PDA
View Full Version : JR Radio & Spektrum Radios
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. dx5i on more than one plane
  2. DSX9 and failsafe
  3. aileron to rudder- how to assign a switch?
  4. Spektrum frustration
  5. 3 Servos on same channel?
  6. Spectrum DX7 Odd Behavior.
  7. 9303 2.4
  8. DX3.0 E-maxx help!?!?
  9. Strange Radio and Receiver behavior
  10. Spectrum model - re-trim
  11. Servo for G460T Gyro on Rudder
  12. JR 10X Batt Voltage readout fluctuates....
  13. setup crow on the JR 10X ???
  14. 4 Aileron Servos on 9303
  15. JR9303 Synthesized Channel Instructions Needed!
  16. 8411 and 8411sa compatible gears ?
  17. Aerial wire from Spektrum module
  18. JR 12X break system. Help please.
  19. Jr Going 2.4 GHz what is the
  20. JR 2.4GHz Equipment
  21. Dx-7 Tx and AR6250 glitch, 2.4GHz
  22. DX5E charging with a DX6i charger??
  23. SR3100 DSM2 receiver Voltage
  24. DX6i Question
  25. JR/Spektrum Module
  26. How to reset my dx7
  27. AR9300 rx , no satelites available yet
  28. Dual 2.4s
  29. Ds 8711 Voltage??
  30. Why is this forum here
  31. Dumb Question: Throttle Stick
  32. Spektrum DX7
  33. AR9000 Firmware or Hardware Bug?
  34. Spectrum Receiver 7000 question
  35. Trimming elevators on DX7
  36. Uneven travel in elevators
  37. Spektrum Tx/Rx problems
  38. My DX7 fail when I choose "Model 2" Help please
  39. Dual elevator setup spectrum radio
  40. 9303 Help please !
  41. does anyone know if this module will fit my 9303
  42. JRXF 421
  43. JR Sport digital servos good enough to operate 91 FX pattern ship?
  44. Futaba Spektrum Module
  45. AR9000 and PowerBox 40-24 Binding issue
  46. DX7 heli
  47. DX6i help
  48. X9303-2.4 Limited range 350'
  49. Throttle Curve Setup
  50. 9309selectscan transmitter Swich assignments
  51. Brown out with DX 7 - is it fixed?
  52. Spectrum AR 6000 RX problem help please
  53. JR 347 issue
  54. JR 9303 2.4 New Release??
  55. Dsx9 /9303 flap settings
  56. X9303 AILERON GIMBAL WIRE CHAFING MODIFICATION????
  57. dx7/ ar6100 binding issue
  58. Want to know more on the GUID
  59. JR DSX9 Programming
  60. 12X and long gimble stick ends
  61. HELP!!! Split Elevators on AR6100?
  62. JR 12X and JR 12X MV incompatible for data transfer?
  63. 9303 Missing Features
  64. DX7 settings templates for Microsoft Excel
  65. two batteries in JR 2.4 different sizes
  66. DSX9 will not store any new settings after fuse blew.
  67. JR 9303 gimbles
  68. Battery Killed 2 new AR500. Please Help
  69. Couple of X9303 Questions
  70. Help..Speck. 7 ch 2.4
  71. JR 9303 convert to 2.4
  72. Where is 12X Discussion
  73. AR 7000 receiver dead???
  74. JR 610UL Crystal ?
  75. 10X Retract Travel
  76. Abbreviation Definitions for new users
  77. AR9000's Won't Bind with 9303/2.4
  78. dx6
  79. X9303 fuse Keeps Blowing
  80. jr 1000 gyro
  81. Does the sr3300t and the sr300 work with the dx3.0
  82. JR 9303 ???
  83. JR to Spektrum
  84. Screen freak out- JR6102
  85. New to the 21X
  86. Additional Remote Receiver flashing
  87. a perplexing problem
  88. SX600 Battery upgrade
  89. JR 9xII
  90. Spektrum module rattles around
  91. RS600
  92. S791 amp draw?
  93. DX7 Throttle-elevator mix?
  94. JR DSX9 2.4 & TME Smart Smoker
  95. Tx Antenna cut while in flight : HF module damaged ?
  96. XP 7202 (DX7) corrupted model?
  97. spektrum buddy box
  98. DSX9 crow settings in ACRO ....Help Please!
  99. bvm f-86 flihgt log
  100. X9393 2.4 Throttle cut question
  101. Spectrum DX7 Special Edition
  102. JR 537
  103. 9303 -How to activate gear with flight mode
  104. 9303-2.4 question.
  105. 9303 spektrum setup for Great Planes Chipmunk
  106. Sequencing gear doors with 9303.
  107. JR 9303 QUESTION
  108. How to program the DX-7
  109. someone else's airplane
  110. DX7 auto shutoff
  111. 783 Programming For V-Tail
  112. XP6102 Modulation Problem
  113. JR 10X Newbie Question re using levers
  114. AR9100 uneven battery use
  115. 9303 E. throttle that
  116. Problem with DM8 Spektrum Module and Futaba 9C
  117. AR 7000 Flashing
  118. Duratrax stock ESC and SR3100 incompatibility issues
  119. Spektrum antenna wire
  120. DX6I Lipo Mod Complete - need small lipo batt
  121. DX6i RTF default programs
  122. Transferring model from dx6i to 9303
  123. DX5e rx Problem
  124. Unidentified Spektrum parts
  125. slaving 2 brushless motor setup to aux 2 via mix?
