PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. FLAP SERVO WORKS ON ONE SIDE ONLY XP7202. HELP!
  2. X-347 lost it's programming
  3. JR 8103 Question- Flaps-Lights-Elev. Trim
  4. JR 7202 heli or air?
  5. antenna length
  6. JR 10SX II with Aerofly
  7. Graupner/ JR MC24 Transmitter problem
  8. Screen went blank on 7202 radio
  9. R790 vibration problem?
  10. HORIZON HOBBY WOW
  11. Shortened RX antennae
  12. 7202 throttle setup
  13. Any information on DS8511 digi servos?
  14. JR 9303 battery help
  15. HH Radio Support
  16. JR 9303 that won't turn on
  17. twitchy 8103
  18. JR 7202
  19. JR Twin engines set up..mainly trim settings
  20. JR's answer to the 14mz?
  21. Spread Spectrum modules, and high voltage servos
  22. JRX-8310 case
  23. Charging a Spektrum DX6 internal Li-Po Battery
  24. 5 CELLS UNRERULATED
  25. dual elevator servos 10SX
  26. what is trim step?
  27. Servo lag - dual elevator - can I fix?
  28. OUTRAGEOUS SERVOS OF JR FRUSTATING
  29. 9X11/9303 just deleted hours of programming
  30. Servo Choice
  31. 9303 PG MIX for Webra 160 w/MC carb help
  32. transmitter case size
  33. Hi End JR Radio?
  34. JR 6102 Questions
  35. How many servos can I run?
  36. Synthesised JR Receivers
  37. 490T gyro problems?
  38. 9XII (UK version) - 2500mh Tx Battery?
  39. Battery capacity
  40. Mixing for twin engines on JR 9303
  41. Negative pitch on XP6102?
  42. compatiblity between jr and graupner
  43. Spektrum DX6 Receivers
  44. precise servoes.
  45. no juice
  46. 8611 goes to full deflection on start up
  47. 7202 arrival in the UK?
  48. JR 8103 problem
  49. new equipment
  50. JR in japan?
  51. JR in japan
  52. Timer?
  53. Backlit Screen for 9303
  54. 8103 HELP
  55. JR XP8103 channels
  56. JR 9303 Range Check
  57. dual elevator servos on 6102
  58. 549X
  59. Transmitter Module Pinout
  60. Rebuilding servos????
  61. one switch for dual rates for ail,elev, and rudder
  62. XP9303 PPM resolution - 10-bit?
  63. Lithium-ion voltage (8v) into JR reciever
  64. what is the best transmetter for twin engines
  65. JR 8511 servo slop
  66. JR 7202 throttle cut off?
  67. servo setup with watt meter
  68. 4721 torque ratings at 6.0V
  69. DX6 Not bullet Proof Definite Glitches?
  70. Throttle Activated Spoilerons
  71. 8103 and 549x
  72. Buddy Box & Battery Help
  73. JR8103 and ignition cut-off
  74. 2500mah ni-mh batteries for SX10 TX
  75. DX6 - Generating Interference?
  76. TX nicads or ni-mh ?
  77. Old X347 battery problem
  78. 8611 and 8611A differences
  79. Nearest Service Center
  80. Needed - Heli throttle spring
  81. R700 Receiver Lock Out?
  82. Nimh battery pack trickle charge?
  83. Apex 7 Transmitter
  84. JR XP7202 radio
  85. servo service
  86. 7202 transmitter available separately?
  87. R790 no light
  88. 7202 fuse
  89. 2721 servos
  90. JR 9303 switches
  91. servos for showtime ARF
  92. 10SX
  93. JR 9303 & snap rolls
  94. JR MX16 vs JR 7202
  95. Synthesizer Modual
  96. XP7202 - How do you add 2nd aileron servo on Aux channel?
  97. Spektrum DX6 On Blade CP Pro
  98. Matchbox endpoints
  99. 10x ultra stick programming
  100. How do I switch to mode 4 on my JR9303?
  101. 9303 dsc tech support
  102. 9301 blows fuse when charging
  103. 7202 timer
  104. Elevon on 7202?
  105. JR Pro Century vii
  106. JR R1 transmitter case
  107. refresh my memory on range check
  108. DS 8411 servos question
  109. JR X-388S transmitter
  110. XP-7202 - Flash Memory or Battery backup
  111. DX6 battery
  112. DX 6
  113. trim offset mode on JR 8103
  114. JR R649 RX antenna color
  115. This aint my day with JR: help
  116. JR 8103 Tx help
  117. 9303 Trainer switch doesn't work
  118. 8611a Replacement Case
  119. JR W125
  120. 7202 technology bound for any other JR radios?
