PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38
  1. X347 vs X378 What's the difference?
  2. Slide switch question on 10x?
  3. 8411 Servo Question
  4. Manual - JR Propo Century VII FM
  5. Synth module for 10X?!
  6. Digital and standard servo compatable?
  7. Datasafe versions for 8103?
  8. ccpm upgrade
  9. JR 662 Questions
  10. JR 622 Case
  11. Jr 10sx Question
  12. Using double rudder as a speed brake
  13. older JR still legal
  14. 8103 throttle cut setup
  15. R1000 receiver
  16. 8103 programming guide
  17. matchbox or channel expander
  18. Jr 10x
  19. R700 jittery with 6V battery
  20. 4721 to 2721 conversion?
  21. module damage ???
  22. Have I got a bargain?
  23. Status 652
  24. 783 Manual
  25. New to JR--don't know the #'s
  26. 649s reciever crystal
  27. 50MHz Support?
  28. Pcm 10x
  29. Adjusting Gyro Gain on a XP652
  30. 8417 servo
  31. Trimming Question (10x)
  32. New 250oz/in Servo?
  33. Help! Max4 level meter problem
  34. 549 Reciever tuning and all JR Recievers Min. Antenna length.
  35. JR 3810 and R600
  36. Question for Danny RE:610
  37. Danny check status please.
  38. 549 antenna length ????
  39. 8103 memory backup?
  40. JR10pcm
  41. What color is 'ground' wire
  42. JR 10s
  43. 8103 differential flap setup help needed
  44. XF421EX Problems
  45. how to 2 servos per aerilon
  46. JR 10x compatibility question.
  47. For sale: Translation of the JR R-1 Transmitter Guide into Spanish
  48. Charging: Should I be concerned
  49. Just wondering... What recievers would you recommend for the R1?
  50. rx repair
  51. Delta wing mix on PCM10X Heli
  52. uneven elevon travel again
  53. JR TX Memory Battery Replacement
  54. Danny, Problem Sovled From JR.
  55. Flap to elevator mixing
  56. 8103 spoiler mixing
  57. 9 CH PCM Rx
  58. 3810X Mixing
  59. New TX sticks
  60. 6V on a JR 8411
  61. Data Safe and USB Port
  62. awsome 378
  63. Programming Book For 10X
  64. JR Unlimited Series Mark VIII Mod J128 M
  65. 652xp
  66. 8103 and throttle cut switch location
  67. x 347 and 401 gyro
  68. Century 7 Transmitter
  69. Dead 783, Help
  70. Flap Travel on PCM10X
  71. jr - 378 gear + aux 2 control with throttle hold
  72. NEB-480. Model Beacon
  73. What's the major differences between the 66(X), 65(X),64(X), 62(X) and 631 radios.
  74. XR3 Coming aprt
  75. JR MX-22 transmitter: New for 2003?
  76. broken F400 tx need parts
  77. jr 811 servo chatter need help please
  78. 10x
  79. jr 10x battery part number
  80. Parts for Century 7 TX
  81. Switching modes in JRXF622
  82. Servo 'bounce'
  83. Flawed DataSafe 2 Software
  84. RF Modules
  85. Danny ... same problem. XF631. PLEASE HELP, Danny thread updated.
  86. pcm10s and CCPM?
  87. Jrx378 Manual
  88. DataSafe 1 vs. 2 files
  89. Possible Gyro problem. (or a servo maybe)
  90. JR Buddy Box with mixing
  91. JR servo mounts
  92. Jr R649 PCM versus Jr R700
  93. Ner 327x
  94. Technical question about memory battery....
  95. crappy transmiter
  96. uneven flaperon travel
  97. 10x flaps and spoilers
  98. 10x servo test
  99. PCM10 and G550T
  100. Receivers
  101. Jr Xf622
  102. XF421ex Transmitter
  103. 15 year old Jr propo question
  104. Defekt Gyro or Servo etc...???
  105. Jr 10x
  106. Reciever Compatibility
  107. Nes910xs
  108. Radio and receivers for service
  109. Channel 6 travel
  110. old jr propo10 with ch 14 modual-compatibility problems with 2 fm type recievers?
  111. 8103 why
  112. Why chicks dig Danny...
  113. Radio set up for 33%
  114. Danny, My Radio In For Service
  115. X-378 Servo Speed
  116. Who owns or makes JR?
  117. servos 4721 or 8101 for CA 27% extra
  118. jr1000 gyro
  119. Servo for flaps.
  120. R-1 Charging...
  121. Xp642
  122. JR Switches
  123. 10x Charging
  124. JR662/ Slimline R700 question
  125. 8103 program mixing problems
  126. Servos for glider's elevons
  127. JR R330S and Servo(s) Compatibility
  128. JR PROPO 9X News?????
  129. Losing data
  130. need help jr x3810 mode 1 heli tx.
