PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Convert JR 8303 to 2.4
  2. Rx in Carbon fueslage
  3. DX-8 Availabilty
  4. 9303 rudder to nose gear mix help
  5. Spektrum AR6200 and DX6i
  6. WHY No News about DX8 w/Telemetry??
  7. ar500 antenna positioning
  8. R1221 receiver with dual batteries
  9. JR 10SX screen going bad
  10. JR Transmitter model questions
  11. DX7( back up error )on screen
  12. Wanted - JR XF6 series Transmitter and Reciever
  13. Spektrum Futaba module for the 9c
  14. 9503 or 11x dual rates all on one switch
  15. dx 7 servos hard over on startup
  16. JR Sport 4ch Mode change?
  17. Urgent Help!! transmitter and recievers not jiving
  18. JR 8411 why Airplane only?
  19. Spektrum Futaba module
  20. JR 783 and flaps
  21. 12X model selection issue...
  22. Importance of 30 pace range check?
  23. 9303 help with throttle
  24. ar-500 receiver voltage
  25. Interference issues at large events
  26. JR10x heli TX & airplane ailerons
  27. Running 2 batteries in RX
  28. 9303 2.4 Channel mate question
  29. P Mix on DX6i
  30. dx6i and an MSR....D/R question
  31. SOURCE OF AR500 FAILURES
  32. heli flight on PCM 10SX II
  33. JR 9303 2.4 antenna
  34. JR 11X 2.4
  35. 9503 vs 9303
  36. Need help program my 8103
  37. HiTEC HS-7985MG Digital Coreless Servo Jitter
  38. Re-connect time delay
  39. 2.4 Antenna
  40. What is Camber & When to Adjust
  41. ESC trouble
  42. Differential throttle/rudder mix
  43. JR R921 Reboot time
  44. DX3R and DX3.0
  45. 10x dual throttle set up.
  46. 9303 9 CHANNEL side lever switchs (fuel control)
  47. Spektrum DX7, binding
  48. disabling the gear switch
  49. 4 wing servo Balance Function in 12X
  50. Horizon Hobbies Spectrum DX6I Malfunction that destroyed my aircraft
  51. Dual Flaps jr 12x
  52. Difference between DSM2 and DSMJ??????
  53. AR6110e range in feet
  54. dx7 and dx5e buddy box
  55. DX7 not turning on oh nooo!!!!
  56. Spektrum radio binding issues?
  57. 3 position toggle SW for a XP8103
  58. jr 7202
  59. 9303 range test with rexel ign
  60. programming Ultra Stick 120 in my 12X
  61. JR Sport RS6UL receiver
  62. Jr C4021 Servo
  63. DX7 Flap and Throttle Operation
  64. Elevon mixing LP5DSM
  65. Pigtail Connectors for 6400 Receivers?
  66. JR Radio APEX 7 conversion to 2.4GHZ
  67. 8303 range
  68. New Spektrum Radio???
  69. HELP
  70. HELP
  71. Jr 9303 throttle travel problem
  72. remove please
  73. Incredible service
  74. Firmware versions info please
  75. Spektrum DX6I Mixing
  76. Powersafe RXs and HS7950 servos
  77. Thanks JR/Spectrum
  78. 9303 and governer
  79. Older JR622 question.
  80. Can a JR9303 be converted to HAM Band?
  81. Brand new Dx5e not working?
  82. 8411sa
  83. JR Sport RS6UL receiver
  84. DSM2 vs. DSMJ
  85. AR500 DSM2 problem
  86. dx7 and ar7000
  87. JR cobra
  88. DX7 field charging
  89. Spektrum DX6i
  90. JR PCM10X AUX2
  91. Spektrum Marine Receiver > 1/4 Hitec servo???
  92. JR PCM9X11 - Screen Problem
  93. JR9303 FM failsafe programming
  94. JR X9303 gear and aileron glitch
  95. AR 6200 receiver & carbon fuse
  96. Spektrum DX3.0
  97. DSM?
  98. 9303
  99. AR500 receiver question
  100. Crashed my DX6i... Need a potentiometer
  101. JR 922 Powersafe receiver
  102. Dx3s spektrum radio antenna ?
  103. Demon in my 12X
  104. R600 receiver compatability
  105. Century VII PCM questions...
  106. Use of Air Robart Retracts with Spectrum
  107. AR7000 Lockout question
  108. Spektrum Servo Question
  109. DX7 questuons
  110. 12x-dx6i compatible for training ?
  111. X9303 and dual ELE servos
  112. 12X Throttle-rattle.
  113. Spektrum DX7
  114. FM band interfering with DX7......HELP!!
  115. 8103 "jitter" problem
  116. DX3R compatible with MR3000 Marine Rx?
  117. JR X11
  118. JR 921 2.4 broken wire
  119. 4 Digital Trims Radios
  120. Synapse elevon problem
  121. DELTA WING
  122. XS3 not coming on reversed charge
  123. Spektrum receiver AR6200 issue
  124. JR X9503 Recall
  125. Regarding the AR500 Receiver[2.4 gig ]
  126. DX7se throttle curve
  127. Spektrum 2.4GHz Module Compatability
  128. dx6i and flight simulators?
  129. Older PCM10 Dim Display
  130. 8417 servo flutter!
