PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. Which Trainer kit ?
  2. Restoration Project: UltraSport 40
  3. Goldberg Piper Cub Anniversary Kit
  4. Clear coat
  5. Royal Spitfire fuselage tracing needed
  6. Instruction book for Sig Ultimate Fun Fly?
  7. Which 1/5th P-51D Kit?
  8. Great Planes RV-4 Build
  9. Kadet Senior Color Scheme - Opinions!
  10. Help with ID ...
  11. Dumb question?
  12. what engine for spacewalker2
  13. Best bipe kit for ST 90 2 stroke
  14. Thinning Balsarite for film
  15. Plating aluminum
  16. Anyone ever build a House of Balsa P-51 .29-.40 kit? Older one no longer made
  17. mystery plane
  18. want to buy a kit airplane to build
  19. Advice on choosing 120 size kit
  20. Nylon Wing Bolts
  21. Heat shrink Fabric
  22. Byron Originals Cap 21 Build
  23. Winter Project .60 Plane?
  24. Lanier Shrike .10 Building Manual
  25. Band Saw or Scroll saw
  26. GTM D6
  27. Sig Four Star 40 Question
  28. Du Bro hinges and servo sugestions.
  29. What Kit is this??
  30. Ultra Sport 60 is on Limited Quantities
  31. Balsa USA Phaeton question
  32. Are these two fiber glasses the same thing weave and strength wise?
  33. NEED HELP??
  34. Sig Four Star 120 (now w/ flight report)
  35. Dog House Extreme
  36. Mounting a 4 stroke inverted
  37. High wing trainer type airframes for a...
  38. Build thread for a Carl Goldberg Eagle II Trainer??
  39. super chipmunk Help
  40. What paint/clear coat can I use on foam board? Starting to build a Mud Duck!
  41. Top Flight Contender - electric conversion
  42. Structural Question
  43. Painting fabric
  44. Which 60 to 1.20 Size Extra 300 Kit or ARF do you prefer ?
  45. First Kit?
  46. Building an L4 Grasshopper
  47. Tower Hobbies 40 engine mounting ???
  48. Balsa USA Citabria Pro
  49. Kadet Senior Bash Pictures
  50. How much did it cost you to get a kit cut??
  51. Good kit for .61 four-stroke
  52. Wing incidence
  53. Good kit for 400 to 480 motor
  54. DAVE BROWN PRODUCTS.
  55. dealing with static when applying microlite film
  56. Phaeton 90 with DLE 30 gasser ?
  57. Goldberg super chipmunk 60 any experience with this kit?
  58. What's on your building table or next in line?
  59. Plans for Scratchbuilding
  60. Stearman Kit Wanted
  61. Question About Selling a Built Kit
  62. GP p51 build/retracts
  63. Hi,
  64. Top Flite DC-3 Kit, What engines?
  65. Larger engine on a Hog Bipe
  66. Finishing ABS cowls
  67. EPP Profilm covering question.
  68. Your favorite part of building
  69. Dynaflite 81" spitfire tracings needed
  70. DB Scale Tiger Moth 48" span
  71. Upgrade Scroll Saw
  72. GP .60 Extra 300S Kit help
  73. Arf Review in the Kit Build Forum?
  74. Magnetic Building board sheet gauge
  75. Raven pattern scheme
  76. Building Surface
  77. Looking for a Piper Cub KIT
  78. Twin cylinder in a J3 cub.
  79. Competition
  80. PICA MANUAL
  81. Maco models?
  82. Pica Waco Builders Manual
  83. Looking for recommendations for an entry-level twin aircraft kit
  84. Hinnant F5
  85. GP Super Skybolt engine?
  86. Simcoa/ Simcoe kits?
  87. bud nosen jenny
  88. Ace T 34 Sport kit
  89. Has anybody built this plane
  90. Wing Load Calculator
  91. BalsaUSA eaa 1/4 scale bipe "?"
  92. Remembering Carl Goldberg Models "The Legends of Carl GOldberg"
  93. which pup kit?
  94. Trainer kit build threads
  95. Royal Midi Corsair
  96. Hog bipe maiden today
  97. dnyaflite super decathlon
  98. l4 grasshopper build
  99. Midwest Citabria and a G20
  100. portly kadet seniors
  101. Wanted: Kit Builder for Royal / Murataka Kit
  102. Aileron / flap proportions? (Euro Firebird)
  103. Flair Puppeteer Build
  104. NO MORE NEED FOR REDUCTION DRIVES
  105. WW1 Albatross kits? plans?
  106. goldberg ultimate cg and flight quirks
  107. PLAN MIS-MATCH HELP!!
  108. What's up with Sig and Tower Hobbies?
  109. What servo would you use?
  110. Snaped my retracts
  111. GP RV-4 - How did you mount your receiver and battery?
  112. GP CAP Tail Wheel Assembly
  113. What should I build this winter?
  114. Euro Firebird Turbine Trainer - Help!!!
  115. ProCraft Models Pro Line models kits??
  116. Great Planes Corsair .40 size
  117. old astro hog question
  118. Balance error - second try with pencils
  119. Hatch Help
  120. Somethin Extra motor mount
  121. Balsa USA Phaeton 90 wing kits wanted
  122. Eindecker 90 or Cub
  123. Sig Somethin Extra tailwheel
  124. Balsa USA 75" Mustang Kit
  125. Balance error before maiden?
  126. SIG Kadet Senior Kit Ailerons
  127. great planes BLT plans and motor question
  128. Please help identify this plane
  129. I’m considering building a big trainer
  130. Calypso mk3 aviomodelli
  131. AMR Eclipse50 low wing sport
  132. balsa usa EAA bipe 60 inch wing span
  133. any advice before maiden flight?
