PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70
  1. Help! Need Bridi AT-6 plans!
  2. D-tubing construction...
  3. Dazzler
  4. Can someone ID this please?
  5. I want to buy a someones kit collection!
  6. Large Super Stinker Question
  7. Sig Kougar and a .61
  8. attaching fiberglass cowls
  9. Is it necessary to use cap strips on top and bottom of wing ribs?
  10. Need Help with Engine Mount
  11. Questions on Sig Kits
  12. Venture 60 Wing Clip Question
  13. Eagle II Wing Tips
  14. seeking builder in austin texas or close
  15. Ultrasport 60 question
  16. PT-60 anyone?
  17. Firewall Question?
  18. Yet Another covering question
  19. Midwest Stinker
  20. Balsa U.S.A. 1/3 scale Cub clipped wing
  21. Telemaster Vibration??
  22. Midwest Cap 232
  23. Hangar Nine PT-19 help
  24. help with duel elevator servos
  25. Morris Hobbies Hot Hots long kit
  26. mounting saito 100T in Gp CUB 60???
  27. Lightening Mods for MW Extra300
  28. I have the plans(tif format) extra 300 goldberg
  29. A-26 Construction Log - Building the 7th Chadwick
  30. How to 'glass wing join without clogging torque rods?
  31. Royal P-38
  32. Marutaka Zero Help
  33. do you drink beer........Read more
  34. Muffler in cowl for CG Chipmunk
  35. Styrofoam wing, removing a bow condition
  36. Dyeing Canopies?
  37. What's Your Favorite Hinging Method and How Do You Seal Your Gaps!
  38. Marutaka Cessna 310Q Kit
  39. Anybody "90" a GP Ultimate 40
  40. Aligning the VERTICAL STAB on Extra 300
  41. Ace T-34 CG how far back from the LE ??
  42. Cloud Dancer 40, flight report
  43. wing kit+complete kit
  44. 4-stroke for Goldberg Cub
  45. Slight wing warp
  46. Monokote vs. Oracover color matching ???
  47. 30% Carden Cap
  48. New GP Kit: Rapture 40
  49. Sig Doubler II
  50. GP Super Skybolt?
  51. Goldberg Ultimate C/G, how far back can you go?
  52. Skyshark Kits?'s
  53. Electrical solder
  54. Dubro 2-56 pull-pull sytem
  55. Need Advice on Engine for Venture 60
  56. OK forget all the rest!! Ultra sport 40!
  57. Dihedral on Bridi Escape
  58. help! pushrods for a PT-Electric kit
  59. is the kit easy to build?
  60. Builder wanted in NE area....
  61. Eagle 2 ARF Ultracote RIP!!
  62. Builder wanted for 1/2 A kits
  63. Unionville Fleet Finch need advice.
  64. Covering Question
  65. Tiger II mods and Engine choice
  66. Engine Weight for SE
  67. Sig SE and Fiberglass Specialties cowl
  68. plans required
  69. Global Skylane Kit
  70. Vertical Stab off by 16th inch - help!
  71. Engine for Sig 4 Star 40
  72. Ace 4-40 Bipe
  73. DynaFlite Fly Baby
  74. B@D retracts for TF Airacobra
  75. sig hog-bipe question...
  76. CGM Eagle II Kit
  77. lets see your custom servo boxes
  78. Telemaster 40 NG conversion
  79. Ultra Sport 40+ Wing Foam or Balsa?
  80. RGM's Waco
  81. Converted CG Extra 300 to wannabee EDGE
  82. What do I need
  83. Painting v.s. Covering: Your Thoughts Pls.
  84. Molding a canopy into the hatch
  85. "Kit Bashing" a Mid*40
  86. Where Do You Get Your Covering ? ? ?
  87. Recovering plane... little help with tail section.
  88. SIG Something Extra, GP Skybolt or GP Ultimate
  89. home for my Saito 72
  90. Midstar C.G.
  91. new engine won't fit need ideas...
  92. Best type of CA adhesive for general use?
  93. What is "Cyano FX"?
  94. Monokote, Ultrakote, what sticks to what?
  95. Project: HOB 1/2 A P-51D Mustang
  96. Best way to paint a cowl high-gloss?
  97. Marutaka (Royal) B25 Plan Sheet
  98. Sig 4*40 Tail Wheel Assy
  99. Building Question
  100. Soldering Wire to 1/16 in. wire.
  101. CF langing gear for GP 40 size Cap
  102. info on d&l design edge 540 60 inws
  103. Sig Somthin' extra weight
  104. Sig LT-40 Balancing
  105. Hing Question
  106. Wing hold down methods on Stik
  107. Goldberg Sukhoi
  108. RV-4 Aileron Servos
  109. Help stripping a cowl.
  110. Bill Evans' Pole Star
  111. Manual for Patriot
  112. weight issue
  113. Opinions of GP Ultimate Bipe 40 size
  114. retract switch push rod...
  115. Need help choosing second plane
  116. DuraPlane Engine Mounts/Firewalls
  117. senior telemaster / flat wing
  118. Whick One?
  119. Lanier Stradacher 600
  120. Starting a Venture 60
  121. Mud Duck Aviation
  122. Are kits updated?
  123. GP 40 size CAP
  124. Goldberg kit question
  125. canopy mounting?
