PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38
  1. X-378 throttle hold switch
  2. Recalled 8411s sold as new 8311s
  3. 8411 problem
  4. Danny need a lil' help(10X)
  5. elovater doing this
  6. 8103 Throttel trim inactive
  7. JR J8C-4SH Radio System-Can it be updated?
  8. Jeti receiver with JR radio
  9. JR X347 backup error
  10. Manuals
  11. Safe charge?
  12. JR 9X
  13. making a simple receiver
  14. 10X-Lithium-ACC.
  15. 10x channel swapping / reassigning
  16. JR XP781 no power/dead
  17. RF Filters
  18. 8103 Differential
  19. Flaperons
  20. JR XS3 servo Z590M Centers and Freezes
  21. Using DataSafe (1)
  22. JR DS8611 vs JR DS8511
  23. 8103 No Power/Dead
  24. 10X Heli 4 Servo Set-up
  25. jr 8103 radio
  26. Dual elevator servo mixing, Prog mix 5,6???
  27. Range problem with PCM9X
  28. 50Mhz to 72Mhz
  29. jr frequency modules
  30. Radio specs
  31. safe to fly on a RX that was in a crash?
  32. JR 10X / Crystal ?
  33. 8611
  34. Base Loaded Whip on 50 MHz
  35. NES-507 and NER-266x
  36. XP652 Tx Ch5 modification
  37. 8401s
  38. 8103/Ultrastick quad flaps...
  39. OFNA Micro Fail Safe with JR RS300 receiver
  40. CCPM MIXING VALUE SETUP?
  41. Danny, what's up with my 8103 display screen
  42. Range check problems
  43. Stick centering force
  44. Channel change - was this to much?
  45. Best servo for 1/8 Off Road buggy
  46. Century VII FM
  47. Mode change problems
  48. Where'd my throttle trim go??
  49. reverse battery
  50. 10X set-up Question for Danny
  51. 327x rx
  52. 33% set-up questions
  53. 8411
  54. JR PCM 10x charging/cycling problem
  55. JR-811's digital's wont stop chattering
  56. Danny got a question
  57. JR receiver NER 627X series G
  58. JR Buddy Box Help
  59. JR 10X tx battery fuse
  60. PPM control system info needed
  61. 8311's
  62. 460t with 537 servo
  63. How to use flap with two aileron on 10x?
  64. 8103 Tx module tuning
  65. Throttle Channel expander
  66. 9X with futaba
  67. Servo arms
  68. JR crystal dots...
  69. JR 10x...Bobcat...Brakes
  70. Servos C4421,C4021 etc.
  71. New XS3 System - Worse than Traxxas OEM?
  72. XS3 - problems?
  73. 8611 servo
  74. Rx Xtal Interchangeability
  75. Flight packs
  76. P-MIX
  77. Jr 10SXII touch screen
  78. 8103 dual rudder
  79. Need help with servo buzzing
  80. Receiver replacement for X 3810
  81. JR XP662 programming
  82. Gear Lash & Criteria For Replacement
  83. Dual Elevator mix on 10s
  84. 8411 servo, Blue dot
  85. 622 reverse battery polarity
  86. jr 421 ex for heli
  87. Radio Failure After a Crash
  88. 9X Throttle cut
  89. 8103 and the Co-Pilot
  90. Channel change
  91. BLUSH
  92. JR 955 Rx & 35% Extra
  93. flapperons
  94. JR XF631
  95. JR servo speed/torque info
  96. JR10x Heli Radio question before I buy
  97. Need JR PCM9X manual
  98. 8103 snap-spoilerons
  99. losing memory if remove battery
  100. DataSafe and Windows XP
  101. Need to disable my gear switch on a 8103
  102. JR servo #NES 3321 & NES 8101???
  103. sending transmitters for repair
  104. Tx will not charge
  105. Minimum Distance for Receiver
  106. Aerial length?
  107. 8103 mix problem
  108. JR pcm 10X question
  109. 10X battery
  110. 9411 gearset
  111. JR10X Programing
  112. Graupner/JR interchange
  113. 8103 Swash mix...Little explanation Danny?
  114. 4 servo ccpm for 10x
  115. Programming Digital Servos
  116. Can I fast charge a new 8103 Xmitter
  117. Misreading battery indicator problem
  118. Horzion's address
  119. JR X378 and gyro sensitivity setup
  120. XP8103 TX Module
  121. R940S Crystal
  122. JR378 - setting mixes 1-3
  123. 8103 Crow problem
  124. what jr wire colors are " + - s"
  125. I can't charge my new x378 radio
  126. Where to send my dead controller?
  127. Which came first?
  128. 8411 ???
