PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. dx6 black updates all went well but wont bind
  2. Spektrum My Spektrum updates
  3. 28x transmitter voltage
  4. "The Beast" 60e Programming "Break" or "Crow" using DX18 and AR9050 receiver.
  5. Spektrum Satellite Antenna Placement In Composite Airframe
  6. How to program the rcexl opto gas engine kill switch on the new DX6...
  7. Issue with Failsafe Dx7 and the AR7000 Reciever
  8. AR 9350 mounting
  9. AR9350 compatibility
  10. Charging batteries while connected to Spektrum Powersafe Rx and replacing the softswi
  11. DX9 Flaps to Elevator mixing
  12. Need step by step procedure to adjust sullivan smoke rate with throttle control
  13. XG14 Throttle lag
  14. JR S-801 Servo's
  15. JR's Xbus explained
  16. How do I re-program an AR636a for a different model?
  17. Dx 18 ...how to delete existing models from memory
  18. Dual rate Rudder coupled with throttle? Spektrum DX8
  19. AR9350 RX Configuration Questions
  20. DX9 idle down?
  21. jr dsx9 smoke mix
  22. Question about JR X8103A
  23. DX9 failed update
  24. SPMA9589 No Altimeter data
  25. Two questions about Spektrum setups
  26. Dx 18 gimble
  27. X9303 Flap set up
  28. AR9350 Questions:
  29. JR two free receiver promotion is back thru January 31
  30. Dsm, dsm2, dsmx??
  31. XG 14: puprose of throttle limiter blocks
  32. Any rumors or plans for a JR DMSS 18 channel?
  33. DX18 - programming flaps and 2 elevator servos
  34. servos max voltage allowed
  35. What is going on with the 28X ? Report your glitch's here.
  36. Strange problem with JR8411 servo
  37. Transfering model data between two xg14 transmitters.
  38. Recommend Spectrum System Please
  39. DX-7, registration
  40. JR10X A/S Users only....
  41. Spektrum AR7200 BX Receiver
  42. EC-3 connectors on the RX
  43. spoken airspeed telemetry
  44. AR400 Experience Sharing
  45. Blade QX3 and Spektrum
  46. Need switch ID stickers for DX6i
  47. DMSS to DSM2
  48. Spectrum case broken
  49. JR 11x DSMx from mode 2 to mode 1
  50. Switch assignment for Horizon Hobby F4U Corsair S
  51. Changing the gears in my 6030
  52. DX18 - Using Wing Types WarBird 2ail-Y'd, 2flap, 2elev, 1rud, 1gear
  53. JR Dealers
  54. DX7 SD format
  55. xbus and standard servos?
  56. DM 9 Fut MZ
  57. AR 9000 Compatibility Question
  58. Servos started driving when JR922 turn on. Went thru re-bind, now its worse
  59. DX8 and JR921 Binding Question
  60. Spektrum DM8 Module Won't Bind to Spektrum AR636a Receiver
  61. Ikarus Adapters and Spektrum DX6i
  62. Spektrum Availability Issues
  63. transferring models from DX8 to DX9
  64. Spektrum AR500 rcvr recall? Use them or no?
  65. TM-1000 RPM sensor
  66. Spektrum SPMB2150NM NiMH 2150maH 6.0 V Receiver Battery Charge Rate
  67. Mixing Question
  68. tm1000 temp
  69. Spektrum DX3R Pro Stopped Working
  70. what is an acceptable level of fades on dsmx
  71. th9x upgraded with frysky module.
  72. Converting DX9 Throttle to Self Centering for DRONE
  73. Spektrum DX9 Cross Trims
  74. DX9 and Gyros
  75. Metal JR's
  76. Will we ever?
  77. WARNING - Telemetry users
  78. Binding question
  79. DX 18 problem
  80. Who services my JR 8103 ? Horizon?
  81. JR DSM2 R1221 wont hold bind?
  82. Spektrum DX6I LCD screen
  83. DS8611 and DS8611A servo question
  84. Spekrum Telemetry GPS module - How Accurate is it ??
  85. Help programming a JR 10x
  86. Spektrum AR9350 RX and PC Software Availability
  87. a4030 servo deadband ?
