PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70
  1. Battery location, Herr Cub
  2. Drill size
  3. Thunder Tiger 42 GP and a 4 Star 40??
  4. Ultra Sport Plus Advise
  5. RV4 flaps and such?
  6. All American Kit Cutters
  7. Basswood Spars
  8. ACE scale "Clipped-Wing" Taylorcraft
  9. please help
  10. Building services
  11. US40+ Pic 2
  12. US 40+ Pic
  13. Goldberg Clipped Wing Cub-engine choice?
  14. Magnum 1.08 for the GP u-can-do-3d?
  15. *Tail Wheel for Tiger 2*
  16. 60 size Super Aeromaster Biplane
  17. Great planes fuel tank ?
  18. V tail kits?
  19. Chekers on my cowling?
  20. Gluing balsa on a glass table
  21. tiger 60 GAS ENGINE
  22. Help- Fuel Tank For My Cg Extra
  23. Is it a sin?
  24. CG on a hots
  25. TopFlite p51
  26. Help! How much Ultracote is needed??
  27. Another covering question...
  28. Chips Acro maiden flight
  29. T.T. Pro 46 or Tower 46?
  30. Covering - What type? Silk or Plastic?
  31. My latest toy
  32. Canopy Source
  33. All done!!!
  34. Filling in large areas in Trailing Edge
  35. Cowl fitting (AGAIN)
  36. Anyone in the universe got a Speedy Bee?
  37. trimming monocote with paint
  38. tiger .40 vs four star .40
  39. Sig Fizer Wing Help
  40. 4 star 40 monokote trim question?
  41. combat models a-10
  42. Sig Mid-Star 40 - Roll problem !
  43. Bought Ultra Sport 40 kit today. Enquiring mind needs advice
  44. How do you secure kevlar on pull-pull?
  45. Beechcraft Baron - control horn issue
  46. new Tiger 2 ?
  47. Almost finished!
  48. Help with wing hight
  49. sig kits
  50. Need a Pilot for my 1/7 Spitfire
  51. Joining a wing
  52. Robart Hinge Placement
  53. Colombo-Anderson Models 27% 300L Build by RSlocum
  54. Bridi XLT
  55. Building 60 topflight Corsair
  56. C.G. Ultimate Biplane
  57. wanted plans for a 049 size falcon
  58. balsanova 1.2
  59. Top Flite Elder 40
  60. Gluing windshield on a Slowpoke Sport 40
  61. bob dively models how to reach
  62. Venture.60
  63. UHU Hart Glue
  64. Somethin' wheel pants
  65. Proctor Nieuport Fuse bracing "wires"
  66. Carbon fiber pushrod system sizing
  67. recommend inexpesive kit (feeling cheap!)
  68. Sportster 60 dihedral
  69. Wanted: Plans of Bridi "Chipmunk"
  70. Ca Glue On Monokote (removing)
  71. what to build as number two
  72. Canopy Glue - Secrets to Sucess??
  73. New Hangar 9 covering iron ?
  74. Sukhoi Kit?
  75. edge 540 25-27%
  76. How to build a cowl from scratch.
  77. Direct Connection Kit
  78. Sullivan tail gear spring
  79. Need Lazy Bee balance point
  80. Pilot model kits?
  81. Covering corners
  82. anyone heard of a MOTUM plane before ?
  83. Studs for tail mount - Supplier is???
  84. Solder clevises? How to?
  85. GP 10-300 Ultimate Wing's
  86. Covering around symmetrical stab joint
  87. Nelson Paint?
  88. 5-15-30
  89. Nieuport 28, the beginning
  90. TF P47 Gaint Scale Questions
  91. Airfoil GP Extra 300s
  92. G.P. PT-40 balanceing
  93. beaver kits?
  94. Tinting a canopy-suggestions?
  95. T2
  96. Uproar 60 Balance
  97. Help me cut ailerons from foam wing
  98. Profile plans wanted
  99. Anyone built a Sig Liberty Sport
  100. Mufflers
  101. Skybolt vs Hog Bipe
  102. Goldberg Extra cowl
  103. AGWagon RC Plans Wanted
  104. Reccomendation for spinner nut/cone on OS .91 4 stroke?
  105. Debonding Titebond Wood Glue
  106. DB SE5a, anyone else?
  107. Sig vs. Midwest Citabria
  108. Pilots
  109. How to smooth CA 'hard spots' in balsa
  110. finishing balsa
  111. Next project - Something for my Saito 72
  112. Want another CA Models 27% 300L building Thread
  113. GP Super Skybolt vs. Goldberg Ultimate
  114. kit/plan Vulcan B2?????
  115. Goldberg Tiger 2
  116. CG Super Chipmunk landing gear
  117. Zenoah G26 Fuel Tank
  118. Building Top Flite P-39
  119. Correcting Screwup - Thanks For The Help!
  120. Robart Hinge Points
  121. engine for Astrohog?
  122. Fuelers - The real truth sought
  123. House of Balsa P-51
  124. Need help finding kit to build
  125. My GP Super Skybolt Project
  126. Can I use fishing line for pull-pull?
  127. Chrome Ultracote or Monocote
  128. Fuel Tank for Sig SE?
  129. tiger 60, how much does yours wiegh?
