PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38
  1. XP642 motor interfearance?
  2. xp6102 PCM
  3. loss of spring tension on gimbals
  4. Danny, please help??
  5. 8103/F400 programming
  6. 378 Tx
  7. JR 783 Fuse Size
  8. Programming Quad Flaps with JR 10C-5SFR Heli
  9. Programming Quad Flap Ultra Stick with JR 10C-5SFR?
  10. 351 randomly flutters
  11. JR Radio
  12. JR 9X = 9303
  13. xf421 flaperon
  14. 8411 - Buzz
  15. Few questions
  16. Futaba Tx to JR Rx
  17. 8611 Jitters
  18. Single stick gimbal for JR Century 7
  19. JR single or dual conversion?
  20. Urgent help needed regarding JR 378 radio and JR 770 receiver...
  21. MX-22
  22. jr 8103 momentary switch
  23. JR crystals on low end of 72 band
  24. JR Century 7...another question
  25. Removing aluminum arms from Metal gheared servos
  26. Transmitter Modules
  27. JR 3021 Servo Problem
  28. 549 RX and 811 servo jitters and Futaba gyro issue?
  29. JR XF421 FM Manual
  30. flaperon travel adjustment
  31. Flaps and Ailerons
  32. Receiver's, What is abc&w
  33. JR XP 783 - 120 Deg CCPM?
  34. JR Rx Batteries & Charging
  35. Servo & RX Compatability
  36. receiver battery for smoke pump
  37. 8231 servo flutter
  38. JR X-378 VS Futaba 7CHP
  39. JR Max Computer Radio
  40. 4 ch. JR Quadra radio
  41. Power of JR transmitters
  42. 4721 servos
  43. Mode Change in JR X378 (heli)
  44. 8103 hi-low rates
  45. What are the major differences between the XP6102 and the XP662?
  46. Digital Servo / Battery Question
  47. Revolution Whip Antenna on a 649 Rx
  48. JR Buddy/Training radio
  49. jr xf622 need to replace crystals?
  50. XP6102
  51. Flaps not going down together
  52. RC Frequencies
  53. xp8103 radio on but receiver not responding
  54. 10X xmtr question
  55. 8103 on Delta mode setup?
  56. JR 8103 7 or 8 channel
  57. Thanks for great support!!!
  58. XP 783 manual
  59. JR x388s transmitter
  60. Jr 610 Rx.
  61. 8411 servo jitters
  62. 10x Range Testing
  63. Actual Height Of 9011 Servos ???
  64. JR DS811 Servo
  65. 8417SA
  66. OLD SERVOS (NES-517, NES-IO2, NES 2001 and NES-L4001)
  67. DS811 DIGITAL SERVO'S
  68. Convert JR XP8103 72mhz to 35Mhz
  69. Just bought the JR X-3810, (8103) which recivers can I use?
  70. 10X ground range check
  71. Throttle cut
  72. 378X conversion to 6M/50Mhz Ham?
  73. aux knob 2 still affects the second ele**8103**
  74. Changeing Crystal in XP8103..?? Yes or No
  75. Flap on a XP662
  76. JR X-347 Won't power up! Help!
  77. X-347 Elevator D/R setup
  78. On board Lithium
  79. 8103 questions
  80. NEW Graupner JR MX 22 - LANGUAGE prob.
  81. Channel difference or quality difference
  82. 8103 - Negative Differential?
  83. Control Horns
  84. Mode Change JR X-347
  85. What receiver for the XS3
  86. E306/E151 Micro Servo
  87. Changing Crystals
  88. JR 10X and Trace Rate?
  89. JR 537X Reciever
  90. JR 500A Gyro ?
  91. FLAPERON in R610M ??
  92. Matchbox
  93. X-347 Aileron trim in mixing
  94. Sailplane programming for the 10x
  95. JR R770 Receiver problems...
  96. Ferrite Chokes
  97. 8103 questions
  98. Questions re 9X
  99. 10x heli stunt switch
  100. servo buzz
  101. xs3 trouble
  102. JR Servo S537DS
  103. What servos to install?
  104. New to twin engine setup on 8103, will this work ? 1 last question..
  105. alloy servo arms
  106. Receiver soaked with fuel....
  107. Transmitter Question
  108. Noise from matchbox affecting ground check
  109. 8611 servos with Futaba receiver?
  110. Danny, please check your PM's
  111. Couple of simple questions *8103*
  112. Servo Resolution
  113. Transmitter Troubles
  114. tx battery connector
  115. JR-NES 4011
  116. JR 652
  117. Crystal question
  118. 945 xtal question??
  119. Receiver for Jr Propo R 756 PCM Transmitter
  120. 8103 programming instruction
  121. 8103 Reset
  122. 347 or 662?
