PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. XP662 programming
  2. 8103 Trims
  3. JRXP8103 Dual Elevator
  4. PCM vs. FM
  5. XP662 - Throttle Hold Problem
  6. Fuse for JR 2610
  7. buying JR
  8. Modules interchangeable?
  9. pcm 10 s transmiter
  10. 8103 Will not move servo's...then starts working again???
  11. crow on 10x
  12. 8103/3810 mode change?
  13. jr 6101 and trex
  14. Hi
  15. smoke pump set-up
  16. Replacement Trans battery
  17. JR 9x, 9xII, 9303 differences?
  18. 9303 Z PCM
  19. No Parts for Jr Servo's
  20. 9303 and CCPM
  21. ZPMC?
  22. 8611 Conversion
  23. 9303 Flight Mode setup
  24. JR 622 question
  25. Do I lubricate servo gears??
  26. Tx Module
  27. JR Charge plug size
  28. jr 6102,both fm and pcm?
  29. dual elevator setup - pcm 9x2 (9303)
  30. i
  31. Servo comparison chart
  32. Flaperon set up on JR XP662 ?
  33. Two vs One Receiver
  34. Please help me turn on ZPCM on 3810
  35. JR388s PCM: JR 649 recvr
  36. jr matchbox question
  37. Pitts S12 Monter 1.20 servo selection
  38. 9303 and smoke to throttle mix controlled by switch
  39. Mode Mix
  40. 75 MHz Module for 8103
  41. JR Data Safe I
  42. Horizon JR Service time
  43. Question on 10X Heli Mixing
  44. Question off Topic for Danny
  45. Left my TX on all night in the case
  46. Just got my new 9303!!!!!!!!!!!!
  47. transferring settings
  48. blown fuse
  49. Radio Range Probs. Please Help!!!
  50. JR X-388S
  51. twin servo mixing
  52. JR 783 flap help
  53. Can I use Futaba Servos with a JR R-700?
  54. JR Receivers
  55. Converting from Futabaism to JRism
  56. Using exponential feature
  57. 9303 battery capacity
  58. Throttle Expo.
  59. 10x Charging Port Cover
  60. 9303 d/r
  61. Range Checks JR-
  62. JR8103 switch problem
  63. 9303 CHARGE QUESTION
  64. X 2610 SET UP
  65. JRPS3121
  66. 9303 questions
  67. Transmitter on with Antenna collapsed
  68. Cost of reversing a servo
  69. twin elevator servo problem
  70. jr 8411 servos
  71. 6102 fuse?
  72. co pilot use on a 8103
  73. modules
  74. New Battery = "SW WARNING"
  75. 10X mixing problem...
  76. 9303 Flight modes
  77. Servo and Hookup Wire
  78. Reciever Sensitivity
  79. Pilto link Trainer mode on XP2610
  80. Throttle curves setup for X378 radio
  81. JR 600 "Credit Card" Reciever
  82. an obvious question
  83. Servo resolution
  84. 9303 - No Timer Beeps???
  85. Servo Maintenance
  86. XF631 Transmitter Alarm
  87. 12ch jr
  88. JR XS3 Pro - Install Help
  89. servo arm ring
  90. Setting the JR XP9303 Prog.Mix
  91. xf631 should i warranty?????
  92. Timer Question
  93. Dual Rates
  94. JR PCM 10X Heli Md2
  95. Galaxy 8 & Dual Aileron Servos
  96. Danny is offline
  97. JR6102 - Buddy Box
  98. RS300 Synth FM 3Ch Rx Possible Failure?
  99. Jr's new receiver
  100. reciever shut down problem
  101. Charger/Cycler for JR
  102. 8103 choke and smoke
  103. servo load on recevier
  104. xp783
  105. Range Check
  106. 6102 throttle expo
  107. 9303 Programing help
  108. 6102 switch programming
  109. CCPM on a 10S (Aircraft)
  110. JR6102 expo question
  111. JR 2610
  112. XP6102 "Total Time" feature
  113. 8611 case tops??
  114. New Tx
  115. looking for xf-622 manual
  116. Gyro Servo Combination
  117. JR Transmitter Battery Pack
  118. 8611 question?