  121. Help!
  122. Shift select on 9303
  123. How to set up flaps?
  124. 9303 Heli vs Air
  125. JR 9303, INVERTED HOVER SWITCH????
  126. Changing 6102 to mode 1?
  127. X2610/XP6102 PC connectivity
  128. JR 9X II Programming
  129. 7202 Throttle Recovery
  130. JR Receivers
  131. Duralite 11.1 V TX battery
  132. PCM10X as Master
  133. D/R on JR 7202
  134. Alternative rx's
  135. 9303 range test question
  136. 9303 Flight Mode Question
  137. jr radio + Ultra Stick
  138. 8103 + UltraStick Crow programming
  139. planning to buy jr 7202
  140. PLEASE HELP. Interaction of Ailerons and Flaps????
  141. Quatro/S400
  142. Replacement touch screen for 10S
  143. 8231 Servo oscillates around neutral
  144. jr mixing 2 throttles
  145. 3810 2nd hand Price
  146. 9303 programming- mate assignments
  147. 8611a torgue 240 vs 260
  148. Regulator ?
  149. 50cc Gas Engine Throttle Servo
  150. 9303 and matchbox programming
  151. DX-6 rudder expo?
  152. JR tansmitter battery
  153. 8103 question re 2 servos for elevator
  154. 8103 SPCM Fail Safe Settings
  155. Heli vs Aircraft
  156. New JR 16 channel radio...
  157. 8103 and retract help plz.....
  158. 9303 Blown Fuse
  159. JR "Z" PCM on 9303 - will the rx's work?
  160. PCM 10sx screen?
  161. 10X Throttle Detent?
  162. JR 9411 servos
  163. 9 x11 how do i free up aux4
  164. Glitch hunting
  165. burned up 8611's
  166. Jr Transmitter Springs
  167. JR 8611 programmable?
  168. Hangar 9 Aluminum servo arms
  169. Can't Freq. Program new R790 RX
  170. CCPM Settings on X-388S
  171. Discontinued product specs
  172. JR 10S Radio
  173. JR Channel 12,13,14
  174. Aileron settings do not stay put
  175. NEW ER539 Servos noisy when moving
  176. PCM 10
  177. Programming question (MX-22)
  178. 8103 LCD
  179. XP652 & Hitec HFS-04MG Receiver
  180. 6102 retrac end points
  181. MX22
  182. How to change models on JR631
  183. Return policy
  184. Rudder Dual rate 6102
  185. gyros
  186. 8611a's And Titanium Gears
  187. 8611a servo arm screw size
  188. Transmitter trays
  189. JR X-388S problem
  190. 631 switch problem
  191. R945S dual conv.Rx
  192. Old SPCM Rx, New Tx?
  193. Dual Elevator setup
  194. XP8103 compatibility
  195. New synthesized module
  196. 9303 quad flap?
  197. MAJOR PROBLEM JR8611A
  198. Jr Tx-Hitec Rx compatibility
  199. JR/Graupner MX22 range test
  200. Charging JR XS3
  201. 9103/digital trims/expo
  202. R700 Receiver Problem
  203. Danny - Setting up Flaps on 10x to use Flap Switch and not side lever?
  204. 8611A Jitters
  205. 8103 TX Springs
  206. 8103 w/ Quattro Lite Buddy
  207. XP652 and a R600
  208. Spektrum radio in the UK
  209. JR PCM9XII questions
  210. 8611a Problems
  211. XP9303 Synthesized
  212. 10X aileron setup help
  213. What JR for Dual Ele
  214. compatibility
  215. JR PCM 9 SS TX
  216. 10x xmtr take apart
  217. Perhaps an old question.. about parts
  218. current Ham TX models?
  219. Problem with Turmoil Spectrum Radio
  220. Another 9303 programming ? pretty simple though
  221. 8103 problem
  222. JR PCM 9X series 1
  223. Is it normal?????????????
  224. JR 10X Battery?
  225. Any new "NEWS" on the 7202?
  226. Lihium Battery
  227. 9303 mode switch
  228. Trainer switch activating full flaps
  229. Buddy Box 9303
  230. 9303 Memory Problem
  231. 9303 problem
  232. What PCM rec?
  233. x-347 pcm spec
  234. Digital servos go crazy
  235. Century VII rcvr. crystal
  236. Spektrum Jr. R-1 Pro System--receivers
  237. Questions about JR 622/642 Setup
  238. Faulty JR 8511 servo
  239. jr r1 pro
  240. JR Matchbox
  241. Two JR Rcvr's are dual conversion-why?
  242. Euro Fighter setup on 10X
  243. 10X and 8103 trainer cord set up
  244. Older 8611 Question
  245. RS10DS Synth Rx
  246. Servo ATV @ 150%
  247. 9303 trainer button question
  248. New synthesized JR 9303 - dials on module?
  249. XP9303 or 10X System?
  250. mixer offset for 8103..........