  131. Very Bad Twitching New JR 631
  132. 2 batterys 2 reciever or 1 battery 1 reciever w/10 servos
  133. Century 7 and Appolo 6 modules
  134. Throttle cut program mix?
  135. my JR631 is doing strange things
  136. jr matchbox
  137. Reciever and servo recomedation
  138. Jr Radio Transmiter Upgrade
  139. JR Max66-ii User Manual
  140. singal or dual conversion
  141. Problem with Radio or Receiver?
  142. Transmitter Antenna
  143. Dual elevator problem
  144. How can you Recycle Tx Battery
  145. Channel Xpander vs. Matchbox
  146. Need info on what seems to be a JR radio
  147. Help setting up gyro on 10X
  148. Danny
  149. JR 388 with airtronics reciever?
  150. Manual
  151. 80" Profile servos
  152. Lead problems. X378 with Reflex SIM
  153. 98" Cap 232
  154. Did I bugger my R1? help!
  155. Trying to make HH selectable
  156. 610 in a Fun Fly
  157. New group....
  158. X-378
  159. Use JR radio encoder/decoder only
  160. Want to purchase new JR receiver....
  161. Whats up with JR servos?
  162. JR X-378 Instruction Manual
  163. Elevon Adjustment On XF631
  164. Need help - charging Tx/Rx batteries
  165. Transmitter moduals
  166. 9x
  167. 8103 Program Guide
  168. Where do I send my R600 for repairs?
  169. xp662
  170. 4721
  171. Rx crystal question
  172. century 7 transmitter battery
  173. Jr 627x
  174. Gyro lockout?
  175. Charging TX battery with field charger
  176. Danny Help!!!
  177. Trainer Channels
  178. JR Century Vll
  179. Jr Nej-130
  180. Broken heart or Matchbox?
  181. manually transfering model setups from XP562 to 8103
  182. Does Jr 8103 Have 8 Dedicated Channels?
  183. datasafe compatibility
  184. PCM10 Questions
  185. JR 3421 Servo Torque
  186. Range check???
  187. Datasafe 2
  188. 378 & gy401
  189. jr radio repair/testing
  190. Jr Nes-591
  191. R600 receiver lost a couple of channels in cold
  192. How to avoid noise created by long servo wire runs
  193. 10X vs 8103 Channel Assignments
  194. Datasafe versions?
  195. Servo Tray
  196. Changing TX crystals
  197. JPR 55 Base Loaded Ant.
  198. Century 7 system
  199. JR XP622 Questions
  200. Matchbox - Will My Settings Be Lost
  201. Alternate Battery Plug-in for 955 Receiver
  202. problem with mc-20 TX
  203. R 700
  204. JR 622 battery question
  205. 10sxii
  206. HELP!!! Radio problem
  207. Servo arms compatability
  208. 10x crstal swap
  209. 8103 mode1.2.3.4
  210. Voltage
  211. 9411 Servos
  212. Jr 652
  213. Elevator to Flap Mixing
  214. JR Galaxy Radios
  215. Match Boxes with Redundant Battery packs
  216. Radio manual needed
  217. mc24 left ON overnight without cristal
  218. 9011 Gears?
  219. Older Jr tx and rx
  220. Older Jr tx and rx
  221. High band-Low band
  222. JR Match Box
  223. JR XP783 switches
  224. Jr 955
  225. 8103 Flight Switching.
  226. JR 955 receiver
  227. 8103 Air vs. 8103 Heli
  228. Is there a new JR Radio coming???
  229. Flap travel inadequate on 8103 landing switch.
  230. jr 652 and a eco 8
  231. 8103 Dt
  232. mode 1 instructor mode 2 learner
  233. Matchbox on ailerons....
  234. servo selection
  235. Changing receiver crystals
  236. Dual receivers
  237. Help With Programming R-1 Mix1.
  238. JR XP8103 1650mA TX Batt Upgrade Help Needed
  239. JR 8103 DT with analog trims?
  240. Single vs Dual Conv/1 vs 2 Receivers
  241. 1 dual rate switch???
  242. 700 Rx
  243. JR 10SX Trans.
  244. Changing a x-378 from mode 1 to 2
  245. Tx Channel Flags
  246. TX battery charging
  247. questions
  248. JR NES-509 servos?
  249. Matchbox questions when used with dual rx?
