PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38
  1. JR servo 4041
  2. Throttle curve
  3. Where to buy a RS300 40 Mhz Receiver
  4. JR 8103
  5. 3yr Warranty still valid if bought new from EBay?
  6. JR 10S throttle problem
  7. JR Quattro Repair Manual
  8. !.20 ultra stick program.
  9. Xs3 installation
  10. xf631 crow programming
  11. XP8103H Aileron Dual Rate Switch
  12. j/r 10x radio, is it better
  13. non-synthesized rx for xs3
  14. Throttle Curve
  15. JR net-W125H manual
  16. JR 8103 Turn Off Knobs
  17. Does the 9X do this?
  18. Rechargeable Batteries for XS3?
  19. rudder speedbrake w/10X
  20. 6102 Elevator-Flap(eron) mix
  21. JR 6102 Dual Elevator Servos
  22. 8103 Repairs
  23. 8103 nightmere
  24. XP6102 Better then a Futaba 8U?
  25. Xp662 memory loss
  26. Servo specs.
  27. 8417
  28. DANNY NEED HELP!!!!! RF INTERFERENCE W/GASSER
  29. JR 622 Radio???
  30. exchange Crystal in 10x
  31. 10x JR smoke set up detail
  32. PCM10 Helicopter
  33. 4001 Servos
  34. PCM 10SX question--please help
  35. 6102 sMix Setup
  36. 945, good range, then bad range..
  37. 8103 programing video
  38. Ailerons & flaps
  39. 10X smoke setup
  40. JR X-378 question
  41. JR10X for helis and airplanes
  42. 6102 mode 2 to 1
  43. Re-soldering leads in 8700G servo
  44. XF 631 mode change
  45. DS3421 - Alloy or Plastic?
  46. JR811 spline is stripped
  47. Lack of voltage on JR servo specs???
  48. Bad JR 537 servo??
  49. PCM 10SX II Airplane Manual
  50. Giant racing
  51. 8103 Mode 2 to Mode 1 Change
  52. JR R1 AM modul?
  53. Jr 610 Micro Rx?
  54. 10X Question & Request
  55. Transmitter Repair !
  56. jr x-3810 spcm
  57. New JR 6102
  58. 8103 Flaps & Elevator
  59. JR RX Crystals Compatible?
  60. FS8 Co-Pilot
  61. JR PCM Receivers
  62. JR XP 2610
  63. New JR PCM 9 possible bug
  64. Module adaptability, 8103
  65. old Radio, is it legal?
  66. convert 2721 to 4721
  67. Question on flight modes
  68. Unlimited 8
  69. neutral throttle setting
  70. JR frequency synthesizer
  71. Automatic Dual Rates
  72. Buddy Box for an older 8103
  73. customer service at H-H
  74. Is there a new jr 9ch
  75. Please review broken spring post below
  76. Model programming
  77. crystal ?
  78. Out of the office
  79. 8103 malfunction? Fail Safe lockout?
  80. Servo Chatter
  81. 8700G compatability with 9Z
  82. 8103H and the Ultra Stik
  83. Flapperon programing on JR X9
  84. Modulation
  85. Plugging in an extra battery pack to the R900S receiver?
  86. Jr Charger question???
  87. PCM 10X question
  88. jr extra battery packs
  89. JR 10S Rec'rs
  90. Need a Good Glider radio
  91. 8103
  92. gimbal tuning
  93. Gear Switch
  94. 8411's, 8511's and 8611's on li-on regulator
  95. Expo on a buddy box
  96. Flaperon Programming - JR 8103
  97. JR6102 w/ R770S PCM
  98. JR NER 326-X receiver question
  99. 91 FX on WM midget mustang--what prop size?
  100. JR SX3 radio CRASH!!!!!
  101. FlaperonsHow do you set up a R610M RX for Flaperons?
  102. 6.0v VS 4.8v
  103. Servo lifetime
  104. Range problem w/50MHz
  105. Connecting my JR to the Real Flight G2 simulator?
  106. brand new ds3421 smoked!
  107. jr xp662 spoilerons on a switch? how?
  108. 8611 With Play
  109. 8103 landing switch
  110. JR 10X
  111. JR 8103 programming help needed.
  112. battery weight?
  113. JRPG500A Gyro
  114. rx issue
  115. 10x Switch replacement question????
  116. digital newbie help
  117. Amplified y harness
  118. 8103A with throttle
  119. crystal question
  120. NES-4421 ?
  121. NES-4131 soft spot
  122. Using a 421 as a buddy box off of a 622
  123. Spring is here ! Where is the 9X ????
  124. GW/R-4PII
  125. Great service again from Horizon.
  126. Graupner XS6 (Europe)
  127. JR Crystal dots ?
  128. 8101 servo moving
  129. 6102 Diode ?
