PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38
  1. Question about landing setting for the 8103
  2. Myth or Fact
  3. RX Antennea Length - More Info needed
  4. JR 9303 DSC cord with Li-Ion regulator
  5. Duel Battery Setup
  6. JR modules
  7. R700 Voltage
  8. Dual battery setup question...
  9. JR 9303 battery question
  10. JR radio repair
  11. Broken timer switch
  12. buddy cord
  13. DZ8450 Problem
  14. 8103 PCM aircraft
  15. JR's answer to the Futaba 14mz?
  16. 9X support
  17. 9303 and Hacker ESC "Heli"
  18. 6V RX packs for JR
  19. Old JR 622 Manual
  20. Heli collective pitch and old JR XP8103A airplane Tx
  21. 6102 Airplane throttle curve mixing
  22. 9303 3 position throttle switch...
  23. JR XR-3 and XR-3i 3rd channel
  24. 507,517 servoes
  25. JR XS3 Pro
  26. Swapping modules in JR TX's
  27. Runaway rustler
  28. WHEN?
  29. JR 10X
  30. 1988 JR GALAXY COMPUTER 8 PCM
  31. JR Transmitter Frequency Module - All the same?
  32. RX just quit
  33. JR RS300 receiver with a Futaba 2pk Radio?
  34. 9303 question
  35. 378 ?
  36. 10X Transmitter/Datasafe Questions
  37. DSC
  38. Radio fifferential set-up for funtana.90
  39. XP 783 a
  40. Servo Help
  41. JR Manuals on Line ? (9303&10X)
  42. JR9303 and a JetCat
  43. Flaperon with 622
  44. mixing switch JR 388
  45. 10x vs New 9 channel
  46. Replacing my 347
  47. 9303 vs CAP
  48. 9303 Mode One question
  49. charger polarity
  50. jr 10sx II
  51. Quattro Question
  52. Maximum Tx stick resolution for heli
  53. tx repair
  54. PCM 10X battery problem
  55. 9303 for DLG
  56. JR XP783 - Throttle Trim and Backup battery
  57. 9303 and Datasafe
  58. JR XS3 40 mhz channels and frequency
  59. SERVO ARMS
  60. JR Tx X-2610 ELEVON wing type
  61. 6102 Mode 1
  62. JR 9303 question
  63. Problem with 642 transmitter
  64. Matchbox Questions
  65. 10x doesn't boot
  66. Servo screws
  67. 10x 9303 Master Slave Control - servo rev
  68. Changing freq., the real answer...
  69. JR 9303 Model Copy Function
  70. JR Radio used for flight sim
  71. JR 652 3D setup for simulator use
  72. PCM 9X english Manuals
  73. JR XS3 and NiMH Batteries
  74. 9303 auto rudder D/R
  75. XS3 Timer?
  76. 9303 DSC socket
  77. Butterfly/crow
  78. JR X2610 Tx mixing
  79. JR-X347 AUX1 Does not reverse.
  80. high band, low band
  81. 9303 Mode 1 Date?
  82. 8231 servos "fluttering"
  83. programing mixes
  84. 9303 manual, what gives...
  85. 9303 trainer switch
  86. 50 MHz conversion
  87. Replacement antenna for JR max 4
  88. Help - Bad Tx Module?
  89. 8103 programing new choke switch
  90. JR X2610 Tx mixing
  91. Program for Choke Switch
  92. 8103 Old vs New
  93. 811 Servos Trouble finding Center..
  94. revo and xs3 problems?
  95. 8103DT heli radio ?
  96. Pulling my hair out-trying to get dual ail. servos right w XF631
  97. 331 Servo and 6V
  98. TX Throttle
  99. JR 9303 - Rudder/Spoiler set up
  100. DS3421
  101. New JR 9XII Radio in Japan
  102. 9303 PCM Fail Safe
  103. iHobby Expo, out of the office
  104. 9302 Trim Offset
  105. 9X question
  106. Servos for 1/3 extra 330
  107. where is #1 position
  108. can I order just the plastic gear...
  109. Servo compatibility
  110. 8103 dual servo 3d setup issue
  111. Differential Airlerons with a JR6102
  112. 8231 Servos Chattering
  113. HELP - 8103 Trims went crazy on their own
  114. THROTTLE KILL
  115. JR 241 OUTPUT ARMS
  116. Concerns about moving up to an X-388S
  117. 10X ???s
  118. XP9303 DSC
  119. 9303 switch labels
  120. Is Graupner MX-22 serviced by Horizon?
  121. JR X-378 Flaps/Dive brakes
  122. XP9303 A/S
  123. Do 10X Tx's have 3 a/c modes?
  124. JR Programming guide suggested amendment
  125. 9303 - All Channels Proportional?
