PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38
  1. Did I kill my 652JR
  2. Battery Location
  3. jr600 rcvr problem?
  4. Unwanted Channel Swap?!?
  5. Century VII FM system
  6. Aileron/Flaperon on XP662
  7. 631 Radio
  8. JR XF 631 Trans?
  9. radio sending no signal out
  10. Servo extension lead lengths & Filters?
  11. JR XP662 throttle problem
  12. JR 4721 jittering with 6v, but not 4.8?
  13. 8103 Trainer switch
  14. Is there a reason why Futaba has bigger filters than JR?
  15. JR MAX 4 question
  16. 10X heli question
  17. Buddy box question 8103 and 642
  18. Danny - question PCM +/- dual conversion
  19. I need help please
  20. Thanks Danny!
  21. 120 radio VS 140CCPM Swashplate
  22. JR MAX 4 need help
  23. Flap/Elevator mix possible with JR XF631?
  24. XF 631 Manual
  25. 1 more question with 8103
  26. Danny - Digital Throttle Servo
  27. JR 410T Gyro Question
  28. Buddy Boxing mode1-mode2 ?
  29. Why no flex-equip with JR 10X and DS168/DS281 servos?
  30. Jr 8411 Sa
  31. 10X to 10X buddy box setup question
  32. help with x378 and telebee setup
  33. JR NER 226X Rcvr
  34. Danny - JR R770S PCM receiver & 10X Compatibility.
  35. new radio
  36. Throttle Trim Problem on XP662
  37. Danny - Mode 1 or Mode 2 question
  38. Just purchased an 8103 W/digital trims
  39. JR radios and Ham frequencies
  40. Servo Jitter
  41. 10X warning?
  42. JR PCM10 Owners Manual
  43. JR X347 heli problem
  44. Changing Rx Freq, 72 to 36Mhz
  45. Change from ch50 to ch31, now its reversed
  46. JRPA043 Color Gimbal Sticks
  47. MatchBox programming problem
  48. 513 Servo current drain question
  49. JR 331 servo and 6V
  50. 10X? Airplane and Heli owner
  51. Dual Elevators and Flaps on a 8103, YIKES!!!
  52. JR Receiver wiring polarity
  53. JR Y Harness
  54. Using Buddy Cord Mode 1 - Mode 2
  55. 10X battery pack
  56. change switch to proportional?
  57. JR XF421EX programming mode
  58. X378 and GY401
  59. Flaperons on the XF631
  60. Great Service
  61. 8103 Lithium Battery
  62. Best way to connect two batteries
  63. match box question
  64. 10x dsc problem
  65. JR XF631 Repair
  66. Jr X-347
  67. JR NES-L4001 in 60-Size Heli Going Bad?
  68. 8103 repair / check question
  69. XF622 Manual
  70. Replacing antenna when changing TX modules
  71. XP662 trims
  72. compatability
  73. receiver crystals
  74. JR 900 Piezo Gyro
  75. jr/graupner mc 20
  76. x-347 losing settings
  77. how to properly clean my jr8103
  78. 8103 Switch selections
  79. 8103 analog trim
  80. Is storage harmful?
  81. Danny, Circus hobbies / JR transmitter
  82. 75MHz module for 8103/10X?
  83. 8411 servo horn hold down screw size?
  84. JR XR3i
  85. 8103 screen going berserk
  86. MatchBox with non-digital servos?
  87. Danny please help, have major interference problem at our field
  88. 8103 DT problem
  89. 8103 screen Vs. 10X screen
  90. Danny Rx question ?
  91. warranty
  92. 783 flaps/spoilers
  93. Programming the JR XP652
  94. 8103 bolws fuses- help
  95. JR x347 cpm Rx Availability
  96. JR-R1 radio repair
  97. Dual Receivers/Dual Antenas
  98. 8103 data format and communication protocol
  99. Ultra Stick 60 & JR X-388S
  100. 9411 Servo
  101. 10X Power on without RF shooting
  102. XP652, ner-226x, and Flaperons
  103. 8103 Flap movement
  104. Channel assignments
  105. Moving models between 8103s
  106. JR8103 - Stiffer stick springs available?
  107. jr r700 reciever with 6v battery pack?
  108. Servo choice on H9 T-Craft
  109. Century VII Radio System
  110. delete
  111. 8103 and two elevator survos
  112. JR8103 missing program
  113. XP652 throttle trim wont work
  114. R700 vs R549
  115. Circus Hobbies Rx.....?
  116. Crystals
  117. Can I get "swap" my 75Mhz for a 27?
  118. CCPM and 783?
  119. PCM 9x and Dual Receivers HELP!!!
  120. timer in my JR XP662 ?