  130. 8231 servos
  131. PPM or PCM
  132. XP662 AC mix question
  133. JR-x347 & PCM
  134. XP662 and GY401
  135. multiple radio use for robotics competition
  136. Where is the U.S. JR PCM 9 System
  137. XP-642
  138. Defective transmitter case plastic?
  139. Best heli servos from JR
  140. Servo set up on H9 cap & 10X
  141. Field charging my XP6102?
  142. Balancing flaps on 8103
  143. NES591 Servos
  144. JR 652
  145. instructions
  146. No trim offset in function mode! Why?
  147. Danny - 8103 Throttle Ratchet Removal?
  148. JR NES-2235
  149. 783 delta wing setup question
  150. Rx crystal little "door"
  151. Need help with New 8103DT w/DS811 servos flutter on the ground
  152. xp 6102 fm heli
  153. Can't wait for 9x. Bought EVO 9! See Pics
  154. Airtronics Rx with Jr 10x Tx?
  155. JR XF421EX
  156. 8103- can't use throttle trim on gear mix
  157. 8417 vibrates
  158. cost of transmitter checkout
  159. Models in 8103
  160. JR SC-1
  161. Cessna 182
  162. 10x learning/setup with Tx off?
  163. XF631 with spoilerons?
  164. xp 6102 Throttle to Throttle Mix
  165. JR 537 Std Servos with 6 volt battery question.
  166. JR 783 using flap switch
  167. Digital servo overload ?
  168. RX Parts?
  169. Broken spring-
  170. 8103 fuse question
  171. Servo Problem?
  172. Range Checking he 10sx 2
  173. Retune TX module or buy additional?
  174. PCM TX module work with non-PCM receivers?
  175. JR 9X radio
  176. split elevator with 2 servos and 8103
  177. Dual receivers
  178. DataSafe 2
  179. 950s receiver & gas?
  180. Original (DB 25)Datasafe interface with Datasafe 2 software
  181. xp 6102 dual elevator help
  182. Dual elevs. Travel adjust on spoiler ch.
  183. JR XP6102 Mode Conversion
  184. xp 6102 problem
  185. xp8103 mixing for three throttles
  186. AM Century?
  187. Century 7 Single Stick system
  188. 6102 weird stuff happening
  189. Danny, need help
  190. Antenna
  191. A friendly thanks
  192. JR XP 6102 - Clarification
  193. 50 mhz Transmitter Modules . .
  194. 50 Mhz Tx Module
  195. 3 position flaps, 8103
  196. Need a new Reciver for HPI Savage
  197. JR700 not cutting it for AutoPilot System...
  198. JR 6102 Trim memory??
  199. xp652
  200. New EDGE 540 33%
  201. 10SX questions
  202. JR TX MODULE
  203. CCPM with JR X-388S
  204. 652 Radio and Twin Engine mixing capability's
  205. Throttle Mixing
  206. Channel 12 conflicts
  207. ds811 and gws jitters
  208. Galaxy 8 channel Radio
  209. 10x Two Aileron Servo Setup
  210. RE: Jr Galaxy 8 Channel radio
  211. 8103, re-asign controls
  212. TX Module Question
  213. JR Max Computer Manual
  214. 6102; flaperons; with aileron differential?
  215. DS8411 shudder
  216. jr xp 8103 split elev.
  217. Jr Galaxy 8 Channel radio
  218. 8231s on ailerons
  219. Broke 662
  220. JR PCM 10X gimbal springs
  221. module qustion
  222. Z650M Servo Bearing Upgrade?
  223. JR R1000DS PCM 10 RX...PCM Only or PPM too??
  224. jr 10x
  225. Slow Speed Flaps
  226. JR 9X frequency Modules
  227. JR X-347 radio manual wanted
  228. NER527X info.
  229. JR XP652 Flaperon problem
  230. 6102 Throttle Cut
  231. Help, I need a JR PCM10sx manual.
  232. JR 10X Mixing Question
  233. 8103 question
  234. DS 8611 change
  235. 10X Question
  236. 8103 flap and landing switch mix
  237. JR PCM9X or PCM10sx
  238. Choosing new JR radio
  239. Battery Pack for RS300
  240. difference between DSL jack 8103 vs 6102?
  241. is the JR xp622 digital or analog?
  242. JR Radio manual..V2C-2SH CX..help!!!
  243. 10X question.
  244. JR radio
  245. 8103- programming one switch for 3D
  246. JR XR3i
  247. HF Module for 8103
  248. 6V Torque of 2721?
  249. 8103 Programming ???
  250. Installation of R.F. Filters
