PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Century VII owner's manual, one more time...
  2. DX7 and Cessna 210 Micro
  3. DS378 with FASST R6014 Rx
  4. JR 9X BOOT UP PROBLEM
  5. DX7SE
  6. jr 10x mode2 to mode 1
  7. Max Amp Draw Through JR 9100 Receiver
  8. 12X receiver went submarine!
  9. Has anyone done a JR stick mode conversion?
  10. Training
  11. Mode change. What about switches
  12. JR 8511 servo BIG problem
  13. what is a bettery regulator and where to buy?
  14. dsx9 programing
  15. Major unknown DX7 & DX6I Issue - Please Help
  16. Jr Unlimited 8
  17. New Spektrum dx3s and sr3300t binding issues
  18. X9303 Startup Screen Locked
  19. Correct radio system configuration
  20. Jr Synthesised frequency boot up
  21. DX6i: airplane mode electric motor cutoff
  22. dx6i problems
  23. 50cc Radio and battery setup?
  24. Help With XS3 and RS300 receiver
  25. dopped DX6i down the stairs. Faulty???
  26. New SPektrum recall fire hazard
  27. JR x9309A/G vs x9303H
  28. AR7000 LED flasing slowly
  29. 10x to 9303 JR Data Transfer program ?
  30. Spektrum AR7000 Beware!
  31. Flight log
  32. 10X to Spectrum module conversion
  33. Setting up Flaps JR 9303
  34. Jr radio Id.
  35. X9303 2.4 is it dead...
  36. Spektrum servos
  37. Spektrum range check
  38. wrapping servo wires
  39. DX7 replacement transmitter switches
  40. My R720 Synth Receiver no longer works
  41. slow and fast idle
  42. Power Output
  43. Trouble Shoot this ...
  44. 9C Spektrum Module and Smoke Mix
  45. Century 7 PCM TX receivers?
  46. EPA on 8103
  47. DX7 with MR3000 (Mode1)
  48. JR receiver for a XR2 model
  49. elevon trims for a funjet
  50. Brownouts and delinking in any other kind other tx rx system besides spektrum
  51. firewall mounted servos
  52. Spektrum dx7 lost bind today
  53. DX7 compatible receivers
  54. DX6i Screen/display fault?
  55. spektrum2
  56. DX6i and DX5e Tx Battery Charge
  57. DX-7 Throttle question
  58. Need LCD for JR XP7202/DX7
  59. New JR 11X ZERO
  60. How do I bind two models?
  61. Ar500 RX problems
  62. Another Bind Problem
  63. hope this is the right spot! Tactic 2.4GHz
  64. Buddy box set up with DX6I full range
  65. Are S-PCM Rx's Compatible with X-347 PCM?
  66. 9303 turned on in sun
  67. jr 6102 problem
  68. Spektrum Antenna for 10X
  69. JR receiver battery wiring
  70. 9303 Dual Elevator trims
  71. X9303 Binding Problem
  72. 12x data transfer to computer
  73. How to convert JVC, Canon, Panasonic Camcorder MOD video on Mac?
  74. 9303 problem
  75. Spektrum AR9100 RX question...
  76. Max Voltage on JR8511's
  77. 9303 2.4 warning alarm
  78. JR X-347 setup
  79. X9303 - Hov Pitch/Throttle for Airplane?
  80. DX6i fuse
  81. 10x heli mixing question
  82. JR X6102 (X2610)
  83. DX7 dual elev mix problem
  84. NEED HELP WITH NEW DX3S!!!!
  85. What's going on with my DX6i
  86. PCM10 with 2.4ghz module conversion
  87. ...
  88. dead ar 500
  89. ar6100 wont bind and cant figure out!!
  90. Expo????????
  91. JR 791 low profile servo issue
  92. spektrum module fo fut 10c
  93. DX3S and DSM2
  94. DX7 flaperons
  95. PCM 9XII (9303?) Screen Problem
  96. 8103 mixing problem
  97. spectrum dx7 trouble
  98. x9303 settup
  99. Dx3.0 (reverse full throttle!)
  100. DX7 Programming flaps & ailerons
  101. PCM SXII voltmeter woes
  102. E-flite LP5DSM Parkzone Binding
  103. 9303 mix question
  104. 2.4 5 & 6 ch rx
  105. HOW DO I USE MY RX?
  106. Spektrum DX5e 5-channel 2.4GHz DSM2
  107. 12x satellite receiver location
  108. Programming 9X for biplane
  109. DX3S question
  110. R700 receiver with A123 Batteries
  111. DX7SE Left Stick spring
  112. help needed with jr10x
  113. Spektrum MZ Module Compatibility
  114. DX6i Trim
  115. JR 9303 canot change travel on retract
  116. M11 with Spektrum issues
  117. Communication from Horizon, JR ???
  118. JR 6102 Problem (NEED HELP)
  119. Exploded View DX6i
  120. XRSi problems
  121. Aux trim problem
  122. Help with JR X9303
  123. 10X lipo upgrade
  124. 10X lipo upgrade
  125. Minimum Specktrum Radio for Buddy Box
  126. How many days for recall shipping label to arrive ?
  127. will the dx6i fit in this case?
