PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. LE & TE Radius Forming on FlyBaby??
  2. Pica Waco 1/5 Servo suggestions
  3. Lanier 31.5% Staudacher 300
  4. fuel tank installation/plumbing
  5. Thunderbug 40
  6. super stinker bipe
  7. Cermark Extra 300...!
  8. Anyone have a Sig Skybolt manual?
  9. HERR Engineering Kits
  10. Astro Hog Mods
  11. Attaching BalsaUSA Sopwith Pup Lower Wing
  12. Midwest Super Stearman bipe
  13. Ace Allstar Bipe
  14. Jig to build Sig 1/5th scale Cub?
  15. Sig Wonder advice?
  16. Skyshark 190's
  17. Incomplete instructions..HELP
  18. Good Kit for OS LA40
  19. 4* Flaps
  20. Tail wheel sizes
  21. CG Super Chipmunk instruction book
  22. SIG Hog Bipe Plans
  23. AeroTech 35% Edge 540 Constuction...
  24. Wot 4? 'Cos I always wanted one....
  25. Birdi Old Timer -- Is this a good Kit?
  26. What Did You Put in Your Kadet Senior??
  27. Rubber powered kits
  28. Sig Kobra Kit .19-.35,45"
  29. Using glue properly.
  30. Florio Flyer "Big Nifty" Semi-kit
  31. Top flite p-39
  32. Arizona Models DVII or New Balsa USA DVII
  33. Engine Selection for a Goldberg Tiger 2
  34. Ultimate 10-300S Power?
  35. A BLAST FROM THE PAST! [TAKE A LOOK]
  36. Covering Brand
  37. Sig 1/3 Spacewalker
  38. Ultimate Bipe 3-view
  39. Looking for unique Trainer Kit
  40. Balsa vs. Plastic wingtips
  41. Tired of same ole kits
  42. Stringray 120 & Ryobi pic's
  43. visibility of transparent covering
  44. Mig-25 kit ?
  45. Goldberg Sukhoi
  46. Filler
  47. ARG, 3M 77 eats foam
  48. Does anyone make a kit of a JR ACE?
  49. golberg CHIP, ASTRO hog, engine size
  50. Warpped Wing
  51. HELP! GP Super Sportster 60 Mods
  52. Great Planes 60 size EXTRA.....TOTALLY 3D
  53. Ohio 28% Extra 260 questions
  54. more on arf quality/ safety
  55. Sig 4 Star Completed (pictures)
  56. Building TP P-40E
  57. dynaflites flybaby
  58. Looking for a Second Kit to build
  59. Goldberg Eagle II
  60. Epoxy v. CA
  61. Telemaster 40 fuselage help
  62. Ultracoat trim onto Ultracoat covering...
  63. CA model Funky 40
  64. Wing Manufacturing P-38 CG
  65. COLUMBO ANDERSON WING??????????????
  66. How do I hide the 4cycle muffler in my cessna cowl?
  67. Another 4* question
  68. Waco scale flying wires
  69. 1/4 scale foker dr1
  70. 4 Star 40 engine
  71. R&S Hobby F-16
  72. 4*60 throttle cable help!
  73. Giant So Do Khoi, Giant Stinger, Sig Spacewalker
  74. What's a M. Blose Perfection?
  75. Sig Somethin' Extra
  76. how to prime a cowled in engine??
  77. Balsa USA Phaeton II
  78. Max Blose Perfection
  79. What's the best way to reinforce a Super Sportster 60 kit?
  80. In-cowl muffler options for 1/5 scale Cub and K&B .40
  81. Built up wing question!
  82. Lanier Ultimate Pitts bipe..?
  83. Sig 4 star 40 w/ OS 4 stroke, throttle hook up help needed
  84. D&L Designs 80" Edge 540
  85. lanier dominator help
  86. SlowPoke Sport 40 Builders
  87. Sig SE Wing Tube, Carbon Fiber??
  88. RCM Funster 40
  89. RC Model World Less 'n' Extra
  90. Goldberg Tiger II question
  91. AAMCO H-Ray and A-Ray Plans
  92. PT40 wing modification
  93. Telemaster 150
  94. Top Flite Cessna 182 Covering Suggestions?
  95. four star 40
  96. Four Star 60 in Snow
  97. 1/4 or 1/3 RV-3 or RV-4
  98. Gluing fiberglass
  99. GP Ultimate
  100. Somethin Extra Wheel Pants
  101. Global Quality Kits Cutlass 45 Instruction Book
  102. PRO-BUILDERS
  103. Venture 60 Rudder Throw Question
  104. small pitts special help
  105. Glassing Wing Joint
  106. need help with a su-26 sukhoi
  107. Great Planes T-Craft 20
  108. goldberg ultimate 60 size
  109. Flair Fokker, CG ?
  110. best way to paint my FW190
  111. Four Star 40 kit aielron servo question
  112. wing warp
  113. Foam on bottom of fuel tank for Sig SE
  114. Seal hinges on Somthin Extra?
  115. Herr Cherokee (sort of)
  116. Sureflite Zero kit
  117. What size Robart Hinge for GP Extra .60
  118. micafilm application
  119. Stagger Bee plans WANTED!
  120. Stick Kit?
  121. ATTN: Super Sportster Owners!
  122. K.Senior, OS70 Surpass, Prop position?
  123. G&L Hobbies P-38
  124. To Jig or not to Jig?
  125. C.Golberg Super chipmunk Build questions.
  126. Tell me about your Sig Skybolt
  127. Bashing a 4*120...
  128. 60 Size Uproar OVER POWERED ??
