PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Spectrum Radio?
  2. 10x on PPM
  3. PROBLEM ON MY 388 AND 3810 RADIO
  4. MX22 help
  5. DX-7 ar6100 problem
  6. DX7, AR6100, & Typhoon 3D -- CRASH
  7. Trainer on 7202
  8. Throttle curve on DX-7 ??????
  9. JR NES791 servo don't work with Futaba receiver
  10. manuals for 347 and galaxy 8 tx
  11. DX-7 programming for split elevators
  12. JR 9303 and split elevators
  13. 3 ch mix on rudder with 9303
  14. Servo recommendation
  15. Service Fee?
  16. What are the Major differences between the Sport series and the regular JR Radio systems.
  17. dx - 7 failsafe
  18. Will JR have their own 2.4 offerings?
  19. OOPS my 421
  20. * JR R790 Receiver*
  21. Broken xp 6102
  22. rudders as airbrakes with jr 7202
  23. Spektrum dx3
  24. AR 7000
  25. Jr X-378 backup battery question?
  26. XP6102
  27. JR8103 Versions?
  28. *Dual Elevator Setup On 7202*
  29. size of airplanes for AR6100?
  30. JR Sport SX600
  31. JR servos ST 126 MG
  32. DataSafe2
  33. 10X Aileron Problem (4 Servo Wing)
  34. XP 7202 dual elevator capability?
  35. Problem with new plane setup on JR XP6102
  36. AR9000
  37. JR XP652 with CPP
  38. *INTEG-T on 7202*
  39. JR servos ST 125 MG
  40. Spektrum DX7 Programing with a H9 60 size Ultra Stick
  41. JR-Spektrum
  42. JR 10X radio three modes for Yak 45 50cc
  43. Help: 9303 strange behavior
  44. Hitec Servo's on pcm 9 channel reciever probs
  45. JR PCM9X (9303) behaving strangely
  46. JR sx600 question
  47. Is JR owned by Horizon?
  48. G-450 Gyro ???
  49. JR 2720
  50. Radio Control JR pcm 9 X 2
  51. RS600 antenna
  52. DX7 wall charger
  53. Do I need a power expander or can the RX handle it?
  54. JR791 with servodelay ?
  55. JR PCM9X2/9303
  56. JR HAS THERE PANTS DOWN AROUND THEIR ANKLES
  57. 8611 servo shaft screw size
  58. 10X servo asignment help
  59. R720 rcvr with 7202 xmtr?
  60. JR PCM9X2 fault
  61. FYI DATA SAFE
  62. DX6 mode 1 mode 2 conversion
  63. Spectrum DX7
  64. 8417H Torque
  65. JR X 388S Tx False low voltage indication on LCD
  66. Spektrum
  67. Throttle trim delay question
  68. Tx Stick Extensions for JR PCM 10X
  69. How long before i can hook up a TX to my PC for settings?!?
  70. JR XP 9303 A/S
  71. 10SX mode 1 to mode 2 change
  72. Exp on x-378?
  73. Using a remote gain Gyro with 2610
  74. Service for an older JR radio?
  75. 9303 question?
  76. 7202 Screen Going Blank????
  77. Spektrum buddy box question
  78. JR 7202 'Input Selection'
  79. 8103 model transfer to 9303
  80. Z class JR radio
  81. 8511 servo case replacement different to original
  82. 8103 Programming for a sailplane
  83. Retracts cycling upon startup of DX7
  84. JR 791 servo and 6 v battery
  85. R-2000 Receiver
  86. JR10X
  87. 10X memory battery
  88. PCM10 Sevice Screen
  89. R649S Rx single or dual conversion?
  90. JR 9303 Battery?
  91. DX-7 servos?
  92. JR 783
  93. Dots on JR crystals
  94. 10x Tail Pitch Curve?
  95. 10X LCD Screen Contrast Low
  96. 4 engine mixing
  97. Warning Message on JR Radio
  98. JR Matchbox mounting near receiver
  99. Real Flight G3.5 with JR 9303
  100. Jr 7202 usb cable?
  101. notchy 9253/9254 servos with JR 7202?
  102. Problem with 9303 mixing
  103. JR MAX 5CH RADIO SYSTEM
  104. RECIEVER LOSS
  105. GOOP
  106. What recievers will work with my JR7202
  107. JR x2720 frequency
  108. jr 7202 pcm or ppm? or jr 9303?