  131. spektrum dxs question
  132. Cap or plug for old antenna hole in tx
  133. X 9503 Programming issues
  134. Binding to DX6i
  135. jr 9303/387 FM with Blade CX2 RX
  136. 10x w/new DM9 and AR9000 problem
  137. Big lama spektrum conversion.
  138. JR A6020
  139. Binding JR12X with two 1221 and Powerbox
  140. JR transmitters with Spektrum Modules
  141. JR 9XII
  142. Spektrum AR9100 and VR6010
  143. AR7000 problem
  144. JR 9503
  145. Crazy question about my DX6i
  146. sudden increase in data log numbers
  147. XP9303 to X9303 transfer
  148. R2000 reciever Voltage
  149. x9503 and Data Transfer Software
  150. JR and Microsoft should merge
  151. 10X Help needed
  152. 8103 DM9 Module Issues
  153. Sm 1001 Spectrum module antena
  154. Is a 4.8V Rx Battery OK with a AR7000 Rx in a Hangar 9 Mini Stick?
  155. Tight Receiver Intallation
  156. I need halp programming my DX-7
  157. 6 volt rec batt for DX7
  158. Can the Matchbox handle 7.2v?
  159. jr-spektrum crashes
  160. 12x data program
  161. Voltage Rates of Older Analog Servos
  162. JR 10X with 2.4 Module?
  163. DX7 fried
  164. S200 Spektrum Servo general question
  165. 10x with Spektrum Module
  166. 10SXII
  167. Spektrum H6040 servo
  168. Reciever issues with 2.4
  169. 9503, metal chassis?
  170. Spektrum 5 channel RX
  171. Ar7000 Spektrum receivers
  172. 9503 to 9303 Can You Transfer?
  173. Setting Up a DX7 and AR7000 for full function on an Ultra Stick
  174. Spektrum Air Module with integrated Antenna(Futaba)
  175. Airtronics M8 Antenna Mod Range Issue
  176. dsm receiver
  177. dealer for JR 2,4 ghz Receiver in Chicago?
  178. spectrum voltage regulator
  179. 10 SX Manual / PDF
  180. Spektrum Module for the Hitec Aurora 9
  181. JR 9503 TX
  182. Spectrum modules for Futaba 3PK
  183. PC Data Transfer Program+Windows 7
  184. transmitter problems with my JR 9XII
  185. Setup for an AW P-51 - Help Please
  186. AR6200 Remote RX Flashing
  187. Wiring Dual Receivers
  188. AR6200 Remote Reciever
  189. RT88 Retract servo failure
  190. Frustrating 12X Problem
  191. DX5E and eflite mcx binding
  192. Can a DX7 operate non Spectrum receivers?
  193. JR XP7202 Travel Adjust
  194. JR TX -replacing flap toggle switch with adj.pot
  195. JR 2721 - Ultra-Torque MG Servo
  196. DX3.0 bind but no control?
  197. Will JR NER- 549X work with X-347?
  198. Where can I get one of those red anodised tx balancers?
  199. Transmitter Voltage
  200. Reducing the chances of a Brownout condition
  201. Data Transfer
  202. DSX9 Throttle cut on F/M's
  203. Finding mid-point on trim of spektum radio.
  204. Binding question for the 6200 series rec?
  205. For
  206. JR Matchbox
  207. DX7 Rudder input interacts with elevator trim
  208. JR-10X
  209. Dual Elevator stepping problem??
  210. JR XP6102 Transmitter
  211. aux2 switch on tx.
  212. JR XP6102 Transmitter throttle cut switch
  213. SPEKTRUM BINDING PROBLEMS
  214. DX7 heli Air TX
  215. Connecting Servos to AR91000 Receiver
  216. Flashing lights on 2 different AR500s
  217. Dx7 mixing for Electrifly VFO plane
  218. Spektrum problem/question I guess?
  219. JR R922 vs Spektrum AR9100
  220. Scared to use my Spectrum X9303...
  221. DX7 vs DX7SE response
  222. Spektrum Transmitter Cases
  223. Manual for X388s
  224. x9303 problem
  225. JR does not respond?
  226. Spektrum Transmitter twitchy on roll axis
  227. DX7 3 postion switch
  228. Spektrum Dx7
  229. JR921 vs AR9000
  230. Battery
  231. Anyone understand RF terms and is able to read RF reports ?
  232. X9303 twin engine
  233. Flyzone Cessna 182 Select Scale 47.5"
  234. DX7
  235. JR/SPEKTRUM NOT TO LATESTTECHNOLOGY??
  236. simulation with 7SE
  237. radio gremlin ?
  238. AR7600 vs AR7100 (found the answer)
  239. Carbon fiber Remote Receivers
  240. Dx6i Dual Aileron & Flaps Setup
  241. Help with JR Max computer radio
  242. Spektrum DX3S cannot change model only 6
  243. Brand New DX-7 won't turn off
  244. DSM2 vs or DSMJ
  245. 12x Buddy Box
  246. servos have ratchet action with 9303 2.4 - Help
  247. 6102 mixing problem
  248. JR PCM9X On 2.4 Can it be done
  249. most obsurd story
  250. early 1990s 6 ch coputer tx manuel
