PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. xp8103
  2. Flutter problems on JR Z650M servos
  3. 10X Touch Screen Problem
  4. DS 8301 servo
  5. 9303 ultra stick Aileron+Flap
  6. JR color casings on crystals and the 3 dots
  7. 9303 flap travel adj.
  8. Using a 11.3 Lipo from Common Sense RC
  9. JR 9303 Ultra Stick 60 W/ Y's
  10. 8103 program mix question
  11. 9303 air to heli
  12. xp 9303 questions?
  13. JR 8611 damaged from overheat
  14. jr x347 ?
  15. camber and reflex on left stick- 6102?
  16. 770 or 649
  17. JR RS6UL vs. JR610UL
  18. How do I disable the Knobs on my 8103
  19. x347 reciever question
  20. Danny, 9303 radio will not turn on!
  21. Using a "Y" With Digitals
  22. Wrong Charger
  23. 8103 setup for flaperons on 5 chs?
  24. ES 539
  25. 6.0v vs 4.8v
  26. Servo Travel / Resolution
  27. used 649 PCMrx
  28. DSC
  29. 8411 Tune -up
  30. 10x Programming
  31. 10X Switch assignment HELP for DUMMIES
  32. R2000 Receiver
  33. JR Ner-910XZ
  34. Switch assignment on 9303Heli
  35. 9303 - Can't find the model copy function
  36. PCM 512
  37. JR PLL Synthesising Receiver ( RS 10DS )
  38. uneven servor travel with duel elevator mix
  39. 9303 Programming question
  40. cant access menu XF421
  41. 9303 and RES Topaz Spoiler problem
  42. 6102
  43. 10x Trim Change Problem
  44. JR 10 SXII button problem
  45. PCM9X VERSION2 QUESTION
  46. JR R2000 10ch Auto Select Dual Conversion Rx
  47. ABC&W Patent #
  48. JR 783
  49. JR channel expander compatible with a Futaba Radio??
  50. PCM9X Mixing Servos
  51. Funny one on 9X and throttle curve
  52. Elevator/Rudder Fluttering
  53. 6102 dual elevator mixing
  54. Crystals
  55. reversed controls
  56. X2610 mode 1 -> 2 conversion
  57. 7/70 RECEIVER CRYSTAL QUESTION
  58. 10X question
  59. Help!! 8103 DT rudder centering
  60. gear switch replacement 9303
  61. Battery....need Dan to advise
  62. DS 8411 - oscillates quickly around neutral
  63. Full Trailing Edge Control?
  64. 8103 throttle trim not working.
  65. V Tail mixing for XF631
  66. JR Sport RS6UL receiver
  67. Mechanical or Subtrim first??
  68. 8103 progran mixing
  69. 8103 Mixing
  70. Brand new JR 2610 right horizontal stick problems
  71. s400
  72. 9X twin engine setup
  73. JR pcm 9x.
  74. new JR? more channels?
  75. Timer to Throttle on 9303
  76. 10X code 13 D/R
  77. 10x function 64?
  78. New DX6 System
  79. DS537 vs ST125
  80. Help
  81. 8611 play at neutral
  82. JR 9303 with 610UL RX and Futaba GY401 Gyro
  83. JR 700 rx + digital servos
  84. 8411 to 8611 gear swap?
  85. dsc flight sim problems
  86. SOME X347 Questions
  87. Servicing Form
  88. 9303 on 75 MHz??
  89. Bad FM Receiver
  90. 9303 Problem with the screen?
  91. Programing Question
  92. JR xf631
  93. ium Lost menu item on JR 783
  94. Antenna for 8103 on 50Mhz
  95. xf622 questions
  96. MC 12
  97. DS811 Servo Use
  98. Copying data between 8103
  99. Jr 517 servos
  100. JR10X
  101. 9303 Radio issue
  102. JR 527 Servo Failures
  103. 9303 Prog.Mix? #,+, TIMT
  104. JR Sport SX600 Question
  105. Interference problem? Erratic controls….
  106. JR Servo's output shaft alignment
  107. DS 8231 Specs on 6 volts
  108. JR 9303 question
  109. JR Radio issue
  110. 347 JR Radio
  111. Unlimited-8 pattern. Combination switch?
  112. 8103 EPA
  113. 9303 eCCPM Swash trimming
  114. 8103 transmitter module
  115. ST125MG problem...
  116. Crystals falling out
  117. JR Beat 2 Alpina
  118. Buying a JR radio.
  119. Jr R610M / R610UL question:
  120. Convert 9XII from mode 1 to mode 2
  121. Problem with Expert Onboard Glow & PCM R770S?
  122. JR XF421ex good for 72 AND Euro channels?
  123. DS368 Problems
  124. JR rx battery
  125. JR6102 & RX600 RX
  126. Risk to Tx with Antenna Down
  127. X-347 Lithium change
  128. transmitter crystals
  129. ST125MG application question
  130. ST125MG Servos on 6 Volts??????
  131. jr radio/hitec reciever
  132. 9303 bad balance
  133. Diode sheet for JR X 378
  134. problem with servos.
