PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. *Servo Operated Choke With DX7*
  2. 8301 with buddy box
  3. XP 6102 and Gyro Gain settings?
  4. Which radio will work wit flight simmulator
  5. s-bec problem with JR reciever-poor range
  6. 9303 Antenna Stiff
  7. DS821 vs DS811
  8. Synthesising module on 7202
  9. Help me please and my Graupner MX22
  10. Crow on Ultra Stick 60 & JR 7202--Still can't get it!
  11. Setting up ignition kill switch with DX7.
  12. DX-7 Defect
  13. Need HELP with BUDDY BOX
  14. Lube and rebuild?
  15. Uses DX7 the SPCM-protocoll?
  16. 9303 & Elevator -> Spoileron mixing
  17. mx22 international pilot
  18. DX7 ????
  19. JR Receivers voltage
  20. setting up throttle switch
  21. Difference between JR 9X II and JR XP 9303 Remote
  22. Can this be programmed on a DX7???
  23. 8611A TBO
  24. Duel elevator servos
  25. Range Test
  26. Synthesized Tx Module for 9303
  27. 7202 Programing for Dual Elev. servos
  28. PLEASE HELP - SPECS FOR JRPS507 SERVO
  29. DX7 Receiver problem or safety feature!!!
  30. MAX Computer Heli to Airplane
  31. *JR 7202 Questions*
  32. Gear Sets
  33. Choke on Left slider switch/lever
  34. 19x to 9x2 data transfere
  35. JR flight mode activation
  36. Servo mounting adapters
  37. JR 7202 Flaperon Porgramming
  38. DX7 with Bad Glitch
  39. DX-9 (9303) ?
  40. looking for small reciever to use with JR 9303
  41. Jittering Servos
  42. JR XP6102 and gv-1 governor
  43. DX7 extra receivers and bonding
  44. MC 24 english manual?
  45. Datasafe
  46. Manual for XF622 Radio????
  47. DX7 Accessories #2
  48. 7202 Transmitter
  49. DX7 aircraft/heli version question
  50. MODE 1 ON DX7 ??
  51. minimum receiver batt size for DX7
  52. DX7 accessories
  53. DX-7 receiver battery. is it different?
  54. 9309 Black Screen
  55. Spektrum
  56. Spektrum DX 7 / Travel Adjust
  57. Using a Matchbox to change voltage
  58. JR 331 SERVO
  59. 8611 oscillates on pull-pull rudder
  60. DX7 And Interference
  61. JR r125 recievers
  62. 10x question
  63. danny i sent you a PM
  64. JR 9xII release throttle hold and it cut the engine
  65. JR 12 Channel System
  66. DX7 Charger issue.
  67. Strange question about magnetism...
  68. 2.4 ghz for 8103, 9303 etc?
  69. 8103 - PROGRAMMING MIX DUAL ENGINES
  70. 9303 mix questions
  71. Field charger use on DX7
  72. Gyro on twin rudders
  73. DX6 Issues ??
  74. JR service?
  75. What's the XP9303's range?
  76. 6102 flaps and gear channel
  77. ? about xp6102
  78. Model copy from 9303 to 10X using Datasafe 3?
  79. JR Service in Hong Kong
  80. Max6 Manual
  81. Buddy Box Options With DX7
  82. JR 8715 servo
  83. XP8103 Mode1 Need Help to Change It
  84. DX-7 charger question
  85. DX 7 questions
  86. dsc function jr9303
  87. Service Dept.
  88. DX7 mystery clip.
  89. Elevator setup on XP7202 Radio
  90. 1400mah blown 2610's fuse
  91. changing who transmits - buddy box question.
  92. DX7 for Thermal duration gliders
  93. Plastic servo arm on JR8611
  94. G500A vs G500T Gyros
  95. 6102 CCPM Limited pitch/throttle travel
  96. R790 wont tune to all channels
  97. JR XP7202
  98. Help w/ JR G500A Gyro
  99. 9309 gv-1 heli
  100. DX6 dsc signal
  101. Trouble with JR 9X display
  102. jr10x battery
  103. 9XII Rx Battery
  104. 9303 Idle up Switch using the retract switch?
  105. Should I send them in
  106. DX6 Idle UP issue
  107. Buddy Box set up
  108. DZ9000S Servo Specs at 4.8v
  109. XP 9303 Question When Setting Up An Airplane With Dual Aileron Servos
  110. Jr battery meter question
  111. trasnfering data from one 9303 to another 9303
  112. Type of Receiver with an X2610
  113. 9303 Prog. Mix 1 Question
  114. Discharging XP9303 Tx Battery?
  115. JR XP783 RADIO
  116. Fuse for JR XP9303
  117. 4721s on 28% plane?
