PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. binding issues
  2. delta wing setup
  3. xp9303
  4. AR7000 problem!
  5. JR Receiver NER-649S PCM Question
  6. BROWNOUT AND THEN THIS. WHAT DOES THIS MEAN?????
  7. Spektrum Programing
  8. JR 9303 2.4GHZ BINDING...MUST READ!!
  9. Flaps on Cessna with 7 servos/DX7
  10. Sub Trim
  11. AR6100 in FlyZone Cessna 182
  12. Auto Flap setting on DX7 and X9303
  13. Binding problem
  14. AR7000 DSM2-7 Receiver Upgrade
  15. Spektrum DX6i
  16. 9303 timer question
  17. Twin engine setup with JR 10 SXll
  18. DX6i in UK?
  19. 9303 + Flight Modes
  20. DX7 Trainer Mode
  21. xp 7202 FIRST CHARGING
  22. 9303 2.4 TX Battery cycling ?
  23. JR 9303
  24. AR 7000 Binding Question
  25. DIFFERNCE B/W 7202 & 2702
  26. spectrum dx2.0
  27. Spektrum DSP75's Oscillate
  28. 7202 memory freeze up
  29. mounting 921
  30. AR9100 Question?
  31. trace rate
  32. JR XP 7202 WANT TO BUY ?
  33. JR 3810 gyro menu options
  34. 6 Volt for Spektrum
  35. Spektrum 6XI Question
  36. Binding More Receiver's
  37. AR7000 RX issues
  38. DX7 Flap on Boomerang Intro
  39. DX7 Mixing
  40. 9303 battery cycling
  41. New JR Battery Packs-EC-3 ?
  42. Any way to get around "model match"?
  43. JR 7202h and FSOne
  44. 921 receiver questions
  45. R921 battery
  46. X-378 help please, pitch, elevator reversed?
  47. JR 8103 Trim Offset help
  48. JR 9303 twin settings help
  49. Quick Connect "Feature"
  50. JR 9303 heli or air 2.4ghz
  51. definition of a brown out (spektrum DXS-7)
