PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38
  1. DataSafe Plus - $300?! Thanks but no thanks ...
  2. Data Safe
  3. EXPO Question
  4. DSC cable
  5. 6102 question, Diode? Timer? Danny
  6. jr max band
  7. DS3421sa
  8. JR 507 servos?
  9. POWER ISOLATION
  10. 631 Elevator Trim Problem
  11. How to alter trimming - JR Max 66 radio
  12. regulator?
  13. 6102 buddy compatable with a 8103?
  14. 8103 question
  15. Manual request ignored?
  16. jr xr3i
  17. jr max 6 band
  18. Whatever happened to Channel 14 (72.070)?
  19. 72 MHz Channel Distribution
  20. XF622 ner-226x
  21. x-347 dual servo elevators
  22. 8103 rudder to AUX2 mix
  23. Problems with new 770PCM receiver.
  24. Digital = to JR341 ?
  25. 550T Gyro Problems
  26. NER-627X
  27. Will an Airtronics Rx work with my 662?
  28. JR 8103 how to quick charge?
  29. XS3 w/ Ni-Mh?
  30. JR 8103 and the JR950 spcm receiver
  31. 8103 DUAL ELEVATOR AUX POT
  32. glitches 8103/r700
  33. Still Confused about HAM
  34. x378 spoileron mix
  35. 10X Battery Case
  36. New 6102 Question!
  37. JR 8411 vs. 8401
  38. 8103 flattening battery
  39. Compatibility of JR 6102PCM Heli with a FUTABA GY401/S9253?
  40. JR XP642
  41. 10 x
  42. JR 347, service questions
  43. 8103- cold weather causes glitches?
  44. 331,341, or 368??
  45. 8611 quality
  46. Muti-Point Mixes, trying to understand
  47. JR XP662 Fuse
  48. JR-241
  49. jr backup battery
  50. 6102 diode protection
  51. 8103 mix question
  52. Converting F400ex from air to ground service
  53. pcm9x trims
  54. 10x battery charge/discharge question.
  55. 8103 to 837 Buddy Cord
  56. aileron setup
  57. 6102 Question???
  58. 783 mixing for pitch control
  59. 8103 mix question
  60. JR TX Batt Connector issues!
  61. JR PCM9X Sailplane mode question
  62. Dual aileron JR X378?
  63. JR8103 TO JR421FOR BUDDY BOX???
  64. JR MAX COMPUTER
  65. Stiffer Springs for 10X Transmitter
  66. BROKEN ANTENNA WIRE
  67. XP662 error 5 question
  68. 955PCM vs 770PCM
  69. matchbox wiring
  70. Switch repair
  71. Futaba 9CAP with JR equipment?
  72. 8103 how to use different channels?
  73. JR g410t gyro problem
  74. New 50Mhz don't work
  75. 50Mhz Ham Band
  76. 8103 mixing for two functions: ailerons and retracts
  77. dual aileron w/7ch quattro tx and 7ch rx?
  78. JR X-378 "Automatic Dual Rate" option
  79. Servo seals... where to get?
  80. Jr PCM 9x
  81. Choosing between 9Z & 10X
  82. XP 662 problem
  83. JR PROPO Century VII Need a Manual
  84. PCM 9x Device Select
  85. JR servo specs
  86. Urgent Info needed about my JR XP662 Radio
  87. Snap Spoilerons
  88. XF 631 Programming and Crystal Question
  89. JR Digital servos
  90. Ds 368 problems
  91. xp783 user manual
  92. PCM 10 Question
  93. JR 652
  94. 10X question
  95. Dual elevator servo question
  96. Servo Case Replacement
  97. 4721 Servo gear set
  98. Rx antenna blanking
  99. How to set up Dual Elevator servos with a 700 Rx and 10x.?
  100. 8611 Gear slop
  101. Rf interference question
  102. XP662 again!
  103. Age of my 8103
  104. JR ds168 wing servo
  105. where do I send JR servos for service?
  106. 10sx to 10x buddy box setup
  107. 8231 voltage
  108. JR Transmiter Module
  109. 8411 voltage
  110. 8611 Servos?
  111. Servo Info
  112. TO BUY NOW OR LATER
  113. What comes with JR PCM 9x ?
  114. Radio Won't Charge
  115. LCD Display problem
  116. Outstanding Customer service at Horizon
  117. lithium battry in JR XR2
  118. JR/Horizon Great Service
  119. 8103 battery or transmitter problem?
