PDA
View Full Version : Kit Building
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. Down thrust and right thrust
  2. Fun Aero Albatros DIII Instructions
  3. Top Flight Sierra Plans
  4. Someone out there have a Mark's Models Fun Scale P-51 .60 size ? Need to check plans
  5. Flite Metal Application
  6. Can anybody provide me with the wing tube dimensions from their Sig Kadet Sport?
  7. Al Sievers Old Timer airplane
  8. New "Golden Oldie" Completed
  9. Top Flite Stinson on Floats help
  10. Stevens Aeromodel/Todd Long Gym-E Park Flyer
  11. Stevens areomodel/todd long gym-e part flyer wanted
  12. Goldberg Cub Build - back at the table
  13. Fliteskin Ta152 build
  14. Mid-Star 40 with OS .55ax ideas
  15. Lozengetex ?
  16. Alien Aircraft question.
  17. HELP! Does anyone recognize this model?
  18. Direct Connections F-18 or F-20
  19. Stinger 120 plans
  20. BALSAUSA 1/4 Sopwith Pup
  21. Sig Kadet MkII build
  22. Big Mastake
  23. Morris hobbies hot hots plans
  24. Building Plans for a Birdie Forty Kit by Global
  25. BalsaUSA 1/6 scale Nieuport 17 kit
  26. Where to go to get Goldberg Kit fiberglass parts
  27. Ugly Stick 20 by Great Planes
  28. mustang exhaust and guns?
  29. hk covering foil colors
  30. ziroli at6 wing tubes
  31. BALSAUSA 1/4 Sopwith Pup
  32. Simplified Sig 1/4 scale Clipped Wing Cub build
  33. How to get Throw even ?
  34. Kit building with a wing jig
  35. Where to get kit plans?
  36. gas to electric
  37. 1/3 Scale 'Pitts Super' Composite Kit Build
  38. Curare 60 as a tail dragger
  39. Plastic control rods causing trims changes....
  40. RCM das ugly stik CG
  41. B25 Engines?
  42. Sticky Hinges
  43. Midwest Jetster 20 Build
  44. Direct Connection P-40N plans
  45. BUSA 1/4 Sopwith pup
  46. RCM plans
  47. Lanier Shrike 10 Plans
  48. ISO quarter scale Sig J3 cub plans
  49. Looking for Wing MFG. B-25 Side view plans
  50. Stiks.
  51. Top-flight S.E.5a
  52. Global/Hobby People Wacky Waco assembly manual...
  53. Sig Kobra 52 four stroke?
  54. Rv-4 wingtips
  55. American Eagle B17 Composit
  56. 100cc Ugly Stick Plans
  57. Direct Connection F-18 instruction book needed
  58. SkyShark rc Kit for a first build?
  59. Epo-Grip Beat The Heat Summer Sale ends Friday
  60. Super Cub LP electonic question regarding flaps
  61. 4 star 20 cowl
  62. Midwest Jetster 20 build manual/instruction sheet?
  63. original great planes PT-40 kit
  64. Brian Taylor P-51D 69"ws.
  65. Royal Staggerwing Build Problem
  66. Ever hear of the AERO-LECTRA by Midwest Production co.?
  67. Retracts on an Old Kit...??
  68. shorting ailerons ?
  69. Top Flite P-51 Acessories
  70. Airsail Tomahawk II Balance Point
  71. anyone sell me a set of 1/4 nosen champ plans?