  52. Low Range on JR-10X / 2.4 ghz
  53. DX3R question
  54. 12x switch locations
  55. Plug in Capacitor
  56. problem BINDING a DX3R system
  57. Remote Extensions
  58. DS821 servos
  59. JR R10DS Reciever.
  60. Are X9303 printed manuals available yet?
  61. Spektrum X9303
  62. DX7 question on setup.....
  63. Will futaba and hitec servos work with spektrum RX
  64. DX7 TX with R921 COMPATABILITY QUESTION
  65. Changing Modes
  66. JR MATCHBOX REVERSE
  67. JR921 receiver
  68. 9303(2.4)/DX7 Data Transfer
  69. 9303 snap roll problem
  70. use of "other" 2.4 receivers
  71. X2610 and CROW
  72. Servo Question
  73. AR7000 Hookup for Trex 600
  74. Wing Servo Mounting
  75. JR921 remote receiver
  76. DX7 split elevators
  77. xp 8013 prblem
  78. 9CAP using Spektrum
  79. DX7 Setup Options for Esky Belt CP Heli
  80. Is the DS820G servo compatible with the 401Gyro?
  81. 12x
  82. DS8717 in 50cc?
  83. DX3.0 Cutouts of Doom!
  84. JR 6 Channel transmiter/Throttle Adjust
  85. MX-22 (JR 9303) , JR 10X + Spektrum Module: Voltage Display Error
  86. Optical Kill w/DX-7
  87. JR Radio and Hitec 6S Receiver
  88. DXS-7 Loss of binding
  89. Met Danny!
  90. AR6300 Pinouts?
  91. DX 7 loosing its Bind with receiver
  92. Glitching
  93. DX6I power settings
  94. Firmware Fix ?
  95. fast connect
  96. Can't get AR9000 to Bind
  97. JR R790 Rx
  98. Customer Service is not dead - Re: AR6100
  99. 9x crow mixing
  100. converting 35MHZ to 36MHz
  101. 9303 dual elevators
  102. light just flashes
  103. DX7 Heli Comptibility with AR Receivers
  104. antenna mod
  105. Upgrade radio for future
  106. Spektrum Flight Log - Compatible Rx?
  107. JR - New Battery Design's ?
  108. 2.4 Antenna question
  109. DX-7 TX - What's the Top Bar on LCD?
  110. 9303 with module vs.x9303
  111. HDX500 heli with Spectrum problems
  112. humming noise from 9303
  113. DX6 TX Battery Question
  114. Digital Servos (DS285) - Rattle?
  115. JR G550T gyro...
  116. trouble with ar6200
  117. 9303+Spektrum Module Battery Issue
  118. DX7 with duel batterys
  119. 9303 2.4 power up issues
  120. WHERE IS DANNY???????????????
  121. DSX9/X9303 Tx Batt.
  122. Binding Second 921 RX
  123. 9303 2.4Ghz programming
  124. airtronics to jr
  125. 7-Channel RX
  126. JRX9303 and dual RXs
  127. X9303/R921 Resolution/Reboot
  128. X9303 2.4GHZ Servo Centering
  129. DX6i Power Setting
  130. PBY
  131. Data Safe 2 for 9303
  132. Second DX7 question- power up failures?
  133. DX& - channel mod question
  134. JR Servos and A123 batteries.
  135. X9303 Aileron Travel Variance...
  136. Is there need for Powerbox?
  137. I need Help with AR6100 Antenna
  138. 9303 flap swtich assignment
  139. Will Spektrum remote receivers work with the JR R921???
  140. Binding?
  141. Trottlecut on DX-7
  142. 2.4GHz PCM 10X radio
  143. Two batteries into AR9000?
  144. X9303 Range Testing Question
  145. WARNING 'F' MODE What do I do?
  146. XP9303 "Parking Brake"
  147. Battery 4 dx6
  148. JR X2720 Backup Error
  149. DX6i Questions
  150. Spektrum lock-outs
  151. Spektrum DX3.0 short range problem
  152. dx7 tx problem
  153. Spectrum radio & Servo question.
  154. JR X9303 2.4 TX Battery Cycling ?
  155. Spectrum DX-7 and mixing..
  156. Spektrum modules and Futaba Tx
  157. Wrapping AR7000/R921 Rx with foam?
  158. XP783 Tx dead
  159. SPECTRUM DX 7. (TX)
  160. 9303 72/mhz to 2.4ghz Question
  161. XP783 - Plugged battery in backwards (opps)
  162. 8717 servos
  163. 12X universal transmitter
  164. Spectrum Buddy Box W/ Futaba
  165. 6100e Receiver Problem ????
  166. pro spektrum vs. non pro
  167. Spektrum Sat. receiver
  168. 10X pilot link
  169. Spektrum DX7 Mode 1 and Mode 2
  170. Dx7 question
  171. Spektrum Receiver new "Quick Connect" feature
  172. Copying from a 9303 to a 10X?
  173. DX7 flap setup for Raptor
  174. Spektrum AR9000 RECEIVER
  175. JR X9303 2.4 PROBLEM
  176. Remote receiver's antenna wires are MIA
  177. AR 9000 Question
  178. DX7 EFL Paunee
  179. 8411 to 8311 servo conversions
  180. DX 7 CLUB
  181. DX7 elevator dual servo programming
  182. Danny, need your help on this one....
  183. Mixing flaps--JR9303
  184. Timmer and throttle
  185. AR7000 Receiver on 6.0 Volts
  186. Model transfer from DX7 to 9303 2.4 ?
  187. 12 Channel Spektrum Question
  188. X9303 and R921 affected by outside "interference"
  189. DX7 Throttle ratchet worn out
  190. Just a quick gripe...
  191. 2.4 Ghz 9303 Rx power capacity
  192. Question about DX-7 and AR6100 not connecting?
  193. DX6 TX battery doesn't hold a charge?
  194. METAL GEARS FOR JR SERVOS
  195. PROGRAMING FOR ULTRA STICK 60 QUAD FLAP??
  196. JR9303 2.4Ghz LCD contrast
  197. Strange results with my DX6???
  198. JR 6102 and 30% Gas
  199. X9303 + R921 Receiver WIERD BEHAIVOR.
  200. How do you hook up separate gear battery 4.8v?
  201. Danny,whats the 9303 output power?
  202. DX6 Help
  203. DX7 binding and failsafe questions.
  204. Need to reverse DS3421 servo. How?
  205. JR Sport MN48 "MINI" 6 volts?
  206. Which JR Servo???
  207. reciever compatability
  208. DX-7 Trainer Mode
  209. Replacement Memory Battery on JR 10X
  210. Center the TRIM. DX7
  211. DSX-9 Vs 12x
  212. Danny - 9303 service advice
  213. Tx X9303 Rx 6200 Rx pwr on Throt not safe
  214. JR 8103 Fuse
  215. DX7 (Battery) exploded
  216. Mixing Digital and Analogue Servos
  217. Contrast on X9303 screen
  218. Default settings
  219. Battery voltage drop?
  220. What is JR thinking?
  221. Spektrum battery issues.
  222. need help with JR!0x
  223. Airtronics Reciever issue where to buy
  224. Another DX7 Question
  225. X9303 Kill Switch
  226. JR 9303
  227. Split elevator problem
  228. DX3.0 3rd channel
  229. Dx6 battery and charger
  230. Air & Heli DX7
  231. FLY RC Mag & JR 12XMV
  232. Battery for AR6100
  233. Trainer Setup trainer sytem with new DSX9 / X9303 and old JR631
  234. 8103 programing question
  235. mode 1 vs. mode 2
  236. What Servo for this?
  237. using a JR amplified Y harness with a Spektrum system??
  238. JR Buddy Box as 72MHz Radio?
  239. DX7 Programming Guides
  240. Data logger numbers on R921RX ?
  241. Thanks
  242. A123 batteries on AR9000
  243. New Spectrum module in 3810 making voltage fluctuations
  244. When to make RX decision ?
  245. JR x9303/dsx9 Mode transferable?
  246. JR 7202
  247. Spektrum flight log - which receiver ?
  248. Dual Elevator servo setup on 8103
  249. Spektrum Issue/DX6i QUESTION
  250. R921 antenna question
