PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. First kit, 3rd airplane...which one to build..
  2. Need Help mounting Drop tanks
  3. clear options with sig koverall
  4. Monokote A Cowl?
  5. BUSA 1/6 Sopwith Pup
  6. top flight t-34 mentor
  7. flyzone cessna parts for gws tigermoth
  8. Maybe New Life for Kits?
  9. Building a kadet senior
  10. help with gluing fuselage
  11. routing fule tubing through firewall methods?
  12. Structural Airframe Tubing?
  13. Fiberglass over Foam
  14. RETRACT INSTALL YELLOW ZERO
  15. My first kit Pilatus PC-6 building
  16. TF Giant Scale P-47 Razorback
  17. Most important piece of equipment?
  18. have an extra OS 25 FX, want to build a Sea Plane
  19. Need a Canopy
  20. Thinking about a Great Planes Ultimate 40
  21. TF Giant P-47D Elevator leading edge
  22. Goldberg Chipmunk & FA-80?
  23. Problematic location for covering
  24. HOB pt-19 25-30
  25. The BEST Covering Material
  26. O.S 40 4c
  27. Help with early TF AT6 .90 Thrust Line
  28. Pull-pull setup on goldberg Chipmunk
  29. To Fiberglass or not to Fiberglass?
  30. Coverite Covering
  31. formers
  32. kadet seniorita build
  33. TF P-51 Vertical Stab mounting question
  34. Kit for DA50 - which one to go for
  35. CA
  36. Stinson reliant kit
  37. House of Balsa kits
  38. worst broken screw
  39. Sig Kougar or Top Flite Contender
  40. First time kit builder Questions
  41. DX7 is it all that (and a bag of chips)?
  42. Aerodrome Kits
  43. SKYSHARK WARBIRDS ARE BACK!!!!!
  44. WW II Shiden
  45. Charles Kellog TBM avenger
  46. Top Flite kits
  47. Need help with 4*60 covering.
  48. Building Spirit of St. Louis (NEED HELP!!!)
  49. ELEVON ISSUE...
  50. Slow Poke .10-.25 Q
  51. First kit build, Ikon N'West Super Cub
  52. Where to find Blitz plans
  53. Need some advice on my TopFlight P-51 build
  54. NOSEN jenny
  55. covering cowling
  56. four * 40 kitbash group build this winter?
  57. What type of scale to buy?
  58. 4 * 60 Maiden Flight Report
  59. Just a thread to make me disgusted ! just kidding ..
  60. storing kits?
  61. Adding Counters to an SSE
  62. Tired of building sport planes, ready for something harder
  63. House Of balsa FW-190
  64. CG Location
  65. Kit bashed 4* into ME 109
  66. Wanted Top Flite spitfire plan
  67. ACE Big bingo , kit or plans?
  68. Sig King Kobra Foam Wings & Retracts Question
  69. GP Extra 300s .40 or .60 ??
  70. sig smith miniplane
  71. Are there any kits of 3D planes?
  72. balsa usa experience
  73. Elder 40 Tail
  74. GP Extra 300 vs D&L Edge 540
  75. Where to start
  76. Ikon N'WST Curtiss Robin
  77. 40 size GP cub with 72 Saito
  78. United hobbies covering
  79. GP Extra 300 vs. GP UltraSport 40+
  80. Best kit ever?
  81. Do I need dihedral in Ultrasport 60?
  82. Kadet Senior with Saito?
  83. 1/5 Sig Cub Build Pictures
  84. ace 4-60 mono wing
  85. Giant P-47 Cowl
  86. Robart Pin Hinges question
  87. Flying weight for HOB P-51-20
  88. Flexing frame to form fuselage taper
  89. Midwest sweet-n-low
  90. Steerable landing gear
  91. Balsa USA 1/4 scale Cub landing gear upgrade
  92. Putting 2 sig kits into one airplane
  93. Need a Tiger 60 Kit
  94. what with these electric sanders?