  123. servo twitching please help
  124. Rate the JR X 378 radio...
  125. 6102 Timer
  126. transmitter questions
  127. TX crystal
  128. 10X Programming ?
  129. JR/Horizon Service Issues
  130. 8611 output shaft
  131. JR TX Battey Question
  132. 8103 second aileron servo travel
  133. Thank Danny
  134. stripped 9411's in Funtana
  135. Questions re 9X
  136. Glitches - Help!!!!!!!!
  137. 8103 Antenna
  138. Noisy JR 537 Servos
  139. EPA question on X-378
  140. DS 811 vs DS 537
  141. JR - Hitec trainer question
  142. 72MHz conversion to 75MHz?
  143. SPCM Failsave settings...
  144. 10X touch screen issues
  145. JR X-388s Manual
  146. 2 rx's
  147. No throttle trim on my X-378
  148. Datasafe 2
  149. 6 meter micro Rx
  150. Battery Packs
  151. 8103 Mixing
  152. JR 10X charging
  153. DS 281 Servo Control Horn
  154. JR radio 3810
  155. Buddy box for 8103
  156. DS811 @ 6v
  157. Broken 8103 transmitter antenna
  158. DataSafe 2 Question
  159. 10x failsafes
  160. Danny 6102 question??
  161. Centry 7 and 388 S
  162. X-347 Manual Available???
  163. Diode in the 9X
  164. JR388S Dual Elevators
  165. Jr 8103 check up
  166. JR service in the UK
  167. I left my transmitter on all night with the antenna down
  168. JR 10 Ch. NET-A110FZ radio
  169. JR XP652
  170. My XP 783 is fried
  171. Question for Danny re: Voltage drop??????
  172. 8103-A vs 8103-H
  173. 1 year later and still no 9X in the US?
  174. Jr servo name and torque chart
  175. 10X manual
  176. Why is the JR 3810 radio discontinued?
  177. JR8611 Servo jitter. Help!
  178. how much to get a check-up
  179. Rudder /Elevator and Offset mix ?
  180. 10X help
  181. Dead JR 662
  182. NER649S Rx antenna length?
  183. older 8103 ccpm-where to send?
  184. WHEN DO I CHANGE THE MEMORY BATTERY - 8103
  185. compatability
  186. JR XS3 I can't get reverse to program
  187. Jr xf631 Radio Throttle Cut
  188. Servo stress
  189. Mixing smoke with throttle
  190. 8103 dual rate end point adj?
  191. How set-up JR X-378 radio with Raptor 30 V2
  192. Needing help setting up JR X378 radio with Raptor 30 V2
  193. JR RXs
  194. Aileron Glitch
  195. 8103 won't holld program ??
  196. 8103 question
  197. jr 622 shows .1 volt on display
  198. Danny Jr 10x Charging and Cycling simple question??
  199. Trim Resolution and Servo Centering
  200. JR 10SX
  201. JR811 DIGITAL
  202. 8103 Problem , wont turn on now
  203. 8231 Servo Failures
  204. 8103 Throttle Cut?
  205. JR 347 dead
  206. JR TX module frequency select
  207. JR 10x buddy box
  208. JR Battery query
  209. New JR 9X LCD screen questions
  210. 4.8v & 6v for servos
  211. Need new antenna's on 3 rx's... should I do it or?
  212. elev's
  213. 8103 & 783 Linear Throttle Mix For Fixed Wing
  214. JR servo connectors
  215. rs300 antenna wire
  216. JR6102 w/Hitec reciever?
  217. Frequency Conflicts
  218. 6102UL JRP6654UL**
  219. 622 dual servos for aileron
  220. Danny-
  221. 783 problem
  222. JR PCM 10S Auto Rudder
  223. JR Shift
  224. 6102 Tx??
  225. 783 Fuse
  226. new jr 9x transmitter with old futaba receiver & servos
  227. Fast Charge 10X Transmitter Battery?
  228. XP6102 & Funtana
  229. Help with 3D throws and flap-elev mix
  230. manual for jr xp 783
  231. XF631 screen issue.
  232. JR 8411 to Futaba receiver??
  233. JR XS3 disabling battery warning?
  234. DS 9411
  235. 783 and Venture 50
  236. Screw size for DS8611?
  237. 500A gyro
  238. 4721 to 2721 Conversion Gears
  239. XP652 Delta/elevon setting
  240. 955 or 945 rx ?
  241. 8103 Programming Timer Question
  242. will the xp6102 work with...
  243. 4.8 vs. 6 volt/JR 8411'S
  244. 8103 Programming Question
  245. Servo Chart
  246. 783 withy V-Tail and Flaparons Also
  247. XP662 Flaperon setup
  248. 8103 v-tail and flaperons
  249. jr DZ8450
  250. Throttle Servo?
