PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. House of Balsa 43" P-51 HELP
  2. What is your first kit ? And what kits do you own/building ?
  3. Your opinion please!
  4. Prop Advice for GP 300S 40 size
  5. 4*60
  6. 4* sheeting the leading edge of the wing
  7. Pica 1/5 scale Spitfire all up weights and powerplants used?
  8. Foam wing question...
  9. Need some engine/kit advice
  10. Sig Spacewalker
  11. Help with LT-40 Tail wheel linkage
  12. My TF Nobler
  13. midwest citabria, cowl and wheel pants
  14. Nylon Pinned Hinges or CA Hinges or Pivot Point Hinges for my kit ?
  15. sullivan bracket 4*40
  16. Venture 60 and YS 63
  17. Sorrell SNS Hyperbipe Kit?
  18. Aviomodelli Storch
  19. GP Extra 300 pics!!!
  20. Question on 3D Plane
  21. 4* engine mounting
  22. Please Help, Anyone built the Dreamer?
  23. CG Sukhoi kit
  24. Longer "Uproar" - fix CG & help 3D
  25. eindecker E111 top pylon (swg size)
  26. Old Sig Kit - SCAMP
  27. Challenge Wanted
  28. KRIER KRAFT BIPLANE PLEASE HELP
  29. sig Smith Mini plane engine& covering?
  30. 4* Info sought
  31. Quarter scale Piper Logo
  32. Fuelproof Paint
  33. midwest citabria
  34. Incidence question?
  35. Kaos lookalike modifications (Retracts & flaperons - pics)
  36. Which glue - Where ????? (for UPROAR)
  37. Balance Sig SE inverted?
  38. Beveling and Rounding Wing, Fin and Stab's Trailing and Leading edge
  39. Covering colors
  40. Aero star 20 Plans
  41. Sig KADET SR. Ailerons???
  42. Great Planes RV4
  43. Suggestions wanted... Mid-size bipe.
  44. Wonder RIP
  45. top flite C182 - into a tail dragger ??
  46. Augh!!!
  47. Sig 4 * 40 wingspan
  48. My Hummer and SST
  49. Jerry Bates Hellcat Covering/Finishing
  50. Beechcraft Bonanza? But from which kit?
  51. Info on Ohio R/C Cap 232?
  52. Just Another GP J3 Build Along
  53. Do I need a wing jig for a sig SE?
  54. Somethin extra rightthrust
  55. Somethin extra cowl
  56. Extra 300 Kit- Which would be better
  57. Bridi Stick w/ Moki 1.35
  58. ugly or big stick kit
  59. Flying King
  60. Need Some suggestions on a new project
  61. Considerations using Trim Strips vs Ultrakote?
  62. Goldber Extra 300 engine mount & pitts smoke muffler
  63. 1/12 scale landing gear or retract options
  64. Sukhoi 26 - need data!
  65. Built myself a GP Extra 300s .60 brick..
  66. I wanna build a kit but...
  67. hows she look?
  68. Reinforcing the Sig LT-40 tail
  69. Turning Balsa plane into R/C plane
  70. Paint
  71. 4* Engine question
  72. Piper Tri-Pacer Kit
  73. Direct Connection Tsunami
  74. Ultimate Plywood
  75. What is IT ???
  76. Its finished!
  77. Ultra Sport40( elevator's resonance)
  78. JGRC Aggressor - A neat delta wing
  79. Four Star 60 - my first kit, probaly not last question tho
  80. Show Your Sig SE's
  81. 15 or 25 size 4* kit?
  82. has anybody built a Sig Doubler II?
  83. Economy of efforts, building many planes from the same kit
  84. wing dihedral on cub
  85. Need Help with V60 Landing Gear
  86. 4 star engine mount
  87. Cowl for Tiger 2?
  88. All about Piper Cub J-3
  89. Midwest Citabria Heading wanders
  90. covering
  91. Top Flite T 34 Mentor
  92. Ultimate 10-300
  93. I buy-----kits because....
  94. Relocating Rudder and Elevator Servos on CG Extra 300
  95. Old Sig Kit - Scamp
  96. Puppeteer Builders lend me your ears....
  97. Best .60 Hellcat, Ultimate, Citabria kits
  98. What Size Engine for Bud Nosen P51 Kit?
  99. Model Aviation Mag SIG Cub review?
  100. The only Real bipe
  101. Ohio R/C Extra 300 84"
  102. Great Planes p51 retracts
  103. Diamond C1 Evolution
  104. Venture 60
  105. Great Planes Piper J3 Cub - Does size matter???
  106. GP Extra 300 60. wing mount
  107. 4 star 40 fuel hatch
  108. dual aileron servo setup
  109. My Gyro Bee progress
  110. Show me some 4*'s!
  111. first kit and wood warpage
  112. Retracts for .90/1.20 size Sport Plane
  113. Pica T28 Retracts
  114. Pitts S-2 fiberglass cowl
  115. NEW EXTRA SCHEME AND RE-BUILD HORZ. STAB!!!
  116. mechanical retracts? Are they durable?
