PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38
  1. Newbie Question
  2. 8103 Heli/Airplane difference
  3. Need info on old servo
  4. jr max6
  5. Jr Xf 631
  6. Supplimental Users Guide for 10X
  7. Lithium Battery
  8. jr 610M rec problem...
  9. Replacement Model #'s for Older JR Servos?
  10. Trim Memory for Non DT XP8103??
  11. 378 interface problem
  12. .
  13. flapperons with 5 channel receiver
  14. Kill Switch and Resolution Question
  15. lock up
  16. Is the 10X higher quality and more reliable than the 8103?
  17. Need Help With JR 10X Aircraft Radio Programming
  18. JR 8411 servos
  19. JR 10x on 50MHz
  20. JR X-388 CCPM Progtamming
  21. X-378 programming help
  22. new jr radio
  23. 10X Fast Charging
  24. Jr 8103 mixing question
  25. JR Help!!!
  26. Jr 3810 FM or PCM ??
  27. 8103 ---> 10x
  28. Jr 652
  29. XP8103 MD1 vs MD2
  30. Tran. Module
  31. JR 4721 service
  32. 2721 vs. 4721 Servo
  33. PCM receiver
  34. Servo Leads
  35. 3810 adt -- resolution
  36. Programming?
  37. rec.
  38. rx xtals
  39. servo lead length?
  40. JR NEJ 3000 Gyro
  41. JR Battery connectors
  42. 783 radio--six servo sailplane set up...
  43. Where is the Trim Offset Memory on my XP8103?
  44. Changing crystal in Modules
  45. Charging with a smartcharger?
  46. JR & European Frequencies
  47. 10 sx
  48. Question on the NER-226X
  49. Flaps
  50. Jr 662 ?
  51. figured it out thx anyhoo
  52. interface question
  53. JR 662 Not transmitting
  54. 8103 ailevators?
  55. JR649 receiver
  56. digital servo frequency
  57. voltage regulator
  58. R-700 Reciever ???
  59. Receiver Type
  60. Gyro Manual needed - NEJ120A or maybe NEJ720a
  61. Please close thread
  62. setting up a gyro
  63. New 9 channel radio
  64. JR PCM Transmitter w/FM Receivers
  65. 6x2 flaperons
  66. X-378
  67. Digital Servo 8301
  68. JR 3810 - Flight modes
  69. JR3810 dual rates on one switch
  70. Matchbox and non-JR servos/receivers
  71. DataSafe2 Pc Interface System
  72. 810
  73. 8103's replacement ...
  74. Exponential
  75. Programable switch assignment
  76. Jr X-3810
  77. Fail-safe X-3810- Spcm - Adt
  78. 6 Volts
  79. 8103 Flaps
  80. Snapped Antenna
  81. Server flutter/jitter when transmitter is off
  82. 8103 trim
  83. JR 610 Rx
  84. JR652 flaperons
  85. Ultra Stick and a 783 mixing?
  86. NES - 4011 JR Servo
  87. Ailerons on 662
  88. Charging Question JR 8103 A
  89. Elevons on 8103
  90. Dual Eleavator setup PCM10
  91. Dead JR display on a 347 Tx
  92. Radio interference Can you Help?
  93. JR 10X Battery Problem
  94. JR 4131 servo buzzing
  95. 783 w/Hitec 555 and flapperons
  96. Need spec. JR4031 servo
  97. limitations on the 10x
  98. JR 8103 and what receivers ?
  99. Stalling 8411's???
  100. 10X Trace Rate
  101. 10X Idle Up Mix (Page 44)
  102. 12x
  103. 10SX mixing
  104. Amplified Y's?
  105. 8411 Life span
  106. Horizon Service Suggestion
  107. JR XR2 problem
  108. y harness or not.