  134. Defthane Interior/Exterior oil based polyurethane
  135. fixed gear on warbirds
  136. sealing balsa before final sanding
  137. Adhesive Question
  138. Gas Engine Recommendation
  139. Avonds F-14 build
  140. HELP!!! Anywhere to get BYRON parts???
  141. Dupli-Color Chrome paint is not fuel proof
  142. FOUND THANKS PICA KIT Rapier II instructions
  143. Need some expert opinions please.
  144. Make your own Plastic Parts
  145. My Great Planes PT-60 came out tail heavy
  146. Anyone ever build the Balsa USA P-51?
  147. Wanted: flying styro panda kit
  148. B-24 Build
  149. CG Super Chipmunk & OS 70 Surpass
  150. Robart Retracts HELP Please
  151. Lustrekote on epoxy
  152. Der Jager 1/3 scale
  153. Kit building table?
  154. Would you clear coat - what would you use.
  155. Source for lead weight
  156. Herr Piper Cherokee or Cessna 180 built as electric?
  157. how to soften rubber wheels - due bro 2.25
  158. Tower discontinued Four Star kits ?!?
  159. Need help with wing.
  160. SIG stixit =dope?
  161. Byron Corsair Main Wheels
  162. Retracts question for GP UltraSport Plus
  163. Can't view old Giant Aeromaster thread
  164. Using covering for hinge's instead of tape
  165. Show us your workshop!!
  166. GP Extra 300 kits discontinued?
  167. next plane
  168. Sig King Kobra
  169. Tinmans' 4*60 build has begun... 1st build!!!
  170. 1903 Wright Flyer
  171. Creating Flaps?
  172. Airbrushing
  173. filling weave in fabric
  174. Ziroli plans ?
  175. Canopy Tinting
  176. Does anybody have the Great Planes Ultimate 40 with Saito 72 in it?
  177. Sig 1/4 scale Cub
  178. How Strong are Zap products?
  179. Wendell Hostetler's 26% Cessna 182
  180. Offer: 3GS Iphone (32Gb) HTC MAX 4G New Unlocked @ affordable Prize!!! Buy Now !!!
  181. Traplet 72in Bucker Jungmann
  182. BUSA Phaeton 90 build questions
  183. dope tissue and paint
  184. GP P51 Mustang retracts
  185. BTE Venture 60 landing gear/ wheel pants, where can I buy them?
  186. Falcon 56 MkII Build
  187. Working with 21st century fabric
  188. Builder Needed Houston Texas
  189. Dynaflight PT-19
  190. Open Cockpit Cowl Installation - Need Help
  191. GP Extra 300S - Questions
  192. proper diil bit
  193. Ikon GB mod Y engine recommendation
  194. COSMOS MODELS 1/4 PIPER CUP (revoluationary building technique )
  195. Giant Stinger...thoughts on finishing the kit
  196. Which would you rather build on?
  197. Well done SIG
  198. Looking for a .09 plane kit or arf
  199. Kit Collector Price Guide
  200. Great Planes Pete-n-Poke kit
  201. Problem with a Kit I just purchased
  202. LOOKING FOR STIK KIT
  203. Yep, another beginner build question...
  204. Topflite olive drab monokote color difference (SOLVED)
  205. R.I.P. Super Skybolt Kit
  206. Help Required minicraft javelin
  207. SIG: Hog Bipe vs. Smith Miniplane
  208. Sig & Tower
  209. Pull Pull Rudder and Tailwheel on TF P-47
  210. lead plates in battery removal
  211. Sig Kavalier Build
  212. Dare fokker DR1
  213. Help!!!! 25% Edge 540
  214. Carl Goldberg: Super Chipmunk
  215. Hog Bipe Should I Lighten Control Surfaces?
  216. Building the Extra 300s [pictures]
  217. Page Aviation 1/5th scale Gee Bee Z
  218. Polyurethane?
  219. CG Extra 300 - Where?
  220. Don't feel like a newbie anymore
  221. Goldberg Ultimate Build 60 size by twn
  222. Newbie checking in
  223. polyurathane & polycrilic
  224. Thanks for all the SSE help II
  225. coverite
  226. Byron 51 Build Thread
  227. Cowl Cutting Advice
  228. Looking at building a 60 sized plane but which one?
  229. Falcon 56
  230. Teach me how to sheet a wing with Alaphatic resin.
  231. Painting Ultrakote
  232. Engine for Unionville 6' Beaver
  233. Super Customer Support from Sig
  234. smoke system questions
  235. Carl Goldberg Finesse
  236. Need a lazer cutting service
  237. I need a source for machine screws.
  238. help covering cub
  239. Top Flite P-47 Giant Scale Mechanical Retracts?
  240. 4-stroke eng. for cgb cub
  241. CESSNA 120
  242. dynaflite super decathlon
  243. Most accurate way to transfer parts image?
  244. Ikon N west Stinson
  245. flat film covering
  246. Just curious, are some colors of monokte harder to use?
  247. Need a better idea for Y harness hold
  248. Sig Kadet LT-40 Discontinued
  249. Help me convince Hobbico to reissue...
  250. Latest Patty Wagstaff Scheme - U got it? I do! :)