  121. JR 8425 servos?
  122. 8103
  123. 10X throttle ratchet
  124. 347 and turbine
  125. 10x program issue
  126. JR Digitals?
  127. Fried 421es
  128. JR Servos, Futaba Gyros
  129. Grease
  130. XP8103 - Out of Stock
  131. 4721 To 2721 Conversion Set [JRPS2721C]
  132. JR crystal
  133. Century VII PCM TX
  134. Mixing smoke pump to throttle ?
  135. XP 783 Question
  136. R600 rec.
  137. XP 783 Battery level wrong
  138. XP 783 Problem
  139. 10s Trim Switches
  140. Jr Trainer Cable/code
  141. 3810 Switches
  142. R600 Reciever-can it take a 6v reciever pack
  143. need help with ds 8417
  144. Question about JR XF622
  145. Band Change
  146. Out of the office
  147. Life of an 8411 gear on a 33% EXTRA?
  148. Single COnversion RX
  149. 8103 Flaps (again!)
  150. 9x?
  151. Jr 388 Manual
  152. Graupner mc-24/22
  153. Another 537 servo question
  154. Service!
  155. XP652 and PCMs 649
  156. 10x battery question!!
  157. 642 gimbals disintegrating?
  158. ds281
  159. 53 mhz
  160. Gyro Problem - JR 450
  161. 8103: gear and tow release programming
  162. Jr Simulator Cable
  163. 8103, showtime smoke pump programming
  164. Delta wing function....what gives?
  165. 537 ball bearing
  166. Receiver help
  167. Amplified "Y" Harness
  168. Jr 8103a
  169. Adjacent channel & R700
  170. 662 stick spring tension
  171. Old JR servos
  172. Antenna help
  173. 8103 FM or PCM
  174. 8103 Trans Screen
  175. JR537 Servo Acting Really Goofy!!!
  176. Antenna length
  177. XP 783 Question
  178. Can JR Max 6 Computer do elevon mixing?
  179. question for Danny
  180. Fixing a fried XF422
  181. JR 422 compared to JR622 ??
  182. 9x
  183. radio in for service
  184. US version of new 9X - reason?
  185. Data transfer question
  186. Eclipe 7 & JR channel xpander
  187. JR Team Member FM
  188. Simple question. 378 vs 8103
  189. Mode1/Mode2
  190. R610M Question
  191. JR Max 6 Charging Problem
  192. 347
  193. Yikes!! Broke my JR XP783......where to send for repair?
  194. JR Servo P/N NES-4021 tech specs
  195. JR 8103 exponential Graph
  196. Hitec / .JR compatable???
  197. 10sxII
  198. Can I use a 6v pack on a R700 Rx?
  199. Range Check
  200. Single-switch for 3D Rates on 8103
  201. 4031 servos
  202. Converting 53Mhz to 50Mhz?
  203. XF631 and throttle response?
  204. X-378 Manual
  205. Dim Screen
  206. remove please
  207. Jr Max
  208. Cannot find servo case for JR - ds8411 servo
  209. ner-326x receiver
  210. Twin throttles on XP8103
  211. JR 10x Vs. 10sx
  212. JR 8511 servo
  213. How about another type of DataSafe?
  214. Mixing question for JR 642 radio
  215. jr 10sx Heli -> 1-sx Air
  216. JR Receivers and 6 Volts
  217. How do I program dual elevator servo's on the 8103
  218. xp642
  219. New RX?
  220. 8103 programming guide???
  221. Jr Propo Max6
  222. JR-R1 PCM Radio
  223. G410T Problems?
  224. JR 642 controller plastic cracking
  225. jr 8103 with realflight G2
  226. SX-3 Compatibility with other recievers?
  227. Jr3180
  228. HELP!! MY JR8103 is falling apart!
  229. error message
  230. Tooning
  231. aileron Differential on JR X378
  232. JR RX XTAL Markings
  233. new gimbals
  234. Snap Roll Button for kill switch
  235. Tech question
  236. Jr 388s
  237. HELP JR 7000 servo gears !!!
  238. Help!User man. needed 4 XP642
  239. jr f400ex and r600
  240. JR 8411 vs 8425
  241. 3D rates on 8103
  242. PCM 10X transmitter
  243. Co-pilot & X378 & PCM 649S
  244. JR 378 Transmitter with Futaba R138DF Receiver
  245. NEH 531 fluttering
  246. Part number JRPA255 no longer in production?
  247. I've got the "digital servo jitters."
  248. 3 Position Aux2 Switch - 10X
  249. Programming Elevator to Flaps on 8103
  250. 8103 Programming
