PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. 9303 FailSafe Issue
  2. Spektrum DX-7 problem in Europe.
  3. X 3810 ADT Mode swap HELP
  4. spektrum2 problems
  5. Range check problems
  6. Gear set----9 series servo
  7. Matchbox, Current and Voltage +and -
  8. DX2 questions
  9. 10x xmtr charge problem
  10. Spektrum Air Module Output Power
  11. 2.4 9303 now on backorder?
  12. Looking for Spektrum facts
  13. *R790 Receiver Went Dead*
  14. DX7 7 channels?
  15. Spektrm DX6 Question
  16. SR3500 DSM 3-Channel Micro Racing Rx problem
  17. Battery Size for 8711 Servos
  18. JR upgrade question
  19. 9X lithium battery replacement
  20. DX7 Transmitter Replacement Antenna?
  21. XS3 pro receiver problem?
  22. Spektrum DX7
  23. 8711 gear wear
  24. Split elevator functions
  25. 10X-strange things going on?
  26. AR7000 problem
  27. XP6102 and SX600, Mode 3 or 4
  28. XP9303 Training bugs
  29. LiPo power for JR 10X
  30. XP8103 Secrets?
  31. 12X Fall release still on track
  32. Flaps with 7202 xmtr
  33. 6102 Transmitter Broadcasting Interference on distant channel
  34. JR 5 CELL PACKS - 6 Volt Regulator
  35. mode 1 as a master for training
  36. DX7/AR7000 occasionally doesn't link
  37. Dual elev set up with 7channel rx
  38. Jr and Futaba Compatability
  39. resuming post pages
  40. 6v wall charger
  41. mounting servos how tight?
  42. DX7 Swashplate Mixing EXPo ??? page 85
  43. Probable defect on JR RX RS10DS
  44. 8103 programming question
  45. Spektrum AR7000 Antenna Separation/Extension
  46. Transmitter balance
  47. HOW DO I USE?
  48. DX7 Binding
  49. Great Horizon/JR Service
  50. New JR 9303 2.4 w/921 RX
  51. Spektrum & Voltage Regulators????
  52. Moderator Please remove.. Double post!!
  53. XP9303 BIG problem!
  54. JR boxes aren't the same?
  55. JR pcm 9x11
  56. Trying to locate some old manuals
  57. DX7 for watercraft
  58. JR Hat
  59. JR 10X to JR 12X
  60. what batter can i use to bind my dx7
  61. Spektrum DX7 rx Battery Life.
  62. Gears for DS821 Digital Sport Hi-Torque Servo
  63. 9303 2.4g Shipping Status
  64. JR 10x upgrade to spectrum
  65. AR6200 support Flaperons
  66. JR PCM 9X2 help
  67. Aileron Prob w/ DX-7?
  68. My DX7 experience is a Bust.......so far....
  69. dx6 memory problems
  70. 8103 Question?
  71. ail-flap AND/OR ail-rudder? (sailplane)
  72. Problem with JR XP642
  73. AR9000 rx/module question
  74. 9303 Air - long delay in throttle response?
  75. Servo Travel
  76. JRPA212 length
  77. DSM2 Upgrade for DX6?
  78. Can i use my JR9 MK 2 TX converted to 2.4 with Trainer Chord?
  79. DX-7 Signal Shading Question...
  80. JR RS77S + JR Max 5
  81. currupt model program and 2,4g modual with 9303
  82. Will FHSS system prevent DSSS from finding clear channels?
  83. Brushless tail motor settings for JR x-378 TX
  84. Flaperons
  85. Which one better, between JR9303 and JR10X?
  86. JR XS3 help needed PLEASE!!!
  87. Binding issues with AR9000
  88. AR9000 and Voltage Regulator
  89. Ar 9000 crashworthy?
  90. z1's 3rd channel mixable??
  91. JR 4721 servos
  92. Can I use the AR6200 without the secondary antenna?
  93. Spektrum DX7 with FS One and Wireless Interface
  94. Smoke!
  95. Help MacMan!
  96. 9303 Manual
  97. AR9000 Data
  98. JR S400
  99. JR S400
  100. Spektrum DX3 with Venom failsafe
  101. JR and JR Sport servo splines?
  102. Crash with DX-7
  103. PCM9X and Kyosho Caliber 30
  104. 9303 with esky Lama4
  105. No Trainee
  106. XP9303 Transmitter ---Switch Assignment
  107. Flaperon slow down on 10X
  108. 3 position flaperons on 8103 tran.
