PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. supersportster bipe
  2. fitting dummy engines in cowls
  3. Lanier Stinger .60 Building Questions
  4. Fuel tank mounting in TF Mustang 1/7scale
  5. Here goes!!
  6. Astro Hog
  7. Pull pull clevis. In or out? (GP Cap 232 .40)
  8. Ultra Stick 40 fixing it before you build?
  9. Midwest Sweet Stik
  10. Sky Shark RC "Fantasy"
  11. WHAT ENGINE TO HOVER ON SOMETHIN EXTRA???
  12. Prober Pixie
  13. countersinking hinge points?
  14. Midwest AT-6
  15. PBXL Scratch Build
  16. Bipe for small four stroke
  17. TWISTED?
  18. LT-25 and wood glue
  19. Goldberg Extra 300
  20. Tricycle to tail-dragger conversion?
  21. Straightening warped balsa
  22. Skybolt servos?
  23. Wing twist
  24. Feedback Please - My 1st Kit
  25. Is this good for first try?
  26. GP Extra .60 Kit - Trim Scheme Page
  27. Katana or Funtana Pro Plans?
  28. Ultrasport 60 wing servo
  29. Herr Piper J-3 Cub
  30. BTE Delta Vortex Construction Photos
  31. Sig Kadet Senior Thrust Line
  32. AK Models Propjets
  33. Monokote over Fiberglass
  34. Goldburg Super chipmunk in cowl muffler?
  35. Repair Question
  36. Goldberg Cub Booklet
  37. Wing Incidence over EDGE 540
  38. kit recomendations
  39. Looking for pilots for F-16
  40. Need help with Sig Ment
  41. Art Chesters Jeep ("Anyone build one?")
  42. For all you Sig SE builders
  43. Experience with Skyshark kits?
  44. Goop???
  45. balsa to seal or not to seal
  46. Sweet Stick .40 Plane or Plan, and Aeronca Champ ... :)
  47. Help finding lost web-site link
  48. Precision Cut Kits.Com
  49. Sterling Models Olympic Challenger
  50. Trim solvent and Ultracote
  51. Glueing Wings!!!??
  52. covering foam with film covering
  53. Robin Hood
  54. mr clean plans
  55. Second kit, kinda proud of this
  56. Gorilla Glue ????????
  57. Best Way to Duplicate Kit?
  58. Wanted C. Goldberg Staudacher Kit
  59. JURY STRUTS FOR GP .40 size cub
  60. Lazy ace 62" bipe
  61. Are kits cut from Bob Holman plans any good?
  62. Ace 4-120 bipe to Ultimate 4-120 bash.
  63. Do I really need these?
  64. Best way to fuel proof?
  65. Wiggle at SE wingtips
  66. Need help woth Venture 60
  67. GP P-51 Mustang Wing ?
  68. Royal or Marutaka P-26 Peashooter kit
  69. Carl Goldberg Ultimate Kit
  70. Flaps on a Goldberg Super Chipmunk
  71. New to building
  72. I am looking for plans for an out of Production Plane Where do I go?
  73. Looking for high quality kit to build
  74. Ultimate wing question
  75. Need help with fiberglassing
  76. EAA Bipe Engine Choices ???????????
  77. Donald 4 NOT a good first kit
  78. Kyosho F4U Corsair
  79. Purdue pete? any suggestions?
  80. Skyshark Skyraider kit
  81. CAP 21?
  82. Ailerons or No Ailerons???? there's a Lazy Bee dilema
  83. Modifying a Fazer
  84. GP Dazzler question
  85. Pilot Seduction Freestyle
  86. Anyone heard of the T-Max sport plane?
  87. Acrostar
  88. Is an "un"-hedral elevator on a trainer a problem?
  89. west wings fournier rf4
  90. Another Covering Question
  91. Hog Bipe
  92. 21 Century paint and Lustrecote compatable?
  93. C.G.for the Lazy Ace&Phaeton 90 Please!
  94. Lanier Ultimate Pitts .91-2.2
  95. Goldberg Extra 300 Instruction Booklet
  96. Kit bashing Senior Telemaster question
  97. GP Giles G-202
  98. My progress on the Balsa USA Stingray 120
  99. What filler for cowl seam?
  100. Sig 4*40 canopy
  101. Recommended battery size?
  102. The best affordable laser cut kits?
  103. GP P-51 ARF Stab problem.
  104. Like covering?
  105. Robart Hinge Question
  106. Iron-on hinges
  107. Bruce Tharp Delta Vortex Suggestions
  108. Great Planes Fun-One
  109. Speedy Bee bolt-on wing conversion
  110. Where can I get fiberglass cloth?
  111. ikon aeronca champ kit questions
  112. New Cub
  113. Venture 60... It's Coming along!!
  114. LT-25 or Seniorita
  115. Golden state rc rampage 40
  116. Aspect aviation reflex delta
  117. shaping Leading and trailing edges
  118. Help with kit comparisons!
  119. Biplane C.G.
  120. symmetrical wing for Sig Kadet LT 40
  121. HOW DO YOU CUT DIHEDRIAL
  122. Sig Four Star 40 or 60?
  123. Pica Jungmeister
  124. Sheeting Question
  125. Aligning everything
  126. Hog Bipe aileron servos????
  127. can i convert an electric kit toglow power
  128. Fiberglass/Monokote advice needed.
  129. wing problem
  130. CA only for Somthin extra?
  131. GP RV-4 kit quality
  132. Airsail Beaver
  133. Tower Hobbies Uproar
  134. One Peice Cowl
  135. Gluing plastic cowls
  136. covering an aluminum airframe??
