- JR pcm 9x11
- Trying to locate some old manuals
- DX7 for watercraft
- JR Hat
- JR 10X to JR 12X
- what batter can i use to bind my dx7
- Spektrum DX7 rx Battery Life.
- Gears for DS821 Digital Sport Hi-Torque Servo
- 9303 2.4g Shipping Status
- JR 10x upgrade to spectrum
- AR6200 support Flaperons
- JR PCM 9X2 help
- Aileron Prob w/ DX-7?
- My DX7 experience is a Bust.......so far....
- dx6 memory problems
- 8103 Question?
- ail-flap AND/OR ail-rudder? (sailplane)
- Problem with JR XP642
- AR9000 rx/module question
- 9303 Air - long delay in throttle response?
- Servo Travel
- JRPA212 length
- DSM2 Upgrade for DX6?
- Can i use my JR9 MK 2 TX converted to 2.4 with Trainer Chord?
- DX-7 Signal Shading Question...
- JR RS77S + JR Max 5
- currupt model program and 2,4g modual with 9303
- Will FHSS system prevent DSSS from finding clear channels?
- Brushless tail motor settings for JR x-378 TX
- Flaperons
- Which one better, between JR9303 and JR10X?
- JR XS3 help needed PLEASE!!!
- Binding issues with AR9000
- AR9000 and Voltage Regulator
- Ar 9000 crashworthy?
- z1's 3rd channel mixable??
- JR 4721 servos
- Can I use the AR6200 without the secondary antenna?
- Spektrum DX7 with FS One and Wireless Interface
- Smoke!
- Help MacMan!
- 9303 Manual
- AR9000 Data
- JR S400
- JR S400
- Spektrum DX3 with Venom failsafe
- JR and JR Sport servo splines?
- Crash with DX-7
- PCM9X and Kyosho Caliber 30
- 9303 with esky Lama4
- No Trainee
- XP9303 Transmitter ---Switch Assignment
- Flaperon slow down on 10X
- 3 position flaperons on 8103 tran.
- xp6102 in f3j sailplane
- ScanSelect Rx not Locking on
- Earth magnets and interference
- Antenna direction?
- Full, mid and off Flap setting
- Questions Related to HOLD function.
- 10x issues
- JR 10X as trainer
- AR 7000 voltage
- R921 vs. AR9000
- Can a 9303 be used on surface frequencies?
- DX7 3 position flap switch
- 9303 Trim Step
- Lengthening wires on satellite AR7000 receiver
- XP 783 Elevator Leaf Mixing Problem
- Tx synth module - damaged?
- Spektrum JR module and 9 Ch RX Whats normal?
- 2nd antenna on spektrum receiver
- 2.4 Ghz Binding one Rx to two Tx AGAIN
- receiver stopped working
- binding plug part
- DX7 high/low/kill throttle set-up?
- 72 mhz channels not available 14 and lower
- x347 Lithium question
- We lost 2 planes this weekend
- DX7 plane setup as heli
- F-16 Flaperons
- XF421 radio questions
- AR9000 antenna and satelite antennas
- Help on servo twitching
- Slow Ailerons on Aux 5 of JR10SX
- I have a solution for the DX7 "backup error" !!!
- Chattering servos
- Number of channels for Spektrum module on XP9303?
- Heli Radio in Aircraft
- Problem solved / ignore
- Couple of DX6 questions
- Binding question..
- New X9303 stick modes
- Difference between car and plane servos?
- Mixing throttle and Aux 2
- Changing stick mode from 1 to 2 on x-3810
- JR Sport 600SX Buddy Box Cable Pinouts
- second battery for AR700 Rx
- Servo Returns To One Of Two Spots (Based On Stick Movement)
- Are two 8411 servos enough for 35% IMAC plane
- 9303 Spektrum Module and AR9000
- servos go crazy
- JR Repair address
- Spektrum 7 & AR6100 RX
- JR x2610
- R2000 Rx w/electric Pattern
- Trainer box with DX7 question
- DX7 and gyro
- RS6UL throttle channel problem
- HOW DO I CONVERT
- Setting up dual elevators on 8103 HELP!!!
- 7202 charger
- 9000 and satelite antenna
- A factory 2.4 upgrade from JR?
- Need help with spektrum
- JR 9303 2.4
- XP 378 Module
- AR6100 distance
- JR x2720
- R921 rx accessories available?