  109. JR Century 7 Single Stick
  110. 378 heli gear/inverted
  111. life expectency of JR receivers
  112. I have some questions about my JR 421ex radio (newbie)
  113. XP 662 flaperons
  114. Heli Servos
  115. Pulse amplitude
  116. Orientation of JR G410T gyro
  117. PCM 9 Single Stick
  118. Do I need a servo reverser for dual elevators with 8103 ?
  119. NER-627X receivers
  120. Switch current rating
  121. Servos
  122. Model transfer question
  123. JR-378 and 2 elevator servos
  124. Jr Rcvrs
  125. Jr 652
  126. Backordered from Horizon__Digital Servo Pots
  127. Two Questions??
  128. Lithium Battery life
  129. Dots on JR xtals?
  130. JR 649S RX antenna broke
  131. JR 388S Manual
  132. JR DS8411/DS8411SA Servos
  133. XP8103 Program Help Needed
  134. Crystal compatability Jr / Hitec
  135. servo reversing JR622
  136. JR Crystals
  137. New 10X has a dent on the TX
  138. Aileron & Elevator Servo hook up without using Y Harness ?
  139. Older 8103 upgrade to support CCPM
  140. X-378 FlexEquip?
  141. 10X Throttle Curve
  142. JR 347 Mix and trim
  143. Transmitter Memory
  144. 783 pot problems
  145. Modulation switch on JR 378
  146. New 8103-I Found Out What was Wrong!
  147. New 8103-What am I not doing right?
  148. Some 8103 questions...
  149. Using another 8103 tx for DataBackup
  150. 662 Problem
  151. JR nes 8300 servo?
  152. Help Danny..... Any thoughts ???
  153. 5 cell battery pack
  154. Batteries for XP662
  155. JR 4021 servo's
  156. X378 Manual
  157. 610M receiver
  158. 8411
  159. Measuring servo current
  160. Digital Servo Bounce
  161. JR XP8103 Receiver on 6V?
  162. Books for JR 8103 ?
  163. Dual rates jr pcm 10sx
  164. dropped 783
  165. advice please
  166. 8103 dual rates - 1 switch
  167. Attn Danny
  168. 5 cell receiver pack?
  169. split elv
  170. Two 9411s on a simple "Y" Connection
  171. 2721 gear failures
  172. 649 S-pcm
  173. Difference between 10x & 10sx
  174. "crow on 783?"
  175. Maximum Voltages for digital servos?
  176. JR 378 & Airtronics rx
  177. Danny, 8103 DT Heli trim
  178. Txr Failure Modes
  179. 10x
  180. 8103 dual rates
  181. Whats up with JR receivers availlability
  182. 8103 and Spoiler
  183. Danny, another 8103 question.
  184. 8103 trim
  185. Servo precision
  186. Rx crystal specs
  187. Alivons with 10X
  188. Throttle cut ability?
  189. Changing Crystal
  190. dual elevator mixing problems
  191. DS811 Digital?
  192. Got my 10X today!!!
  193. "non economical repair"?
  194. Screw Size
  195. JR servo spec
  196. Radio Comparisons
  197. split elevator servos
  198. flapper-ons
  199. best radio?
  200. PCM10 Output
  201. Century VII trainer setup
  202. 652 mixing
  203. Gyro Servos
  204. JR 783 sploilers/aileroins
  205. PCM 10 touch screen contrast
  206. JR 652, and dual rates on the Rudder...
  207. jrds368
  208. Repairs
  209. Datasave original/version 2 ??
  210. Servo Movement - unwanted
  211. Datasafe2 Vs. Datasafe
  212. match box
  213. Jr 940 and Jr 945 Receiver
  214. narrow band
  215. Email address for Hartness Topper
  216. JR tx & Hitec RX
  217. Receiver Crystal Change
  218. 642 to a 8103
  219. JR 8103 Set-Up
  220. servo ???
  221. 10x Dual Rate Settings
  222. XP 8103 Mixing
  223. XP783 Manual
  224. JR 652 trouble
  225. 10 s compatible receivers
  226. Datasafe 2 PC Interface
  227. Excessive Current Draw?
  228. JR 652 Dead...
  229. Problem with 347
  230. How many channels are 1024?
  231. Wrong Crystal?
  232. HELP!!! JR radio glitches
  233. Xf 421 Ex
  234. Changing Frequency
  235. Tuned system
  236. XP 652 elevator dual rate trim changes
  237. Jr 378
  238. 8103 dual elevator programming question
  239. Receiver
  240. Problems with digital trims?
  241. Charging Error, mental type
  242. 8103 programing ?
  243. Dis-information?
  244. 10SXii, 10X heli Revo Mix
  245. A, Bee, Cee and Windows
  246. 10x and flight modes
  247. Ultra Sport 60 programming
  248. 8103 programming
  249. JR AM abc&w system crystals
  250. Instructions for JR 378
