PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. DX 7 TX batts
  2. AR7000
  3. 35 mhz Crystals
  4. Graupner MC 12 small anttena
  5. 8103 Flight Mode for Dual Rates
  6. DS3328 vs DS3421 question
  7. X9303 New Ship Dates (estimate)
  8. Inhibit beeps?
  9. DX-7 Tx Antenna issue
  10. Flaps & retracts on DX7?
  11. Update on my 7202 "Issue"
  12. Idle up on Ail d/r switch?
  13. where do I buy spektrum dx6, rx, 4servo
  14. Graupner compatibility??
  15. CAD drawings of JR servos
  16. 9303 Switch assignments
  17. Flaperon menu
  18. DX6 Trainercord mono or stereo plugs
  19. AR-7000 RX Question
  20. Receiver Battery sizing
  21. 9303 spektrum module antenna
  22. Offset question
  23. Crash caused by xtal falling out
  24. DX-7 and endpoints
  25. Radio in for repair
  26. Spectrum DX6 system reciever/servo voltage
  27. Spektrum DX7 Problems
  28. My X-388S looks dead.
  29. Charging XS3 battery with MRC959, What charge rate?
  30. Quick and easy question Re DX-7
  31. 9303/Spektrum Tx power output?
  32. SPEKTRUM VOLTAGE PROTECTOR
  33. Danny...please don't laugh. Galaxy parts question
  34. where to buy a spektrum DX3 antenna?
  35. JR 8711 and amplifier
  36. DX-7
  37. BD-5B and JR digital servo JR DS285
  38. Next X9303 ship dates?
  39. jr xs3 frequency list
  40. Stryker and DX6 setup
  41. Spektrum DX-7 Dual Elevator and Flight Modes
  42. 9303 Spektrum module idea
  43. Telemetry
  44. set up probs with sx 600 to hitec rcd 3600 rec
  45. Please help with JR8103 and Trex programming
  46. How do I use 9303 to run 4 aileron servos?
  47. pcm receiver
  48. 9303, Aileron split?
  49. JR DS3201
  50. 9303 and VTR?
  51. AR-7000, AR-9000 differences ?
  52. AR9000 Possible Issue
  53. JR 3421SA Question
  54. Is the 2.4ghz 9303: 1024 or 2048?
  55. danny..my dx-7 seems to have burned up charging!!
  56. Service Sticky
  57. Tx 9309 idle up?
  58. jr 7202
  59. JR Battery Initial Charge
  60. 9303 Servo reversing problem
  61. Problem XP6102 - R770S
  62. Will a Futaba receiver work with a JR radio?
  63. older jr xp8103 ccpm question
  64. Jr 662 (max66) heli setup??
  65. will there be a 10 channel Spektrum module?
  66. DX7 Manual
  67. dx7 transmitter question
  68. JRPC222 charger and 2500mah 4.8V Ni-MH RX pack
  69. RX Antenna Replacement
  70. Replacing my 8103
  71. Where is trim offset on 8103?
  72. 7202 Lost Model #10
  73. JR RS310 with stock traxxas Servos?
  74. DX-7 fuse ?
  75. DX7 and jittery servos
  76. When is the 12X due?
  77. Spektrum Rocks!!
  78. DX-7 Battery Problem ?
  79. Crow setting and the X9303 ????
  80. JR 652 power
  81. X9303 ques
  82. Battery connector on Spektrum RX?
  83. 2.4 ghz Radiation
  84. twin stick mod?
  85. servo connectors
  86. Who makes Spektrum?
  87. JR and Color Screens
  88. Tx Battery Charging
  89. DX7 fuse/ max current draw
  90. X9303 setup help
  91. st125mg
  92. Spektrum DX7 Dead Screen.
  93. 9303 2.4 Data logging
  94. Are 2.4 gig JR & Spektrum Radios for warm weather use only?
  95. xp9303 Tcut on Left Lever?
  96. .50 size heli servos
  97. Any JR Dealers in Europe ?
  98. X9303 w/o receiver
  99. DS 821 servo
  100. 9303 ailerons programming
  101. Spektrum AR9000 Rx service bulletin
  102. x9303 with 4 Digital Trims ?
