PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38
  1. Ganged retracts/gyro????
  2. JR PCM 9 Single Stick question
  3. 10 touch screen goes blank
  4. 8103 and heli gyro
  5. pcm 10Z proper revo setup
  6. 10X Availability
  7. 8103 Flaperon
  8. JR 10X and PCM
  9. 10x mode change
  10. JR XP783 Manual
  11. Pc software for JR-TX`s.
  12. Datasafe info transfer from 10X to 10SX?
  13. JR transmitter problems
  14. flaparons wrong
  15. how to convert x-3810 mode 1 to mode 2
  16. JR PCM9x & Flight Modes
  17. ES 539 servos for 72" Katana?
  18. 10x charging problem
  19. Changing Crystals
  20. Jr 8103 and 649 set up questions
  21. jr pcm 10s
  22. dual elevator servos with 662
  23. jr buddy box
  24. Advice on problem [FOUND REASON, BUT LEFT WITH NEW QUESTION]
  25. 8103 Switches
  26. 327x Receivers
  27. G500A
  28. JR - 8103 Low Voltage Beep - what voltage?
  29. JR 662 setting up ........
  30. JR 9 Channel - Nobody has asked today
  31. Dual servos
  32. Jr 4000 Servos
  33. Ner 327 X
  34. PCM RX Crystal
  35. Excess Antenna Wire
  36. JR 662 2 Aileron servos?
  37. digital servo jitters
  38. XF631 TX problem
  39. 388 Transmitter
  40. Graupner C141 (really a JR I believe)
  41. DS811's and 6 Volts
  42. XP783 PITCH REVERSAL
  43. Manual for JR-PCM9X ?
  44. 10X simple instruction for basic set up
  45. servo travel unequal...?
  46. 4735 regear to 4721
  47. Jr 347
  48. Jr pcm10x
  49. JR XS3 27 MHz (12 Cahnnels?????)
  50. New JR 9 channel transmitter
  51. 6102 battery care
  52. 8103 Instruction book
  53. Li Batt replacement rate.
  54. 8103 Spoilerons? Flapperons?
  55. 8103 programming
  56. JR DS 8311 servos
  57. Modules & Crystals ??
  58. Danny, question about Expert servicing ...
  59. Wire sizes on JR products
  60. XP6102 setup for Venture heli
  61. XS3 TX Battery Hydrimax
  62. Considering 6102
  63. whats the difference between 10x and 10s
  64. JR XF 631
  65. JR 8103 & U CAN DO 3D Question:
  66. R945S Rec.
  67. ppm-FM vs PCM
  68. NES 4021 specs?
  69. 1100 mah tx battery
  70. Century VII Module
  71. 8103
  72. JR 8103 questions
  73. Redundant battery?
  74. Discontinued JR Manuals!!
  75. JR XP642 Manual
  76. CENTURY VII Manual
  77. backward flaps 662
  78. JR Servo Installation Questions?
  79. 9411 Nylon Gear Availability
  80. JR NER -326 Receiver
  81. DS 811 gear change ?
  82. Higher frequencies better...?
  83. JR decals
  84. Plugging dual receivers together?
  85. JR 9X Radio
  86. Jr X-378 programing for Heli Help!
  87. Century VII manual
  88. jr 3810 modulation selection
  89. jr radios
  90. JR slimline dual conversion??
  91. Battery Voltage Drop
  92. JR radio service
  93. Triple Rates on Radios
  94. Possible JR 241 Problem
  95. 5-cells degrading receivers?
  96. Century VII
  97. XP6102 Manual
  98. Constructive criticism... XP8103
  99. Power output of JR radios
  100. Dropped my JR 662
  101. JR PROPO XS3 VS. JR RACING XS3
  102. Data storage for 10x
  103. 388S flap mix question
  104. XP6102 with AeroFly Pro
  105. Replacement manual ?
  106. Matchbox Instructions
  107. Smoke and Choke ?
  108. 6102 Mix 1,2,3, vs Mix 4
  109. 6102 Flight Timer
  110. Dual Throttle matching
  111. JR PCM 10
  112. US 9X version features and launching date
  113. US 9X version features and launching date
  114. TRIMS OFFSET on 8103
  115. How many channels?
  116. 549 Rx & digital Servos?
  117. JR 10X
  118. 3 servo 90Deg CCPM on 8103
  119. XS3 40mhz
  120. 8103 Question
  121. JR 388S elevon travel adjustment
  122. PRICING INFO ON 9X?
  123. xp 662 flaperons problem
  124. gearset for ds281 servos
  125. JR Datasafe 2
  126. X-347 Elevator Mixing
  127. JR Century VII
  128. Recommended electronics for 1.6 Extra 300
  129. replacement gears for ds281
  130. JR 8611s coreless?
  131. 27 to75?