  118. JR 9X (Not version II) Manual
  119. 8611A servos and early gear train slop
  120. JR9XII Synthesized channel -> frequency translation
  121. 8103 data transfer
  122. 8103 with rubber ducky antenna
  123. DX7 and interferance
  124. JR NET-J72M test / conversion
  125. Radio Gear Problems
  126. Servo Endpoint Limiter & JR XP9303
  127. 9203 Throttle Setup and Throttle Curve
  128. DX7 vs 7202
  129. NER-226X Jr Receiver 36Mhz
  130. How much load from 8611a's?
  131. Two Aileron Servos On JR Sport 600sx
  132. "Crow" and other mixes on 9303A
  133. 9303 Trim settings between flight modes
  134. Jr pcm9x
  135. XF622 WHAT KIND OF BATTERYAND WHERE TO GET
  136. 9303 tx battery
  137. 9X II trainer switch
  138. WHAT BATTERIES TO USE IN XF622
  139. JR R2100 question
  140. New 10X radio
  141. R790 7ch no more working
  142. Jr 6.0 volt 2150 charging ????
  143. Jr x 2610 twin engine setup
  144. 9303 Throttle ques
  145. question about 8103
  146. Spektrum DX6 and servos
  147. JR Receiver Range Differences ... Which is best ???
  148. JR 7202 + ParkZone F27C ???
  149. Will a JR NET-J72P TRANSMITTER MODULE 72mhz FM PCM FIT IN A CENTURY VII
  150. JR 9303 TX Battery Size
  151. dual servo setup for split elevator / jr 2610
  152. 9303 Question
  153. DS285 hunting
  154. AR6000 repair
  155. 783 Dual rate switches
  156. New JR 12 channel radio
  157. JR PCM 9xII Use ailerons as flaps?
  158. JR 642
  159. 4 cell versus 5 cell
  160. JR7202 LCD goes blank while flying outside
  161. JR R600 Receiver Polarity
  162. XF631 Locked Up
  163. TX 9303 questions
  164. Where can I get a JR Max 6 Charger?
  165. PCM 10X going mode 3
  166. Need parts for JR x388s
  167. JR SX600 throttle problem
  168. Throttle problems with the sx600 (Sorry, I hit send twice...diregard)
  169. need help
  170. cleaning out dirt inside transmitter
  171. GY502 with a new JR 7202
  172. no lcd on 8103
  173. JR 8611a Bulletin
  174. Loose TX Ant??
  175. JR 8103 Aux 3 Pot
  176. *JR 7202*
  177. Spektrum operating voltages
  178. dx7 question
  179. Jr Xr2i problems
  180. Positive and Negative Shift
  181. servo gears / ceramic grease
  182. 7202 w/ 2 Gyros
  183. XPCM and uniform servo movement
  184. 10X Problem
  185. DS821 Servos
  186. Replacement Servo Gearsets
  187. 9303 Delta Speed Breaks
  188. Century VII
  189. spoilerons
  190. 8103 High/Low Idle
  191. 8611 Case identification
  192. JR RECEIVERS
  193. ds811 on throttle?
  194. Jr 8103 repair
  195. Synthesized modual
  196. Reciever change
  197. Programming a Hangar 9 Ultra Stick W/ JR XP9303
  198. Shopping for a transmitter
  199. R770S Aileron Diferential
  200. 7202 - Elevator sepaparte channells?
  201. 6102 and g500t setup questions
  202. converting existing 9303 to 2.4 ghz
  203. 9303 won't change models
  204. New DX7
  205. 9303 aux trim button ??
  206. Off Topic: The Team JR P-47 E-conversion setup
  207. JR 7202
  208. Spektrum 7
  209. R770S crystal
  210. 12X
  211. helpp on choosing the right radio!!!!
  212. Rx Max Current
  213. regulate 6v lipo receiver battery
  214. Z590M Surface to AIR?
  215. X-388s for ccpm?
  216. I'm Confused....
  217. 9303 Aileron Gimbal not centering
  218. 10x range test antenna on or off
  219. JR 10x Thro Curve question
  220. Receiver fo JR 8103
  221. JR XS3 310 is the Receiver limited??
  222. JR S400 Buddy Box
  223. JR 10X Problem
  224. R770S Vs RS77S ??
  225. Tx in mind?
  226. Gyro and 2610
  227. JR Z-1 Programmable mixes?
  228. 4735 & 125mg sport
  229. JR7202 LCD screen goes blank
  230. 8103 knobs not inhibiting
  231. Neck strap included with JR7202? Test review says "yes"
  232. Almost perfect 7202
  233. JR8103 with synthesized module
  234. JR 9303 Shortfalls
  235. 7202 and Airtronics radios
  236. 7202 vs 6102
  237. DX6/Blade CP Collective Problem
  238. Base-loaded Antennas
  239. JR 8103 OR THE NEW 7202
  240. TX battery-LI-PO's
  241. Dual 5cell 3300's
  242. JR 2610
  243. DX EBay find needs repair.
  244. JR PCM10xS airplane radio and CCPM
  245. Spektrum AR6000 Receiver
  246. 50 MHz TX module
  247. 6102 - How do I reset the clock?
  248. Redundant battery thoughts
  249. SX600 Reviews?
  250. What is a Left hander suppose to do?