  72. Scratch a plane Fokker D VIII C/G question
  73. glue for hinge pins
  74. Reversing a wing plan
  75. Engine for a small Nosen aeronca champ
  76. Royal P51 Plans
  77. Bigger wing span better?
  78. How old was you when...
  79. 150% tiger 60 build
  80. Wing manufacturing P38 Kit help please
  81. f4u cg
  82. Proctor Micro Antic Electric kit
  83. Did you build the mini telemaster with right or down thrust?
  84. I like a tool thread now and then.. whats the nice setup for a hobby band saw?
  85. Great Planes Ultimate 40 with O.S.70 4cyc - Nose Heavy?
  86. Pull-Pull calculator software
  87. Byron Baron 58 Plane
  88. Royal P-38 Lightning
  89. Proctor vs Top Flite
  90. BTE Vortex C.G.
  91. How to use parts that came with servo?
  92. Looking for a bulder for my partially built Balsa USA 1/4 scale Fokker D8
  93. Searching info for the Pilot Pitts S-2A 1/3 scale
  94. Great Planes Spectra
  95. Super Sportster .60 engine choice.........advise please!!
  96. What servos for this warbird?
  97. stumbled into elevator of my electric ShowTime
  98. TopFlite P-47 .60-.90 Build
  99. Just an old trick
  100. Help Identify p-47 thunderbolt model kit manufactuer
  101. seagull mini cassutt kit, motor thrust angle??
  102. decals
  103. Limbo Dancer plans
  104. Looking for BUSA Stick 40 plans
  105. C/A-Proof building surface
  106. Servo buzzing (HiTec HS-422)
  107. Spektrum DX6i replacement LCD
  108. Midwest Super Stinker F/G cowl question
  109. Newbie mistake HELP
  110. Need Byron Glassair template sheet
  111. Help with four star canopy
  112. GP .60 Extra any good?
  113. Top Flight T34 Mentor Engine ?
  114. Eliminate slop between Clevis pin and control horn?
  115. blind nut or threaded ply?
  116. Need advice on Guillows Porter pc-6
  117. Sig 1/4 Scale J3 Cub w/floats build thread
  118. Meister scale P-47 D-25 Diary of a scale build
  119. Semi-Scale AT-502 Air Tractor
  120. G&L Hobbies Chipmunk Build
  121. My gear reduction to allow big scale props project...
  122. A place to paint airplanes, a retiree needs suggestions
  123. Question regarding Top Flite P-47 GS Razorback canopy
  124. worst kit youve ever built
  125. Official Great Planes Ultimate .40 Build Thread!!!!
  126. Classic Aero Sikorsky S-39
  127. Rough finish on spray painted ABS wheel pant.
  128. Great Planes Lear Jet
  129. Covering This Wingtip??
  130. new asp 40 glow engine
  131. Misstik Brotherhood
  132. First ever Simmer 600 build on RCU!!!
  133. Public domain RC plan wanted
  134. Bridi Cap 230 build instructions needed
  135. wing dihedral on a trainer
  136. Control Throws for a Sig Mini Plane
  137. Ben Buckle kits
  138. Kadet LT-40 with Saito FS62A Throttle linkage problems
  139. Building a competitive scale kit to compete at scale compititions
  140. How long to buid a basic TopFlite 63" P47 kit?
  141. Jemco Texan Parts
  142. Great Planes Ultimate .40??????????
  143. Flair kits
  144. Decisions ......Decisions .........
  145. In case you didn't know, I just found out. Pheaton and Smoothie
  146. Horizontal Stabilizer on Sig 4 Star 60....
  147. X1-A v.4 RC Paraglider : NEW RELEASE 2015
  148. Which Rod Is Stronger & Stiffer:
  149. How will this error affect flying?
  150. Dumas Products electric park flyer Waco YMF-5 (kit#1807)
  151. Info needed on 1/3 J3 kit
  152. Topflite P40 Gold Edition...
  153. Great Planes Ultimate .40 Electric????????????
  154. Rcm Ugly Stick
  155. Looking for a builder, NY metro area
  156. Roadrunner Kit - what engine should I put in it?
  157. Spray Painting Dope and Auto Laquers
  158. Great Planes PT-60 Trainer 2 stroke engine choice???
  159. Xcelerator XL+2 build
  160. Help with SIG 4 Star 1.20 cowl
  161. Goldberg Ultimate bipe templates
  162. Sig King Kobra - Paint?
  163. Warp prevetion/fix question
  164. Workshop cleanup, reorganize and remodel.....
  165. Workshop cleanup, reorganize and remodel.....
  166. Great Planes PT-60 + DLE20cc 'Goof-Off' Build
  167. SIG 4 Star 1.20 canopy
  168. Nosen kit
  169. Sterling Models Flight Trainer S-16 Building Plans
  170. SIG Stratus (#RC4) - the long slow plans build
  171. Discussion on delux materials EZE-Kote.
  172. Top flite p-40 .60
  173. Winter, Burrrrr!!!!!!!!!!!
  174. Top flite beachcraft bonanza engine selection
  175. ideas?