  117. Great Planes Cub
  118. AT-6 Project Finished
  119. gp cub 40
  120. 4* wing question
  121. I give up!!!!
  122. Skyshark FANTASY
  123. Telemaster
  124. 4*60 Aileron Pushrods
  125. Coverite,should I use it?
  126. Lanier Extra 300s 1/4 scale kit
  127. 4*120 with homelite 25
  128. Best engine for a Goldberg Ultimate, opinions please.
  129. Herr 1/2 A J3 Cub Ailerons
  130. Shortening the Fuselage
  131. Aeroworks Full Build Kit.
  132. GP P51 wings
  133. Recommend a good quality kit from your building experience
  134. Wing Joiner on 4 star 60 question
  135. Bipes. Which one to build?
  136. Quest 3D Fuel Tank
  137. Modified GP UltraSport 40+
  138. Goldberg Ultimate 10-300 Radio Installation
  139. Unsupported Covering Seams
  140. original ultra sport 40
  141. C130 kit
  142. GP RV-4 Engine Selection
  143. What kit for an OS26 FS?
  144. Balsa USA Stick 40 Plus (Great Planes?)
  145. Kit cutters???
  146. Goldberg Sukhoi 72 inch
  147. gp cub 40
  148. 30 SIZE ULTIMATE BIBE 46 FX
  149. Super Sportster 90/120
  150. 4 star 120 homelite 25 mods.
  151. Four Star 40 Balance
  152. sig something extra or gp rv-4??
  153. Old Sig p-51 Kit (Foam wing, abs fuse)
  154. PT-20 Ailerons
  155. .40 size CAP
  156. R/C controls for Guillow's kit no 406 (FW 190) 3/4 scale
  157. Four Star 40 wing joint
  158. T-Tail for 4 star 40??
  159. Know of a pull-pull kit that comes with tubes???
  160. Inner Nylon Pushrods
  161. Pushrods for CG Ultimate .60
  162. 4*60 with Mag XL 61 or Mag XL 75
  163. More CG Super Chipmunk questions -- On to the fuse.
  164. Sig Somethin Extra Help! Canopy
  165. Is the Staggerwing too dificult to build
  166. Anyone built the Dreamer?
  167. Suggest an engine for GP Giles 202 46-61 Kit
  168. Citabria Pro by Balsa USA
  169. How to put ailerons on the top wing of a Phaeton 90??????
  170. Have to show someone...GP .40 P-51
  171. Cherokee??
  172. Sheeting on my Sportster....!@#$%^&*(!!
  173. My Midstar
  174. Ultrasport + Just starting
  175. CG Chipmunk - any reason to avoid buying a ten-year-old kit?
  176. Need Pics of Extra 300 for covering Job......
  177. Dreamer
  178. LT-40 Modifications
  179. Suggest a kit to fit an MDS .58
  180. kit building tools questions
  181. Dapper Snapper
  182. Dynaflite Decathalon?
  183. Flaming RV-4
  184. CG Ultimate Engine angle
  185. Tucano kit?
  186. What is the best way to install Aileron servos in the wing?
  187. 4*60 Cowl/Engine Question
  188. vintage kit
  189. Help With flair junior 60
  190. 4* 40 kit question
  191. CG Chipmunk build question (gear installation)
  192. Lets see your Kadet Senior's
  193. What else besides a Venture 60?
  194. aeroworks edge 540 pictured construction manual
  195. Sig 4star ARF or Kit?
  196. Covering Foam Wings
  197. Hi pro soarer
  198. Urgent: Take off weight for an Acrowot?
  199. Need help! - Midwest "Mach 1" pattern plane
  200. My CG Ultimate Bipe
  201. Sig SE finally covered!!
  202. Golden olde Inst. Manual
  203. Help "Blue Printing" Ribs
  204. Crossbow by Leading Edge circa 1999
  205. Will a Steam Iron do the trick?
  206. Time to Build
  207. Somthin' Extra Pushrods
  208. Question about basswood and spurce.
  209. Acro Wot Dihedral?
  210. P-51 3 or 4 Blade prop?
  211. Unionville Norseman (or other Unionville kits)
  212. SM-Modelltechnik F-86 Sabre
  213. TF Nobler?
  214. fuse jig
  215. fueling/cowl
  216. TF 60 Corsair Retract Question
  217. Solder Question
  218. looking for a builder
  219. First Kit Build, what to get?
  220. TF Cessna 182 Saito 1.50 what do you think?
  221. Building Great Planes 20 Cub
  222. four star tail
  223. Citabria or Decathalon - which one is better?
  224. Pica Waco 1/5 scale - large enough for smoke?
  225. sig
  226. Dicontinued,, SIG CUB KIT Winspan 105"
  227. Cockpit Kit
  228. Super Sportster 60 DONE! (Pics)
  229. Cutting/trimming canopy for DJ-1 - Need advice!!
  230. Sounds like flutter....looking for opinions
  231. What colour is best ....
  232. Did I Get Ripped on a Kit Build?
  233. elevator servo question
  234. Lanier 1/4 Extra
  235. 1/4 Scale AOP9 Auster (Airsail)
  236. HELP! GP Skybolt, OS 120III w/pump install
  237. Pilot Zlin Akrobat
  238. Alignment of Tailplane surfaces.
  239. SIG Midstar---DONE!!!! (Pics)
  240. Fourmost Demoutable Hinge
  241. Peer Models Ltd.
  242. sig zlin 526 pics needed
  243. Great Planes cub firewall question
  244. FLAIR YAK 55. Engine help
  245. what basic knowledge before starting a kit building
  246. Sig Kavalier - anyone?
  247. Goldberg Ultimate
  248. Top Flite Cessna engine selection.
  249. 4 star 40 fuel tank
  250. J3 Cub