  129. Balsa Nova Throws
  130. First Kit Laser Arrow
  131. GP ultrasport 40+ build question
  132. Installing a G23 in Ultra Stick Lite 120
  133. Engine Mount on 4*40
  134. Need Help on Balsa Nova 120
  135. clancy aviation lazy bee C/G
  136. Patriot Air Intake question
  137. Ultra Stick 60 Wing Hold Down Dowels
  138. Four star with os 70 engine
  139. My GP Skybolt is finally ready, BUT...
  140. WONDER advice.
  141. 4 Star 120 CG Question
  142. Soft Balsa Wings and Fuselage
  143. conversion for pica1/6 mustang to B model
  144. Inverted Saito 120 in GP Skybolt
  145. Top Flite Cessna and Wood Flap Horns
  146. need small rotating retracts
  147. making fiberglass parts?
  148. OS 90 Engine Mount
  149. How to tint a canopy?
  150. Jerry Bates Plans & Manuals
  151. Need all info for a Byron Sukoi 27%
  152. Radial engine on Hog Bipe?
  153. Fiberglass kits
  154. Instructions f/ Robin Hood 80
  155. Nylon bolts for landing gear
  156. Birdi - Corben Baby Ace ?
  157. Trike to Tail Dragger Conversion - Tiger 60
  158. I think this is a first
  159. Royal Corsair Partly Built
  160. Shear Webs in Extra 300
  161. Epoxy or Thin CA?
  162. Saito 91 on Tiger 60 or Venture 60?
  163. Sig colt plans
  164. which kit of these 2??
  165. GOLDBERG ULTIMATE LANDING GEAR
  166. cheaplanes.com
  167. Laser 3D wingtips?
  168. Engine Thrust Angles
  169. Canopy Tinting
  170. Acrowot
  171. What plane to put my Rossi 60 into?
  172. Replacing fusalage with CF tube
  173. The old Royal kits
  174. Lazy Ace Stabalizer
  175. Biplane opinions
  176. Horizontal Stab Installation Help Needed
  177. LIVE HINGE? Whattheheckisthis?
  178. Hinge gap
  179. GP?? Extra 300 as 3RD plane and 1st kit?? Possible??
  180. 33% Ohio R/C Ultimate allmost done
  181. Super Skybolt Bipe
  182. Byron Cap 21
  183. @#$!!&* TAILHEAVY!!!!
  184. Fiberglassing DC 3
  185. First Kit - Laser or Die cut - Does it matter?
  186. Sig Kadet Mark II
  187. Question of weight, balance and power
  188. Monokote Trim Question
  189. Airsail kit building
  190. lanier
  191. Tiger 60 Cowl
  192. Need recomendation on a good 60 to 90 size kit
  193. GP Ultimate Bipe 40
  194. 4 Star 120 Bashed into a SLURRY BOMBER
  195. First Kit??
  196. Right Thrust on Sig SE
  197. sig hog bipe
  198. Four Star 40 question
  199. catalina kit/plans
  200. Hog Bipe Motor Mounts
  201. Building tips for GP Rapture 40?
  202. SE Questions
  203. Goldberg Super Chipmunk - Need dual servo advice
  204. Lazy Bee kit
  205. Mong Biplane
  206. What to do I use to seal Polyester material?
  207. How is the GP CAP 21 kit to build and fly??
  208. Looking for a four star 60
  209. Balsa USA 1/3 Scale Piper Super CUB
  210. LT-40 Needs a Diet
  211. ROYAL P-51D ?
  212. Best 4 stroke for a Telemaster 40?
  213. laser cut kits
  214. New Kit Covering Question
  215. Goldberg EXTRA vs. GP EXTRA .60 ?
  216. Possible Somethin extra problem???
  217. HELP W/MODS ON CG EXTRA 300
  218. GP Corsair with retracts?
  219. Sig Aerobipe
  220. Cessna 182 weight?
  221. Sig Kobra Kit
  222. GP Extra 300S .40 Kit Stab Warp
  223. CG ANNIVERSARY CUB WING QUESTIONS
  224. Painting checkerboards
  225. Best covering for a beginner
  226. AKM Mig-29
  227. Great pLanes CA hinges are horrible
  228. Santee just finished
  229. unusual older plane from plans
  230. Tail wheel for Sig SE.
  231. Scarf Joints good or bad?
  232. How Much Flaperon Movement?
  233. Great Plans P-51 Mustang kit ?
  234. Newbie looking for hinge advice
  235. Sig Something Extra - Wing Gap
  236. wing isn't straight
  237. 4*60 turtle deck
  238. balsa usa stingray 120 vs 4*120
  239. Fiberglassing a P-51 1/7th scale
  240. Boy, the Sig Citabria is a pain in the...
  241. Great Planes Slowpoke .15-.25
  242. Beldone Models
  243. GP Pitts throttle hookup
  244. newbee into larger planes "help"
  245. Dare Wright Flyer Pics?
  246. how hard is it to build a kit
  247. A good sport bipe?
  248. 4* 40 Question
  249. Sig Somethin' Extra
  250. Ultra Hots question on building turtledeck
