PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38
  1. x378 with 5000t gyro doesnt work?!
  2. Radio Programming Book
  3. Setting Exponential Rates
  4. Memory Backup Failure
  5. receiver question
  6. pcm10 progaming
  7. 642 tx
  8. I've finaly gotten my PCM 9X
  9. Just bought the x378 but want to change the buttons
  10. JR Max 4 Channel Net-B124 AM TX & NER 324 RX
  11. V.Poor Manual for 3810 tx
  12. X-378 programming help ?
  13. Did it this way, now
  14. 327x RX parts question
  15. JR Alpina PCM radio
  16. Jumper location for mode change
  17. Tx module
  18. Mixing wing servos
  19. DataSafe 1 Software
  20. Trainer setup with two 8103's
  21. NER-D940S Dual Conversion and 8103 radio
  22. Pcm 10
  23. Throttle Curve Switching?
  24. Jr X-3810
  25. JR radio's and Buddy leads
  26. Will JR Rx take any channel?
  27. Jr-8103
  28. Jr Xs3
  29. Tail Rotor slow
  30. R700 and esc Q
  31. JR 8411 slop fixing
  32. Jr 10x Expo
  33. x378 throttle cut
  34. Tx & Rx compatability
  35. R700 FM Receiver - four servo wing
  36. xs3 burst into flames!!!!!
  37. X378 dual rates
  38. 8103dt Trim memory
  39. JR Circus 326 Receiver
  40. Danny, tell me how to do this.........
  41. Radio (MAX Computer / JR ) Need Help!
  42. JR AM transmitter
  43. JR 4002 servos
  44. Pcm9x
  45. new XP 662--have compatibility ??
  46. 945 or 955 Rx?
  47. DS8411 to 8311 conversion?
  48. List of JR Channel Frequencies
  49. JR TX Battery Question
  50. Jr radio trainer cord
  51. JR 8103 and Futaba GYA350/351 Gyros
  52. JR 832 and JR R1 PCM
  53. Max 4 Tranmitters.
  54. x388s
  55. Pcm9
  56. New 10X, need to have it tuned?
  57. x3810 wont turn on or charge????
  58. Adequate range?
  59. modulation
  60. throttle expo on 8103
  61. 4051 servo
  62. Mech gyro manual
  63. Danny question.
  64. radio fuse
  65. Matchbox - where to buy?
  66. Help
  67. Data Safe 2
  68. Danny or XF662 user simple flaperon mixing question.
  69. JR Super Max 66
  70. 811's
  71. receiver crystals
  72. 8103
  73. Battery pack Wires
  74. aileron rudder coupling
  75. 622- Manual?
  76. S810G Tail servo
  77. JR XS3 problem with receiver.
  78. mix to snap button
  79. Danny Help!!!
  80. JRPA155 - Base Loaded TX Antenna
  81. servo comparison
  82. Programing a pcm10
  83. Dual Elevator Setup Problems
  84. manual for jr pcm9x
  85. Is the 10X 1024 on all channels?
  86. Jr 642
  87. Jr Modules compatibility
  88. trainer button on xp662
  89. HELP 8103 Flap set up???????????
  90. Brake with snap roll button
  91. TX Module Question???
  92. upgrades for 783 radio
  93. JR 781 radio????
  94. JR PCM 9X request for N. American market
  95. Mc12
  96. 8103 Programming Question
  97. Quattro trainer tx."buddy box"
  98. Manuals
  99. need good sailplane radio
  100. Holding Power 8101
  101. 10x update?