  128. WHICH BATTERY CAN I USE?
  129. RADIO TX ANTENNA
  130. Hissing X9303 2.4
  131. DSM2 technology
  132. AR7000 Receiver....
  133. dx3.0 bake on rutler
  134. JR PC Data Transfer software
  135. DX6i Reset Question
  136. Dx7 throttle kill switch
  137. JR ST126MG Servo Question
  138. Remote Receiver's
  139. Help with DX7 to slave twin ESCs using Throttle channel & other channel?
  140. AR7212 - Fly a glider with up to 12 servos using your DX7
  141. Help! Link up probs and blinking after landing!
  142. DX7 Throttle stick
  143. 9303 mix questions
  144. DX6 Throttle Problem - Often won't go to 0
  145. JR 9303 to synthesized module?
  146. 7202 freezes when selecting model 1 from model 2 or 20
  147. 9303 switch question
  148. 9303 Help!!!!!!!!!!!!!!
  149. DX7 F Mode Warning
  150. Jr 12x VS 9303
  151. How to get Spektrum DX6 to output negative shift PPM
  152. XS3 PRO question
  153. JR R790 UL receiver
  154. JR1222 with A123, which batt is bad?
  155. 10X to 9303 transfer
  156. Spektrum / Horizon Customer Service kudos!
  157. Using DX6i as a trainer 'slave' ?
  158. How the heck do you get the DSX9 to Bind?????
  159. Dead Receiver
  160. System Voltage for 2.4
  161. JR 9303 throttle-glow driver mix ????
  162. DSM-2 Receiver's - R921 or AR9000 ?
  163. TX on Lipoly?
  164. DSX12 - Twine Engine, MATE, Dual Menu Not Accessible at Wingtype
  165. dx7 help
  166. 650 M servo
  167. DX-7 Spectrum Radio - Trim Switches
  168. XP8103....Help!
  169. JR MAX 6 MANUAL?
  170. Spektrum 6100 and ESC with no bec.
  171. JR 9303 Smoke system help.
  172. encoder type
  173. Spektrum Operation
  174. DX7 RF Deck Replaced Twice...Why?
  175. Spektrum AR7000 locked out
  176. throttle cut for slaved channel on a twin
  177. JR changing 2.4 RF link to freq. hopping?
  178. JR RADIOS NOT AVAILABLE IN THE STATES
  179. DX7 Ailerons travel adjust
  180. 2.4 antena wiring
  181. How to set throws in the transmitter's program?
  182. Any plans for a Spektrum 4channel pistol radio?
  183. Spektrum Module stops transmitting for 1 second
  184. AR 7000 Receiver....blinks once
  185. JR 8611A and 2 cell Li Ion
  186. JR 12X Software
  187. Failsafe for JR9303
  188. Tx low voltage warning?
  189. JR 12X 2.4GHZ
  190. Spektrum 9100 up in smoke.......
  191. Sectrum glithing on engine start up!
  192. DX7 to DX7 master/slave trainer help
  193. FUTABA SERVO IN JR RECEIVER
  194. older datasafe v2 compatibility with 9303 ?
  195. AR9000 - No Fades - Many Holds
  196. what to turn on first?
  197. ar 7000 reciver
  198. Hyperion Atlas Programmable Digital Servos DS 20 Series
  199. DX7 Crash
  200. Need help with programming flaps on DX7
  201. DX7 & shadowing
  202. TX/RV COMBO'S
  203. 10X and four aileron servos
  204. 9303 & 120 ccpm channel assignments ?
  205. DX9 and DX7 AR7000 Rx
  206. Dx 7 with 2 battery packs-which way ?
  207. JR PCM 10 Manual
  208. DX7 & rudder dual rates
  209. Spektrum dx7 two batterys
  210. DX6i : Servo center changes when rate switch flipped
  211. Add nitro telemetry to a DX6i?
  212. 9303 binding issues?
  213. JR Servos on 6volts???
  214. dx3.0
  215. Spektrum Problems and Questions....
  216. AR 500 Loss of SignalCrash-Spektrum response requested
  217. 8103 Throttle Curve
  218. R7000 Receiver Battery
  219. MatchMaker neutral and Radio neutral don't match
  220. DX7 Gear Switch Replacement ?
  221. Spektrum Warranty Service Stinks
  222. Futaba Spektrum Module Servo Chatter/Movement
  223. What problem with servos?
  224. 12X diagnosis needed
  225. JR 12X - Trainer Assignment
  226. Spektrum DX7\Futaba S9252 Servo Flutter
  227. transmitter ?
  228. need specs on a ds361 servo
  229. Spectrum DX7 Power Failure
  230. JR MatchBox with a JR R922 receiver?
  231. DX6i Aileron Stick Loose?
  232. 9303 - split elevator- trim function?
  233. 12x sailplane setup
  234. Stick tension adjustable on DX5e?
  235. AR6000 long time to boot with dx6i
  236. DX7 transmitter is buzzing
  237. JR xp8103/ 3810 spare parts?
  238. 9303 Delta Elevon Setup Hassle
  239. JR/Spektrum firmware updates for QuickConnect?
  240. X9303 Slider Switch Assignments?
  241. JR 10X - How do I assign elevator DR switch to also actuate elevator DR?
  242. Corona 2.4 conversion tx mods & rx
  243. split evevators
  244. Training Cable
  245. Possibly moving from 9C to 9303
  246. 12x throttle throw?
  247. DX7 and electronic kill switch
  248. 9303 Coversion to 2.4
  249. JR pinout
  250. AR6200 question
