PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Can JR advise re US sales of XG11?
  2. DX8 Questions from a "newbie"
  3. JR XP7202 Aileron with Rudder Mix ?
  4. Fitting two DSM2 Rxs
  5. DX6 - Park Flyer Transmiter
  6. Dx 6I
  7. Can a JR 6102 be converted to 2.4Ghz?
  8. jr8103 programing help
  9. Can a Spektrum DX8 Buddy with JR9x?
  10. Spektrum DX 7S
  11. JR 9303 Subtrim random change
  12. found a white paper
  13. Adjusting low voltage warning JR9303
  14. Gyro use with a Spektrum DX-7 ?
  15. DX7/ar7000 nearly cost my heli
  16. 12X MV 2.4GHz DSMX Module
  17. AR7000 Receiver Satellite Lead Length
  18. Jr X-378 help with gyro ?
  19. jr 9503& ar9000 receiver
  20. False bind.
  21. AR 6100E in a Stryker
  22. Spektrum AR 9100
  23. Horizon Hobby Spektrum Support
  24. Radio Shack mono cable for trainer cord
  25. software problem 12X hybrid
  26. DX8 and DX5 buddy box? Can I do that?
  27. Setup for multi engine
  28. DX8 Firmware 2.03 Beta
  29. High fade count on 7010 receiver satellites
  30. I had my Specktrum AR 7000 stop >
  31. Another JR DSX11/11X Programming Question
  32. Buddy box - 7202 tx (master) on 72mhz, Spectrum DX6i (slave) 2.4 ghz
  33. question for support JR8103 TX module
  34. JR/Spektrum RX??
  35. Dx6i Tx -change mode 2 to mode 1?
  36. Airborne power supply LIFE or LIPO
  37. JR Prop Contacts
  38. 6210 x 6255 receivers
  39. Does an AR6000 have that 4 second brownout deal?
  40. DX8 or 11X for 30% IMAC
  41. DX3R Pro
  42. AR7000 sets throttle at wide open when turned on
  43. 8 Frame Losses and 1 Hold
  44. 11X Zero dsmJ SERVO GOING MAD
  45. JR Zoom650
  46. DX8 quibbles
  47. Throttle subtrim
  48. Spektrum DX3S Issue
  49. Movingup to DX 6i
  50. Movingup to DX 6i
  51. Spektrum DX8 Travel,D/R
  52. HELP! Spektrum DX3s won't show menu
  53. AR500 Reciever & 2 BEC ESC's
  54. JR 11x Programing Question
  55. DSM2 AND DSMX RX
  56. R125 receiver
  57. Does JR DS331 has rubber grommets and eyelets
  58. JR12X replacemnt??
  59. Does the 1st gen DX7 have software updates?
  60. Programing DX-7 for dual ailerons and elevators
  61. AR7000 voltage spec
  62. JR DMSS 2.4 Receivers
  63. Setting up pan and tilt for a Jr 7 channel radio?
  64. JR 8103 FLAP PROGRAMMING
  65. Minor Glitching on Heli - Any Ideas?
  66. Jr x-378 flap control?
  67. DX8 Conversion
  68. "Range assets have lost telemetry with HTV2".
  69. JR XP9303-2.4 Native- Modulation Problem now Dead
  70. jr xp9303 display
  71. losi t ten tries to start itself
  72. Need more channels? Suggestions please....
  73. Spektrum and retract servos
  74. AR9000 versus AR8000
  75. MPI Miracle Y - 2.4 GHz Compatible?
  76. Re-binding can help and using a Flight Log
  77. Is this a software problem on my DSX11
  78. Total write off
  79. Relocating rotary knob on DX8
  80. 4 aileron 4 servo 10x setup
  81. How to Confirm your radio is working in DSMX
  82. Flaperon travel on a sailplane
  83. Upgrade on DX7 for automatic timer?
  84. Radio conversions?
  85. Copying models on a DX7?
  86. 11.1 Lipo in a JR/Graupner TX?
  87. Spektrum 7010 with Flight Log
  88. Lost another one today
  89. R922 Receiver - Soft Switch
  90. AR600 & AR6210 What is the difference
  91. Spektrum Dx6i roller sticks down ...?
  92. Spektrum Power Box Receiver
  93. AR8000 on JR 11X What frame rate is it?
  94. JR10x to DSMX
  95. AR9000 lost bind/won't re-bind
  96. DX8
  97. AR 6210 ?
  98. Spektrum and Lightning
  99. Help With DX7 Programing
  100. dx 6-i
  101. Trim Issue With Four Aileron Servos
  102. Ar9110 Receiver high fades and RX LED dimming?
  103. JR DS8911 servos
  104. DX6i...Using gear switch for engine cutoff?
  105. 12X flight mode for heli
  106. dual receivers
  107. DX6I Throttle cut
  108. JR 921 RX Updated
  109. Lipo in 9303
  110. Is MSR affected by Spektrum recall
  111. the 11x's little brother
  112. A feature I would like to see on a Spektrum Transmitter
  113. I want to buy a JR11X DSMX but can't find one!
  114. Jr 10x radio mode change ?
  115. DX8 mix
  116. Twin Engine Throttle Cut
  117. dx 10T deliverydate?
  118. Spektrum DX8 Warbird setup????!!!!!
  119. JR11X BALANCE FUNCTION
  120. JR Data Transfer Software
  121. Help in flap/elevator mix
  122. Programing crow
  123. DX8 Re-binding issue
  124. Will the rtf transmitters bind to a normal dsm2 receiver
  125. 53Mhz crystal in 50 Mhz reciever?
