PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. DX6 battery
  2. Gold Wing Rc ALL NEW!!!
  3. Data Flight Log
  4. DX 18 vs Others
  5. Refresh rate for Spektrum H6040
  6. Jr r921 rx
  7. JR XG11 brake set up
  8. Having trouble installing setup files on my DX8
  9. Programming Butterfly into JR9503
  10. Dx 18 problems after update
  11. JR 9303 Tx
  12. JR Apex 7
  13. Jr xg11
  14. JR 11X working with PCM reciever?
  15. JR G370A Mounting Question
  16. AR635 can't get flaps to accept failsafe position
  17. DMSS module for a 10X
  18. Binding Dx6i to Ares Gamma 370 receiver
  19. binding 1221x receivers
  20. AR8000 Issues
  21. DX9 More bugs than a bait store
  22. JR10X A Transmitter
  23. Spektrum Servos A6000
  24. DX5 to DX9 wireless trainer binding problem
  25. JR11X setup for DS821 servo
  26. Dx18
  27. Having trouble programming DX8 using 2 elevator servos
  28. JR 2.4GHz DMSS module (TG2.4XP) - poor fit on JR 12X MV and Jr PCM 10X
  29. Can't Load Newest DX9 Sound File
  30. Older DX-2 radio
  31. JR Powersafe 922 sends power to some servos even when soft switch is off
  32. Spektrum Radio Link Question
  33. X9303 Elevator Offset
  34. DX-9 1.03 Update
  35. Spektrum x-plus 8 configuration
  36. JR 922 Powersafe Receiver
  37. low flying voltage on tx
  38. JR X9503 quick question.
  39. DX8 Problems
  40. how does the balance function work on the DX9 Spektrum
  41. Dsm2 dsmx
  42. ATV as it Relates to Resolution
  43. ATV as it relates to Resolution
  44. DSM DSM2 DSMX help
  45. NES 2721 Servo arm screw
  46. Need help-JR R921 Reveiver dual battery hookup
  47. UMX AS3Xtra programing
  48. Long delay in AR7010 Receiver initialising
  49. Century 7 Single Stick Battery?
  50. Spectrum DX7S / AR8000 - Binding Issue Following Crash !
  51. WARNING: Spectrum DX 9 Transmitter
  52. DX6i Throttle Stick Missing
  53. Specktrum DX9 , DX8 , DX 7s Toggle Switch
  54. Interpreting Spektrum Flight Log Results
  55. DX18qq question/AR12120
  56. JR Radio Service
  57. trying to decide between JR 9503 and Spektum DX9
  58. Binding Dms2 receiver with the new DX9
  59. Andy kunz-dx9 wow-one question
  60. 9503 Flaperons issue help please.......
  61. DX18 throttle to left slider mix
  62. Need programming help new dx9
  63. JR 11x compatibility with Spektrum Receivers
  64. How to get the correct rpm readings with the Spektrum pickup
  65. Spektrum Flight Log not compatible with AR610 Receiver?
  66. X347 doesn't work with R649s,why .
  67. Need to expand DX 8 - is it possible?
  68. turnigy lipo in a dx-7s
  69. Why cant I turn off switch's on my DX7?
  70. JR/Spektrum - has anything really changed?
  71. Spektrum A3040 servos problem.
  72. Spectrum AR8000
  73. JR 8103 conversion to 2.4, worth it & cost (?)
  74. any adjustment to DX8 Roller sensitivity? It clicks too easily on mine
  75. JR DS8911 servo
  76. Jr rd1222 out voltage ?
  77. Spektrum TM1000 Telemetry /Temp sensor
  78. DX18 Servo setup for the Ch# > 10 without XPlus
  79. dx18
  80. JR DMSS RX binding plug polarity
  81. JRC NER-327X Reciever
  82. xg14
  83. 2.4 module on a 10X
  84. A funny thing happened to my DX7S today
  85. STI and TM1000
  86. DX9 mix programming
  87. JR 9X2 Transmitter
  88. STI app closes when starting turbine
  89. Jr x9303 and servo travel
  90. dx6i dropping control mid flight, just a few q's
  91. mode 1 master to mode 2 slave
  92. servo setup menu is backwards
  93. DX8 7.4 4000 mah Lipo battery question
  94. DX8; dual flap servos-can they work together?
  95. JR 8103 w 2.4 DMS2 Module having problems with EMS Door sequencer
  96. Spektrum Servo Q ie reversed servos
  97. Dual/Redundant Battery systems
  98. Training with Spektrum radios
  99. Need info on Spektrum dx7 info... Rx? Version?
  100. will jr receivers work with spektrum radio
  101. No Charging Indication on the Spektrum DX6i
  102. TM1000 Telemetry Module Question
  103. DX9 Shipped Today!
  104. AR610 Unbinding
  105. DX-18 vs XG14
  106. Dx8 problem
  107. 11x and G370A gyro.
  108. DX6i Battery Connection Tabs
  109. Any news on new JR super transmitter?
  110. Need Serious help with telemetry (Robosoft)
  111. DX8 Throttle control with motors
  112. What's the difference between the Spektrum AR6255 and AR6260 Rxs ?
  113. JR 9503 battery on circuit board?
  114. DX7 and lipos
  115. Does Aerofly professional (not deluxe) work with windows 7
  116. 9503 Programming for Dummies?
