PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38
  1. 10x throttle curve question
  2. Two questions for dsnyder, or anyone else who knows.
  3. throttle problems
  4. More Channel Change
  5. Diodes?
  6. Manual for JRP Cobra
  7. JR 622 and Elevon's again
  8. Jr-r1
  9. Matchbox, 8103, Whats the best way to plug in 2 elevator servos?
  10. fried radio????
  11. Changing channels on 8103 tx and rx
  12. throttle curve for JR 783?
  13. 10X Question
  14. Century VII FM Trans.
  15. I'm confused 8103
  16. JR10pcm
  17. 8103 Mixing ON/OFF switch select - limited?
  18. xf 421 ex
  19. Lengthened RX antenna
  20. Proportional flap knob....
  21. Mulit Point Mixing For Throttle Control - 8103
  22. 649 PCM Receiver & Crystal
  23. x-378 again
  24. Base loaded antenna
  25. 10SX spoiler set-up
  26. JR 6volts or 4.8 v
  27. WANTED : R-756 Manual
  28. receivers
  29. Data Safe,, XP compatable ?
  30. Module/Rx/Tuning Question
  31. X-378
  32. Pcm?
  33. That was a lot of reading!
  34. Backup Battery
  35. PCM10 & buddy system
  36. Can I use the datasafe ?
  37. ZPCM vs SPCM
  38. Trainers ?
  39. Jr Ds 559 Fet Digital Servos
  40. JR Galaxy 8, need help
  41. JR Servo Specs'
  42. 783 and a heli
  43. JR Max 6 & JR Quattro Buddy Box
  44. X 378 Data Sheet For Ergo .46 Initial Set Up
  45. Jr Servos
  46. Glitch in JR TX
  47. Receiver Crystal Question
  48. Where to send module for channel change?
  49. Help! I need gears for a 9011
  50. 8411 update to 8311 for helis
  51. Any JR servos interchange with IC ?
  52. Thread Size DS8411
  53. Changing Frequency crystal for tx
  54. Changing Frequency crystal for tx
  55. Datasafe question
  56. JR radio problem
  57. 8411 Question
  58. JR Datasafe - can I view/modify settings on PC?
  59. 10x Touch Screen Problem
  60. JR 631 Reversed Stick Controls
  61. JR PCM 10X and Duralite Batteries
  62. R700 receiver max voltage?
  63. servo twitch/??????
  64. NES-L501 servos
  65. re: XP783 broken toggle
  66. RX imtermittant faults
  67. X378 Programing For Ultra Stick 40
  68. Danny JR question
  69. How to make a 72 mhz radio 35 mhz??
  70. 517 servos
  71. Jr Pcm9x
  72. setting crow mix?
  73. JR 347 Manual
  74. 10x airplane for heli use
  75. 2 Batteries to 1 reciever how?
  76. Older 4131 Problem
  77. Trainer function...
  78. My Plane is Buzzing (Newbie)
  79. Jr Galaxy 8
  80. Frustration with programming on Ultra sticks
  81. JR652 err 2, lost all programing ?
  82. 6 volt glitces
  83. thanks for your help.
  84. 8411 runs to limit and hangs
  85. 8311, 9411
  86. Trying to SMOKE
  87. 8103 to Ham Bands
  88. 10X servo slow & mixing
  89. Jr700 series receivers
  90. 627x receiver
  91. Advantages of x-378
  92. Hey Danny, I still need to get that manual for PCM 9 Heli Tx
  93. Switching Crystals
  94. Datasafe 2 problem
  95. 10x
  96. JR Receivers on 50MHz
  97. JR receivers
  98. 8103 Split Elevators
  99. 347 Twin Elevator Set-up
  100. JR Alpina PCM question
  101. DS 368 drift
  102. 388/xp8103 questions
  103. XP662 Question
  104. JR PCM reciever 627x and 627xz
  105. 33% plane one reciever?
  106. 10x snap button
  107. RX Crystal Change
  108. NER & RCD receiver questions.
  109. Jr 388
  110. 8411@8411sa just a question danny
  111. JR Service/Turn Around Phenomenal
  112. JR rerceivers getting bad hits
  113. Datasafe "
  114. XF631 glitching?
  115. Tmaxx Steering Servo
  116. JR 8103 Mode 1 radio
  117. JR Datasafe 1 vs. Datasafe 2
  118. 10X bugging! ? need help
  119. 8103 Dual Rudder Servos
  120. 649 vs 945 vs 955
  121. Servo Torque
  122. Hello 10X - I have a few questions.
  123. Danny - Some help please...
  124. Tx Modules
  125. ultra stick and Jr652
  126. 8411sa
  127. Single Conversion vs Dual Conversion
  128. JR 40 series transmitter
  129. 652 dead please help!
