PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38
  1. pcm9x to pcm9xII conversion????
  2. Blown Fuse in 9303 Tx
  3. 9303 flight modes & D/R
  4. Old JR Equipment
  5. xr2i battery question
  6. 6102 Spoilerons and Snap Spoilers
  7. Servos died in midflight - now twiching noise
  8. Out of the office
  9. HOW TO ASSIGN FLAPS ON A JR 10S
  10. Grinding 811 Servo
  11. 6102 RUDDER SWITCH
  12. Aileron Servo
  13. Low idle trim lever
  14. Can you use the Timer in the X2610
  15. What's the different between Nes-649S and R-900S JR Receiver ???
  16. JR 10Z
  17. JR 8103 and dual elevator servos
  18. just to make sure
  19. Wha
  20. JR 9303 with RealFlight Simulator
  21. JR compatibility
  22. 642 transmitter
  23. JR2610 BATTERY CYCLING
  24. XP 8103 PCM?
  25. dual servos for elevator with different max deflection
  26. JR 9303 heli or air
  27. 9303 Throttle Trim
  28. JR 10SX?
  29. 9303 (original)/9303 (new )/ 9X2 Screen changes ?
  30. Century VII PCM update
  31. JR X347 help / manual
  32. JR PCM10 older TX's
  33. P-51 Flaps and 8103
  34. 9303 Timer function
  35. JR R1 Pro Center Spring
  36. Programing
  37. 9303 PROGRAMING SETUP FOR VENTURE 30
  38. Jr 9X range problem
  39. 18 paces on range test
  40. Old Modules?
  41. 9303 model memory backup
  42. freqency differances
  43. Easy 9303 question
  44. jr R1 ...
  45. 6102 with Hummingbird FP
  46. Quattro Lite and GWS A-10
  47. Single 8611 enough for 33% Edge Aileron?
  48. JR PCM 9X questions
  49. Data refresh rate of JR compared to Futaba
  50. JR 9303 Questions
  51. Aussie 2610
  52. Quick Service turnaround from Horizon
  53. JR 9303 TX Memory Backup
  54. Spoilers 6ch rec... 8103
  55. 9303 Aux Trim
  56. 10X throttle-rudder mix ..
  57. Car radio and brake mixing
  58. Setting up a 9X
  59. JR xs3 throttle response
  60. JR9303 Battery Concern
  61. Frequency change.
  62. Dual conversion
  63. 6102 throttle curve...
  64. My XP 652 has been at Horizon service since 11/24-what gives?
  65. Marketing versus Support
  66. H2 mode on PCM9x II
  67. problem with servos
  68. Datasafe2 electronics schema
  69. Datasafe2 electronics schema
  70. Z3550 servo
  71. 6102 for Eco 8 help
  72. data transfer
  73. 10X throttle curve
  74. Flight Mode Switch Warning
  75. 9303 Data Safe / Synthesizer Module
  76. Can the MX-22/9x/9xII and 9303 firmware be changed?
  77. XP8103 Servo Throw Adjustment
  78. pcm 10 signal
  79. Using Gy502 Gyro With PCM 10X
  80. 10sxII ???
  81. JR PCM10SXII Question
  82. Which receiver for a PCM10SX ?
  83. 10S 0r 10Z
  84. 9303 transmitter case plastic?
  85. 6102 Elevons & DR's ?
  86. Lack of parts for JR radios
  87. Danny, check your email
  88. JR Servos Oscillate at Neutral
  89. ?
  90. 9303 Programming Question
  91. 8103 Dual Elevator Set-Up
  92. 6102 and pilot link
  93. PCM9X Range
  94. Danny is it possible to make servo substitutions when ordering?
  95. CLR uses on 9303 aircraft
  96. Need manuals for Jr PCM10SXII and 8103
  97. 8103 throttle curve setup for 3d
  98. PCM9x V2 v PCM9x
  99. 9303 MODE 1!!!
  100. gproportiopnal elevator trim to flap setting
  101. 9303 Data Transfer??
  102. Transmitter Modules
  103. 9303 not support Z-PCM
  104. Transmitter Module
  105. Century VII...
  106. xs3 no range
  107. 9303 governor activation
  108. Is there a Lithium Backup Battery for JR 9X v2 or JR 9303
  109. how many digital servos on a r770s
  110. 9303 DSC question
  111. 9303 Snap Roll Function...Howzit work?
  112. JR 347 disconnect
  113. 6102?
  114. Reciever and Module question
  115. 955 Rx Antenna lenght question?
  116. 955
  117. Glitch in same spot in the sky ??Base Loaded Whip Antenna??
  118. Is all 8103 and 9303 ( AIR )are PCM capable ?
  119. Matchbox Question
  120. RX/TX Basic Questions
  121. 241, 331, or 341 servo questions..
  122. Help, reversed charger polarity
  123. What TX to buy?/ 3810 or 10X?
  124. 9303 Programming
  125. JR 9303 Flaperons
  126. Datasafe ?
  127. 9303 Throttle Kill?