  117. XG8 Jr
  118. JR leaving the U.S. Market
  119. Spectrum 9100 Slow Blinking Lights
  120. DX18 Gear switch setup
  121. Brand New JR DSX9 is Faulty - wont save any settings
  122. JR Sport Sx600 72Mhz transmitter elevator stick does not return to center
  123. DX5e buddy box - Mode II and Mode I
  124. Spektrum DX5E buddy box with DX7 as slave - how to?
  125. Help please
  126. radios that will work on differnt recievers
  127. JR DSX9 Limited - Does it have Bearing Gimbals?
  128. Transmitter Beeping
  129. Receiver Antenna Wire
  130. No response after removing wing?
  131. DX 6i servo travel
  132. JR Matchbox & Futaba or Hitec Servos
  133. RG831B DMSS Receiver Problem
  134. DX8 throttle rpm adjusting help?????
  135. Spektrum AR 9310 Rx's not coming into Binding Mode-
  136. Master/slave mix problem
  137. Spektrum Dx2e transmitter and sr201 receiver
  138. new DX7 S and Orange receivers?
  139. Just Got A New DX8 and ???
  140. Electrical hum coming from JR9303
  141. Older Dx7 Question
  142. JR 10x Cassette / Circuit board needed
  143. DX11X Elevons and elevator mix
  144. SPMR75010 VS SPM6830
  145. old DX7
  146. DSX 9 mode 1 master to DSX 9 Mode 2 slave
  147. spektrum 2.4 dsm7 signal loss
  148. Dx6I Trims reversing
  149. Antenna Knee Joint
  150. JR 10x touch screen
  151. JR XF622 not transmitting, what's wrong?
  152. JR11X and Hitec programmable servos question
  153. JR 11X STICK POSITION SWITCH
  154. Problem registering a new purchase on DX6I
  155. DMSS Telemetry range?
  156. Jr Tx Wall Charging Problem
  157. Radio Transmitter question
  158. What could cause TOTAL RX power failure??
  159. DX-7 Dual Aileron Programming
  160. 8611 and older 8711 at HV?
  161. Eflight HP6DSM Radio Reconfigure Trainer Connection
  162. SPECTRUM RX
  163. dx6
  164. AR500 issue
  165. DSMX compatable
  166. XG8 Very different feel?
  167. JR Xg11 mode 1 (swap)
  168. Spektrum servo connectors
  169. Transmitter timers/resets
  170. Need help please
  171. JR XG11 telemetry with RPM Tach Gas engine
  172. DX7s channel assignments & roller
  173. JR XG11 with the Assan XD8 TX module
  174. Setup Problem With JR G370A Gyro
  175. AR7600
  176. JR X9303 Screen Blank
  177. 388S TX Lithium Battery gone flat
  178. Spectrum Binding question.
  179. DX8 Mode 1
  180. New DX6i elevon program backwards?
  181. Spectrum DX6i trim setting questions
  182. STI /Spektrum telemetry for iPad MINI?!?
  183. JR Servo Gears
  184. Spektrum Telemetry Extension
  185. Modding DX5E Transmitter
  186. NEED HELP!
  187. DX18 Telemtry
  188. Use flaps as ailerons in the air with XG11??
  189. JR & HiTec Servos
  190. jr radio
  191. JR Receiver Choice
  192. Tm1000 with hobbywing rpm sensor
  193. Spektrum AR400 rx antenna position
  194. Flap Servo Humming/Chattering
  195. PCM 9X II compatibility
  196. PCM-9 Questions
  197. JR XG11 radio
  198. DX8 Throttle reverse and timer issue
  199. Need Help with iPhly iPhone Software
  200. DX4e Binding issue.
  201. DX7
  202. DSMX update for my XP9303 ???
  203. Sprktrum 9546 remote receiver
  204. Specktrum remote dx2 old, mod to add more models??
  205. XG8 Aileron / Elevator
  206. Can I use a JR romote extension instead of Spektrum?
  207. JR X347 question
  208. Using a orangerx Satellite in a spektrum receiver
  209. 9303 Screen Problem.
  210. JR matchbox jumper: where can I get one or make one?
  211. DSMJ module in 9XII possible?
  212. Smoke System Programming Question
  213. 2.4 conversion & unstable voltage indicator
  214. JR 9303 Programming Help Please ....
  215. Jr max44 manual
  216. having failsafe problems
  217. DX7s mixing for Icon A5
  218. DX 18 QQ
  219. DX 18 QQ
  220. Problem programing JR 652
  221. TM1000 can it be plugged in the 9th channel with DX8
  222. JR 10 X AIR
  223. JR DMSS Module
  224. DX8 setting
  225. Spektrum AR9210 Voltage Regulation
  226. Spektrum DSMR Technology for the DX4S
  227. JR XG8 Transmitter
  228. Spektrum A6020 servos are humming at idle.
  229. Can I use digital and analog servos on same Rx?
  230. Heat shrink tubing on satellite antennas
  231. DX7 using Mix switch to operate Gear Channel
  232. 9505 Duel Ele
  233. JR 11X2.4 Version 2 Update
  234. 10SX II Helicopter Instruction Manual
  235. JR 9303 2.4 DEAD
  236. XG11 software update
  237. 12x rudder centering issue
  238. New to 2.4GHz
  239. JR XG8 Update failure
  240. Power consumption on AR12100 while switch off
  241. Problem with telemetry when using Spektrum GPS?
  242. JR X9053 DSM2 - Mod help needed please
  243. RCV CD RPM telemetry
  244. JR XG 8 software update question
  245. Binding the R921 Thru EMS Battery Backer
  246. JR R921 RX Bind
  247. Rate control mix support
  248. DMSS and DMSX
  249. Add Reflex in Acro
  250. DX18QQ question.