  130. Throttle link Q'
  131. Direct Connection Wing Rib Patterns Wanted
  132. "Wing mounting" 4 Star 40 "NEW BUILDER"
  133. Replacement for H9 Ultrastik 40
  134. Need a few airplane plans!
  135. Anyone built the 1/12 Pica P-51
  136. Hobby Lobby Cobra EPP
  137. Spray Paint???
  138. Pete n Poke
  139. Cub blue/white military trim scheme, ideas?
  140. Need plans for Hobby-Lobby Telemaster!!
  141. Tiger 60 finally covered
  142. Goldberg Chipmunk....which muffler??
  143. monocote vs. ultracote
  144. Best engine for Sig SE?
  145. Can you recognize this Aircraft for me ??
  146. Goldberg extra/webra 120?Too much?
  147. Need Help with Top Flite Spitfire Retract Fit
  148. Senior Kadet HELLPP!!
  149. volksplane
  150. Laser 3d
  151. Os 35 Fp
  152. My new website!
  153. 1/5 Scale Cessna 182 Skylane (Pica)
  154. Ultimate G.P. Bipe .40 Engine problem
  155. Lazy Bee engine choice
  156. Engine offset calc....
  157. 90" Clipped-wing Ace Taylorcraft Kit
  158. Dyna Flite Fun Scale Spitfire Manual
  159. Problem Solved
  160. Soldering Landing Gear Wire
  161. Precision Fiberglass contact
  162. Rv 4 Dihedral Problems
  163. Thinning Down Finish Cure for Glassing
  164. V Tail alignment
  165. Wing fillet help on Top Flight P-51D
  166. monocoat question
  167. Number of kits untill become a non-idiot?
  168. easiest way to make a large building board?
  169. "KIT HELP PLEASE" Biggest fuel tank 4* 40 ?
  170. One last hog bipe question - Windshield
  171. Biplane Wing Incidence
  172. Sig Somethin' Extra Cowl.
  173. First Time Kadet Senior Builder Advice
  174. Anyone here build kits for other people?
  175. Chipmunk Fly Bay or PT19 Plans help
  176. Lt40/lt25
  177. YS .91 doesnt seem to fit into cowl for lil cap 232
  178. Centering Hinge hole on aileron
  179. GP Super Skybolt, Wing Spars
  180. Which Extra To Build?
  181. Attaching canopy with silicone
  182. Stinger 120
  183. Does Monocote have a "direction"
  184. Covering Question
  185. Ohio Model Planes Edge 540 questions
  186. Falcon 56 Question
  187. C.G. Eagle 2 Bashed
  188. Fuel proofing field box
  189. Paint and primer
  190. Bob Godfrey - Citabria Pro
  191. bridi sunfly 60
  192. GP Super SkyBolt
  193. CGExtra Landing Gear
  194. TF Corsair
  195. 2nd pic
  196. Please see my engine installation
  197. Engine swap issue, advice needed
  198. Building the Balsa Nova 40 tips tricks etc
  199. Klett hinges by Carl Goldberg
  200. Buckner Jungmeister plans
  201. My new WING PRESS
  202. aileron hatch covers?
  203. 4 STAR 40 Ailerons "HELP PLEASE" At a stand still.
  204. Scorpio Safari
  205. Canopy tinting with Blue Rit
  206. covering with film
  207. Lindberg Sirrus
  208. Decals and CG Balance Help
  209. Decals for Great Planes Extra 300 .60
  210. CG SOPHISTICATED LADY....building improvement tips???
  211. Fiberglassing
  212. Balancing my GP Ultimate Bipe
  213. Covering a F4U
  214. Cub Interior
  215. Got my GCM Ultimate up today
  216. warped ailerons
  217. GP Ultimate Bipe Help
  218. I need 1/4 scale Nosen Cub plans
  219. Carl Goldberg Cub and A Magnum 52
  220. Prefab wheel Wells
  221. Kyosho Wingmaster Ultralight-Help!
  222. F4U Corsair cooling flaps
  223. Do,s & Dont,s "4 Star 40"
  224. My bashed 4*60 bipe
  225. Canopy can o'worms
  226. 1st kit questions
  227. Professional Builder in Florida or Georgia?
  228. GP piper Cub
  229. Jamara Ford Flivver
  230. Here's a nice addition to your Robart Incidence Meter
  231. Royal Staggerwing
  232. Dihedral for GP Skybolt
  233. Pica Waco Bi-Plane
  234. Kaos wing kit?
  235. Dazzler Kit Mods
  236. What to do?? Kit's assembly is designed for CA!!
  237. First kit to build?
  238. KADET LT-25 Dihedral
  239. fuel proof spraypaint?
  240. Giles .46 wing
  241. Motor for 60 size GP 300S?
  242. CA fumes..... Bah.... I'm tough!!!???
  243. In the process of bilding the wing on my PenKnife
  244. Aged Monokote
  245. I need a light covering
  246. Building Newbie error - Now what can i do ?
  247. Hobby Poxy / Epoxy Paint
  248. Monokote on cowl?
  249. pica spitfire canopy ?
  250. 1/4 scale TIGERMOTH kit