  88. XG11 battery voltage
  89. DX9, cannot get flaps to work evenly side to side (two channels)
  90. JR XG11 Trainer Function
  91. New DX7s programming question
  92. AR 636 - Programming with PC
  93. Getting the temp data to show up on the XG-11 transmitter
  94. X plus module question
  95. DX8 and Quad flaps help!!
  96. JR 921 receivers
  97. JR 9x 2.4 failsafe Question
  98. Can I set up a delta on a 4ch jr rx?
  99. DX9 & AR6210 - Question
  100. Spektrum AR8000
  101. DX 9 Registration and Update Woes
  102. DX9 Flight Mode Scare
  103. DX8-AR8000-TM1000-5 SavoxSC1252-20cc gas SBach 68"
  104. AR7010 DSMX and TM1000 compatibility
  105. XP8103 Screen dim
  106. Spektrum and JR Receivers
  107. JR's new XBus information thread
  108. DX6i- is it dsm,dsmx or dsm2
  109. replacement TX battery?
  110. Spektrum™ AR610 DSM2®/DMSX® receiver
  111. Dx6 & dsm2
  112. AR9020 Servos and Switch Harness Compatability
  113. 9303 Question
  114. DSM2 - The brown-out bug strikes again (AR6200)
  115. Kudos to Horizon Hobbies on Spektrum DX9 Support
  116. DX9 Software Version
  117. DX9 - Removing TX Battery
  118. Spektrum DX4e versus DX6i transmitter
  119. DX7s
  120. Spektrum (DX9) System Idle
  121. JR XG14 Disabling Throttle trim from Flight modes
  122. NEW DX9 Black Edition - BAD SD Card
  123. dx 18 throttle curve
  124. a6220 servo arm
  125. DX6, DX7, DX9, DX18, DX18QQ, DX10t, and DX18G2DX18t updates released
  126. DX9 switch change report
  127. Will JR 28X copy settings of Spektrum DX18QQ
  128. Model memory question on the XG11
  129. Can't get the flap system working on my DX8
  130. Another new DX-18
  131. JR 11X - 4 Flap Set up
  132. JR NES-517 Retract Servo Specs?
  133. DSX12 access code to gain entry to the service menu
  134. General Servo Spec Clarification, also JR NES-517 default degrees of rotation.
  135. Which JR XG?
  136. Need help programming 9303 for Blade 180QX HQ
  137. Best XG-11 receiver for CO helo
  138. JR G370A Gyro Question
  139. Swapping Models Between TwoTransmitters
  140. JR 11X Case Dimensions
  141. AR9000 maximum voltage capability?
  142. DX9 Problems with LCD/Screen going Out
  143. Programming Landing Gear/Door Sequence in JR 11X24
  144. XP9303 Flap Program Question
  145. Programming Flaps on a DX7 with ar7000 reciever.
  146. What does the Crystal Ball see for the near future.
  147. Spektrum AR 7000. Will a Hitec Female battery connector work?
  148. 9303 Bind problem after DSMX Upgrade
  149. Need a Useful Guide to programming the JR 11X
  150. DX9 Charge LED Does Not Turn Off
  151. NIB Spektrum Receivers, any need to return for an upgrade on these?
  152. DX 18 Gen 2 Mode 2 - Outdated
  153. DX7 programming
  154. JR 28X - Where is it?
  155. JR R921 - AR8000 Question
  156. Difference between MPH82T and MPH82T MKII
  157. Flap setup on jr 12x
  158. Is an older JR347 radio worth converting to 2.4?
  159. RG 831B Receiver problems
  160. Looking at new radio.
  161. DX6 lilon battery upgrade.
  162. Spektrum DX 7 dual elevator servos, dual aileron servos, dual flap servos programmig.
  163. Spektrum & bus technology
  164. DX9 - Kick in pants!
  165. JR XP9303 Sailplane
  166. Servo Twitching
  167. Is my servo digital