  128. What's the different between single and dual conversion RX ???
  129. what is this worth?
  130. JR PCM 10 Z - Ely
  131. Which JR radios have these features????
  132. JR Syntheized module - when?
  133. Is there custom Radio packages?
  134. distance range for a JR R700 reciever??
  135. Matchbox 6 volt?
  136. Data Transfer
  137. FM, ZPCM, PPM and SPCM
  138. Dual Rx question??
  139. MX 22
  140. 421ex
  141. JR Data Safe Ultra Files
  142. Futaba PA-2
  143. JR transmitter
  144. 8103 airplane flight modes
  145. Servo Gear replacement
  146. JR 421ex Transmitter
  147. 4131 servo case replacement
  148. JR 9303 and 10x
  149. Difference between 9303 sailplane and airplae versions
  150. What Crystals for JR R-1
  151. 6102 manual in PDF download?
  152. 9303 trim levels and gyro sens?
  153. JR X-378 flaperons
  154. Digital variable load meter work on li-ions?
  155. G500T setup help
  156. JR 10SX Flight Mode
  157. Radio Interference
  158. WHERE CAN I GET PCM10X TX ONLY ?
  159. JR 6102 with 537's cold weather problem
  160. NEED A PCM10S INSTRUCTION MANUAL
  161. Newbie asking dumb ? about receivers.
  162. X 388S CCPM upgrade?
  163. 4735's on a 90 size profile?
  164. gyro piroette rate
  165. converting TX to mode I
  166. JR6102 DSC Function?
  167. xr2i lcd flickering
  168. XP8103 Throttle Kill (Question)
  169. 8103 smoke mix to throttle & dual flap servos
  170. PCM 9x II
  171. Dual Servo Unison Movement and EP Problem
  172. XP8103 S-PCM Radio question about dual servos....
  173. jr radio pcm10
  174. R1000 DS Rx & interference
  175. 8103 program flaperon on rec chan 5
  176. crystal markings
  177. Will JR 6102 work?
  178. JR 10X - need a less expensive buddy boxer..
  179. servo recomendations for Goldberg Extra 300
  180. X347 RADIO
  181. Module-53.200 mhz
  182. How to set up dual elevator with JR 3810
  183. Quick setup addendum.
  184. tx batt upgrade on 9303
  185. DS 3301 Servo - Proper mounting.
  186. JR R600 50mhz receiver question
  187. Mode change
  188. Range for jr6102 and r610
  189. JR 9303 140 CCPM problem ?
  190. 9393 Monitor
  191. JR9303 buddy box with Futabu 9c
  192. 8103 aileron programing with elevator
  193. XS-3 Pro Servo Travel on Brake
  194. 8103 Tx / Airtronics PCM Rx Compatibility
  195. Trouble with 9x radio
  196. JR 10S
  197. JR X2610 mode changeable or not
  198. Any good receivers for Futaba servos??
  199. Can i use 6V??
  200. century VII, need help
  201. How do I program dual retract servos?
  202. RX Repairs
  203. Adding Expo To Aux3 Lever On 10X
  204. Galaxy 8
  205. 9303 Dual elevator set up
  206. Need to get a 4131 reversed
  207. 33% set up
  208. JR PCM 9X - HELP!!
  209. Gyro Gain on 6102
  210. Where to Buy JR XP6102 PCM (JRP6664)
  211. Why doesn't JR have a Dual Conversion RX under $200?????????
  212. Backup Battery
  213. H9 Ultimate and wing servos question???
  214. 22 awg servo wires
  215. JR 9303 Compatibility in Australia
  216. Dual Rate Switches
  217. How much Expo do you use???
  218. 4721, 8101 SERVOS
  219. 8103 snap roll switch problem
  220. Mixing out coupling for knife edge
  221. I don't like the location of the throttle hold switch
  222. JR 10 SX II Switch Assignment
  223. High rate - low rate servo movement ?
  224. R700 crystal problem
  225. JR 811 Digital servos
  226. newbie crystal problem take 2
  227. flight modes with a 10X
  228. 8611 servo rumors
  229. 622 gimbal replacement
  230. Servos buzzing
  231. Jr aileron problem and repair....
  232. JR PCM9XH vs PCM9XA
  233. JR 6102: in-flight flap trim possible?
  234. heli crystals
  235. newbie crystal problem
  236. Dots on the JR Crystal.
  237. What's up with these !@#$%^&*glitches???
  238. JR 9303 Radio
  239. Z650M applications
  240. 9303 Mode One - are they in staock yet
  241. 9303 throttle tension question
  242. 8103 compatibility with 3810
  243. Differences in the 8103, and 9303
  244. Receiver
  245. JR500T Gyro
  246. glitches when cold
  247. 8401 Servos
  248. 9303 switch warning?
  249. maintenance
  250. XP 8103, G500T, 610 6Channel for Heli