  109. xp6102 in f3j sailplane
  110. ScanSelect Rx not Locking on
  111. Earth magnets and interference
  112. Antenna direction?
  113. Full, mid and off Flap setting
  114. Questions Related to HOLD function.
  115. 10x issues
  116. JR 10X as trainer
  117. AR 7000 voltage
  118. R921 vs. AR9000
  119. Can a 9303 be used on surface frequencies?
  120. DX7 3 position flap switch
  121. 9303 Trim Step
  122. Lengthening wires on satellite AR7000 receiver
  123. XP 783 Elevator Leaf Mixing Problem
  124. Tx synth module - damaged?
  125. Spektrum JR module and 9 Ch RX Whats normal?
  126. 2nd antenna on spektrum receiver
  127. 2.4 Ghz Binding one Rx to two Tx AGAIN
  128. receiver stopped working
  129. binding plug part
  130. DX7 high/low/kill throttle set-up?
  131. 72 mhz channels not available 14 and lower
  132. x347 Lithium question
  133. 2.4 Ghz Binding one Rx to two Tx
  134. We lost 2 planes this weekend
  135. DX7 plane setup as heli
  136. F-16 Flaperons
  137. XF421 radio questions
  138. AR9000 antenna and satelite antennas
  139. Help on servo twitching
  140. Slow Ailerons on Aux 5 of JR10SX
  141. I have a solution for the DX7 "backup error" !!!
  142. Chattering servos
  143. Number of channels for Spektrum module on XP9303?
  144. Heli Radio in Aircraft
  145. Problem solved / ignore
  146. Couple of DX6 questions
  147. Binding question..
  148. New X9303 stick modes
  149. Difference between car and plane servos?
  150. Mixing throttle and Aux 2
  151. Changing stick mode from 1 to 2 on x-3810
  152. JR Sport 600SX Buddy Box Cable Pinouts
  153. second battery for AR700 Rx
  154. Servo Returns To One Of Two Spots (Based On Stick Movement)
  155. Are two 8411 servos enough for 35% IMAC plane
  156. 9303 Spektrum Module and AR9000
  157. servos go crazy
  158. JR Repair address
  159. Spektrum 7 & AR6100 RX
  160. JR x2610
  161. R2000 Rx w/electric Pattern
  162. Trainer box with DX7 question
  163. DX7 and gyro
  164. RS6UL throttle channel problem
  165. HOW DO I CONVERT
  166. Setting up dual elevators on 8103 HELP!!!
  167. 7202 charger
  168. 9000 and satelite antenna
  169. A factory 2.4 upgrade from JR?
  170. Need help with spektrum
  171. JR 9303 2.4
  172. XP 378 Module
  173. AR6100 distance
  174. JR x2720
  175. R921 rx accessories available?
  176. 8700G SERVO ON 2.4
  177. Need Help with servo reversing
  178. HELP spektrum DX6
  179. Max Voltage on 8611's
  180. JR PCM 9x VII elevator mixing
  181. AR7000 Installation
  182. NES 527 and DS 811
  183. AR9000 RX
  184. servo cycling
  185. DX7 Programming Question
  186. Remote Receiver Question
  187. DX7 Problems
  188. DX6 Trainer Cable wiring
  189. RX Antenna installation
  190. Is JR7202 tx able to use different rcvr if i use JR crystals?
  191. Need JR servo/gyro recommendations
  192. JR 4500 nimh battery
  193. Telemetry system question????
  194. Jr radio charge post polarity
  195. WHAT THE DEFINITION OF "FORUM" IS?
  196. Electronics Compatability
  197. JR PCM9X program
  198. JR 2721 servo problem?!
  199. 9303 firmware
  200. R2000 receiver range problem
  201. retracts on h9 p51 77 inch
  202. 10X on Spektrum 2.4GHz
  203. AR9000 System on my 8103 - Servo glitching
  204. hrottle and rudder trims on my 6102 going crazy! Please help JR radio gods!
  205. question about JR PCM 10 (NET-A110FZ) radio system
  206. Spektrum DX7 need HELP!
  207. I Too Have This Problem: 7202 locking up accessing model 6
  208. Setting up G7000T Gyro
  209. DX7 and Charging.
  210. ESC connection to receiver
  211. spectrum dsm2 pin out version?
  212. Binding key
  213. DX7 and AR6100 binding
  214. 9303 Duck Style Ant.
  215. DX7 Tx Question
  216. How much is too much???
  217. 9302 2.4 Model Match
  218. Trainer button/switch
  219. Gas ignition RF noise
  220. JR Failsafe behaviour
  221. Travel settings on DX7
  222. Setting up a Spektrum DX7 & a buddy box
  223. Out of the office
  224. Programming the 9303 for a smoke pump
  225. servo oscillation when engine is running
  226. Spektrum Voltage Protector
  227. DX7 + AR7000 Lost Binding Issue
  228. 8103 and Schulze 32.55KA
  229. Receiver servo outputs for > 10 channels
  230. trainer settings - xp652
  231. X-388s Dual Rate
  232. SERVO ARM SCREW SIZE
  233. DX7 ok with FliteMetal ?
  234. DX7 and X9303 programming questions
  235. Purchase of JR XP7202 Tx Only
  236. AR9000 Binding Problem
  237. PCM 9X II - TX Module
  238. JR 8103 Question?
  239. Best radio upgrade choice?
  240. spectrumdx-7 with futuba 601 gyro??
  241. Help 7202 problem with locking up accessing model 6
  242. Spectrum elegal in Europe!?
  243. ds8711 & 5 cells
  244. AR6200
  245. JR 410T gyro with digital servo
  246. DS537
  247. Can't figure out how to make a buddy box work with a DX7
  248. Extending the 6 inch cable to the Spektrum 2nd rx?
  249. Programming 8103+9303 3 and 4 channel w/flaperons adjustment in Spoiler stick
  250. 2.4GHz for the ROTW