  132. Dual elevator servo's on a 347
  133. How do I program a throttle curve on a 8103?
  134. x378 dual rate switch asignment
  135. Blue Dot/Green Dot
  136. Jr 378 Flap Deployment Programming ?
  137. Servos for CA 27% Extra
  138. 8103 and CCPM
  139. Bipe Wiring
  140. JR Receiver that works with Sanwa RD6000
  141. The new JR PCM 9X
  142. Pilot Link and the XP8103
  143. JR 662
  144. 783 throttle to throttle mix
  145. 783 using channel 8
  146. XS3 drag brake setup
  147. JR Pcm 9x
  148. 8103 Danny what did I do
  149. VG 6000 Computerized transmitter
  150. XP783
  151. 8103 throttle
  152. XP662 F-E Mix
  153. Century VII Questio
  154. JR X378 & GY401 setup
  155. Is there really no XP783 manual for download?
  156. G500T neutral adjustment
  157. which JR reciever is closest in size to the hitec 555
  158. JR 6102??
  159. X-378 Cancel setting?
  160. JR Crystals
  161. Chaging 75 Mhz to 72
  162. JR 10x Throttle
  163. My JR Digital servos are acting crazy!
  164. Receivers
  165. two recievers
  166. XS3 Frecuencies
  167. JR NEB 480 model Radio Beacon
  168. 662 & Ultra stick .40
  169. 9x memory ability?
  170. Single Stick-life after death?
  171. Older Jr Heli Radio's
  172. WHAT BATTERIES WITH iSOLATOR ?
  173. Danny, DS8455 = DS8417?
  174. 8103
  175. 527 or 537? What is the difference?
  176. x388 tx problem
  177. Compatibility Question
  178. Just a quick thanks
  179. Where is the link for the 8103 and us 40?
  180. JR MODULES HELP
  181. Another DCS Question
  182. Is JR 9x balanced?
  183. DSC lead problem
  184. 8103 PCM
  185. Another Flap Question
  186. jr 652 question?
  187. Danny, 8101's on 6.0 V?
  188. ner-327x
  189. JR 649 receiver
  190. JR XF622 MANUAL
  191. Dual Throttle control.
  192. Thanks Horizon Hobbies
  193. JR X378 Heli Question . . .
  194. Seperate control for three engines
  195. JR falling behind Futuba...
  196. Drilling a hole in the switch
  197. What am I doing wrong w/Exponential 783, 388s
  198. 8103 4 aileron servos in 33% edge
  199. JR 783
  200. 8103
  201. JR y harness w/amplifier
  202. Yet another 8103 Program Dilemma
  203. servo jitters ?????
  204. JR XR2 steering linearity issue
  205. x 378 programing
  206. Xs3 and RS300 problems.
  207. JR X-347 Transmitter Modules
  208. HP8103 with Hitec Micro 555 receiver and Flaperons
  209. What is the diode in the charge circuit on my 8103 for?
  210. 10x mix for a ca2.6
  211. 10x origin mixing... at a total loss here
  212. 6102 Questions
  213. 6103 switch assignment
  214. Jr plane gyros
  215. Since changing to JR XP 662......
  216. 8101 servo question
  217. 8103 question
  218. JR F400EX
  219. Throttle cut.
  220. JR PCM RECIVER AND HITEC SERVOS
  221. 10x battery shorted help please
  222. 8411 vs 8611 digital servos
  223. 10x hely programming to plane
  224. 8411 arms fit on the 8611?
  225. JR PCM9X manual
  226. How Do I Program Reverse Differential On JR 8103
  227. XF631 Ailerons set up
  228. NER-549X receiver
  229. XP6102 6 Channel FM Radio (Airplane)
  230. Module question
  231. 4735
  232. Old JR Century VII Transmitter
  233. JR X-2610
  234. Throttle cut question for xp662
  235. JR XP642
  236. Jr 9x
  237. Mixing question, please help JR X-378
  238. JR compatibility
  239. 6 volt's battery packs???
  240. dual elevator servos(ds811's) on 8103
  241. Transmitter specifications
  242. PCM10SXII
  243. G2 interface cord used as a trainer cord?
  244. 9X in US?
  245. Flying both airplanes and helis with a 10x?
  246. Using ailerons and Flaps with no y Connector
  247. Manual for JR 783
  248. Expert servo specs
  249. Transmitter modules
  250. glittch