  95. Bad answers from a LHS!
  96. First Kit ideas/help
  97. Elder 40 - Covering Tail
  98. Hostetler, 1:4 Gilmore Red Lion-HELP
  99. How do i close this gap on the canopy block?
  100. Building a wing, need some advice.
  101. Percisioncutkits Buyer Beware
  102. Winter Projects
  103. help top flite bonanza
  104. Maule M-5 - Powerplanes International
  105. Gee whiz Bee maiden report
  106. Adhesive information needed
  107. Wing epoxy fit to fuselage
  108. LT-40 Bolt down wings?
  109. Glue
  110. Ace 4-60 Center of Gravity
  111. Lanier 81" Cap 232 BUILD
  112. EPF F-14 Cockpit + pilots 1/16 scale
  113. Fuselage stringers
  114. good 3d kits
  115. Great Planes Learjet Twin Electric ducted fan???
  116. ACE Big Bingo
  117. GP Extra 300 gear gripe
  118. Primer and Paint for glass over foam
  119. B-18 "Bolo" from a TF DC-3 kit?
  120. Robart Hinges. How to set to depth
  121. Goldberg Ultimate 10-300 help/advice
  122. GLUE
  123. No Sig Products in Tower 2009 Catalog
  124. Ultrasport 60 wing fillets....
  125. Crunched my hog bipe, giving birth to a 4*60
  126. Building a HouseofBalsa P-51
  127. CG and throws for Sig SE?
  128. Buiding preperations-work area
  129. Easy way to set wing incidence ?
  130. GP MUSTANG OR ULTRA SPORT
  131. Sig Kits (Limited Quanity)
  132. Great Planes Corsair 40
  133. TOP FLITE Elder Bi-plane
  134. Would you buy one of these kits? SR-71, OV-10 Bronco, F-4 Phantom. Market research, please help.
  135. Good kit for a Saito 90 twin
  136. Hauling Bipe in open bed pickup question
  137. Why use glass?
  138. TF Piper Aroow II Newbie
  139. Polyester Resin instead of CA and Epoxy
  140. Williams Brothers Cylinders?
  141. Balsa USA
  142. Balsa USA 1/3 scale Cub question
  143. Building a P51 and need gear door advice
  144. Kadet Senior Build Blogs?
  145. Sig 1/5 Cub Build Engine Ideas
  146. Uproar 60
  147. Engine for Pietenpol Sky Scout
  148. Topflite p47 60 size Gold Edition Parts
  149. 3 great plane Kits I finsised this weekend!!!
  150. Engine Mount: Bolts or Screws?
  151. Nightly team building...
  152. Mechanical Retracts Installation
  153. 1/8 Aeronca L-3 engine?
  154. Point Style Hinges
  155. Frenchie79 Ultracote Covering Job
  156. GP Super Sportster 60
  157. Good base for building
  158. Free control linkage and landing gear wire
  159. taileron help
  160. Great Planes Super Aeromaster 60 Plans
  161. Nosen Big Stik Wing
  162. Unionville 1/4 scale Beaver kit builders
  163. Coverite Lt Red and Krylon
  164. 1/4 Sig J-3 Cub FIRST BUILD HELP!
  165. HELP WITH RETRACTS INSTALLATION
  166. My Latest Project
  167. List of Kit Makers?
  168. My Kingdom for an Extra 260 kit!
  169. I'm trying to decide what to build this winter
  170. 4*60 Maiden
  171. Phaeton II CG ??
  172. lightening Telemaster 2000 ARC ??
  173. Vintage Bridi AT-6 Help
  174. Quality kits online?
  175. Solartex Covering
  176. Eagle 52 Trainer
  177. What is this airplane?
  178. Bridi / Direct Connection Ultimate Kaos 60
  179. Paint Nightmare Lustrekote
  180. Herr Lil' Extra Build
  181. Sig 1/4 Scale Tail section clarification
  182. Senior Ailerons and Engine
  183. dc-9-10
  184. AAMCO Aeromaster bipe canopy
  185. telemaster
  186. Fabric Covering for GP Taylorcraft?
  187. Kaos wing rib.
  188. Top Notch Products Shoestring 60 anyone?
  189. Using gorilla glue yellow wood glue
  190. sport plane
  191. Sig 4* 60 wing construction mistake
  192. citabria maiden
  193. Topflight P-39
  194. question about a kit I'm buying
  195. B25 Mitchell - Top Flite
  196. Some more Tger 60 Questions
  197. Hobby Shack Citabria -Need instructions
  198. Is Pacer Zpoxy Finishing Resin ok for fuel proofing?
  199. Completed 4*60
  200. How to keep weight down. Epoxy or ca
  201. OS 40 or 30 FS for GP Taylorcraft?
  202. 40cc size Aerobatic Kits. Would you??
  203. Sig Astro Hog
  204. 4* 60 Servo help
  205. cowl help needed
  206. Another Tiger 60 Question
  207. To build or not to build...8 year old sharing plane.
  208. Bucker Reborn !!
  209. Builders Choice Products Nieuport 11
  210. Engine choice for Sig 1/6 Cub
  211. Carl Goldberg Kits
  212. The Wild thing kit
  213. Painting wood...
  214. Page aviation Kits
  215. OS 75Ax for a TF piper Arrow
  216. Need Instruction manual for Goldberg Bucker Jungmann
  217. Best j-3 cub landing gear?
  218. Purple/Pink Trainer
  219. PT-40 WIng Kit
  220. GP Corsair 4u kit problem
  221. Club Trainer, PT-60, what size faults gear and tires?
  222. Opinions please!
  223. Senior Telemaster kit plans
  224. Who has built a Phaeton II?
  225. Info on Kit for young laddy to build
  226. Help me choose my first BUSA build
  227. Golberg Extra with Zenoah G20e
  228. Sig 450 Mustang
  229. AerodromeRC Sopwith Pup build
  230. Nelson Litefilm
  231. Midwest Extra 300s to 300XS airfoil conversion?
  232. One more SIG Somethin' Extra
  233. Midwest Extra 300s to 300XS airfoil conversion?
  234. Titebond II
  235. T-Craft Maiden flight, workin out the bugs
  236. Another 4* question
  237. 4*60 canopy questions
  238. Sig four star build question
  239. a top flite cessna2nd kit
  240. BOEING P-26
  241. Sig Four-Star 40 mods?
  242. 3 servo mechanical retracts
  243. tiger 60-retract doors
  244. Engine mounting in Fiberglass fuselage?
  245. Piper Arrow in cowl engines
  246. Another Completed Sig Somethin Extra kit
  247. GP F-14 Kit
  248. Second plane, first kit
  249. FINDING A KIT CUTTER ??
  250. BTE Venture 60 CG and control throw.