  126. What is "FROL" in the 9303?
  127. Duralite TX battery
  128. Rudder-throttle mix on Twins
  129. Catalina Build
  130. JR red letter transmitter case
  131. this question is for danny
  132. 8103DT Blowing fuse and 8411's need service
  133. 9303 Sailplane Switch Names
  134. two servos for elevator
  135. Dual Aileron Setup
  136. 9303 flaperon and spoileron
  137. 388S flap
  138. JR 6102 vs 621 buddy box help needed
  139. PCM 9X Programmable Mixing II
  140. Downlink receiver voltage
  141. Spread Spectrum
  142. Trim does not affect a slaved channel.
  143. Xp8103 (Heli) Stopped working. Will not turn on.
  144. PCM 9X/9303 Programmable Mix
  145. JR 6102
  146. changing crystals
  147. 8103 mixing problem
  148. jr radio airtronics reciver?
  149. 9303 on AFP
  150. XF 622 manual
  151. XS3 Compatibility problem with hitec receiver
  152. 8103 Jitter
  153. JR 10X radio problems.
  154. Setting up three DS8611 for rudder!
  155. JR 770 PCM receivers
  156. Whip Antennas
  157. Masters
  158. JR XP642 Ailevator
  159. JR R770 PCM
  160. Digital servo reversing
  161. JR 9303 Programming Guide
  162. 622 controling three engines
  163. JR9303 & Buddy Box
  164. Charge jack intermittent operation - XP783
  165. 9303 Sailplane Mode 1 switches
  166. JR X-347: Pot 5 doesn't appear on display? Help Please!
  167. JR radio
  168. 9303H auto dual rates/triple rates
  169. Need helt with flapperon on my JR PCM 9X
  170. 9303 issue: mixing elevator to flap through the gear channel
  171. 9303 PCM possibilities
  172. 10X module temperature
  173. Dual Rate Switch Assignment
  174. Setting the offset in a mix
  175. 9303
  176. Range Check Questions
  177. XP8103 'stick monitor' issue
  178. Function 14 Question - 10X
  179. DataSafe2
  180. G500A Gyro 955S RX and 8611's /10X Problem
  181. JR DS8411, JR DS8411SA and JR DS8311
  182. Original (DB 25)Datasafe interface
  183. JR9303-8103-9X same tx module???
  184. any news on a 10X replacement?
  185. JR X-3810 programming for flaps
  186. 8411's
  187. XP 642/652 Special Menu configuration
  188. I NEED JR PROPO CENTURY 7 MANUAL
  189. 662 Programming Guide?
  190. JR servos not working with Novak Synth Receiver
  191. 9303 Sailplane Setup
  192. Dual Elevator Servos setup on JR662
  193. X-342 radio flight modes question
  194. 9303 and 8103 info compatible and elevator mix ?
  195. Manual for JR x-347 Radio
  196. Dead JR 652
  197. 8103 Transmitter
  198. JR 700 Receiver Question
  199. 8103 replacement batterys
  200. 10SX Modulation
  201. Can the 8103 be connected to 10X mode1?
  202. 8103,dual elev.servo mix
  203. Z4800T Servo
  204. 6102 flaps
  205. JR 10X question.
  206. 6102 Channel Change
  207. 8013 DSC Cable
  208. PCM9X/9303 Aero flight modes
  209. 9x device select prob
  210. 6102 problem
  211. Voltage in 6102.......How can you tell ????
  212. 8103 throttle up-down
  213. XP642 Flperon, flap, gear
  214. 8103 And Negative Differential
  215. Converting DS3421's to Plastic Gears
  216. You know better than I
  217. New servos noisy/grinding?
  218. mixing elevator servos
  219. Expo on Throttle with 8103
  220. JR Transmitter Modules
  221. JR6102 and GY401 set up help please
  222. Mode 1
  223. JR 810G Servo with Futaba GY 240
  224. JR 8103 and V-Tail
  225. 6102 programing question for micro-jet
  226. Are JR transmitters type accepted for use on the Part 90 commercial frequencies?
  227. maintenance
  228. DS 3421
  229. set up redundancy
  230. 9303 - Ultra Stick
  231. 9303 Manual Questions
  232. 6102 Mixing
  233. 10X 52mhz to 72mhz
  234. XP783 - Help - can't get control knob and land Switch to work together
  235. Can the 9303 upload plane info from 8103?
  236. XF-421-EX Flaperon
  237. erratic aileron servo
  238. 10X Heli to Aircaft Conversion
  239. 6V receiver packs
  240. DS9411 Servo
  241. Youth size transmitters
  242. Wider Pulse?
  243. 9303 -Mode I & Mode II & recvr shift
  244. 8103 Flap Setup
  245. switch assignment
  246. 9303 SoftWare the same in all the Radios(Heli, Glider, Plane)
  247. Old JR Radios
  248. 10x has issues
  249. JR 10X / flaperons and spoilerons ?
  250. DELAY ON AUX CHANNELS
