PDA
View Full Version : JR Radio & Spektrum Radios
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. JR Century VII
  2. iX12 and DX18 Compatibility Mode
  3. AR9020X servo problem/DX8
  4. DX20 Unavailable
  5. DX6iCapabilities
  6. High-channel count receiver shopping
  7. Sektrum IX12 Flaps as Spoillers
  8. Spmar410 - on board capacitor
  9. Spektrum DX8 Reverse Polarity
  10. spectrum AR9020 Receiver
  11. DX20 Model Import Error
  12. DX6i info
  13. Dx8-1
  14. JR 12X flap sys question
  15. spectrum 12120 power safe receiver
  16. Switching j r crystals
  17. What's Up With the AS3X Phone Program?
  18. DX8e
  19. Need Current sensor telemetry - 100 amp
  20. DMSS Altitude Sensor
  21. HELP Manual JR RG812BX Receiver
  22. 28X Lost setup
  23. DX18 no movement
  24. Need a JR X-347 manual
  25. JR XG14 replacement battery LiFe 6.4V 1400mah
  26. How to program a Throttle mix that will retract flaps
  27. How to charge a JR Colt battery outside the transmitter?
  28. Size of the power plug that fits in Spektrum DX8
  29. Spektrum iX20 or upgrade to DX20 in works?
  30. JR 28X screen unresponsive to touch
  31. JR XG11 Programming for Retract and Gear doors
  32. Spektrum new AR620 Reciever
  33. Binding the new AR620 receiver help
  34. Binding the new AR620 receiver help
  35. Driving me insane. Scimitar by eflite
  36. Charging dx8 1 gen correctly
  37. Model Transfer to DX20
  38. Trims not working in Slave mode on DX9
  39. Getting feet wet after years being out...which spectrum to get?
  40. DX9 - Moving Throttle to Right Lever
  41. JR PC data transfer software for 12X
  42. DeeForce Aviation
  43. Caveman Question
  44. Buddy boxing DX8 Gen 1 with 12x?
  45. DX18 binding problems
  46. AVC stopped working DX4S
  47. DX9 with AR9030T Programming Help 2-Aileron, 2 Flap, Retracts
  48. Dx9 fades
  49. RG812BPX MODE/SENS slot
  50. AR9350 Stabilization Settings
  51. DX18 G2 hardware fault (intermittent)
  52. DX8 loost switches
  53. Spectrum 9030T
  54. SAFE Rx setup questions/concerns
  55. Radian XL Beeping
  56. JR Americas Service center- Fast turnaround!
  57. XG11 Giving me Fits
  58. use of 2 DXes
  59. AR9350 Programming
  60. JR products history to date
  61. JR 9503 Radio
  62. 4 aleron service option on 12x
  63. DX7 with 2 ESC's for zero turn
  64. Spektrum Dx4e Motor No throttle ESC
  65. DX 18 G2 range issue
  66. Where`s aux1 on my XG14?
  67. JR xf421ex screen issue
  68. DX8G2 4 aileron servos
  69. Future of JR
  70. AS3X Binding Issues
  71. Flaps on DX8 Gen 2
  72. JR 12x Gimbal
  73. DX8 with AR400
  74. Combining slave and throttle ESC leads into EC3 connector?
  75. New Spektrum iX12 Transmitter
  76. Flap problem with the Jr 9303
  77. program aux1
  78. Dx8 gen 1
  79. Who has been running the Beta Firmware:
  80. Confused with Spektrum DX8G2
  81. Spektrum Satellite JST Connectors
  82. DX 6 Carbon Z T 28 questions.
  83. HD servo wire
  84. 8010t, dx8G2 and dual elevators
  85. dx8 change from mode 2 to 3
  86. DX6i charger can I used something else
  87. AR8010T, Ultra IBEC, DLE Igniiton, RPM telemetry problem
  88. Installing a Spektrum DX6
  89. The Future of the 28X
  90. DX9/AR9020 system issue?
  91. Spektrum DX6i dropping bound transmitters?
  92. dx7(heli) older version
  93. Two Idle settings with DX9 Throttle Curve
  94. DX7 (heli) DSM2 - Memory Lock
  95. DX6 vs DX6e
  96. servo gear sets
  97. Spectrum Transmitters
  98. Frame Rate
  99. DX-9 - Increase Elevator For Landing
  100. JR XP9303 need to add LED light
  101. Spectrum dx7-s
  102. JR Transmitter Batterie Packs
  103. ? Any Way to Change Voice Personality or Speed? DX18
  104. Spektrum DX8 gimbals
  105. XG8 programming
  106. Have I screwed something up?
  107. CROW to jet plane in a JR 12X
  108. JR 11 X charging
  109. DX9 Timer Button
  110. I bought a DX6.............
  111. JR RG1131B receiver
  112. DX18 Gen1 telemetry question
  113. Flight Mode and Control Surface Range - DX8
  114. Spektrum DX8 mode change problems
  115. transmitter or receiver problems
  116. Spektrum ar6210
  117. Programming crow on DX18
  118. Programing the E-flite Convergence VTOL
  119. DX-9 Quality
  120. 9503 battery question
  121. DX6i controls swap
  122. JR Kill Switch ?
  123. 28X aux channel trim switch select
  124. as3x receiver program wing type flap issue
  125. I'm to GD stupid to set up dual effing rates
  126. Are AR636 receivers gyro function easily damaged?
  127. Programming Xbus for 28x and xb1-cv4
  128. Spektrum DX9 Telemetry Possible Report Error?
  129. DMSS And Matchbox
  130. Re-program JR 3810 TX
  131. Igyro on my DX 18 HELP.?
  132. Left aileron Control
  133. Spektrum DX18 variable mix
  134. Spektrum dx18 gen 2 interference???
  135. binding dual receivers in airplane...