  119. NET-J72P Schematic
  120. JR9303 No more backup battery?
  121. JR 2610 setup
  122. JR10x Hi throttle curve
  123. JRP6664 vs JRP6667
  124. JR 9303 and 4 alierons
  125. 811 Digitals
  126. 10X flaps in Bobcat
  127. JR XP8103 channel/switch assignment
  128. DSC question
  129. Update 9303 Manuals
  130. two Modules on 10X
  131. JR Transmitter Antenna
  132. JR ES579
  133. JR Tx synthesizer module...
  134. Servo to Receiver Compatability
  135. 6 volt receiver battery
  136. JR 652 Memory Battery
  137. IS EXPERT RF650 SIMILAR TO R700 RECEIVER?
  138. JR 652 ailerons
  139. Rx Antenna Length
  140. 9303 no power please help
  141. 9303 instructions
  142. synchronize JR receivers
  143. JR 9303 battery
  144. JR9303 Question
  145. 9303 Programming help
  146. JR century 7 pcm manual
  147. How much $ to check out & narrow band?
  148. rev mix XP783 and JR G400
  149. XP9303 dual channel Elev. +Ail
  150. PCM 9X Throttle Stick Adjustment
  151. 8103 Trims
  152. JR TRANSMITTERS
  153. pages from 783 manual
  154. JR - DS8321
  155. Charging JR TRX and RX batteries
  156. Servo broken? buzz....
  157. 783 Manual
  158. XR2i 27/75mhz
  159. Crow Again
  160. Flip 600
  161. minimum voltage
  162. 8103 D/R switch
  163. XP6102 Helicopter Programming
  164. Flaperon Programing on 347
  165. Channel changing
  166. Flap/landing switch on dual elevator servo
  167. Xp783 and NER 627 pcm rec.
  168. 8611 resoulation
  169. Servo suggestion for a new trainer?
  170. Removing Throttle Ratchet on X2610
  171. JR 347x functions and a 378 function
  172. JR Servos with Futaba Radio
  173. JR R700 funtana 90 glitch problems
  174. jr 9303 need help
  175. PCM 10X Trim Problem
  176. 8103 overheated battery????
  177. tx question
  178. JR R610 quality
  179. Problem with Voltmeter
  180. Does Land mode override other modes on JR9303?
  181. JR wiring
  182. JR Transmitter w/Hitec Receiver?
  183. 9303 plane transfer
  184. 8231
  185. JR 10X Charging Issue
  186. Xp9103 Compatibility
  187. Does the JR R610UL Receiver support DSC?
  188. flaperons w/ 6102
  189. JR x-378 Discontinued?
  190. 9303 mixing - several questions
  191. JR X-378 flap help
  192. JR NER-527X
  193. JR XP562 Question
  194. 8103 and swash type
  195. Removing Battery Connector in Transmitter.
  196. Setting up Delta og 9x
  197. 9303 and high capacity battery pack
  198. 9303 in flight mode
  199. TX Comparison chart?
  200. 9303-AUX2 and 8 Channels in Monitor
  201. Service...
  202. JR10x Downline Mixing
  203. oJR 8311s and airplanes
  204. JPA 55 Base Loaded X-Mitter Ant
  205. Dual Elev. Servos
  206. JR 9X change MODE 1 to MODE 2 ?
  207. Help to set up my X2610
  208. JR Transmitter Difference ?
  209. TX Mode
  210. 9303 datasafe
  211. Few questions -need your expert help
  212. JR6102 Radio Transmission Distance?
  213. 9303H Flapperons and Dual/Triple Rates
  214. charge rates 9303
  215. 9303--pardon my dumbness
  216. XF622 Stuck At .0 volts
  217. digital servo pulse-width range?
  218. Century VII Module question
  219. How do I combine my dual rates to one switch?
  220. 9303 flap switch warning in triple rate mode
  221. Z-PCM and the 9303
  222. Flight Modes
  223. CCPM - 8103
  224. Synthesized Module
  225. G500T gyro w/ 9303 heli transmitter
  226. 8103 dual rate trim changing?
  227. Change Mode 1-2 , XP 652
  228. PCM10S Software Update
  229. www.jrpropo.co.jp
  230. 9303 idle up for airplane
  231. 6ch XP652 and a gws 4ch pico reciever
  232. R700 receiver and digital servos
  233. JR10X - Mix INClude bug
  234. Gear Channel Travel Adjust
  235. Output shaft on 8611
  236. XP652 not working
  237. Dual elevaotr servos with x2610
  238. RS300 range problem.
  239. XS3 Loses Connection from Battery
  240. New JR 72Mhz Synth Module
  241. JR PCM 10 X Heli
  242. Matchbox question
  243. jr recievers
  244. XP8103 Base Loaded Antenna
  245. Camera Trigger Configuring switches
  246. Used a Futaba charger on a JR radio
  247. TX battery
  248. 9303 travel adj on Ailerons Question
  249. Stealt tranny outdrive slop! help?/
  250. rely to your advice on 563 versus max 66
