PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Servo Question
  2. DX7 Trims
  3. JR R921
  4. DX3 has barely any steering to the right
  5. Spektrum receiver recommendations
  6. Spectrum voltage protection?
  7. FUT Compatable Modules w/ More Channels ?
  8. AR6200
  9. X378 JR Radio, Pulling My Hair Out Here
  10. Fast charge for a JR 8103 DT Radio
  11. PCM9X(9303)FLAPERONS SET UP.
  12. DX7 and carbon
  13. X9303 draws current with power off; XP9303 does not; why?
  14. DX6i
  15. 9303 losing model name ?!
  16. AR9000 vs AR9100
  17. 10x and glider programing
  18. RX power supply
  19. Spektrum and Twin Flight Packs
  20. JR X9303 2.4g throttle expo??
  21. Advantage of Upgrading to R2000
  22. Hiding the wire
  23. JR XP6102
  24. AR9000 vs AR921 ?
  25. Throttle expo on DX7.
  26. Binding DX7
  27. Buddy Box for DX7
  28. XP662
  29. XP7202 Memory 2 to 8 freezzed
  30. Jr Module/RX
  31. 9303X, all dual rates on one switch?
  32. DX6
  33. 7202 programming help
  34. JRPA135 Y Length
  35. 2.4GHZ for JR
  36. AR9100 regulation
  37. Battery for AR6200 receiver
  38. AR9100 BATTERY INTERNAL IMPEDENCE
  39. pooched Jr XS3 pro
  40. Constructive question
  41. 9303 2.4 timer
  42. What is Z modulation for JR 9303
  43. X9303
  44. 10sx to a 10X transfer?
  45. JR 9303 transfer question,,
  46. DX7 with long servo extensions
  47. JR Unlimited 8 with Spektrum module
  48. Were is the right place to debate issues DANNY??
  49. AR 9100
  50. Spektrum receivers fail in flight!!!!!!
  51. Battery for AR7000
  52. Selective channels on trainer?
  53. WHICH SERVO ARMS FIT DS821????????????
  54. 9303 and flaps
  55. AR 6000
  56. 8611 8611sa
  57. Question regarding JR G500t gyro...
  58. 9309 2.4 and aluminum TX tray
  59. DX 7 & JR 9303 Trainer compatible?
  60. XP9303 reversed polarity problem
  61. X9303 2.4 legal in EU?
  62. Re: 9303 2.4 recievers
  63. JR Gyro recommendation
  64. Datasafe 2 with X9303
  65. SOURCE FOR MORE EXPANSIVE GUIDANCE FOR THE X9303
  66. Spektrum Futaba 9Z module question
  67. 9303 AR6200 problem
  68. JR NES 3021 servos
  69. DS821 question
  70. JR DSX9 and 9303 2.4
  71. Question about the AR9100 RX and Lipos
  72. AR9000/ DSM2 glitch on jet
  73. New Batteries
  74. A few DX7 questions
  75. AR9000 bind question
  76. Spektrum module for JR
  77. JR 791 intermittent operation
  78. What is the formula for EXPO ?
  79. JR XP27202 Mode 2 Heli Model -- Does not Power UP
  80. NEW Spektrum RadioW/ Full Range AR6200
  81. 8103 Smooth Throttle
  82. Very Much shorter range than normal for my PCM9XII/9303
  83. QQ and 12X
  84. Out of the office until 11/14
  85. deleted
  86. PCM9Xll stick calibration.
  87. Trace Rate Question on 10x
  88. I4C and X9303 Compatibility
  89. DS3421 on Futaba receiver
  90. Servo Plugs are Reversed
  91. Reversing Switches
  92. X9303 2.4 and AR6100
  93. JR XP652 how to Aileron & Rudder identical
  94. 9303 and Exponential
  95. LiPo batteries for DX-7
  96. Throttle cut set up at XP8103 (asia XP3810)
  97. light receiver for 45'' electric plane?