- 8700G SERVO ON 2.4
- Need Help with servo reversing
- HELP spektrum DX6
- Max Voltage on 8611's
- JR PCM 9x VII elevator mixing
- AR7000 Installation
- NES 527 and DS 811
- AR9000 RX
- servo cycling
- DX7 Programming Question
- Remote Receiver Question
- DX7 Problems
- DX6 Trainer Cable wiring
- RX Antenna installation
- Is JR7202 tx able to use different rcvr if i use JR crystals?
- Need JR servo/gyro recommendations
- JR 4500 nimh battery
- Telemetry system question????
- Jr radio charge post polarity
- WHAT THE DEFINITION OF "FORUM" IS?
- Electronics Compatability
- JR PCM9X program
- JR 2721 servo problem?!
- 9303 firmware
- R2000 receiver range problem
- retracts on h9 p51 77 inch
- 10X on Spektrum 2.4GHz
- AR9000 System on my 8103 - Servo glitching
- hrottle and rudder trims on my 6102 going crazy! Please help JR radio gods!
- question about JR PCM 10 (NET-A110FZ) radio system
- Spektrum DX7 need HELP!
- I Too Have This Problem: 7202 locking up accessing model 6
- Setting up G7000T Gyro
- DX7 and Charging.
- ESC connection to receiver
- spectrum dsm2 pin out version?
- Binding key
- DX7 and AR6100 binding
- 9303 Duck Style Ant.
- DX7 Tx Question
- How much is too much???
- 9302 2.4 Model Match
- Trainer button/switch
- Gas ignition RF noise
- JR Failsafe behaviour
- Travel settings on DX7
- Setting up a Spektrum DX7 & a buddy box
- Out of the office
- Programming the 9303 for a smoke pump
- servo oscillation when engine is running
- Spektrum Voltage Protector
- DX7 + AR7000 Lost Binding Issue
- 8103 and Schulze 32.55KA
- Receiver servo outputs for > 10 channels
- trainer settings - xp652
- X-388s Dual Rate
- SERVO ARM SCREW SIZE
- DX7 ok with FliteMetal ?
- DX7 and X9303 programming questions
- Purchase of JR XP7202 Tx Only
- AR9000 Binding Problem
- PCM 9X II - TX Module
- JR 8103 Question?
- Best radio upgrade choice?
- spectrumdx-7 with futuba 601 gyro??
- Help 7202 problem with locking up accessing model 6
- Spectrum elegal in Europe!?
- ds8711 & 5 cells
- AR6200
- JR 410T gyro with digital servo
- DS537
- Can't figure out how to make a buddy box work with a DX7
- Extending the 6 inch cable to the Spektrum 2nd rx?
- Programming 8103+9303 3 and 4 channel w/flaperons adjustment in Spoiler stick
- 2.4GHz for the ROTW
- 9303 assignable channels ???
- JR 8401
- 9303 question
- DX 2.0 antenna, I got a problem.....
- switching between models DX-7
- Activating dual positions on 5 and 6, DX6
- G500T and 6 volts
- Possibility of parameters change in JR2610 !!
- 9303 Latency Programming?
- jr xp 8103 help
- spektrum 2.0 help
- JR DS3421
- Availability of new products
- spktrum mocdlue for 8102
- Out of the office until 5/21
- Danny please help!
- Is this a Bad Servo?
- Battery and charger for DX2.0
- deleted
- XP642 Heli Radio
- Suggestion
- X-378 Switch Assignment
- Inside the DX7, internal antenna routing?
- Will a JR S400 buddybox to the XP7202
- 9303 timer
- Lost DX-7 contact ?
- RS70 Battery
- Hangar 9 Ultra-Stik Flaps
- Spektrum receiver battery?
- Wild Stik Dx7 setup help
- 9303 switch alarm
- 50 MHz FM Compatibility
- Servo arms, Spektrum =JR?
- sr3000 receiver broke?
- Range of the AR-6000 and Ar -6100
- How do I get a repair estimate?
- DX-7, Tx antenna orientation ?
- 9303 Choke safety
- jr x3
- DX-7 Charging Rate, an FYI
- 9303 throttle mixing questions
- DS821 vibration?
- Scratch on 9303 display
- Q's about suggested DX-7 batteries & chargers
- JR NER-790 Receiver channel lockout while flying
- 791 Retract servo problem
- 821's on a 12 pound Cap?
- 12x question
- DX7/JR7202 Software bug?
- It is normal ???
- JR RECEIVER WITH FUTABA SERVOS???
- JR X3810 adt mode3 trim display as mode1
- 8711 modification
- DS821 problems/limitations?