  168. DX7 eu not giving safe mode with RX 636s
  169. Satellite loses it's bind
  170. Buying new 2.4 transmitter.... which one?
  171. JR 7202 digital trim problem& elev. dual rate was on the "fritz"
  172. Hitec servos and spectrum Rex
  173. How can I set up an Apprentice on a DX9?
  174. JR Matchboxes and A123 Batteries
  175. DX8 Servo Setup/Travel/Throttle %'s
  176. Spektrum Aluminum Servo Arms
  177. 9 channel Spectrum AS3X
  178. JR XG radio programming Questions and Tips
  179. 9503 Throttle Curve
  180. batteries for 652 and 421 radios
  181. Issue with buddy box - JR 11X, 12X, 9303
  182. AR8000 stopped working
  183. Spektrum trainer
  184. Defining extra flight modes with XG-14
  185. dx18 range check
  186. Flaps and throttle cut?
  187. throttle limits on a DX18
  188. Problem upgrading firmware on JR XG8
  189. XG14 programming questions
  190. weird spektrum receiver problem i am baffled
  191. 2 Power Inputs to RX
  192. Spektrum DX7s When is it fully charged?
  193. AR8000 Rx trouble with flaps
  194. 11x mode1 to mode 2 convertion
  195. as3x programmer
  196. DX9 rudder double rate problem
  197. Major loss with my 12x
  198. Help Programming Flaps on a DX8
  199. DX7S & Hobbyzone Sukhoi SU-29MM programming problems
  200. How many antenna faeds are OK
  201. Voltage change with stick movement
  202. 12x flight modes won't turn on.
  203. Different behaviour between model memories on my DX8
  204. DX6 setup download question
  205. AR 6200 & 6210 clones
  206. JR RG831B receiver
  207. DSM2 TM1000 use with a DX9?
  208. Trainer Cord set up between XG14 and XG7 or older JR radio
  209. DX 11 Flap Setting Questions
  210. spektrum radio and receiver problems
  211. how to convert dx 18qq files to dx18
  212. DX9 timer programming question
  213. Spektrum DX-9 Timer programming question.
  214. Which Spektrum Receiver for 50CC Cap?
  215. DX-18 JR 9304 Trainer cord
  216. 9503 set up for elevator and second elev. servo slave. Trim will only actuate elev.
  217. Need Some Help With My AR9110 Power Safe Rx
  218. 7955 Servo Movement On Powerup
  219. AR6200 fail safe question
  220. DX18qq problem
  221. Help! Looking for a JR 388s Manual.
  222. Help with my new dx6
  223. Module from 11x zero compatible w/xp9303
  224. Receiver Redundancy
  225. Jetcat interface inop
  226. What pole and gear ratio setting?
  227. SPM Uploads!
  228. DX5e and AR600 not communicating.
  229. Futaba servo wiggling with DX6i
  230. JR 3810 Lithiam battery
  231. 4721 servos buzzing, is this normal?
  232. dx18 programming
  233. JR DMSS Telemetry Display or interface?
  234. Compatibility of New Spectrum DX6i
  235. JR 9303 DSM or JR 9503 DSM2 uipgrades?
  236. DX9 Battery
  237. SR301 receiver Help
  238. AR9300 bind issues or what????
  239. DX9 still available for low price
  240. DX9 battery charging
  241. JR 12X MV Abnormality
  242. Spektrum DX6i Eagletree Guardian setup
  243. DX6i help please!!!
  244. JR XG 11 - adjusting mixes in flight
  245. JR XG11 Stick Position Switch Function
  246. dx7 and ar7000 binding question
  247. used dx8
  248. Spectrum community site and firmware updates
  249. assigning channels to switch
  250. JR 921x Bind Problems
