PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. DSM2 AND DSMX RX
  2. R125 receiver
  3. Does JR DS331 has rubber grommets and eyelets
  4. JR12X replacemnt??
  5. Does the 1st gen DX7 have software updates?
  6. Programing DX-7 for dual ailerons and elevators
  7. AR7000 voltage spec
  8. JR DMSS 2.4 Receivers
  9. Setting up pan and tilt for a Jr 7 channel radio?
  10. JR 8103 FLAP PROGRAMMING
  11. Minor Glitching on Heli - Any Ideas?
  12. Jr x-378 flap control?
  13. DX8 Conversion
  14. "Range assets have lost telemetry with HTV2".
  15. JR XP9303-2.4 Native- Modulation Problem now Dead
  16. jr xp9303 display
  17. losi t ten tries to start itself
  18. Need more channels? Suggestions please....
  19. Spektrum and retract servos
  20. AR9000 versus AR8000
  21. MPI Miracle Y - 2.4 GHz Compatible?
  22. Re-binding can help and using a Flight Log
  23. Is this a software problem on my DSX11
  24. Total write off
  25. Relocating rotary knob on DX8
  26. 4 aileron 4 servo 10x setup
  27. How to Confirm your radio is working in DSMX
  28. Flaperon travel on a sailplane
  29. Upgrade on DX7 for automatic timer?
  30. Radio conversions?
  31. Copying models on a DX7?
  32. 11.1 Lipo in a JR/Graupner TX?
  33. Spektrum 7010 with Flight Log
  34. Lost another one today
  35. R922 Receiver - Soft Switch
  36. AR600 & AR6210 What is the difference
  37. Spektrum Dx6i roller sticks down ...?
  38. Spektrum Power Box Receiver
  39. AR8000 on JR 11X What frame rate is it?
  40. JR10x to DSMX
  41. AR9000 lost bind/won't re-bind
  42. DX8
  43. AR 6210 ?
  44. Spektrum and Lightning
  45. Help With DX7 Programing
  46. dx 6-i
  47. Trim Issue With Four Aileron Servos
  48. Ar9110 Receiver high fades and RX LED dimming?
  49. JR DS8911 servos
  50. DX6i...Using gear switch for engine cutoff?
  51. 12X flight mode for heli
  52. dual receivers
  53. DX6I Throttle cut
  54. JR 921 RX Updated
  55. Lipo in 9303
  56. Is MSR affected by Spektrum recall
  57. the 11x's little brother
  58. A feature I would like to see on a Spektrum Transmitter
  59. I want to buy a JR11X DSMX but can't find one!
  60. Jr 10x radio mode change ?
  61. DX8 mix
  62. Twin Engine Throttle Cut
  63. dx 10T deliverydate?
  64. Spektrum DX8 Warbird setup????!!!!!
  65. JR11X BALANCE FUNCTION
  66. JR Data Transfer Software
  67. Help in flap/elevator mix
  68. Programing crow
  69. DX8 Re-binding issue
  70. Will the rtf transmitters bind to a normal dsm2 receiver
  71. 53Mhz crystal in 50 Mhz reciever?
  72. JR XG7!
  73. AR7000 ?
  74. 130 degrees of Throttle Servo Rotation
  75. Jr 9310 Carbon Fiber Rx
  76. DX7 Unable to select model 14??
  77. recall info
  78. DSX9 with RD921
  79. New DX8 Trans/Receiver...what?
  80. x9503 programming for Radian pro
  81. JR DSM9 Programming
  82. Dual rate switch will not switch JR7202
  83. DX10t Manual ?
  84. Important Spektrum and JR DSMX Transmitter Bulletin
  85. Rotary flap control-DX7
  86. How to program 2 elevator servos on a Spektrum DX7 with an AR7000 receiver
  87. JR 12X Battery problem
  88. DX3S PLEASE HELP!!!!!!
  89. S791 retract wiring help
  90. 2.4 trainer cord hookup.
  91. help with receiver choice ??????????
  92. orange rx performance
  93. Do Spektrum servos use JR servo arms?
  94. dx7 programming
  95. Bind 12x twice to same Receiver?
  96. XP8103 charging diode
  97. range test question
  98. Which Receiver To Buy
  99. DS 378 Servo issue on flaps channel
  100. jr x-378 question
  101. JR 10X question.
  102. NEW DX7s at Horizon....
  103. DX8 Buddy Box Problem
  104. Need Help AR8000
  105. Ornage receiver
  106. 9303 travel adjustment question
  107. DSX11 vs HITEC AURORA 9
  108. Flaperon trim not working on Jr XP9303
  109. JR XP662 Radio programing problem
  110. JR RD921 2 Battery packs
  111. New JR transmitter battery with Black Square Plug??
  112. JR 10X question.
  113. FLIGHT LOGGER
  114. DX8 mode 2 flight mode togle switch
  115. 12X auto dual Rudder rate?
  116. DX 8 and a Knife Edge Mix
  117. dx8 servo monitor
  118. Weird throttle problem with 9xV2, help?
  119. JR 10x
  120. Adjusting Sticks on new Spek. DX 8
  121. Futaba vs. Spektrum....
  122. JR programming
  123. RX-extension-battery= Problem ?
  124. DX8 setup for Delta wing, help needed
  125. jr 8711
  126. JR12X Radio Boot up Problem- Battery
  127. V-Tail actions are reversed.
  128. Horizon Hobbies
  129. XP9303 Heli conversion
  130. XP930-3 Newby
  131. X9303 Not switch off
  132. Spektrum Futaba-compatible DSM2 module on Hitec Optic 6 transmitter
  133. data logger questions
  134. JR DS8411 Servo
  135. DSMX 11 With 921x receiver How's it working
  136. Problem with DM8 module in Hitec Optic6
  137. JR DSX9 ENGINE THROTTLE with SNAP SWITCH
  138. JR PCM vs PPM operation
  139. Dx5e throttle not working
  140. are the new dx6i w/dsmx out yet?