  136. AR8010T antenna placement
  137. Must be old news but what' going on with JR?
  138. DX 7 Throttle Cut/kill
  139. More than one Spektrum receiver in the same plane
  140. Another 9303 Question
  141. specktru transmiter DX 10 t
  142. 9303 and 921 Question
  143. Spektrum Telemetry System for Mystique 2.9 ARF
  144. Can you "lock" a switch?
  145. DX6 Display Issue?
  146. Programing DX8 G2 dual ail, single flap and gear
  147. Spektrum 7s Endpoint Tuning
  148. DX& Flaps Programming
  149. Guro trouble can't shut it off
  150. AR636 Iphone programming issues
  151. AR636 Driving me mad!
  152. Program dx18 to select inductix flight mode
  153. 72MHz to 2.4G conversion
  154. Spectrum receiver not sending signal to servo...
  155. Spektrum Powersafe Receivers Recalled
  156. Buyer beware NEW SPEKTRUM AR8010T RX
  157. Spektrum dx8 registration
  158. dx7s dual aileron + differential thrust
  159. Xbus Explained New video
  160. Import model, DX8 not seeing it.
  161. Spectrum DX9 and altitude warnings
  162. Not sure on JR/Spektrum compatibility
  163. Programing Crow
  164. DX6 Park Flyer radio question
  165. Newbie help JR XG11
  166. JR 12X Nightmare Programming: Looking for alternative
  167. Horizon or JR America's
  168. DS8411 and DS8911
  169. Alpha 6 Heading Gain -- Anomaly Or PE?
  170. Elevons WITH Ailerons...
  171. JR 28X twin engines trim
  172. Spektrum AirWare Updates
  173. Spektrum Dx5e binding issue w/ Syma X5C quad
  174. How to setup DX8 with AR8000to control Power MULTI light 7-3030
  175. The AR8000 DSM2 & DSMX Receivers do not flash when power is supplied via batt & ESC
  176. Low signal voltage receiver
  177. Spektrum DX9 Blank Screen
  178. New DX6e compatibility
  179. JR servo load alarm system using Xbus
  180. Serial number for the AS3X receivers?
  181. No throttle control DX6i with PZ Ember 2, Sukhoi 26m or Nano QX
  182. Electric model settings
  183. No response from Spektrum
  184. 2 throttle curves - Spektrum DX9 - using switch ??? possible?
  185. Will the DX3 Bind with a Blue Max SR3100 DSM2 receiver
  186. Telementry sound problem
  187. 9303 Battery
  188. TM1000 voltage limits?
  189. Electric brakes on down elevator
  190. Programming crow with X Bus recievers
  191. JR VSpeak
  192. XG 11 low voltage
  193. How to bind DX9 and DXe wirelessly?
  194. What happemns if satellite RX gets disconnected?
  195. n00b spektrum & roboteq controller question
  196. Spektrum SPMA9605 flight pack capacity sensor
  197. How to open the case of the AR400??
  198. Dx8 g2
  199. Spectrum AR9350, DX18G2, Castle ESC and Castle Link telemetry
  200. DX18 Gen 2 countdown timer
  201. More Spektrum AR9350 Ques.
  202. JR NES 4031 on 6 volts?
  203. New Spektrum DX7 & Hobby King R615X receiver
  204. Alpha 6 Woes
  205. New DX 20 verse DX18
  206. J.r.28x
  207. JR XG 11 Programming Challenge!
  208. JR 2721 acting up
  209. Spektrum AR-7000 and First GEN Spektrum DX7
  210. DX18 Mixing question
  211. Audio jack
  212. Satellite placement question
  213. Binding power safe AR12120 to DX18
  214. issues with 12X and rudder ch .
  215. powersafe ar12120
  216. Spektrum 9 CH not working
  217. Telemetry Altitude and Speed
  218. Jr xg14
  219. DX 18 System Set Up - Questions
  220. Bind the Spektrum AR7610 rx to the JR X9303 tx
  221. DX8 to DX8G2 transfer
  222. DX8 / telemetry / VARIO
  223. Strange telemtetry message from TM1000 and DX9
  224. JR/Graupner MX22 teacher/student pairing
  225. JR12X Transmitter replacement battery
  226. binding new receiver
  227. XG11 - Dead Battery
  228. dx7 question/spektrum rx
  229. Tx problem
  230. JR XG14 Programing help
  231. XG11 - how to bind 2 RX on 1 model?
  232. 7610 DSM 7 channel receiver
  233. JR DSM Air Module 9 channel
  234. Broken TX Stick DX6
  235. Spektrum Receivers - Real or Fake
  236. AR 9020 Pin Out Diagram
  237. Was it the battery?
  238. spectrum ar636 not responding to dual rates/flight modes
  239. jR 12x Single Switch for dual rates?
  240. JR Dmss Transmitter Module
  241. mixing issues dx6 black ail. to rud, using air. stick
  242. Air v Surface receivers
  243. New Dx6 question
  244. dx6 black updates all went well but wont bind
  245. Spektrum My Spektrum updates
  246. 28x transmitter voltage
  247. "The Beast" 60e Programming "Break" or "Crow" using DX18 and AR9050 receiver.
  248. Spektrum Satellite Antenna Placement In Composite Airframe
  249. How to program the rcexl opto gas engine kill switch on the new DX6...
  250. Issue with Failsafe Dx7 and the AR7000 Reciever