  137. What Sort of Blade?
  138. Covering weight chart!
  139. ATI Manufacturing Co (UK)
  140. Pilot Supra Fly .25 plans
  141. Bad covering job!!!
  142. Couple of Building Questions
  143. H-Ray plans Wanted
  144. New source for kits
  145. newbie question.....
  146. Palmar Plans??
  147. Iron on hinges
  148. Great Planes 60 Giles kit-ailerons question
  149. Alternate for balsa filler...
  150. Stock 4*60 in high stress maneuvers
  151. Lanier Kits
  152. Help! broken wing dihedral
  153. koverall and ultra violet light damage and silver dope
  154. Bucker Jungmiester
  155. Venture 60 Landing Gear Questions
  156. Glassing/Painting
  157. Waco fuel tank access
  158. pin type hingers vs plastic ca hinges
  159. TopFlite heat gun problems
  160. omp edge 540 new kit builder
  161. Worldtex/Solartex Color Chart Avail?
  162. Faskolor paint and Monokote?
  163. Goldberg Sukhoi cowl: Stan's Fibre Tech?
  164. Here's a hint for all you kit and scratch builders dealing with balsa sheeting
  165. Thundercat Olympic 20-T kit
  166. Covering Scheme for 4*60
  167. Ace 4-60
  168. covering material strength
  169. Priming and Clear-coating
  170. Winter Project Selections
  171. Are ARF's really safe?
  172. Four Star 40 and Wheel Pants??
  173. How hard is it to fiberglass tail feathers
  174. D&L Edge 540 with 80" wing
  175. skyshark skyraider
  176. GP Cap 232 1/5 Kit
  177. Aeroworks Edge 540 25% Building Question
  178. Solartec and Spray Painting
  179. OS 52 and a Four Star 60
  180. Engine size for Sterling Stearman, Help!
  181. Datum/Referance Line
  182. Help for a warped elevator
  183. Covering and Painting
  184. moved to clubhouse
  185. mini telemaster prop
  186. Super Chipmunk tilted cowl problem
  187. scale-like canopy
  188. Cowling Mod for Tiger 2
  189. How to fix a hole?
  190. Balsa USA Stingray 120 & Ryobi Pic's
  191. Beginners guide to kit building?
  192. Another Somethin Extra question
  193. TF Elder 40 - Ready to go Slow
  194. 62" Lazy Ace engine
  195. Beechcraft D-17 Staggerwing
  196. Cowl for sig SE
  197. need builder for wings and tail for ziroli p-40
  198. Someone to install monokote in Arizona
  199. Smith Miniplane Winter Project
  200. Skyshark TBM Avenger
  201. Where is the balance point on a Patriot, 'prop driven jet'
  202. Bucker Jungmann 2 120
  203. Found a Ohio rc 33% Ultimate
  204. Has anyone used Aerospan from Balsa USA?
  205. Great Planes Ultimate engine choice.
  206. PICA N-Struts
  207. checkering with monokote
  208. Can we tap and thread a CF wing tube???
  209. Adding Tail Weight...
  210. Great Planes cap 232 Kit
  211. I want to paint my scale model, what is the best technique?
  212. lost Bud Nosen A&A industries trainer plans
  213. Corsair KIT?
  214. Curare 40??
  215. 69" corsair kit
  216. engine choice and servos for 1\3 330l
  217. Lazy ace bipe
  218. How can I attach the cowl?
  219. Any Ideas?
  220. GP Ultimate Bipe and engine size?
  221. kit building tools
  222. GP CAP 232 - how scale is it ?
  223. Too much weight?
  224. Will this work?
  225. aileron install question
  226. Venture 60 Construction
  227. 1/5 Scale PICA Waco N-Struts
  228. LT-40 covered with Sig Koverall + dope - Expect to use how much dope?
  229. Gaps between parts
  230. Rudder on Sig Somethin Extra
  231. Pearl White Ultracote
  232. CA Extra hinging problems
  233. Anyone built a CA Widebody?
  234. G Planes Ultra sport 40 ARF
  235. New Skybolt Video
  236. Mr AERODESIGN
  237. Kittyhawk Models- still around??
  238. patching a Glow fuel tank
  239. Where do I get a cowl?
  240. Partenavia P68
  241. sig skybolt
  242. Good first kit after flying ARFs?
  243. Nosen P-51 flap modification
  244. Full Length Hinges?
  245. Hinges
  246. Newbee Kit Builder Equipment Tips
  247. Best engine for House of Balsa Fw190a4 ??
  248. Aileron Setup
  249. Skyshark Fantasy Question
  250. Sig spacewalker II
