PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. JR pcm reciever
  2. PCM 9X programming
  3. 8611's jittering
  4. 10X Fail Safe Programming
  5. couple questions on JR XS3 and R300 receiver
  6. 9XII Problem
  7. DS368 servo problem
  8. Safe TX battery level?
  9. 9303 Mixture Control
  10. 8103 vs. x -378 and digital trims
  11. Help
  12. TX600
  13. TX & RX Frequency Chart
  14. Will the JR 610UL work with Futaba?
  15. JR MAX 6 TRANSMITTER BATTERY CYCLING
  16. JR transmitter repair?
  17. 9303 Throttle Trim
  18. servos clarification
  19. Synthesized TX Module
  20. JR PCm 9X
  21. 9303 Dual Rate Switch Assignment
  22. Centering problem JR 8611
  23. 10x problem
  24. 8411 Hesitates at Center
  25. JR X-378 Enquiry
  26. 8103 flaperon setting flaps
  27. Tx field charger ?
  28. Broken 9303 Antenna
  29. JR Matchbox
  30. 8103 Timer Beeps
  31. Trainer cord compatibility
  32. 9303 Programing question
  33. Could you mention what are the oustanding characteristics for the 10X?
  34. 9411 vs 9411SA
  35. Let's Talk About Servos
  36. jr python radio
  37. XF622 help
  38. 50Mhz Tx Module
  39. JR 770 PCM Receiver
  40. Servo Extensions
  41. new JR radio????
  42. SX600 Dual Rates, Flaps, Mixing?
  43. jr and futaba
  44. JR rec with Hitec equipment
  45. 649 vs 900
  46. XF622 0 volt Alarm
  47. Switch location on 8103
  48. Rudder to Aileron mix in 8103?
  49. what am I missing? New JRXP6102 dead?
  50. Futaba and The new JR servos ??
  51. Expert Servo
  52. Batteries and Charger for JR XS3
  53. 9303 How to turn off flap lever?
  54. 8103 crystal change from #8 to# 46
  55. 10X Flight mode setup?
  56. 10x question??
  57. 8103 Flaps on seperate servos
  58. 700 Rx glitchs w/gas eng?
  59. LED went D.O.A.
  60. Servo jitter's
  61. Crow for 10S and 10X
  62. Futaba receiver with a JR xmitter?
  63. 'm just now getting into J
  64. Tx Battery Capacity
  65. Crystal changing
  66. 9x2 Aileron and flap mix help
  67. Range issue
  68. 10X Crow w/throttle mix and Throttle Cut
  69. How safe is it for Rx to use 6v battery?
  70. Rec. info
  71. Are JR and Airtronics Z charging plugs the same?
  72. mixing ailerons with spoiler
  73. 10x flaperon
  74. 10X Programming Mix Help
  75. jr xf 631 manual
  76. jr radio support
  77. Synth Tx Module - available??
  78. Dual Batteries on 945 Receiver
  79. 9303 Module got wet
  80. 3121 Torque after gear change
  81. Is there a need for isolators with JR receivers?
  82. PCM10X Heli to fly planes with?
  83. JR Servo 6V Ratings
  84. 6V on PCM Receivers
  85. 8103 memory
  86. Can I add a trainer port to a JR Propo Max PCM radio?
  87. Danny, Two more dumb questions
  88. glitching with r600 receiver
  89. reciver defect ?
  90. 8103 and trim offset
  91. Throttle Cut on XP9303?
  92. 10X just arrived!!!
  93. BIG problem with DS811 servos... please help !
  94. Galaxy 8 / new JR receivers
  95. new jr sx600 question
  96. Funny #'s
  97. NEW JR Sport Series Servos????????
  98. JR Equipment comparison chart
  99. 8411 Servo Case Part Number
  100. JR G7000T Gyro with 810G servo
  101. JR 9XII Flaperon question
  102. Older JR GALAXY Receiver - What's compatible
  103. 9303 sailplane mode: how to disable flap lever
  104. What's the orange wire for on my new JR 6102 receiver battery?
  105. JR 6102-how to configure a throttle lock?
  106. composite planes and 955S receiver
  107. Who Runs Horizon Service
  108. 10X poor range...
  109. R700 reciever
  110. 9303 Heli rudder offset ???
