PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. MX22 DIFF from Jr 9303
  2. Incompatibility Between JR XS3 and Losi Micro LST Receivers??
  3. Model Name Setup in XP6102 Transmitter
  4. 8103 PROGRAMMING
  5. shipping for repair
  6. TX Maintenance Question
  7. DX-6 and mode 1
  8. JR Cobra = Acoms Technisport
  9. Battery Upgrade for the JR 6102
  10. 50 Mhz tx module
  11. JR XP6102 and GY 401 set-up
  12. Metal / Alloy Gears For 8101 ???
  13. PCM9XII for air and heli ??
  14. 8103 Mix for tail wheel
  15. 10X Battery Charging
  16. JR PCM9X II - 3 Position Switch Problems
  17. How Do I set Up My PCM9 for Ailevator?
  18. JR crystal for sale or swap
  19. 8103 availability question...
  20. 8103 vs 9303 for first IMAC
  21. 10x and 7 ch receiver
  22. JR Max 6
  23. R2000 VS R2100
  24. E-flite Blade cx Tx swapping
  25. broken antena
  26. XP6102 transmitter alarm
  27. 9303-mix L ael w/ l elv half and right side same
  28. Futaba Rx Crystal on JR Rx
  29. help setting up JR 6102
  30. JR10X - Flight Modes for GS Aerobats
  31. JR receiver interferance
  32. Snap roll programing - XP-8103
  33. Can I buy XP9303 TX ONLY with Synthesized module?
  34. How much torque on the throttle?
  35. Expert F650 6Ch Micro Rx question
  36. digital trim to analog trim conversion table
  37. Just wondering if the charge jack is the same polarity on the hitec and futaba.
  38. Synthesizer Module
  39. Question for Danny or MacGregor please, thank you
  40. Limiting the throttle
  41. JR 10 SXII question
  42. Tight servo arms
  43. HELP! JR radio no response
  44. MX22
  45. Century VII PCM Transmitter
  46. 10 Channel PCM Receiver
  47. HELP ME FIX THIS
  48. JRPCM 10 z model RADIO
  49. SX600 Battery question
  50. JR radio repair and parts
  51. two RXs
  52. programming crow
  53. 72mhertz U.S convertable to 36mHertz 4 Aust?
  54. Transfer question
  55. R-1 Battery problem???
  56. DUH! I gotta be dumb - JR2610 help req
  57. JR 8103 PCM Air
  58. JR DS3421 Servo Arms
  59. Replacing metal gears in 8311
  60. Servo chatter & grounding question
  61. Rx Crystal Questions
  62. JR receiver voltage?
  63. 8611 Gear or Case Top Trouble
  64. jr6102
  65. 9303 D/R Switch Assignment seup
  66. cell phones and JR TXs
  67. Hangar 9 Edge 540
  68. helicopter servos
  69. JR 2721's
  70. Z590M - Servo Noise
  71. Lost Model Alarms and Receiver Problems
  72. 8411 to 8311?
  73. JR Crystal
  74. R2000 or R770S
  75. Synthesized PLL channel selection via software for 9303?
  76. RotorSoft Ltd. DataXchange
  77. Txr Case Touch-Ups?
  78. 10X Beeps
  79. flaperon + centre flap
  80. jr pcm 10 sx 11 touch screen
  81. xf 631 battery
  82. I'm an idiot
  83. 6102 Features not on 9303
  84. Trainerlink cord question
  85. XP8103A: Disabling flap pot
  86. 9303 and Lithium ion Tx battery
  87. Trim Step
  88. RS6UL Reciever problem
  89. x378 fast charging
  90. JR Servos What's The Diference
  91. spektrum modules in 9303
  92. Rudder-elevator, rudder-aileron using 1 servo on each surface
  93. SX600 Programming Sequence Question
  94. Delta wing and JR 9303
  95. ST125MG Servo
  96. Synthisized TX flexequip
  97. DX 6 Transmitter Antenna
  98. Question AGAIN on Freq change!
  99. Question about R2000 receiver
  100. DX6 system and servos
  101. GV1 Governor setup with JR 9CH PCM
  102. Ham Band receivers and 72mhz
  103. tx battery plug ends
  104. JR 9303
  105. Futaba to JR convert newbie
  106. Future Replacement for 10X ?
  107. Spread Spectrum
  108. Display problem in a JR XS3
  109. JR ST125MG Servo in a 1/8 Buggy?
  110. optically encoded servos?
  111. 9303 dumb question
  112. Just replaced JR-x347 lithium battery. Anything else need to be done to make it new?
  113. 8103 and a Smoke Pump?
