PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. 11X Zero stick switch problem
  2. DX8 Software Version
  3. dx6i programming
  4. WDT Error Message On JR Radio
  5. Anyone Else Have This Problem?
  6. Specktrum GPS question
  7. Spektrum remote reciever random quick flashing
  8. DX6I UPGRADE?
  9. Programming for Gliders
  10. help needed please - JR9303 4 servos Alie & flaps mix on-off
  11. Is max66 ADT PCM and ppm selectable?
  12. DX8 and Phoenix Sim
  13. DX6I rf module
  14. DX8 and AR 600 question
  15. Model Presets
  16. DX18 - clearing preflight list
  17. Radio incompatible with fingers
  18. DX8 vs DX7s - What do I get for my extra money?
  19. G370A Question
  20. VQ FW190 setup
  21. Spektrum DX7 HF-Modul repair
  22. Multi cylinder heat monitoring ?
  23. Helion Radios and Spektrum Radios
  24. DX7S Fuse
  25. Chattering servo, please help
  26. DX8 2.05
  27. MODE II to MODE III
  28. JR 922 connection with Powerbox Champion RRS
  29. Distance between AR8000 and TM1000
  30. JR XP 9303
  31. DX 7 troubles
  32. Downloading AirWare on a Mac
  33. Dx7 elevon setup
  34. DX6 shut off in flight
  35. JR 12x with "black" display
  36. DX8 2.05 firware upgrade results in need to change subtrim?
  37. Flaperons - DX7 Setup
  38. should I ditch my Rx?
  39. JR 11X Rudder Gimbal
  40. Spektrum DX18 telemetry data download
  41. Do I need a 6 or 7 channel receiver?
  42. Dx8 with 2ail,2flap and I retract servo help
  43. JR1222 Rx binding problem
  44. Antenna Position as Far as the Planes of Said Antennas
  45. 12X Alarm Volume
  46. TM1000 RPM Telemetry from CDI Module/Hall Effect Sensor
  47. DX7s Question
  48. DX8-Issue with importing all models from SD card
  49. Andy>New DX8 2.05 Firmware Bug!!!
  50. New DX8 Firmware with changes made....when?
  51. Dx3c selector wheel stopped working
  52. DX8 sounds at shut down...
  53. antenna
  54. DX8 Gimbal failure
  55. Need Plane Electrical System Planning Help
  56. Transfer of models from JR11x to 12x
  57. DX-8 Question for Andy
  58. Two Way Radio Install?
  59. What is this on my DX8
  60. powering a few led strips off select scan 700 channel
  61. Battery Replacement and charging in 2 year old DX-7
  62. Spektrum DX 2.0 Setup
  63. SPEKTRUM DM9 2.4 MODULE for JR 9303
  64. DX 8 Question 2
  65. DX 8 Question
  66. PR790 Receiver Case
  67. AR400
  68. 12X to train DX5 ?
  69. Best source for JR servos?
  70. Coverting too 2.4
  71. aux 2 servo travel on DX7s
  72. Dx6i EL Panel Question
  73. HPGDSM Transmitter From My BLADE SR
  74. Spektrum DXE4
  75. XP8103 shorted charging jack
  76. flap setup jr 9303
  77. JR 12X battery
  78. JR11X is dead
  79. JR9303 issue
  80. DX7s battery use
  81. Let's talk DX18 here!
  82. dx-8 programming question.
  83. DX7 Throtle setup
  84. Setting up my DX8 - for spins, snaps, hammers
  85. DX7 with AR6210 reciever and dual elevator servo programing
  86. AR9000 Blinking Light
  87. Horizon Hobbies Customer Service-Poor
  88. JR DS 362 Midi servo
  89. DX8 Mix Page Bug
  90. Spektrum jetcat ecu telemetry??
  91. DX7 DSMX add on
  92. spectrum servo ?
  93. DX6XI Elevons
  94. 921 binding issue
  95. DX8 retract problem
  96. help me convert s400 into liFe
  97. Transfer Radio Programming.... what is possible?
  98. JR stick condition switching
  99. DX7s Buddy box stops working
  100. 10x Switch Assignment
  101. DX10T
  102. JR Remote Receiver Applications
  103. recommend signal amplifier for dx6i
  104. jr9503
  105. Lost 2nd plane using AR9000, 2700mah five cell pack
  106. 12X Balance Function
  107. Where can get 12x USB cable?
  108. DX18 Questions
  109. DX8 with 2 free receivers
  110. 10X/12X battery cycling
  111. Battery doesn't last long in DX8
  112. Need help programming 9303
  113. ChainLinkDare UHF Long range system
  114. XG-9?
  115. JR XP8103 Transmitter Rear Housing
  116. DX8 servo twitching
  117. Dx6i failure need help
  118. Lost a plane today
  119. DX 7
  120. AR9000 blinking light
  121. Spectrum Electric RPM Sensor
  122. 6 volt battery for rx of xp6102?