  135. New Synth Reciver and TX Pack
  136. JR 9303
  137. Is my old Quattro legal to use?
  138. 9303 Question
  139. News on the front ?
  140. 8611 Centering problems
  141. JR 537 buzzing
  142. JR 9X II
  143. JR Dominates RC at NATS
  144. Help on converting to the Ham band
  145. 9303 Switch question?
  146. flap/ gear switches JR662
  147. does jr do any cheap 6ch rx/tx?
  148. Jr X-347 Elevator Troubles! Help...argh.
  149. 10X Programing Trick... Help
  150. antenna
  151. RS600 not working with Futaba Tx
  152. servo trouble on Ultra stick 1.20
  153. Should I be worried?
  154. jr 783 radio
  155. Dual throttle servos
  156. 7 Century & and buddy box
  157. JR DSC cord??? tech data ??
  158. Question about 9303
  159. Using both JR Servos and Futaba Servos on the Same Receiver
  160. Expaned Manual 9303
  161. 8511/8611
  162. 8611A in South Africa?
  163. Mode 1 to mode 2
  164. Can my JR6102 Tx work with my FM tower Rx?
  165. Flap Receiver Port--950S
  166. JR 9303 seperate Elevator and rudder channels on 35%
  167. deleted
  168. XP6102 info
  169. JR repair
  170. JR 10 X AIRPLANE RADIO TO FLY HELI?
  171. Synth module and Rx
  172. Question on my set up
  173. JR Servos - Speed/Torque @ 6 Volts?
  174. Whip Antenna's
  175. Unreliable Trainer Switch
  176. Jr pcm 10 transmitter
  177. Change the X3810ADT Module
  178. 378 W/TJ gov.
  179. TX battery connectors
  180. Servo Guidance?
  181. shift
  182. x3810& walkera#36
  183. current draw on Servos
  184. Receiver X'tal swapping....
  185. Can
  186. Buddy box with 9303
  187. Current Draw of DS8231 Servo
  188. Any JR FM 75 I can buy?
  189. 9303 - two AUX 2's ????
  190. 8311 servo?
  191. 9303 or 10x
  192. 10SX Question....
  193. JR9303 - Mixing Wheel Brakes on Ch7 with Down Elevator
  194. programming guide for 10x
  195. servo.s
  196. Convert 512 to 1024
  197. 10X question
  198. Idiots guide for assigning / mixing channels
  199. Servo Buzz
  200. JR plugged into Futaba wall charger
  201. Flapperon throws using a 631 Transmitter radio
  202. JR Radio Set
  203. ABC & W vs standard Dual conversion
  204. X-347 radio
  205. JR 8103 Mixing
  206. 9303 manual
  207. Range on new Module and Receiver
  208. JR TS125 mg servos?
  209. 6102 aileron to flap coupling
  210. JR PCM 9X Programing 4 servos Ailerons
  211. Circus PCM9 G-series
  212. Prog mix for idle-up on XP9303
  213. Can I assign throttle kill to a different switch on the PCM9X?
  214. XP8103 and gyro gain from tx
  215. nedd link to download JR 9303 user manual
  216. JR 610M receivers hunting and glitch
  217. "Buddy box" tx. ?
  218. Re: 6102 radio air
  219. 9303 rudd > ail mix and rudd > elev
  220. 9303 Radio Set-up in BVM Sabre
  221. 6102 issues
  222. Throttle Servo Problems on 9303
  223. JR 8103 Program
  224. 9411 servo gears
  225. PCM 9X11 - How to use trainer switch??
  226. Questionable service?
  227. 7.2 v rx pack . is it ok?
  228. 6 volt pack with 8231
  229. z650m problem
  230. New TX Syn module
  231. Changing the Frequency Band
  232. Adjustable throttle trigger for XS3 (non pro version)?
  233. new 18 channel JR TX - really?
  234. 9303 Display Problems
  235. buying used servos
  236. TX Module Lifespan
  237. Long Servo Leads
  238. 50 MHZ antenna leingth ....
  239. JR Dual VS Single Conversion Receiver
  240. 652 programing question
  241. 9303 Air Manual??
  242. Data Safe and 9303
  243. jr help please
  244. Switches - Replacement
  245. JR9303 SW WARNING
  246. Best JR reciever for long range ???
  247. Modules vs. Not
  248. Danny, is JR Sport going to replace Expert Line?
  249. Lithium Poly batteries?
  250. How to program split ailerons on JR 8103