  126. Balsa USA Phaeton 90
  127. Great Planes 33% Extra Project
  128. The plane you helped me to build
  129. Covering foam wings
  130. Goldberg Ultimate Help
  131. company or people who build for others
  132. What Glue is BEST ???
  133. Waco wing tips
  134. Telemaster 40 Ailerons/Flaps
  135. Cable soldering problems?
  136. Dark Yellow Ultracote.
  137. Dumas walnut piper
  138. Balsa USA 1/3 Sopwith Pup
  139. i turned 16 today guess what i got
  140. Global A1 Skyraider Kit ???
  141. Bipe for Saito .72
  142. Chris Foss - Acro Wot
  143. WOT4 Air Brakes
  144. aileron rib uniformity
  145. Tinting a canopy
  146. Radio South Paint
  147. Dynaflite Cessna Plans
  148. TF Cessna rear window
  149. Ikon N'west TaperWing Waco
  150. Fly Baby Bipe
  151. kit bashing....an eaglet 50 into Jr. Tiger
  152. Where did the Midstar go?
  153. Northstar by Balsa USA
  154. covering 4*40
  155. New project
  156. 1/5 GP .40 ARF J-3 Cub interior
  157. Sig 4 * 60 FiberGlass Cowl
  158. Phaeton II Owners
  159. Tiger 60 Mods
  160. 1/5 Super Chipmunk
  161. Spirit Kit - Any building advice?
  162. Charger MKII - Walt Moucha (vintage bipe kit)
  163. Black Barron Special by Coverite???
  164. Sig Astro Hog
  165. Goldberg Sukhoi Question
  166. Anyone pinned like this
  167. Tiger II
  168. Hatch lock - any smart ideas?
  169. A whole wing in one day whoo hooo!!!
  170. Securing Electronics
  171. COVERING MATERIAL
  172. PAINTING A CANOPY
  173. need help mounting engine
  174. Sig Kougar Questions...
  175. Tissue & dope
  176. balsa usa enforcer
  177. Help!!! Great Planes Trainer 40 plans?
  178. 25% Aeroworks Edge 540
  179. DELETED POST DONT OPEN
  180. pt electric kit.. first timer..
  181. Building Error.. Will it fly????
  182. GP Cub 40 - Flaps and Floats
  183. Profile 38
  184. Dual Aileron Servos on a Sig Kadet Mark II
  185. NEED LAZY BEE PLANS PG #3!!!
  186. Goldberg Ultimate
  187. jerry bates p-40 warhawk questions
  188. Kadet LT-40 custom symmetrical wing
  189. windscreen beading
  190. Thinking of building a TF Giant Corsair
  191. Y Connectors
  192. Balsa USA Stingray 120 ?
  193. CA Hinges vs. Pinned hinges... Your Thoughts/Advise ?
  194. About a Carl Goldberg extra >> problem
  195. Silkspan Techniques
  196. Glassing techniqes
  197. Duellist 2/40
  198. LOOKING FOR FIBERGLASS COWL TF 182 CESSNA
  199. Top Flite P51
  200. Kyosho Twin
  201. patriot horrors
  202. Preparing balsa for paint
  203. advice on jack devine warbird kits?
  204. Old ACE 4-40 Bipe -Help
  205. house of balsa enforcer kit
  206. Rubber Banded Landing Gear
  207. Cowling Aerowrks Edge 25 %
  208. Goldberg Sukhoi
  209. Sig 1/4 scale SpaceWalker II CG?
  210. Sig 1/4 Clipped Cub (Which engine?)
  211. OLD KADET mark 2
  212. Looking for a Biplane kit - BIG
  213. explain % sizes for extra 300 please
  214. 3rd plane for my .40 from trainer
  215. 3m75 spray adhesive
  216. My plane keeps warping!
  217. SIG 4 Star 40 with cowl
  218. covering on a Great Planes PT electric
  219. Great Planes Learjet
  220. 4mm Coro
  221. Retract air tank install location
  222. Pica 1/5 scale Mustang build pics please:-)
  223. Top flight 1/5 Mustang instructions
  224. GP f4 Phantom
  225. Reference books on building
  226. Sig Kadet Senior Ailerons
  227. Sig Kadet LT-40 step by step
  228. CG Ultimate kit w/ YS .91
  229. Worst tool ever...
  230. Sig Kadet LT-40
  231. Refinishing help!! - How to remove old paint
  232. Can you use dope only to cover with?
  233. Use CA Hinges??????
  234. pilots
  235. SIG Kobra CG Balance Point?
  236. fuel tank help
  237. Tires on StaggerBee
  238. Canopy attachment to painted, fiberglass hatch.
  239. 4*60 CG
  240. is this normal
  241. Delete thread plz
  242. Best Surface to Build on?
  243. DynoFlight Butterfly ?
  244. Sig Seniorita with ailerons?
  245. ailerons on a sig kadet senorita
  246. aileron installation
  247. LT-25 Folded Plans :(
  248. GP cap 232
  249. CG Ultimate Aileron servos
  250. Saturn Models Skydancer - any info ?