  126. JR XG7!
  127. AR7000 ?
  128. 130 degrees of Throttle Servo Rotation
  129. Jr 9310 Carbon Fiber Rx
  130. DX7 Unable to select model 14??
  131. recall info
  132. DSX9 with RD921
  133. New DX8 Trans/Receiver...what?
  134. x9503 programming for Radian pro
  135. JR DSM9 Programming
  136. Dual rate switch will not switch JR7202
  137. DX10t Manual ?
  138. Important Spektrum and JR DSMX Transmitter Bulletin
  139. Rotary flap control-DX7
  140. How to program 2 elevator servos on a Spektrum DX7 with an AR7000 receiver
  141. JR 12X Battery problem
  142. DX3S PLEASE HELP!!!!!!
  143. S791 retract wiring help
  144. 2.4 trainer cord hookup.
  145. help with receiver choice ??????????
  146. orange rx performance
  147. Do Spektrum servos use JR servo arms?
  148. dx7 programming
  149. Bind 12x twice to same Receiver?
  150. XP8103 charging diode
  151. range test question
  152. Which Receiver To Buy
  153. DS 378 Servo issue on flaps channel
  154. jr x-378 question
  155. JR 10X question.
  156. NEW DX7s at Horizon....
  157. DX8 Buddy Box Problem
  158. Need Help AR8000
  159. Ornage receiver
  160. 9303 travel adjustment question
  161. DSX11 vs HITEC AURORA 9
  162. Flaperon trim not working on Jr XP9303
  163. JR XP662 Radio programing problem
  164. JR RD921 2 Battery packs
  165. New JR transmitter battery with Black Square Plug??
  166. JR 10X question.
  167. FLIGHT LOGGER
  168. DX8 mode 2 flight mode togle switch
  169. 12X auto dual Rudder rate?
  170. DX 8 and a Knife Edge Mix
  171. dx8 servo monitor
  172. Weird throttle problem with 9xV2, help?
  173. JR 10x
  174. Adjusting Sticks on new Spek. DX 8
  175. Futaba vs. Spektrum....
  176. JR programming
  177. RX-extension-battery= Problem ?
  178. DX8 setup for Delta wing, help needed
  179. jr 8711
  180. JR12X Radio Boot up Problem- Battery
  181. V-Tail actions are reversed.
  182. Horizon Hobbies
  183. XP9303 Heli conversion
  184. XP930-3 Newby
  185. X9303 Not switch off
  186. Spektrum Futaba-compatible DSM2 module on Hitec Optic 6 transmitter
  187. data logger questions
  188. JR DS8411 Servo
  189. DSMX 11 With 921x receiver How's it working
  190. Problem with DM8 module in Hitec Optic6
  191. JR DSX9 ENGINE THROTTLE with SNAP SWITCH
  192. JR PCM vs PPM operation
  193. Dx5e throttle not working
  194. are the new dx6i w/dsmx out yet?
  195. JR/Spektrum New Product sighting at Toledo?
  196. DSMX upgrade for DX7 includes what?
  197. DX6i RX
  198. AR6000 with DSM2 DX6-i problem
  199. Transferring Models from JR 8103 to JR 9303
  200. Spektrum Microlite RX's in electric ducted fan jets?
  201. how to program 12x to operate a brake system
  202. Real vs. clones, Spektrum RX's
  203. Spektrum Telemetry module and iPhone App.
  204. AR12000 Rec w/inop AUX5
  205. DX7 Programming
  206. Spektrum Dx6-i in Nitro powered plane?
  207. Is it wide band or narrow band 72MHZ PCM
  208. How to turn G270 3D off ?
  209. Data Safe Software
  210. JR 11X Setting Up Crow
  211. Help With my JR XF631.....
  212. HELP!! Mixing throttle to throttle for smoke
  213. MR200 in BJ55
  214. X9303 / dx6 trainer compatable?
  215. Charging DX8 transmitter battery
  216. Spektrum DSX8 servos not centering
  217. How do you keep the antenna sticking out straight on the receivers
  218. How to setup Radian Pro BNF with 9303 A/S?
  219. ground receiver needed
  220. DX6I wall charger
  221. which rx for my sailplane and Dx7?
  222. Orange RX dsm2 receiver ??
  223. DSM, DSM-2, and DSM-X, Help?
  224. Programming the DX8 for Ultra Stick
  225. dx-7 binding light
  226. DX8 telemetry RPM pickup for Gas engines - SOLVED!!
  227. DX8 2.xx is it possible?
  228. DX8 Flap Question
  229. JR 9503 $75 to upgrade
  230. Solar Flare's & RC System's
  231. whats up with dx8 warning
  232. Horizon Hobby charges 75$ to upgrade the Dx7 to DSMX, while offering it free for Dx8
  233. DX8 AirWare 2.01 now available for download
  234. Spektrum DX8 Prog Mix question
  235. Crazy servo jumping with AR7000 and Jr 8103
  236. AR 9200 sensor switch
  237. Spektrum Rx in a "Strong Box"????
  238. DX RF Deck problem
  239. Telemetry Sensor/engine temp
  240. DX8 Telemetry Screen
  241. moved
  242. Trouble binding xp9303H to 922 powersafe Rx
  243. AirWare 2.00 relased for the DX8
  244. Battery Replacement
  245. Futaba servo & JR receiver
  246. Binding Light Flashing with new AR8000 Receiver?
  247. DX 7 Dual Elevator Setup - trim not working
  248. 9303 intermitting servo movement
  249. Ar6110 holds
  250. Can you use "Dual Elevator" setting in DX8 with AR6200 Rx?