  129. JRPSG8101 Gear Availabiliity???
  130. Single Stick
  131. 9411 sa
  132. JR servos
  133. JR PCM9x and other recievers
  134. my 8417 needs pot replacing
  135. TX Connectors for XP 783
  136. Flight Mode Question?
  137. Who managed to connect JR and PC?
  138. JR 4131's
  139. Great Planes Pitts 4 Aileron Servo Set-Up for 8103
  140. 8411/8411SA/8311 or new 8611
  141. 10X charging
  142. 8103 Module gone bad?
  143. 8103 dual rates act like they have offset
  144. 662 DR and Expo question
  145. RX VIBRATION
  146. Radio choice.
  147. XP783
  148. jr radio 652 discontinued????
  149. DS8411 Help !
  150. NER-910XZ
  151. 8411 v 8425
  152. Converting to 50Mhz
  153. G'day all
  154. NEW Steering Servo?
  155. 8103 tx module crys. change
  156. JR3810 Conversion?
  157. XR2 setup
  158. JR 8311 SERVO VS 8411
  159. Max 66
  160. 10 yr old JR 388s
  161. Old JR Rx & Servo Info needed
  162. 9411SA Serovs
  163. jr 622 & quad flaps
  164. 236 receiver mystery continues
  165. XP 783/x347 RADIO
  166. 8103 Battery Plug
  167. Graupner MC 22
  168. Trim offset memory function
  169. JR 10SX HELP!!!
  170. Manual for NETJ125V
  171. X-378
  172. JR Net J125V
  173. 347 batt?
  174. Danny receiver question
  175. Another reverse charge question
  176. Base-loaded antenna on 10X
  177. RX Crystal question
  178. XP783 90deg CCPM
  179. 10X models
  180. XF631 and Flaperons
  181. new xs3 conversion?:?:?
  182. mixing two rudder servos on 662
  183. dsc on X-378
  184. 8103
  185. DS3301
  186. JR X378 AND ULTRA STICK
  187. Danny...HELP...(Part 2)
  188. Danny....Help
  189. Out of the office
  190. JR 10X Flexibility
  191. Manual Nej-3000
  192. Manual for JR x-347
  193. Question about XF622
  194. 8103 Fuse?
  195. Jr Pcm 10s Screen Blackout
  196. Does jr Python use different crystal that other jr radios?
  197. TX Module temperature
  198. aileron to flap coupling
  199. 550T gyro question
  200. snap spoilers
  201. 8103 flaperon question
  202. JR 8103 Polarity Mix-up
  203. JR 8103 4 Servo Aileron Set-up on the GP Pitts
  204. JR XP642/XP652 controlled by PC
  205. Convert US 72 to Australian 36 Mhz
  206. Jr 510 servo
  207. Programming levers (switches) faulty
  208. Electronic switch has regulator?
  209. New 8301
  210. Danny ... service status please.
  211. x378, 8103 or 9x. Which one for me?
  212. 8103 with "L" on screen
  213. JR Max 6 Tx's - Help!
  214. Manual for XR-6FM race
  215. Flaperon & servo travel
  216. 378 Heli vs. 378 air ???
  217. JR and Airtronics Crystal Interchange?
  218. gear kit for servo
  219. Flaperon with PCM 10 X
  220. Two Position Flaps on 8103
  221. Servo jitters
  222. radio manual
  223. jr 347
  224. Servo Shutdown
  225. Voltage regulator
  226. 8103 setup problems with flaps/gear
  227. Jr 8103 Ppm Spcm Zpcm
  228. JR3810/R770S failed range test
  229. Mixing
  230. Throttle curve on a 8103 non DT?
  231. Need 75 Mhz TX Module for JR 8103 - Help
  232. JR 642 radio. Need some info please
  233. Jr 10 Sxii Software Updates
  234. 6 volts with JR
  235. mixing problem on JR X-3810
  236. JR 2700G Servo
  237. 6v servo
  238. Servo noise
  239. Out of the office
  240. Jr Max 6 Fm help please
  241. JR NER 627x PCM RX
  242. JR XR2 Problem
  243. 6V Operation
  244. 8103 vs 662 xtals
  245. JR PCM 10X DataSafe
  246. DS 368 Servos
  247. Throttle trim on 652
  248. 75MHZ problem
  249. shift compatibility dilemma
  250. 10x expo and flight modes