  114. 6102 flap switch
  115. R945S RECEIVER WITH DIGITAL SERVOS
  116. Duel conversion recevers.
  117. XS3 Pro, RS 310, DZ9000S
  118. JR 6102/ r770s Cold weather - CRASH!
  119. electronics 4 my revo
  120. Are DS8411SA's OK in Gas Planes
  121. JR 8103 DT - Aileron Trim Problem
  122. JR XF622 ccpm
  123. g410t gyro problem
  124. DS8411 Specs
  125. Duel Elevator Throw Problem
  126. Jr-347 Can't Switch to Mode 2
  127. JR8103 throttle - rudder mix
  128. X-378 Servo delay?
  129. JR ST125MG Servo trouble
  130. JR xr3i with AIR reciver?
  131. Jr 6102 Changing Frequency?
  132. 8103 problem
  133. 8103 Dual elevator problem
  134. Radio Feature Suggestion
  135. Switches/Charge Jacks, Whats the difference?
  136. JR10X touch screen problem.
  137. 9303 glitch?
  138. Any titanium gear servos on the way?
  139. Switching from Airtronics TX to JR 8103 TX
  140. Battery Recycling of JR transmitters
  141. Antenna Down for 2 hours
  142. 8311 replacement gears
  143. 8311 replacement gears
  144. Early European 10x
  145. Can I use a non-JR servo?
  146. Trim doesn't work on slave channel
  147. Forgetting One Small Item on 10X Program
  148. Need help For JR 10SX
  149. What are the major advantages to a JR 6102 PCM over the Futaba CAF 7-channel PCM
  150. spectrum
  151. X-388S Transmitter parts?
  152. jr 8103
  153. 5 cells
  154. JRtoFutaba TrainerLink w/ Spektrum DX6
  155. V-tail function on x-378
  156. PCM9X and Choke on large gasser
  157. 10X vs 9303
  158. Another MG125 problem on 6V
  159. 10X dual throttle setup & ZPCM/SPCM differences
  160. JR XR3i compatibility
  161. 6v ratings...
  162. JR Sport 125OZ Servos
  163. Throttle ratchet spring-interchangeable?
  164. XP6102 Question
  165. question:more info on thottle cut on 9303
  166. Spektrum support & question
  167. How do I set a second model on my XR2
  168. How do I set a second model on my XR2
  169. 10X mode1 to mode2 change
  170. Future of 10X
  171. JR 10x heli
  172. 8103 mixing
  173. Dispensing with Feedback Potentiometers
  174. JR Pricing
  175. JR 6102 elevon mixing
  176. jr quatro 4ch battery wrong polarity
  177. 6102 using expo on rudder and throttle
  178. JR Max 44 (uk spec)
  179. G500A Plane Gyro
  180. 9303 mods
  181. buddy box compatability
  182. Setting up crow braking on PCM9X?
  183. JR XP662 Wing troubles
  184. Spread spectrum
  185. jr 783 channel mixing
  186. Can Gyros be performance tested on the bench?
  187. Mixing Flaps to Aileron
  188. DSC won't work With Hitec Rec. & JR8103
  189. 10x module swapping with 9303
  190. 27% ultimate on 6 channels
  191. JR 10X Airplane programming guides?
  192. lithium memory backup batteries
  193. Flaps on 9303
  194. pro boat shockwave
  195. JR Z-1 vs EX-10 Helios
  196. Address
  197. 490T gyro with 8103
  198. 6102 on an OV-10
  199. INSTALLING DUAL R2000'S WITH JUMPER
  200. jr propo apex(century?)
  201. 9303 crow on ultra stick
  202. Converting JR radio from air to ground frequency
  203. Strange Interferrence Issue
  204. Radio check rudder movement
  205. Stop me from Buying a 14MZ!!!!!!!!!!!!!
  206. JR 9303 antenna base loaded question
  207. 6102 on a flight sim
  208. 783 LCD replacement
  209. Tx Module and swapping crystals
  210. 9303 suggestion (Mix names)
  211. R2000 Setup
  212. JR 10X with rubber duck antenna
  213. new synth module for jr 9x
  214. 8103 Switch Reconfiguration
  215. JR 10SX Questions
  216. spektrum telemetry system?
  217. JR PCM 10 tunning
  218. RS6UL Negitive
  219. 9303 + two "Y" connectors
  220. JR Crystals R700 Question
  221. 8411/8611
  222. Proportional flap?
  223. Right stick causes ailerons to move irradically
  224. Servo Matching
  225. jr 9x smoke on throttle throws off mixer switch
  226. 9303 flap switch for mix?
  227. Radio manuals
  228. JR 9303 Throtle cut
  229. CROW on JR9303
  230. Connect Jr to an Hitec through trainer cord.
  231. New Synth module for 783
  232. 9303 vs 6102
  233. Jr Radio 9XII
  234. NER 327X
  235. 6102 and Flaperons
  236. Aileron differential AND flap-elevator
  237. Data safe JRPA301
  238. 388 manual
  239. 10x Tx Module question???
  240. jr 388x mixing
  241. 10X Idle up
  242. gyro sensitivity
  243. JR XP652 problem & XP9303 question
  244. DS 168 @6.0V?
  245. JR X347
  246. SX600 Flaperons
  247. 8103 & 9303 MODULE QUESTION
  248. Problem with PCM R900S receiver
  249. jr z pcm reciever question
  250. JR Recievers