  103. 6V Supply to 790
  104. Six digital servo....too much loading on battery/switch harness?
  105. Re: mode 2
  106. Rebind or not ?
  107. X9303 Questions
  108. Lithium Backup Battery
  109. JR XP 6102 set up for TREX450
  110. NO receiver flashing when binding
  111. Century VII xmtr
  112. programing xp9303
  113. DX-7 Losing Bind
  114. Binding problem
  115. DX6 Flaperons set up
  116. DX-7 Air throttle curve
  117. Qestion about selecting vacant frequencies on DSSM2
  118. 10 sx mixing help
  119. Servo arms
  120. Securing Receiver
  121. JR DS 831 servos on unregulated 5 cell
  122. Program Flaperon Question DX7
  123. Binding without switch?
  124. JR 388 Transmitter
  125. DX 7 Mixing
  126. JR 7202 Springs
  127. Questions About DX7
  128. Spektrum Glitch
  129. Century 7 trainer port
  130. When will we see specs for JR 12X?
  131. messed up TX
  132. cycling a JR8103 battery
  133. new 8900g servo
  134. Failsafe position
  135. Spektrum and Century 7?
  136. Modding a DX6 for longer runtimes
  137. JR 9303 smoke pump set up on aux 1
  138. Battery requirements for JR G500T gyro...
  139. Are the days of 2.4 GHz systems already counted?
  140. Failed AR 7000 reciever
  141. Spektrum Module/AR7000 Not Consistently Connecting
  142. Fail safe on AR7000
  143. JR servo torque Kg to oz
  144. JR R770S receiver
  145. NEJ 900 gyros
  146. Carrying case for x9303...???
  147. TX 8103 Data Transfere Mode
  148. DX7 and AR7000 won't bind
  149. What's this?
  150. XS3 Pro lacking Adjustable Trigger
  151. JR Sport S400 as buddy box w/DX7?
  152. Servos no work!!!!!!!
  153. 9303 2.4
  154. antenna adapter ith ar7000
  155. How many ways can an AR9000 be bound
  156. dx7
  157. jr 9303 idle up switch?
  158. could you make 7.4 volt servo's
  159. 8103 Question?
  160. Spektrum/Carbon Cover
  161. How do I use Aux 3 Lever for choke
  162. Thumbs up to Horizon!
  163. Spectrum DX7 programmable mixing
  164. AR-7000 signal blocked ?
  165. DX-7 (ailerons...two servos...two channels)
  166. Flapron question
  167. Split Elevator Trim Set Up on PCM 9X
  168. DX7 CP PRO SETTING QUESTION
  169. Heli vs Air DX7 radio
  170. DX 7 CHARGER.
  171. Battery scare
  172. AR9000 Problem
  173. DX7 programming
  174. What radio for gas boat??
  175. XP9303 and aileron differencial
  176. dx7 settings help
  177. Tx modual
  178. Spektrum repairs
  179. changing board in TX for a different channel?
  180. JR Charging Plug Mount
  181. 9303 Twin Engine Programing
  182. DX7 twin engines servos mix
  183. 9303 Springs
  184. 9303 and S400 buddy box question
  185. DX7 TX Battery Not Holding Charge
  186. Question re: which trans/receiver to buy
  187. AR7000 Satellite Failure Mode
  188. spektrum dx3.0 GLICHING?????
  189. JR X9303 with Spektrum TX Systems
  190. DX7 size
  191. Serial Interface
  192. THEY DO EXIST!!!
  193. New JR 2.4 surface module
  194. Spektrum remote receiver extensions
  195. 2.4ghz technology
  196. Split elevator rate setup question
  197. DS 8411
  198. 9303 and Spektrum 2.4 help
  199. Will the DX7 handle .30, .50, and larger size helicopters?
  200. I think my gear switch is broken...
  201. Airplane or Heli Spektrum
  202. video of my Swash not staying level through all 3 modes... plese help
  203. How many 2.4gHz at the field are too many?
  204. binding problem.
  205. Ar9000 problem discovered last night
  206. Servo troubleshooting
  207. 2.4 GHz and PCM9XV2
  208. 7 channel v 10 channel
  209. Question about versatility of DX7
  210. Using an Older Radio
  211. DX7 Feedback
  212. Plug type/size on the AR9000/AR7000 receiver
  213. New 8611A's - Noisy Geartrain
  214. JR Flight packs
  215. Internal differences between the JR and Futaba modules
  216. PCM Module crystal?
  217. Back-up lithium in 8 yr old JR X388S
  218. Servo comparison?
  219. More 9303 Setup Questions
  220. Are they the same?
  221. Spektrum DM9 module in PCM9XII issue
  222. DX7 and carbon fibre
  223. 10x - Throttle Curve Expo?
  224. AR7000 won't bind
  225. DX 7 Binding question
  226. Ground use systems
  227. DX7 and GY 401
  228. DS 821 Servos
  229. Spektrum DX7 Manual
  230. ST126MG
  231. UK Spec PCM9X11 Transmitter
  232. Set up radio and gyro
  233. DX6 on gas?
  234. 9303 airplane, heli, sailplane difference?
  235. DX7 AR6100 Rx with EFL25 CUb on Floats
  236. Servo Failed - JR MC35 Micro Sport Servo
  237. 10x pilot lights
  238. Ganging servos together
  239. binding AR9000 w/2 setups on same plane
  240. JR Receiver / T-REX Compatability
  241. Need Advice on XP9303
  242. AR9000 and Failsafe (Retracts)
  243. xp7202 programming
  244. dsm for 8103
  245. AR9000 and Matchbox
  246. 4721 vs 2721 servos
  247. DSM2 Remote Receivers
  248. DX6 and 7 conversion to NmHi batteries
  249. JR8103 Flap to elevator mixing instructions
  250. JR UNLIMITED SERIES VIII MODEL J128F