  141. JR/Spektrum New Product sighting at Toledo?
  142. DSMX upgrade for DX7 includes what?
  143. DX6i RX
  144. AR6000 with DSM2 DX6-i problem
  145. Transferring Models from JR 8103 to JR 9303
  146. Spektrum Microlite RX's in electric ducted fan jets?
  147. how to program 12x to operate a brake system
  148. Real vs. clones, Spektrum RX's
  149. Spektrum Telemetry module and iPhone App.
  150. AR12000 Rec w/inop AUX5
  151. DX7 Programming
  152. Spektrum Dx6-i in Nitro powered plane?
  153. Is it wide band or narrow band 72MHZ PCM
  154. How to turn G270 3D off ?
  155. Data Safe Software
  156. JR 11X Setting Up Crow
  157. Help With my JR XF631.....
  158. HELP!! Mixing throttle to throttle for smoke
  159. MR200 in BJ55
  160. X9303 / dx6 trainer compatable?
  161. Charging DX8 transmitter battery
  162. Spektrum DSX8 servos not centering
  163. How do you keep the antenna sticking out straight on the receivers
  164. How to setup Radian Pro BNF with 9303 A/S?
  165. ground receiver needed
  166. DX6I wall charger
  167. which rx for my sailplane and Dx7?
  168. Orange RX dsm2 receiver ??
  169. DSM, DSM-2, and DSM-X, Help?
  170. Programming the DX8 for Ultra Stick
  171. dx-7 binding light
  172. DX8 telemetry RPM pickup for Gas engines - SOLVED!!
  173. DX8 2.xx is it possible?
  174. DX8 Flap Question
  175. JR 9503 $75 to upgrade
  176. Solar Flare's & RC System's
  177. whats up with dx8 warning
  178. Horizon Hobby charges 75$ to upgrade the Dx7 to DSMX, while offering it free for Dx8
  179. DX8 AirWare 2.01 now available for download
  180. Spektrum DX8 Prog Mix question
  181. Crazy servo jumping with AR7000 and Jr 8103
  182. AR 9200 sensor switch
  183. Spektrum Rx in a "Strong Box"????
  184. DX RF Deck problem
  185. Telemetry Sensor/engine temp
  186. DX8 Telemetry Screen
  187. moved
  188. Trouble binding xp9303H to 922 powersafe Rx
  189. AirWare 2.00 relased for the DX8
  190. Battery Replacement
  191. Futaba servo & JR receiver
  192. Binding Light Flashing with new AR8000 Receiver?
  193. DX 7 Dual Elevator Setup - trim not working
  194. 9303 intermitting servo movement
  195. Ar6110 holds
  196. Can you use "Dual Elevator" setting in DX8 with AR6200 Rx?
  197. DSMX
  198. JR 9303 Conv to 2.4
  199. DX8 flap and elevator....
  200. DX8 issue inside metal buildings
  201. AR500 LOCKOUT
  202. JR XP-7202 WORKS FINE AS SALVE (STUDENT) BUT NOT AS A MASTER (TEACHER). PLEASE HELP !!!
  203. Link Failure
  204. multiple recievers
  205. just got my DX8
  206. PKZ3351 (vapor) won't bind
  207. JR gyro ?
  208. Setting up flaps
  209. DX8 files
  210. Servo arm screw for DS 8411
  211. JR DSX 9 ceasing to transmit
  212. Buddy Box for 9503
  213. RX921 flashing leds
  214. Jr vs Spektrum receivers
  215. 72mhz AND 2.4 Ghz in one Radio?
  216. Mixing channel to itself !
  217. JR XF622 setup with dual wing servos
  218. JR XP 6102 FIXED!!!
  219. Telemetry In JR?
  220. RPM sensor for DX8 radio
  221. JR X9303 Doesnt Turn On
  222. new jr 9503 for plane with futaba servos
  223. Trouble W/ Ar7000 receiver
  224. 921 RX Satelite
  225. Blown fuse in DX7
  226. DX8, Dual Ailerons
  227. Transmit and Receive Crystals
  228. 2 Reciver in 1 Plane?
  229. Satellite antenna placement
  230. HELP! Spektrum Dx7 freezes when selecting a certain memory slot!
  231. JR Pc data transfer
  232. PowerBox Royal Spektrum 12K
  233. X9303 - Gear switch activates elevators
  234. JR x9303 Throttle cut
  235. 9309 & Opto Kill switch setup
  236. Need JR Max Computer NET-W126HZ manual
  237. Twin engine set up with 2 servos
  238. Help programming Spektrum DX6i radio dual ailerons
  239. Aileron differential problem
  240. 8103 and Power
  241. DX-7 recalled after being sold as new?
  242. JR 10X
  243. AR500 RX
  244. DX6i issues
  245. 9503 Program Transfer?
  246. JR NER 226X and new crystals
  247. R922 "Powersaver" problems with HS-7950 servos.
  248. 12x usb drivers for window 7
  249. Receiver compatability
  250. WHAT SHOULD I DO NOW??????