  111. JR pitch curve
  112. JR 8103 Programming Guides
  113. LiPo in JR transmitter
  114. jr9303 - changing from Mode 2 to Mode 4
  115. questions on 9303
  116. JR Propo xs3vs. JR racing xs3
  117. Dual elevator servos
  118. 783 Manual
  119. 2 JR 8103 Tranny Questions,,,,
  120. Screen completely black with power on
  121. 8611 Case Tops
  122. 8103 antenna - can't be tightened down
  123. 10X stick lengths
  124. Servo Recomendation
  125. JR Max 66 Manual
  126. 610 UL gitters
  127. Servo Recomendation
  128. New JR systems and Old Airtronics receivers
  129. Z-pcm conversion time
  130. My radio is not working, do i need a new one
  131. Touch Screen on 10X
  132. Synthesized TX Module
  133. Mixing Ailerons. and Elevator together - 8103
  134. 9303 vs 347
  135. 9303 Question
  136. JR REceiver Z marked
  137. Y or mix for 2 servos/elevator?
  138. 610ul vs r770s pcm receiver
  139. 9303 6-surface programming
  140. XS-3= no brakes
  141. Receiver compatibility
  142. XP8103 Antenna Question
  143. Danny
  144. Z650M glitch?
  145. setting-up JR XP8103 for training
  146. 9303 D/R and Ailerons
  147. Synth Tx module
  148. Graupner 3728 equivalent
  149. Timer that works with throttle stick on 9303
  150. Synthesized tx and rx
  151. new version of ds811 servo?
  152. XP6102 charging-JR connectors
  153. 9303/PCM9xII: Flaperons with 5-channel receiver
  154. 8411 Servo Failure
  155. JR 9303 elevators matching up
  156. 770S PCM & Digital Servo's
  157. Sending in my 9303
  158. Can I run 6 volts on 4031 and 4131 Servos
  159. 9303 And Flapperons
  160. XP662 QUESTION
  161. 9303 won't charge
  162. 2 questions
  163. JR RX Crystal
  164. 9303 3 position switch
  165. 9303 question
  166. JR 9X v2
  167. 9303 question
  168. XP8103 Programming Guide for Dummies Needed
  169. JR Crystal Swapping
  170. 9303 auto dual rate
  171. R610M receiver problems
  172. Danny is offline
  173. Charging a PCM9xII
  174. 8103 Module Freq Change
  175. 9303 Programming Gyro Sense on a 6 channel Rx
  176. JR 10X battery pack diode blow up
  177. xf421
  178. DataSafe Ultra
  179. 10X Servo Channels 9 @ 10
  180. Is There a Future PCM10X?
  181. Programming 10sxII Heli for Ultra Stick 40
  182. Many thanks for the great service
  183. Ooops... fried 8611A?
  184. JR6102 Ultra lite availability?
  185. 8611a torque?
  186. JR10SXII FUSE
  187. MacGregor Data Exchange reliable? Complete?
  188. Programming Mode 1 on an X-388S
  189. Jr 421 EX Tx battery cycle
  190. JR10SXII Snap Roll Button activate smoke?
  191. JR Max Computer Radio Help! Fast!
  192. Servo case for DS8417
  193. JR receivers
  194. Jr 6102 PCM radio
  195. jr battery packs
  196. mc 20 problem
  197. PCM9x/9303 failsafe setup?
  198. R135 problem...
  199. replacement dsc jack on XP652
  200. Aluminum Servo arms for 8611A
  201. Elevator and Aileron Mixing
  202. Fast charging 9303
  203. Programming PCM9X for the Ultra Stick model
  204. One switch for 3-D flight
  205. BIG thanks to MacGregor Industries
  206. XP 642 broken centering, fixable?
  207. Can JR9X II operate a turbine ECU?
  208. JR XS3 interference issues
  209. 8103 programing
  210. Throttle trim
  211. JR 9303 Flaps & Flaperons
  212. Include?? 9303 Mix Help
  213. JR 610ul - ???????????????????????
  214. Ultra Stick Programming 9303
  215. More 9X elevator questions
  216. Question about the 6102
  217. Upgrade from JR X347?
  218. LCD contrast on 9303 tx
  219. Converting from 70Mhz to 36Mhz Rx
  220. Radio request possibility
  221. Transmitter Module
  222. JR8103 pich\throttle knobs
  223. JR 791 Retract Servo Full Stroke
  224. !!What is a gyro!!
  225. new locjing servo arms
  226. Danny
  227. 9303 Flight System Remap?
  228. JR 10X programs
  229. 421 problem
  230. 8103H and US 60
  231. 9303 with dual elevators and ailerons
  232. Changing Rec. Freq.
  233. Matchbox 'problem'???
  234. Trim Sensitivity
  235. 9303 timer change possible?
  236. Datasafe for 9303
  237. dual input/output gyro from JR
  238. ignition wiring and interference PCM
  239. DS3301
  240. Will JR PCM 9X work with Hitec Electron 6 Reciever?
  241. Reversing elevators with mix switch
  242. 10x radio heat vs radio check
  243. 791 High Torque Lo-Profile Retract Servo
  244. JR PCM9 G-series From Circus Hobbies?
  245. JR9303 Airplane Radio for Heli Use
  246. JR 2610 Curve setting for stunt and mormal mode
  247. switched from futaba to jr
  248. Programming JR Servos (How?)
  249. Quad Flaps on 9303
  250. Synth module ship date slipping