  130. crystals
  131. 627x/627xz receiver
  132. JR 8411 gears
  133. JR Service Address?
  134. 783 tune up
  135. Setting up a choke servo
  136. Dual batteries on 659 receiver
  137. 8103 does not turn on
  138. Jr 8103
  139. JR5000 Gyro setup?
  140. R700 got wet???
  141. Jr Pcm9x
  142. 652 flaperon set-up
  143. Specs on 517's
  144. jr 652 TX cracked screen
  145. Jr Xp662 Problem. (panic)
  146. R700 Aux2 output?
  147. 8103 heli for aircraft use
  148. GV-1 Governor with JR X-378
  149. Factory programming
  150. J.r. Xf 622
  151. DS161 servos
  152. JR NER J 228F 8 Ch. Double Conv. FM Rec.
  153. Datasafe serial number
  154. Problems with 2721 servos !
  155. Will a 12year old PCM10s work with R1000DS Rx?
  156. ds811@ jr 550t
  157. 8103 programing
  158. Antenna quesetion
  159. JR10X & Hitec fm recievers (shift selectable)
  160. 700 receiver vs 649 PCM receiver
  161. Matchbox on First?
  162. JR Radio for 3d
  163. JR Sensitivity.
  164. matchboxes causes radio failure?!
  165. servos
  166. XP8103 V tail and electric sailplane
  167. JR Datasafe trouble!!!!
  168. 8103
  169. 610m
  170. Quatro radio
  171. JR 517 servos
  172. Is this possible
  173. Whip antennae
  174. channel mix
  175. jR ds368 CASE MOD FOR WING INSTALLATION
  176. Knife Edge Mix - 8103
  177. How do I set up flapperons and spoilerons for 3D flying on a 8103?
  178. JR 783 module question.
  179. Questions for Danny
  180. Digital Servo and Standard JR RX
  181. Danny this is so funny, its about the 610M
  182. Large/Longer JR control Sticks
  183. XP662 heli vs Air, any difference?
  184. Jr Radis Past To Present
  185. 10sx2@10x
  186. 610M Qustion Again
  187. Need Manual for a JR PCM 9 Heli Radio.
  188. Horizon service
  189. 610m`
  190. servos for a 35% extra 26 to 28 lbs.
  191. 6 volts on 531 servo
  192. Servicing TX and Rx
  193. 10x Keeps Going Into Failsafe On The Ground?????/
  194. jr10x
  195. 783 with 2 elevator servo's
  196. Rx Crystal Change
  197. Trim Offset Memory Missing
  198. frequ. change
  199. broken flap switch
  200. ?'s
  201. 8103 Programming - Complete Guide
  202. Y Harness vs. Direct Connect
  203. Lihium battery
  204. 10X Battery Case
  205. Ppm Receiver ---pcm Receiver
  206. 662 Initial Charge (Newbie)
  207. Circus4 Receiver
  208. JR servo chatter
  209. JR Amplified Y Harness
  210. re: x378 spoilers and flaperons
  211. JR10X Switching from Mode I to III
  212. dual conversion crystals
  213. JR 3021 and 3121 servos
  214. Will a JR NER-627X receiver work with my X-347 ?
  215. Jr PCM10
  216. XP8103 Warning Message
  217. JR 10SX FOR AIR PLANE TX module2->1?
  218. JR matchbox question
  219. 783 went bad
  220. 10x battery case part # / discharge ?
  221. Xf622
  222. Gasket for 4721 servos
  223. No RC controller dealers in India
  224. 8411 gears
  225. 8411 and 2721 gears/deadband
  226. Strange 8411 movement
  227. 537's
  228. Jr 9x
  229. 8103A vs 8103H
  230. 8103 Kill Switch
  231. Dual Rec'rs
  232. 10x question
  233. Nes 3001mb
  234. JR XP642 and flaperon programming
  235. 2721 servo gear problem
  236. Serious servo jitter
  237. Dual elevator set up
  238. Snaps And Downtime Switch On 8103
  239. 5 cell problems
  240. JR 10 series
  241. Types of PCM and 8103 question
  242. 4721 to 2721 conversion
  243. 8231 servo
  244. 811 digital servo gear slop
  245. XP662 question
  246. datasafe
  247. Servo Shopping
  248. 8103 heli vs 8103 air?
  249. Another 8103 Elev. mix question
  250. Another 8103 Elev. mix question