  102. JR Receiver with Hitec servos
  103. JR 662 & R700 - Delta Wing/Elevon connections
  104. 3021 coreless specs
  105. 8103 Switch assignment
  106. Old Radios
  107. 9X manual
  108. XP8103 - Mode 1
  109. XF631 Feature List
  110. JR 631 changing crystals
  111. Datasafe 2
  112. Crystal swapping
  113. 8103 mixing
  114. 10x mix switch
  115. 1 1/2 meter discus launch glider
  116. JR 3810/8301 Flap trim question.
  117. JR. 770 PCM receiver
  118. Jr 10sx11
  119. ham band on JR
  120. JR servo specs?? website maybe?
  121. xf631
  122. Receiver tuning
  123. Simple JR radio question for someone or Danny.
  124. Radio Wierdness- is it haunted?
  125. Idiots Corner
  126. JR 10sxII question
  127. 8103
  128. CCPM on 347 what type?
  129. Jr10x QUESTION
  130. XP662 Programming
  131. 4721 servo twitch
  132. XF421ex No Power
  133. Century VII
  134. 8103 master, Quattro trainer
  135. rotary knobs on JR 8103
  136. Need 8103 programming guide
  137. Difference between 8103 AT and DT
  138. Replacement switches?
  139. JR 550T Gyro discontinued in Australia?
  140. 347 mix no trim
  141. MAX 4 problem
  142. Damn! Wrong channel, options?
  143. JR DS281 servos
  144. Danny,
  145. used tx n rx check up
  146. Output torque of ganged servos
  147. Just One More ? Danny!
  148. Crystals, Modules and Confusion
  149. JR NES-371 servos noise
  150. JR 622 reads .0 volts, beeps and flashes BAT after full charge has been completed.
  151. xf622 - ccpm "turned on"
  152. JR PCM Rcvr w/servo ext
  153. One 8411 on rudder. Pull pull or tail mounted?
  154. 8103 Fail Safe acting funny
  155. Jr Pcm 9x?
  156. xp 783 problem
  157. Could my XF 631 have a problem?
  158. Bling Bling club.
  159. Jr Radio Service
  160. How to comprehend all the stuff?????
  161. rates and flight modes
  162. Older 8103 CCPM?
  163. XF631 voltage question
  164. 10X Air for Heli
  165. Large Gimbal Stick Ends
  166. Quattro TX internal switch
  167. subtrim vs. trim offset
  168. jr rf module compatibility
  169. JR R1, question about multiple models
  170. Mem Battery
  171. jr120 gyro??
  172. Ultra Stick Quad Flaps and 8103
  173. dual rates
  174. buddy box
  175. 955 receiver in 33% Radiocraft
  176. Lo Thr-Down Elev Mix
  177. Jr Pcm9 Ss
  178. Jr Radio Charging
  179. 10X battery
  180. Rubber Duck Antenna for JR8103
  181. sailplane issues w/8103
  182. lose antenna --- interference
  183. Intermitting Aux3 servo problem
  184. 10X_Reflex Mix
  185. Contrast pot adjustment PCM10 ??? mistake !!
  186. Crow using throttle position..
  187. Problem with New JR X2i....HELP!!
  188. DS 811 Servo
  189. programming JR 8103
  190. Century 7 Radio Questions
  191. 8103 Programming Flaps help
  192. 8103 dead
  193. Smoked 10x batt...
  194. Jr X-347
  195. R700's have a high and low difference??
  196. 811 Servo - Very high speed vibration/Flutter
  197. Flaperon and normal comfiguration...??
  198. Problem with GWS receiver
  199. flutter
  200. 8103 / US 60 / Crow - Help!!!
  201. 8103
  202. Danny Question ...
  203. JR 8103 programming question
  204. JR PCM 9 Unlimited Series
  205. JR 10X module question
  206. jr 8411 and matchbox question
  207. P-Mix for Dual Elvator servos? JR652
  208. I think I fried my JR642
  209. 10X Switch
  210. May have cracked xTal or bad reciever, PLEASE HELPPP!!!!!!!!!!!!!
  211. 10S Trans.
  212. Circus RX question
  213. JR 10X heli/airplane question
  214. Graupner mx-22
  215. New Jr 9X Tx
  216. JR10 Trx
  217. xp662 Questions
  218. pcm 10
  219. Jr 8103
  220. Servo Arms/Control Horns
  221. Battery charge
  222. JR 9 chanel
  223. xtra switch in the jr quatrro?
  224. Charging 10x batt
  225. old alpina pcm problem
  226. 10x mixing problem
  227. New 8103 stick tension adjustment
  228. 537 chatter
  229. 10SX-II key code
  230. JR 4721 Conversion kit to 2721? Who has them?
  231. New JR Radio
  232. Best way to set up dual rudder servos without a "Y" with a 10x?
  233. gears where to get
  234. JR Datasafe 2 installation problems -- The Solution !!!
  235. Problem with a 10x
  236. xf622
  237. Matchbox for Non Digital servos ?
  238. MiMH Batteries for JR Radios
  239. Jr 4721
  240. Gyro/servo problem
  241. Need your help Danny 10x?
  242. Mixing Elevator and Aux3 - 8103
  243. Pcm9
  244. 8103 Flaperons
  245. Where to get a spare Battery pack for a JR 10X?
  246. Transferring from old JR 10 channel to a 10X, no way?
  247. Changing Rx from 72Mhz to 50Mhz???
  248. Spoilerons for harrier
  249. Engine Start with PCM 10X
  250. please close