  126. XP9303
  127. Spektrum Buddy Box
  128. 10x throttle problem
  129. Mounting AR6100 Receiver
  130. hmmmmmm why does this happen :o
  131. Update PCM9x DSX10 when?
  132. aileron setup on diferent channels with DX7 im confused :{ please help
  133. DX7/AR6300 and cheap digital servo interference?
  134. What Lipo for DX6i
  135. 42% Products DX7 Super Cap
  136. DX6i dual receiver binding
  137. DX6i Specktrum
  138. ONEWASP-A STREIGHT SHOOTER
  139. Spoilers on a 9XII
  140. JR7207 mode change
  141. DX7..how to use AUX2 as 2nd elevator
  142. XP9303 AUX2 Problem!!
  143. x-3810 flap switch
  144. jr xp642 dead no response
  145. Setting up TH on a X9303?
  146. Jr Receiver r790ul
  147. Product Recall: Spektrum DX6i Transmitters
  148. JR10DX
  149. 2.4ghz module dilema
  150. jR 10 X - looking for easy programming tips, links
  151. JR 6102
  152. Glitching servo on spektrum RX and tamiya ESC + DX3S
  153. Smoked SR3300T receiver expert electronics engineer required
  154. AR7000 Receiver lost its bind to Tx
  155. Need to get a push button snap roll switch off 9303 Aero
  156. using a Y harness to control split flaps
  157. Binding Problem
  158. Difference between X9303 Heli and Air?
  159. AR500 Quickconnect
  160. Spektrum 9100 RX question
  161. X9303 9Ch Rcvr and Servo Travel
  162. comparing the dx7 vs the dx6i
  163. Spektrum DX3R and Redcat Lightning EXP Pro
  164. twin engine trims
  165. Backlit LCD on the JR X9303 2.4?
  166. Horizon/Spektrum Awesome Service
  167. JR 9303 2.4 Question
  168. JR Spektrum 2.4 conversion "Module"
  169. Dual elevator mixing
  170. Spektrum DM8 (futaba) module with XPS antenna
  171. DX6I fail safes
  172. JR 10x
  173. Gear Travel Adjustment
  174. dx-6i binding
  175. AR 6200 Rx Installation questions
  176. Saw 2 planes go in today-Spectrum
  177. voltage drop in spectrum rx
  178. JR 12X Stunt Trim
  179. Spektrum DX6i Stick Pot Service Bulletin
  180. DX6i Dual Rate
  181. Left Stick Centering (Throttle) ?
  182. JR X9303 2.4GHz questions?
  183. DX-7 throttle curve program
  184. Spektrum DX6i charger plug problem.
  185. Spectrum aux2 help
  186. DX7 & AUX 2 channel
  187. Charging my DX6i with supplied charger...help
  188. 4.8V or 6V Rx Battery for my Spektrum radio system???
  189. JR 9303 question
  190. 9303 Broken Rolling Selector
  191. DX6I - Direct fast charge rate
  192. Dx7 wierd problem
  193. spectrum regulator in DX7
  194. Current draw 8611's
  195. 5-cell NiMh charger?
  196. Transmitter Battery
  197. Dual aileron programming 10X
  198. dx7 and ultra stick
  199. JR, HITEC, OR FUTABA SERVOS
  200. JR 3810 Tx Battery
  201. Spektrum range checking - DX7 / AR7000
  202. SPEKTRUM 2.4 ANTENNA ORIENTATION
  203. 9303 Dual Elevator Issue
  204. JR Vs Spektrum Receivers
  205. DX6i TX Minimum voltage help
  206. 9303 DSM 2 failsafe on gear channel
  207. R921 Data port
  208. Help binding DX6
  209. DX7 - Rx Info Needed
  210. 9303 2.4 - throttle cut
  211. Voltage and RS600 receiver
  212. DX6I AND AR500/AR6200 VOLTAGE
  213. Servo noise
  214. Differential steering with X9303
  215. What does the Rt. lever do on XP9303
  216. JR 9303 2.4 and ailerons move when rate switch moved?
  217. JR 12X
  218. Which spectrum reciever?
  219. Spektrum Connectors
  220. Dual Battery Setup ?
  221. DX7 Lose of sound
  222. Is this forum supported by Horizon
  223. JR DS-8411 servo voltage
  224. BUG in the DX6i software ?
  225. 9303 with adapter controls wrong model
  226. R790 SCAN SELECT
  227. DX6i and buddy box
  228. JR 12x Throttle Ratchet
  229. Spextrum 5e for boats
  230. 10 x dramas
  231. JR Servos issue
  232. quad flaps and JR9303 2.4
  233. spektrum 7000 large led blinking
  234. JR R790UL rx
  235. JR 12X For Supra Sail Plane set up
  236. spectrum AR6200 heli copatible?
  237. spektrum 7 and the ar9000
  238. Jr DSX9 Stuck
  239. JR X9303 model memory change procedure
  240. JR 9303
  241. JR 7202 settings
  242. JR Tx Battery charging outside of box with Triton 2
  243. X9303 antena wire damage!!!!!!!!!
  244. 8103 and spektrum module
  245. 8103 Trainer problem
  246. Spektrum DX6i problem - losing settings
  247. 8611 servos
  248. 8103 subtrim resolution
  249. DX6i, JR G500T, T-REX450
  250. Buddy box
