PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70
  1. Great Planes RV-4 (Flaps?)
  2. Wanted
  3. GP vs. H9 cessna 182 ARF kits
  4. goldberg tiger 60 dihedral?
  5. warped balsa
  6. Dual tanks... ?
  7. purchasing balsa
  8. kit bash 4-120 bipe
  9. Four star 60/ cowl building
  10. 8 degrees right thrust?
  11. DOH!! TopFlite Screw up!!
  12. Name This Plane
  13. Recovering an ARF
  14. first GB eagle II kit
  15. Speedy Bee #2 is DONE!
  16. strengthening lite-ply in kits
  17. Plane painting question
  18. Engine mount
  19. Painting/Finishing
  20. CG bipe cowl problem
  21. which servos for goldberg ultimate?
  22. TF Elder 40
  23. CG Super Chipmunk color scheme
  24. Built Up Sheeting technique
  25. monokote or paint and epoxy
  26. Skyshark FW-190A8, anyone build it yet?
  27. Patriot Kit ?
  28. Modifying Balsa USA Laker
  29. Top Flite F4U Corsair Gold Edition Kit
  30. Spitfire
  31. placement for fuel hose in ultimate
  32. Landing gear reinforcement for U Can Do 3D
  33. Sig Koverall Question
  34. Giant stagger bee,
  35. A bad day at the flying field...
  36. Wood sealer for painting?
  37. Skytiger Jr
  38. Balsa USA Phaeton II or SIG Hog Bipe
  39. Mounting a canopy
  40. top flite DC-3
  41. Aviation Lights for P-47
  42. 1970's scale kits
  43. fixing plastic canopy
  44. sig 4*40
  45. Dazzler Ailiron adjustment help
  46. Which Cub
  47. Building Uproar 40 (pics)
  48. Starburst Graphics for DF Super Decathlon
  49. Living dinosaurs in the kit world
  50. Jamie's Piper Cub???
  51. Saito .91 or 1.00 / Sig 4*
  52. Dragon Lady.... Any Tips?
  53. The Dazzler is done!!
  54. Rear Servos on GP Giles 46 and other mods...project complete
  55. soldering landing gear parts
  56. Robart air fittings
  57. U Can Do 3D
  58. kit building price for another member
  59. Securing pushrods?
  60. professional balsa kit builder out there?
  61. Ultracote directly on fiberglass?
  62. KAOS kit ... Which One ????
  63. polyurethane - fuel proof?
  64. Which by-plane kit to build
  65. Sullivan "rubber nuts"?
  66. Poly Glue ??
  67. Help - Warped fuselage
  68. Bucker Jungmann Rollout
  69. Yellow Aircraft Cap 10B Deluxe Kit
  70. Kyosho Shrike Commander
  71. Covering a one piece plane is......
  72. Coastline RC Model Noorduyn Norseman
  73. Your aircraft mods, show and tell.
  74. fueling ?
  75. Vacuum Bagging?
  76. GP extra 300s Fuse length
  77. Control horns and sevo arms
  78. Covering Question
  79. help need pitts
  80. 4*120 Canopy
  81. SIG Kougar vs. Kobra
  82. Sig somethin Extra getting started, mods?
  83. Want to see a construction thread-- Midwest Extra300S-giant scale?
  84. Building burnout?
  85. Sig Tri-Star
  86. Few lazy Bee questions.
  87. B Usa Dviii
  88. Utimate?
  89. K and B Paint
  90. CG Super Chipmunk thrust angles
  91. source of information
  92. Aircore??
  93. Elder 40 plans wanted
  94. PT=17 kit...?
  95. Stab Incidence
  96. Spectra Motor Assembly
  97. question about 4*60 kit...
  98. Mounting Battery and Rx
  99. spinner
  100. Lazy Bee Special W/Ailerons 40"
  101. Great Planes Cub 40 - Covering
  102. novice builder
  103. Any Cap 232 kits with 72" span?
  104. Wing Warp Fix?
  105. Canopy glue??
  106. Building a built up wing
  107. Question for Corsair owners !
  108. Pica T-28 Detachable Wing Panels
  109. a different look.... for a 4* 120
  110. Rv-6 ?
  111. name this plane?
  112. What would be a good match to a Norvel .15?
  113. Dazzler turtleback help!!!
  114. Dazzler update begining to present
  115. Klett Hinges
  116. Sig 4*60 or Bruce Tharpe Venture 60?
  117. Another Hog Bipe Flies
  118. balancing goldberg ultimate
  119. Fuselage in two parts
  120. Need manual for Sig SE Kit
  121. Anyone know where to get carbon fiber Ultracote?
  122. anyone build a sig LT-25????
