PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. JR X-3810 with a 4 Channel Receiver
  2. JR 9303H and airplanes?
  3. New Products
  4. PCM 10 MANUAL
  5. tx and rx cyrstals
  6. 8103 way to match throttles on a twin
  7. XP6102 and R610UL - Receiver problem?
  8. question on trim memory
  9. JR RADIO 9X2
  10. 9303 trainer setup and tx modules
  11. HELP !! My 8103 lost all Power.. Oh no :(
  12. XS3 Charging?
  13. need help w/9303H dual elevator set up
  14. Spoileron travel limits
  15. Battery life and charging
  16. 9303 camber & reflex set up
  17. JR PCM 10
  18. Jr PCM9x elevator mix
  19. Short wire base loaded RX aerial
  20. JR R1
  21. XP6102 terrible glitching and range issues.
  22. Aileron Help
  23. Does JR XF622 Have Exponential ? ? ?
  24. Can matchboxes be used with Hitec servos and Futaba receivers?
  25. Programming spoilerons on a JR-8103
  26. XP6102 - didn't wake up
  27. Which 9303 radio?
  28. Jr 700 receiver
  29. Programming Spoilers on JR-8103
  30. XP2610 Vs X2610
  31. 9303 Transmitter will not turn off!
  32. 8103 battery low voltage?????
  33. JR 8103 DT PCM on 50 MHZ
  34. 6102 questions
  35. 6102 Throttle Cut Switch
  36. 9303 tx
  37. Will my Matchbox work?
  38. JR-Channel 11-PCM
  39. Toasted XF631 worth repairing it?
  40. 10x & 3pos Flap Switch
  41. How do YOU remove JR servo connectors from JR receiver??
  42. JR RC systems, which models R on 50 MHZ?
  43. pcm9x manual ??
  44. PCM9XII Manual now available
  45. 783 problem
  46. JR RC system on 50 MHZ
  47. Transmitter Memory during Battery change
  48. Quattro module to XP6102
  49. 8103 negative differential?
  50. Help w/ XP783
  51. 8411SA for Giant scale
  52. 10X INH
  53. Software update to 8103/783 tx avaiability
  54. Charging ni-mh batterys
  55. PCM 10X Parts
  56. I am driving a Nostalgia class sailplane with my 8103. Rudder,elevator,spoilers
  57. dual throttle question
  58. Battery Pack
  59. Why Doesn't JR Have Adjustable Gimbal Angle?
  60. moduel ch.22-ch.18
  61. 6102 Flaps?
  62. 8611 case recall
  63. 10x program question
  64. PCM 9x (9303) stick tension adjustment
  65. PCM9x (9303) cleaning
  66. 9303 flaperon with HiTec 555/535
  67. Is the R945S receiver be used with the 9303?
  68. jr ner-627x
  69. Spektrum Unit
  70. Connecting Servo Extensions
  71. dsc not working on 9303
  72. Receiver Help
  73. 9303 problems.. Can you help Danny?
  74. 9303 hook-up & set-up on 1/4scale warbird
  75. JR DSC Not Working, Help me!
  76. 9303 - Primary & Slave channels ?
  77. JR X642 Heli question
  78. XP642
  79. modules
  80. 9303H Version for stunt plane flaperons
  81. 10sx Intermittant Problem
  82. JR 347X
  83. 9303--lousey range check???
  84. 9303 AUX 2 and 3
  85. 6102 and 783 Tx Problems with Rx
  86. Matchbox mounting question
  87. 9303 Manual
  88. MAX-66
  89. Servo centering
  90. x378 throttle stick question...
  91. JR 9303 flaperon mx vs. camber adj & camber mix
  92. XP6102 shift selection? TX module?
  93. 9303 - Black line on display when shutting off !
  94. 9303 Switch warning mandatory??
  95. PCM10 Heli to Air or Sailplane
  96. 9303 Sailplane Moto Function, moto hold and ESC location
  97. aileron differential
  98. 10x heli radio, hitec receiver, 401 gyro ?
  99. 9303 Gyro Gain Adjustment in Flight
  100. 9303 and Servo travel
  101. X-Models Whisper Setup
  102. Servo Dimensions
  103. XF622 Problem
  104. DS-9411 Unavailable?
  105. trouble with my x-378 again
  106. Radio Range test question (10x)
  107. 811 Servo problem revisited please help
  108. JR 10SX PCM Failsafe
  109. servo selection
  110. jr6201 charging
  111. Crow
  112. JR8611 with metal servo arm trick?
  113. Single conversion or dual conversion
  114. x 378 with twister heli..
  115. sub trim and EPA for 9303
  116. 6102 662 throttle cut setup
  117. Differential ailerons and flaps
  118. Mixixng question for 10SX
  119. Master/Slave option
  120. 9303 manual, am I missing something.
  121. 9303----Another throttle-cut????
  122. 8611 travel with 10X
  123. Frequency
  124. 9303--I have a comment or two
  125. 9303 Rudder-Aileron Mix
  126. does xp9303 support failsafes?