  109. Current Draw
  110. JR Sport receiver (JSP30610) - problem in cold weather!
  111. JR 2700 tail servo
  112. 10x Buddy Box
  113. R790 and SX600
  114. ST-126
  115. x3810 ADT Mode change
  116. CHARGER NOT FUNCTIONING
  117. Spektrum Mode 1?
  118. DX7 Programing for H9 Ultra Stick 60 size
  119. 10X acro spares question
  120. PCM9XII - flaperons set up
  121. DX7 in 25%Yak/Servos
  122. Erasing Memory on 8103
  123. the future of the 10x
  124. Master Slave with 9303 and 7202
  125. JR Sport125 Servo's
  126. DX7 & Stearman
  127. 9303 battery charging
  128. XF 631 mode change
  129. XF631 Throttle Cut Switch
  130. JR XF631 mode change
  131. XP9303 Channel selection
  132. 10x quetion
  133. Another Crow Question - Re: DX7
  134. Jr Radio software problem
  135. 7202 and gyro sensitivity settings
  136. JR - Futaba compatibility
  137. module question
  138. 7202 discontinued ??
  139. New mx24s with another modulation
  140. 537 Servo Grumble
  141. TX vs RX crystals
  142. Exponential throttle adjustment.
  143. 8103/Dual Elevators
  144. Spetrum dx7 combo
  145. Throttle servo
  146. Throttle servo
  147. DEBATE
  148. 9303 Program Question
  149. Range on a JR 8103H
  150. Dimensions of JR 8103 Please
  151. 241mg servo availability?
  152. JR battery and charger
  153. Expert Electronics Extension W/Filter
  154. Slaved channel lag
  155. DX7 in composite sailplane - will it work?
  156. spektrum airplane vs heli
  157. crystal question
  158. 9303 Slaving Flap to Aileron
  159. JR 8103H, interface cable?
  160. Stummped on 8103 set-up
  161. Mini Servo
  162. Servo NES-537
  163. Servo NES-4231
  164. 9303 programming question
  165. Need some advice with DS821 digital servos.
  166. XP7202/R790 lock out on Airleron Channel
  167. 9303 Question
  168. E-flight receiver
  169. JR receiver question
  170. Still waiting
  171. PCM vs FM
  172. interfacing with computer
  173. JR R135
  174. Warning - F.Mode
  175. 8103 synthesized module
  176. Jr xp652 transmitter
  177. JR Heavy Duty Gold Servo Extensions
  178. Jr 10x crystal question
  179. AR700 RCVR - connectoin cable
  180. Need spare parts for JR 9303 / 9X2
  181. JR xs3 Pro not working properly!
  182. 8103DT Trim offset function
  183. Your recommendation to SECURE servo extension leads
  184. Flight Mode Set-up
  185. Reveiver Question
  186. Receiver Antenna Routing
  187. My Thanks to Horizons Service Centre
  188. Need help:9X II throttle stick movement problem
  189. 9303 or 10x
  190. DX7 speaker buzz
  191. Another DX7 BLANK SCREEN OF DEATH
  192. JR 8411 SA Returning to Center
  193. Spectrum radio... old vs new?
  194. JR receiver choice for micro/mini heli
  195. JR PCM 10X Heli history?
  196. battery question
  197. JR XP7202
  198. JR 783 - dual elevator servos
  199. Ne Jr 9xII from UK
  200. DX7, AR6100 and a Stryker?
  201. SX600 FM 6 CHANNEL
  202. DX6 - 8 hour run-time?
  203. DX7 BACKUP ERROR
  204. 10X backup battery life w/o main pack
  205. throttle trim problem on Dx7
  206. x388s
  207. ds3421
  208. 10X and Li
  209. pcm10 x and digipace 3 cycler
  210. Spektrum manufacturing
  211. Aux options - XS3 Pro
  212. Programming 7202 in H9 Skylane 182
  213. JR 7202 frequency changing?
  214. 9303 AND ULTRA STICK
  215. JR8103 Mixing ailerons to elevons
  216. X378 Dual Flaps
  217. pcm10x mode 3 it's possible????????
  218. throttle hold on jr 6102..how to ?
  219. high band rx
  220. Servo problems
  221. JR 4131 Servo
  222. 9303 + heli = questions..
  223. 9303 free mix ???
  224. READ ME FIRST (for all RCU members)
  225. ds821 dx7 servo defect
  226. R790 and 6102
  227. Correct DX7 Antenna Orientation
  228. Need TECHNICAL advice - DX6 Tx
  229. 9303 Servo Neutral signal
  230. X3810 ADT reset trimmers missing
  231. DX7 duel elevator and flaporans
  232. Charging 6.0 volt packs
  233. DX7 with Ultra Stick and Crow / Flaps
  234. TX Modules on 6 meters
  235. Karbinite gears
  236. my experience with JR Txs
  237. 6 volt flight pack for the DX7 ?
  238. EXTRA BATTERIES
  239. 6102 screen black outs
  240. JR 7ch Synth rx problem
  241. Help,Dual aileron servo setup x378?
  242. DXT binding to 6000 Rx
  243. 7202 help please!!
  244. Will there be an 8 or 9 channel version of the DX7 soon?
  245. DATA SAFE ULTRA
  246. 6102 charging issues
  247. JR 9303 slave doesn't reverse rudder
  248. DX 7 Supplied Charger
  249. Trainer switch
  250. Mode 1 change