  123. DX7 Voltage Indicator fluctuates
  124. JR X9503 suddenly stops transmission HELP !
  125. DX6I servo travel in delta wing configuration
  126. PCM 10C transmitter with dim screen
  127. New JR DMSS Radios Announced
  128. NEW DX7s programming issue
  129. 9303 and EFlite Scimitar
  130. 11x booklet
  131. MP80s
  132. Bird of Time on JR9303 2.4
  133. DX8 vs X9503 glider mode
  134. Dx8 programing help
  135. HELP
  136. Reciever compatability?
  137. JR XG8
  138. Mixinf elev. to aux.
  139. Spektrum DX7
  140. AR7010 / AR8000
  141. equipment upgrade
  142. dx18
  143. How do I inhibit AUX POT 3 in XP8103
  144. Phoenix Sim-Spektrum Transmitter
  145. Servos fully deflect at switch on
  146. Jr 9303 pcm9x11 crow brake switch position question
  147. Controlling AUX1 channel w/switch DX8
  148. JR servo arm?
  149. electronic speed control
  150. Solar Storms effecting our Flying
  151. DSMX updates for DX7
  152. DX7 and AR600 Rx - Flap Programming
  153. Jr 11 radio
  154. JR X2720 to 2.4GHz?
  155. DX8 throttle response
  156. Jr X378 Flap programming ?
  157. duplicate post
  158. my "older" radios
  159. Snap Roll
  160. Jr DSM2. BUY now or is already OBSOLETE???
  161. JR 9303 Flaperon Programming
  162. Trim versus Sub-trim
  163. 922x servos jerky on aileron and elevator
  164. Answers by JR Reps..
  165. 11x zero
  166. Brownouts, first time
  167. dx7, dx7s, and receiver problems
  168. travel adjust
  169. 10X on Lipo, guess what?
  170. JR 11x and Trex 450 set up
  171. How to bind 2 recievers for a dual reciever setup
  172. DX8 and 4000 Lipos
  173. DSMX Transmitter and older receivers
  174. DX-18
  175. Transferring programs from a 9503 to an 11X
  176. DX7s download Problem-Question
  177. spektrum dm8 Modular
  178. mistake
  179. JR 11X and Rudder Gyro for Airplanes
  180. Dead X-378?
  181. JR/Spectra
  182. how many amps can a JR 9x receiver handle
  183. One Arm RC Flying
  184. JR 11X dual rates help
  185. Spektrum DX8 - manufacturer's defect
  186. JR nes-9021
  187. flaperons on a dx6i
  188. AR500 True or False?
  189. AR9200 battery connections
  190. Spektrum Altimeter
  191. AR10000 Receiver Bind Problem
  192. PCM9x device select in glider mode?
  193. Single Stick TX
  194. Should it be re tuned
  195. Found a BUG in DX8
  196. spektrum rx
  197. Rpm sensor for electronic ignition
  198. PLEASE HELP ME with my jr racing XS3 remote
  199. 9303 and lipo's
  200. DX 7 Modle Select not working.
  201. JR PCM9x Throtle cut problem
  202. DX8 Download
  203. Is there a time limit for free DSMX conversion?
  204. R1221 Satellite Rx question
  205. !0X aux 3
  206. jr 9303 2.4 trim tabs
  207. JR9303 smoke system question
  208. Dx6i and AR6210 Rx w/9645 sat
  209. STI/ telemetry incompatable with AR9100,AR9200????
  210. Please Help with DX7!!!
  211. Region code
  212. JR 9303 programming
  213. Momentary toggle switch for 9303?
  214. DX8 LiPo Tx Battery
  215. Complex Brake Switch Setup on 9303 2.4
  216. Jr century 7 pcm and spektrum module
  217. Anything new for 2012 JR ?
  218. Jr 10X Transmitter Battery Problem.
  219. E-Flite Super Cub/AR7010
  220. 12X
  221. Lets talk about JR11X 2048 resolution
  222. 9303 2.4
  223. Taileron/Ailevator mixing on DX8
  224. Radian pro set with ar 6115 and dx7
  225. AR7600 Receivers
  226. Habu 32 steering Setup
  227. BLINKING LITES ON RX & SATTALITE
  228. DX8 AirWare Update
  229. slider sw
  230. JR11X initial model setup question
  231. DataSafe Software
  232. 10x
  233. X9303 flight modes?
  234. DX8 question: Does the F.Mode switch save left and right trims settings?
  235. DM8 Discontinued?
  236. How to get DX8 to read gear/flap servos?
  237. 9503 data to an 11X
  238. AR 9000RX
  239. Stiffer Gimbal Springs
  240. AR 12110, will it work on 100cc without power supply system?
  241. DSM2 Module (DM8) with DSMx receiver problem
  242. PowerBox Sensor Switch for Spektrum/JR Receivers
  243. New to DSM...hooking up an R921 rx question.
  244. X9503 DSMX Air Control Loss
  245. dx8 timer help
  246. X9503 Oops!
  247. JR 1222x receiver question
  248. any way to erase memory
  249. JR 12X active mixing
  250. JR DS821 HV & DS 821's