  120. 10sxII Question
  121. Best reciever to use with the JR DS811 Servos
  122. Radio suggestion
  123. JR 1100 MA charging problem
  124. 10x transmitter module
  125. 9411 Gears
  126. 8411 conversion to 8311
  127. Converting Mode1-Mode 2
  128. Important stuff low on menu priority!
  129. Reversing an 8411
  130. Another repair form request...
  131. JR Repair form
  132. JR 549 receivers and 811 digital servos.
  133. Old JR AM Transmitter
  134. xp6102
  135. Cycling batteries on X378
  136. Danny - 8611 question
  137. 652 / spoilerons
  138. Transmitter Battery
  139. rf module for x347
  140. DS8611 Availability
  141. JR DS8231 Servo mod
  142. JR Datasafe file needed, PLEASE HELP
  143. Another manual request
  144. servo arms
  145. 8411 gear train "feel"
  146. Is the 10X going to be discontinued?
  147. Manual Needed For
  148. Trim offset in JR10X
  149. servo/ reciever question
  150. Synthesized Tx module?
  151. How old is the 10x ??
  152. new PCM9X - throttle cut problem
  153. x-378 Programming question
  154. Century VII radio
  155. Manual needed
  156. XF421EX Trainer box
  157. It goes stiff in cold weather....
  158. XP6102 Modulation
  159. How to mix out aileron roll on knife edge?
  160. Ultra Stick 60 & JR 8103
  161. JR 10X transmitter as slave for training - can't reverse servos
  162. JR X-347
  163. n/m
  164. Throttle Servo Opening by itself
  165. PCM10Sx
  166. snap spoilerons with jr 10sx (heli)
  167. How to reverse the direction of the landing switch on 8103?
  168. JR Tx charging ?
  169. SPCM & ZPCM with JR 8611 Servos
  170. 378 questions?
  171. 9411SA Servos
  172. jr r-1 programing
  173. 8103 FM Transmitter Module
  174. Can the R910 reciever handle large loads
  175. Battery Upgrade for X 378 ?
  176. Cold weather storage
  177. what receiver?
  178. CAN I USE ANY JR RECEIVER?
  179. Expo??
  180. where can i buy jr servo ends??
  181. overpowering 649RX
  182. Mode 1 & 2 Tx diagrams/channels
  183. New XP6102 radio - nice!
  184. xr2
  185. $49. Sport Digital JR
  186. G450 Gyro
  187. XS3 with Hitec receiver?
  188. xp783 voltage problem
  189. JR421ex trainer box
  190. Servo drift
  191. 8411sa Upgrade Question
  192. Using 6V with my 511 & 517 servos
  193. jrxp642
  194. Frequency change, TX
  195. 10x programming w/ dp four wing servo ultimate
  196. Up grading from 2721 to 8611
  197. JR 703 Retract servos
  198. JR XF631
  199. jr xp642 setup
  200. Antenna
  201. JR 8103 Mode 1 (JR 3801) Manual
  202. Servo life ?
  203. 10X to 8103
  204. Matchbox and alternate battery
  205. NER-549X Updates?
  206. JR Standard servo for Throttle-4 stroke
  207. 9X PCM?
  208. jr crystals???
  209. Dual elevators wih JR 662
  210. 10x and ppm pcm question
  211. 8103 & 649PCM Rx problems
  212. Correct Fuse For XP642
  213. 10X duel rates
  214. service question
  215. Training on the XF421EX
  216. XP8103 and basic setup
  217. XP 662 for Heli & Aircraft
  218. Cycling the JR 8103 transmitter pack??
  219. 770 PCM Rx ?
  220. servo tray
  221. 2700G
  222. Changing XP8103 from 72Mhz to 50Mhz?
  223. Cracks in 631 case. Covered under warranty Danny?
  224. TX.
  225. Two aileron Servos
  226. 8103 - I need flaps AND throttle ?
  227. ABC & W
  228. JR 10X transmitter battery
  229. X388S Mode 3 using mixing
  230. Is it safe to use 6 volts with 8101's?
  231. 2-6volt batterys into 1-RX
  232. 8103 Spiolers
  233. 10X servicing and maintenance
  234. Subtrim programming question
  235. XP662 Query
  236. Updage JR 631 to 9C or wait for 9X?
  237. 3810 and buddy box
  238. 10x batt with 9x
  239. 8411 availability
  240. Wow Danny, you're good aren't you!
  241. JR Quattro, servo went nuts yesterday
  242. 2 questions regarding the Matchbox
  243. Danny another question
  244. servo jitters
  245. 10x mode change
  246. Dual Conversion RX?
  247. Is the XP8103 promo still on?
  248. is the jitter problem with 8103 solved or get a 378 tx
  249. JR retract servos(NES 703)
  250. Radio output