  123. Thick CA vs wood glue, strength?
  124. Mustang Bipe?
  125. TopFlite Corsair
  126. first bi-plane
  127. Aileron Servos For .40 Size Plane
  128. Marutaka Corsair 20
  129. First Bipe
  130. Making a cowl...any tips
  131. Leading edge wing, covering overlap
  132. Ultra Stick Question
  133. Rubberized CA???
  134. Warp Removel?
  135. kyosho ferias covering match
  136. transparent covering tidbits needed
  137. Need advice on building in an apartment
  138. Pica 1/5 WACO Kit, anybody built one?
  139. wing servo lead tubes?
  140. Float planes
  141. Joining Solite on glass
  142. wing bolts
  143. SIG Smith Miniplane vs. Hog Bipe
  144. Got both planes in the air today!!
  145. Great Planes RV-4 Plans
  146. kits will be gone soon?
  147. Gaps
  148. Goldberg Extra 300
  149. epoxy blues
  150. My monocote started blistering after 12 months... Help!
  151. Glenn Torrance Models
  152. Once and for all...which paint is fuelproof?
  153. Junk sealing Iron's
  154. Covering TF Contender Wing Tips
  155. Where to get Ultracote?
  156. Can I use thick CA on plastic hinges?
  157. Tip to Tail length?
  158. gp extra 300 .40 dihedral
  159. Has anyone noticed Tower doesn't sell Ultracote anymore?
  160. CG Ultimate cabane repair
  161. Dazzler on the board
  162. Tiger 2 completed
  163. PT-40 completed
  164. Wing Construction - all balsa or sheeted foam?
  165. bte super flyin king
  166. Missing parts for GP 1/3 Scale Extra
  167. Proctor Nieuport 28 project
  168. what is link to pica manufacturing?
  169. Pica RC-7 Jungmeister BU-133
  170. HELP!! identify plane
  171. Goldberg Sukoi landing gear
  172. What iron on covering works for you???
  173. fuelproofing
  174. Cig Citabria on the building board - any tips?
  175. re-covering the skin of a lanier arf??
  176. Balancing TF Corsair
  177. Machining a 4 - Blade warbird prop
  178. What engine would you recommend for a CG Ultimate?
  179. Aileron and Elevator or Rudder and Elevator
  180. GP RV4 aileron
  181. sig 4* 120
  182. First Kit
  183. Getting ready to start building the Dazzler
  184. HEY,Sig 4*60 Bldrs
  185. Dubro Hinges
  186. painting my scale!!!!
  187. Building instructions/plans for CM A-10
  188. house of balso stand off kits
  189. Please Help.
  190. Tiger 60 Construction Re-re-re-re-visited :)
  191. Supertigre on Uproar, Good fit?
  192. Cowl REPAIRING
  193. construction stand for wing.... and fuse too.
  194. West Epoxy System?
  195. Triangle stock and tail feathers
  196. Goldberg Ultimate instruction manual
  197. Where's Midwest Sukhoi CG?
  198. How do I make a "building board" for a P-47????
  199. balsa and bass wood-where do they come from??
  200. Minnflyer's sheeting repair article
  201. Fuel Proofing under Ultracoat?
  202. Suggested Mods for Astro Hog?
  203. fluorescent transparent ultracote?
  204. Whats the advantage of glassing or covering with film?
  205. Tiger 60 retracts question
  206. OK to freeze CA?
  207. Best kit manufaturer??? Opinions welcome.
  208. I am never using monokote again, ever
  209. 12 year old daughter wants to fly now.
  210. Kit for wife after she solo's?
  211. help need plans for vintage kit!!
  212. Let's see some Ultimate Bipe covering jobs...
  213. Solartex question
  214. Moving thrust line
  215. GP Ultimate Bipe
  216. What to build???
  217. Pica Cessna 182
  218. Ohio 27% Extra Ready for Covering!
  219. first and last pictures of Zlin Acrobat
  220. Did something Stupid
  221. Gp Patriot Tank Hatch?
  222. AW 1/4 Edge 540 questions
  223. gp f4 Phantom throw rate
  224. Advice for first kit?
  225. contender CG
  226. Hob At-6
  227. GP RV 4 Flap Set-up
  228. GP Corsair Dihedral Gauge Question
  229. great planes slow poke .40 ele. throw
  230. Ben BUckle Fokker HELP!
  231. GP Extra .60 Wing Warp
  232. lazy bee question
  233. GP Dazzler
  234. short kit's where to buy
  235. any one built a stangel short kit
  236. Goldberg Ultimate canopy
  237. whats the real difference in CA ?
  238. finishing resin vs. glass
  239. question on CA
  240. sheeting turtle deck RV4
  241. Pilot DJ3
  242. Recently discontinued kits...
  243. Does anone have H9 330L building plans?
  244. Need Help With Retract servo Setup
  245. Gluing firewalls
  246. what did you do to get rid of weight in your GP cap 232 kit ?
  247. Sig Wonder Down....3 to Go
  248. building without hold downs
  249. Hitec servo question on my wings.
  250. painting instead of covering