  98. JR 9303 Spektrum makes noise
  99. Flaperons
  100. Question on the DS821
  101. JR Transfers
  102. Crossed trims
  103. Digital Servo & Receiver Current Meter
  104. Bing Plug holder thingy
  105. THANKS TO RANDY IN HORIZON SUPPORT
  106. DX7 and Spektrum ROCK!!
  107. Direct Support Forum posting rules
  108. Transmitter Carrying Case
  109. JR 8611A's. Noisy, Hunting, Help !
  110. DX6 setup problem with 401 gyro
  111. spektrum stick modes
  112. JR 9303 2.4
  113. g770t, g7703d
  114. Low voltage capacitor
  115. Multi Servo 40%set up
  116. AR9100 SPECTRUM RECEIVER
  117. Buddy box with a 2,4Ghz remote
  118. fail safe on the bench
  119. JR921 won't link up, won't re-bind - intermittently???
  120. X9303 - 921 Receiver Question
  121. Spektrum/JR 2.4GHz radios
  122. To bec or not to bec
  123. 10X with Module Flap Setup question
  124. X9303 NEED AILERON SETUP HELP
  125. Throttle lock for electrics on 9303 2.4
  126. PCM
  127. X9303 Crow set up for turbine - Answered Already
  128. CCPM interaction on XP7202
  129. New 9303 2.4 ..no smooth throttle plate!
  130. Defilbrator and DX 7
  131. JR 7202
  132. Spektrum receivers fail in flight!!!!!!
  133. 12X delayed until spring/summer 2008
  134. spektrum dx3 mannual
  135. Han9 B-25 and 9303 Programming
  136. Changing Tx Batttery on 9303
  137. Digital Servo Programming
  138. JRxr2i Radio system
  139. Jr 12 x
  140. Received Info
  141. New DX7 and AR6100 won't bind.
  142. X9303 2.4 Transmitter
  143. Radio Help
  144. DX6i manual
  145. dx7 trim problem
  146. DX7
  147. Throttle Exponential - Airplanes
  148. Troubleshooting AR6100 Reset on Small Park Flyer
  149. 9303 2.4 Transmitter Shipped
  150. 10X and Spektrum module
  151. 8103 programming question
  152. JR XP8103 Heli crystals
  153. DUAL RECIEVERS
  154. Understanding the DX7 - Setup for a heli
  155. JR R921 Dual Power Input and other ???'s
  156. I hope someone is listening!
  157. SPM9540 COMPATIBILITY
  158. Out of the office until 10/29
  159. X9303 Manual
  160. 9303 programming question using separate servos for each elevator half
  161. JR 2610 Aux2 switching
  162. JR reciever battery wiring question
  163. Hope JR can match this
  164. Position of AR7000 sat. rx in 29%
  165. Buy the ar9000 or wait for R921 any difference?
  166. AR7000 Questions for Danny
  167. tx attenna question on 8103 spektrum tx module
  168. Question on the DS821
  169. 2 servos 1 port
  170. Fades, and frame losses ?
  171. DX7- Need Help setting up dual elevator mixing.
  172. walkera #37 and spektrum dx6 Tx
  173. X9303 switch labeling confusion?
  174. DX 3.0 set-up in Traxxas XL-5 Rustler
  175. Spektrum DX7 Dead
  176. G770-3D
  177. Loosing bind on 9303
  178. JR10X - 4-servo flying wing
  179. Bad jitter on my DX6
  180. How do I?
  181. Spektrum & JR servos
  182. Sub-trim effecting Servo Monitor Screen
  183. charger question
  184. SX 600 Question
  185. Hellooo Danny? DX7 Fail-Safe Question
  186. DX6 Problem - servo jumping
  187. JR X9303 Carrying Case foam inserts
  188. DX7 Spreadsheet
  189. Case for R790
  190. broken rx
  191. 12x 72Mhz
  192. jr 9303 2.4 g ??
  193. JR 9303
  194. JR 8103 and Futaba 401 Gyro Prog. Help
  195. Buddy Box for the DX-7
  196. Assigning D/R's to a single switch 9303 2.4
  197. just askin about the dx7
  198. JR x9303 2,4
  199. JR 8103-Mode1 to Mode 2
  200. Dual RX's
  201. can I use my 4 cell rx nicad packs with the AR9000
  202. ar7000 install
  203. Still Isolate Your Ignition from 2.4 Ghz Radio Systems!
  204. Spectrum FAILSAFE
  205. need TSB re: analog servo mixed with digitals
  206. spektrum dx6 hook up to real flight simulator
  207. New x9303 2.4
  208. Binding X9303 - 2.4
  209. JR xs3 pro
  210. Need help with 8103 mixes.
  211. 9303 4 servo wing programming
  212. Question About Range Checking
  213. Powerbox Needed?
  214. JR DS821 Servo Not Recommended on Giants! Why?
  215. how does x9303 detect 10 bit vs 11 bit rx?
  216. AR9000, what batteries?
  217. 9303 manual on CD problem
  218. X9303 2.4 GHZ transmitter charging polarity
  219. Servos and 5 cell nicd packs
  220. 9XII help
  221. DX7 Connections
  222. JR/Spektrum 2.4GHz receivers and rx antennas; how many and what type?
  223. Changing 2610 to Mode 2
  224. B1 Hybrid Gear: 8231,8411,8550 (1)
  225. DX6 Wing Programming
  226. XS3 problem
  227. JR PCM 10 modules
  228. throttle cut off
  229. 8417 with G500T
  230. A REALLY EASY DX7 QUESTION-TRIM SWITCH OR SLIDER?
  231. X9303 and Duralite TX Battery - OK???
  232. Spektrum binding to a MRX-3000?
  233. Battery setup for 28% Edge
  234. JR 12X
  235. pcm 10sx gear switch to throtle mix for smoke
  236. XP9303 throttle kill
  237. DX7 Programmable Trainer Function??
  238. Spektrum and Powerbox 40/24 ?
  239. jr xr 3 question
  240. JR 610m glitching
  241. DX3 in a Revo?
  242. DX-7 Trainer
  243. X347 Parts Availability
  244. AR9000 Flashing on binding?
  245. DSM2 DX7 with AR9000???
  246. 9303 Mix 1&2 multi point
  247. Specktrum, for What it's Worth
  248. spektrum dx6 charger/rx/batt channel
  249. Jumping Servos
  250. DX7 RECEIVER CHOICE
