roll flight condition for 10sxII (heli)
  72. firmware update?
  73. 10X Battery Diode
  74. Service menu for 10SX
  75. Why do I feel so dumb all of a sudden?
  76. 9303 2.4 Frustration
  77. 9303 and flaps
  78. 9303 2.4 Binding Issue
  79. AR9000 and Data logger
  80. Changing modes
  81. DX6i included with Blade 400 3D
  82. Spektrum 2.4 Modules
  83. JR FM/PPM compatibility
  84. Spektrum DX7
  85. JP Radio with TIMER?
  86. FUTURE OF 72 MHZ RADIOS
  87. SPEKTRUM DX7
  88. 2.4 9000 rx analog servos will not work
  89. edit
  90. JR 12X MV
  91. Flap and alerions on ar 6200 with DX7
  92. NEW AR7000 BIND/DATA QUESTION????
  93. Powering the Rx via the Matchbox
  94. Lights up in R921!!!!
  95. JR XS3 Pro Question
  96. difference/ advantages DX6i vs Dx6
  97. Out of the office
  98. 10X Question
  99. Using JR reciever; Hitec servo.
  100. Bad servo - DS285? How to test?
  101. Truth or Myth about 2.4 antenna
  102. Lost my plane
  103. JR 8911 vs. 8711
  104. jr 921 Receiver two batteries
  105. Airskipper 50 install with DX7
  106. JR 12X vs 9303 Module
  107. JR DSX9 2.4 Ghz Australian versus X9303 2.4 ghz
  108. Help me pick a radio
  109. Dropped the Spektrum 7 chl RX
  110. REBIND HELP!!!!
  111. module question
  112. 2.4 and PCM
  113. XP783 will not arm motor
  114. Danny are you there? Please Help
  115. dx7 question
  116. Conflicting JR Transmitters
  117. Best rx power set up for 7 digital servos
  118. Danny, Dual ailerons servos with a 6102?
  119. Spektrum AR9100 question?
  120. antenna lenght
  121. JR 9303 2.4 Prog to Spektrum AR6200 Rx ?
  122. Resolution vs. servo speed
  123. Matchbox question
  124. SPEKTRUM VR6010 REGULATOR
  125. AR6300 JST servo adapters
  126. gas engines and 2.4
  127. JR-XP6102 ..Mode Change needed.
  128. Did Spectrum change DX6i recently (buddy cord compatibility)?
  129. Ganged JRSport servos
  130. JR 9303
  131. servo jitters
  132. initial power up
  133. Using JR 3801, 9303 9xII in UK
  134. AR-9000 problem...
  135. R1221 info
  136. Hitec Supreme FM Autoshift DC Receiver
  137. 2.4 Question
  138. 9303 W SX600 BUDDY BOX & FLAPERONS
  139. 9100 will not power up
  140. 921 RX install & Extension's
  141. Firmware upgrade instructions
  142. What does Spektrum mean by "Park Flyer
  143. Spectrum cordless link for simulator
  144. Antenna Location for 2.4 Radios
  145. DX7 and pull pull setup
  146. 9303 instruction cd
  147. AR7000 channel assignments
  148. Help with programming an JR XP8103
  149. DX2 going into failsafe
  150. Kudos to the Horizon Service Center!
  151. battery voltage drop capacitor - please clarify
  152. alarm volume DX7
  153. quick connect
  154. JR/Spektrum 2.4 GHZ Failsafe
  155. DX-7 Bind button green light
  156. Trim values between 6102 and x9303
  157. DX-7 system, not linking, or losing the bind.
  158. JR XF421
  159. AR9100 : 3 questions
  160. Dual receiver install
  161. Flaperons in a DX7
  162. Duel Rates with 2 servos on ailerons
  163. DX6 battery question
  164. WHAT RECEIVER
  165. Why wont it switch?
  166. 921 receiver
  167. 8103 module change?
  168. Quick Connect info.
  169. Flaperon Woes
  170. SR3100 Rx with a DX7 Tx ?
  171. DX7 vs JR X9303 speed response
  172. Have I covered my bases for Spektrum power?
  173. DX7 microflight/parkflyer package
  174. 14MZ Spektrum module Failing Range check
  175. JR XR3
  176. dimensions of JR's new radio case?
  177. Major glitching with Spektrum systems
  178. AR700 and flight log
  179. wich gyro
  180. Wich reciever?
  181. JR 921 with 2 batteries???
  182. “QuickConnect” Voltage Recovery System for DSM2 AIR receivers
  183. DX7 Binding AR7000,AR6200, AR6100
  184. Adjusting heli swash expo on DX7
  185. 12X/m advertisement ???
  186. 6 or 7 Channel Radio?
  187. JR Scan Select Receiver 2000 / 21000
  188. DM8 in FUTABA 9ZHP WC2
  189. XP 7202 Change in Mode 2 to Mode 1
  190. DX6i throttle stick
  191. 12X Available next month?
  192. Tight 921 RX Mount
  193. New AR7000 receiver
  194. 9303 Kill Switch hold on - let go off
  195. XP9303 Help Needed
  196. dual elevator
  197. spektrum and carbon fiber!
  198. JR Single Stick Transmitter's
  199. I have DX6i and DX7 Which do I keep???
  200. DX7 Rudder Dual Rate Problem...
  201. TX crystal for JR s400
  202. Futaba9c and Spectrum Module
  203. X9303 Can I bind Flaps to Ailerons?
  204. trainer mode 9303 2.4Ghz vs dsx9
  205. dx7 not binding
  206. Spektrum Module
  207. Spektrum DX 3.0 Cuts off intermitently
  208. Specktrum DX6i trainer port
  209. AR9100 Quick Connect
  210. DX6i & Flaps
  211. 2.4 Failsafe Support
  212. Spektrum channels ?
  213. Request the 12X manual be made available
  214. AR 9100
  215. 10X Radio service
  216. spektrum lockouts
  217. DM8 alternate 2.4 antenna
  218. 11.1v Lipo for JR10X Transmitter ??
  219. 1100mh battery fuse
  220. A123 batteries-JR retract servo
  221. DX7 Aileron Setup Help
  222. DX6i Timer?
  223. deleted
  224. DX3 Trouble Shooting
  225. X9303 programing questions
  226. xp7202 tx battery 600mah
  227. JR 652 transmitter
  228. JR X9303 and Spektrum 6200 Flight Mode problem
  229. xp7202 time function mode ?
  230. Using my DX6 with Mutiplex Easystar
  231. jr 8321 servo specs
  232. XP 7202 WITH NORMAL RECEIVER ?
  233. Receiver installation help
  234. 2 servos on rudder and front wheel?
  235. R1221 rx any thing like the R922?
  236. Cross-mode with buddy cable?
  237. DX6i NiCds and Charging Info Needs
  238. PLEASE HELP
  239. Buddy box with a DX6i or DX7
  240. 9303 2.4
  241. F400 JR Radio
  242. Hello Danny.need advice on 500A gyro
  243. 6100 7000 swap out?
  244. Analogue Throttle Servo?
  245. JR 9303.2.4 Modes.
  246. Advanced Range Testing Results
  247. Futaba/JR compatability
  248. dx7
  249. DX7 lost my model memory
  250. DX6 features