  127. JR CRYSTAL RECIEVER swap
  128. choosing a TX
  129. 9303 DSC jack vs 8103 DSC jack
  130. 9303 Flaperons/Elevons Mix
  131. HS-55, oops Futaba
  132. 9303 PCM and Lockout
  133. 9303
  134. XP9303 and throttle cut engine
  135. 8103 and US60 flaps/crow
  136. JR 281's
  137. 9303 Sailplane version, Stick Switch?
  138. Need program help with 8103 out of channels and still not smoke!
  139. 6102 with an esky receiver
  140. 9303 Ultra Stick & Venture
  141. Help! I think my gears are stripped
  142. Repair form
  143. 8103 Throttle Curve
  144. 8103 programming 2 servos for elevator
  145. Upgrading to the JR 9303 currently fly Futaba
  146. JR 9303 TX
  147. Transmitter crystal
  148. XF 421 Programming
  149. JR-662 & 6102 and sim help
  150. JR PCM 10S
  151. Switching Crystals/Tx Modules
  152. Manual for JR PROPO Galaxy computer 8
  153. Changing Freq's on Transmitter Modules
  154. 10x problem? - please respond
  155. 6102 throttle mixing
  156. 9303 Throttle Curve Question
  157. 8103 needs repair keeps blowing fuses
  158. 8103 no elevator dual rate?!!!!
  159. 10SX and Dual Elevator servo's
  160. 8103 qnd 53Mhz
  161. Defect with 8103?
  162. 10x RF LED Blinking Off
  163. ES 539
  164. NER-327x
  165. JR 9303 Thank You!
  166. Datasafe Ultra
  167. PCM9XII / Hitec Rx compatibility
  168. Horizon 9303 Z enable?????
  169. 6v compatibilty
  170. manual
  171. 9303 Dual Channels
  172. Flapperon oddity
  173. JR NES-4000 Servo
  174. 5 digitals and 2/6v batterys
  175. 6102 and 8103
  176. JR Reaction To 14MZ from Futaba
  177. throttle trim quit working on xf631
  178. 8103 Turning off Aux 2 knob "completely"
  179. JR 378 ?'s
  180. 9303
  181. 9303 throttle
  182. USING FLIGHT SIMS WITH JR TX
  183. Does the XS3 PRO have brake mixing?
  184. Rx Antenna lenght question?
  185. Weird Servo Behavior
  186. 6102 & Berg 5CH DSP II rx
  187. 9303: Behavior of Timer button when used as switch
  188. JR XP783 - Malfunction
  189. R945S
  190. 9303: How to program a 3-position switch
  191. 537with broken tooth
  192. 9303 Heli Throttle kill using Trainer switch?
  193. 9303 Gyro Sens
  194. JRRacing XR2 radio
  195. 8611 Gear Problem?
  196. JR 6102 mixing question...can I do all these?
  197. 9303 Datasafe
  198. Jr PCM 9 single stick
  199. 6 Volt system
  200. Question on the 9X
  201. 9303 Airplane/sailplane difference
  202. JR 652 What did it do to it?
  203. JR DS161 / DS168 servos
  204. 10 x or 9303 air
  205. X378 elevon,rates and variable geometry wing
  206. Composite-arf Extra 2x2 servos
  207. Which servo connector for RS300
  208. X-378 heli problems
  209. 8611 servos
  210. DS8411 Specs?
  211. FCC regulations transmitter or module
  212. New JR Radio
  213. JR Apex 7 manual
  214. MX-22 low idle -> high idle
  215. JR Receiver Compatibility
  216. 9303 Elevator mixing
  217. 9303 and Jetcopter
  218. Activating Rx Aux5 with Slider??
  219. 8103 throttle mixing multi engine
  220. XF622 Manual
  221. transfering models???
  222. PCM9X2
  223. 9303 REVERSE SWICH
  224. Jr 388 battery
  225. Trainer system questions
  226. JR xp783 triming four wing servos on an Biplane - Danny please help
  227. R700 Rx and Quattro Problem
  228. Lost futaba 9z WC2 want to replace with 10x..??
  229. 8611 Splines
  230. JR radio crystals
  231. Dual retracts, Flaps and aileron setup on 9303
  232. Power lead induced servo buzz..
  233. 6102 and Ultra stick
  234. No JR Website? Am I missing something???
  235. Any possible ways to work in 29Mhz?
  236. 9303 Questions...
  237. Matchbox, 1 or 2
  238. DUAL RATES 8103
  239. range checks
  240. JR 378: Can't get Auto Dual Rate working...
  241. JR Rx Battery Pack Extension Cord?
  242. Blown Diode
  243. Help with JR Radio Designations
  244. Servo chart
  245. 652 Flaperons R700
  246. XP8103 Manuel
  247. Transfering data from 8103 and 9303
  248. TX Module
  249. Dual Elevators as well as 4 Aileron Servos with the 6102
  250. XP6102 aircraft select inop