  176. Sig 4 * 120 Mods........
  177. Pitcairn Mailwing pa-5 plans?
  178. G2 Rotary Drive System for Ailerons
  179. The Evil UAV!!!!!!!!!!
  180. Painting / covering around windows
  181. Stevens AeroModel kits
  182. Glens Models 78" Cap232 ARF
  183. Anyone want to build a Beechcraft King Air?
  184. Building board question
  185. Moucha Models Fly Baby Instructions?
  186. Goldberg Super Chipmunk wing ribs
  187. Great Planes RV-4 40 Kit build thread
  188. balancing ultimate with swept back wing
  189. question about type of covering I have?
  190. Lightest glue for foam wing sheeting?
  191. Ikon nwst super cub help
  192. MR Aerodesign De Havilland Beaver
  193. SIG Biper Cub (Kit Bash)
  194. TF LustreKote Paint and clear coat compatibility??
  195. Lets build a great planes sailplane
  196. Top flite p-47 60 size retracts question
  197. A great loss - Roger Moffat of Sequoia Systems
  198. top flite gold 63" p-47 -- electric powered
  199. Well, at least one wing isn't warped on my Great Planes RV-4 40 kit.
  200. GP Goldberg Tiger 60
  201. Where have all the builders gone
  202. My very first Kit!
  203. Midwest Cherokee 40 instruction manual
  204. Restoring Vintage Royal SE5a, need some dope experts advice
  205. Bridi/GP Cosmic Wind, "little Toni"
  206. Hysol epoxies
  207. Glues for kits?
  208. Top Flite Cessna 182 *81" Gold Edition Build Question
  209. Super Cub cowl for GP 60 sized CUB?
  210. Dynaflite PT 19 ( 82 in span )
  211. Earnies Kadet SR.
  212. Hobby King covering
  213. Found a comet p-38 #3504 and a guillows Dauntless #1003
  214. Balsa sheeted foam wing has a curve in it
  215. Anyone familiar with the Bridi Bree-Zee?
  216. Moving Back a Firewall
  217. Photos in our profiles??
  218. New year resolutions
  219. Filling gap between outer and center wing panels, need suggestions
  220. Leisure RC Models-Jack Stafford
  221. Glow or electric?
  222. How I cut my wood
  223. Goldberg Cub build, thoughts, gripes, insights etc.
  224. Tips for Measuring Wing Incidence
  225. Jack Stafford (Leisure RC Models) Aircoupe Winter Build
  226. Lanier Stinger 10 kit plan
  227. pre-build great plains 300 extra .40 size
  228. Planes for Europa XS monowheel
  229. Please help identify this kit!
  230. Cutting truss sticks
  231. Question about Value Hobby covering
  232. Laser Design Services Crusader 2 build
  233. Ohio Superstar Tail Wheel
  234. BTE Delta. vortex question
  235. SIG SSE engine mount question
  236. top flight f4u corsair 60 balsa kit build
  237. Glue Canopy to which surface?
  238. A 26 Invader from Wowplanes?
  239. Stafford Buckaneer build
  240. Proctor Albatros
  241. New Guy- Great Planes Extra 300S .40
  242. Feedback on FlyingThingz.com?
  243. Covering question...
  244. Handley Page H.P. 42 Hannibal Build from S. Newton plans and LDS short kit
  245. Covering Balsa USA Northstar with Minwax Polycrylic - Fuse Question
  246. MountingSullivan tailwheel on Sig 4 Star 60
  247. Old GP Big Stik .40 Shrinkage
  248. SIG Somethin Extra Build - 2nd Plane
  249. Help i am having alergic reaction to ca glue
  250. Incidence - problems getting consistent results
