PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70
  1. Goldberg Sukhoi help?
  2. Balancing Hog Bipe
  3. ARF Weights
  4. Coverite Gee Bee E (QUESTIONS?)
  5. Finished my first kit and I'm hooked!
  6. looking for good builder in the nyc that has free time to finish up a few model
  7. After glass prep
  8. Shoestring plans
  9. covering help
  10. Wanted ; Instruction Manual Ohio 62" Ultimate
  11. Monokote wingtips radius cuts?
  12. When to use CA vs Epoxy?
  13. Monokote dips between ribs?
  14. Stupid question.. Cover over wood ???..
  15. Top Flight P-40
  16. Finished at last!
  17. pacer hinge glue on CA hinges into foam?
  18. Sliding canopy
  19. Painting advice needed
  20. Hog Bipe
  21. Top-flite giant p47 construction.Currently building the right wing panel.
  22. sheeted foam wing adhesive
  23. GP Ultimate Bipe pilot figure size - manual is wrong!
  24. Wing Jig
  25. Silk Or Koverall?
  26. Utter Chaos servo?
  27. Help Please! Pica 1/5 Waco
  28. American Kit Cutters Vs. Precision Cut Kits
  29. Show me your bellies!
  30. Corben Baby Ace by Bridi ??????
  31. Transparent covering hues
  32. Four star 60 sanding
  33. Sig Somethin' Extra Building Question
  34. Hing Slot Cutting, need help!
  35. Conachen Sea Fury
  36. Aerodrome Models Jenny JN4
  37. Canopy ventillation?
  38. instruction manual for Eagle II
  39. Older kits??
  40. Thunderbird paint scheme
  41. PICA Corsair 1/8 Servos?
  42. choosing the airfoil
  43. Pete N Poke Added Strength
  44. Sig 1/4 Cub servos
  45. GP .40 Cub, Clipped wing or full size?
  46. Page Aviation Gee Bee R2 Kit
  47. hog bipe pull pull and fuel hatch
  48. shaping leading edges and wing tips
  49. first time kit builder
  50. Tower Kaos/Ultrasport?
  51. Desktop kit
  52. Midwest Messerschmitt Kit .40-.46,54"
  53. Great Planes,fokker Dr-1,arf
  54. Pitts muffler for Enya 50cx
  55. Kadet Senior 2 piece wing question
  56. Covering over fuse opening?
  57. VK Cherokee babe
  58. Woodpecker
  59. Warped ply 1/4"
  60. Trike to Taildragger conversion advice needed
  61. Piper Arrow 2
  62. Great Planes Old Timer .40-Opinions?
  63. Slotted CA Hinges?
  64. 2 BUILD or NOT TO BUILD
  65. Is Tremclad Fuel Proof
  66. GP Extra 300 (60) Flys!
  67. Sig Kadet JR Aileron mod 3 of 3
  68. Sig Kadet JR Aileron mod 2 of 3
  69. Sig Kadet JR Aileron mod 1 of 3
  70. Saito 45 & Sig Liberty Sport biplane??
  71. Extra 300S cowl
  72. 20 years of storage
  73. Sig 1/4 Piper Cub
  74. Bending thin plywood
  75. Kits
  76. Sig Ultimate Profile
  77. Cold weather storage
  78. Ohiomodels edge540
  79. Sig 1/4 Cub Windows
  80. placement of strobe and navigation lights.
  81. wanted pearl monocote
  82. Global Dehaviland Beaver 40
  83. will a saito .91 work on kadet senior
  84. Cheveron color match a joke!!!
  85. kit bashing
  86. Super Coverite?
  87. covering questions
  88. Wing Incidence
  89. GP Ultra Sport Plus 40 2 stroke or 4 stroke?
  90. Anyone Built A GP Patriot Kit?
  91. MidWest Extra300s
  92. New Sig Cub vs old Sig cub
  93. Re-Forming fuel tank.
  94. Is this an Aliphatic glue?
  95. i need tip's on cuting mono coate
  96. Bridi Rockwell Mustang....experiences?
  97. Nylon filament strapping tape ????
  98. Piper Arrow 2
  99. TF Corsair fuel tank placement
  100. Sig Kadet Senior - Balance
  101. More questions for 4*60
  102. Dare Wright Flyer
  103. seugston for panting and covering's
  104. Ultracote
  105. Shorter Langing Gear Questions?
  106. tip on C A
  107. What to Build for my Saito 91?
  108. Retracts for TP Spitfire???
  109. Need Sig Kougar Mark II Instruction book
  110. Mirage F-1C
  111. metal to metal RF interference...
  112. sig Kadet MArk II
  113. HELP Identify this plane.....
  114. quick! need a cheap wood sealer/spray paint
  115. Countersunk Soket Head Screws?
  116. Urethane Glue Opinions
  117. For those who have this combo
  118. Always get air bubbles when mixing epoxy...
  119. pushrod help
  120. cessna 182 topflight?
  121. Control Rod Installation Problem
  122. Gp Extra 300s 60 size
  123. is os .61 too big for gp 300 40 kit
  124. Piper Cherokee or Piper Comanche
  125. Sig Kadet
  126. 1st Time sheeting wings, vacuum or weights?
  127. What am I building
  128. Frustrated at building
  129. GP Slowpoke .25
  130. stupid mistake - wing warp
  131. My GP Extra 300 .60 setup
  132. No more ca hinges.
  133. Crease CA Hinge?
  134. Tailwheel
  135. Top Flite Spitfire Elevator to Stab fit
  136. Pull-Pull Wire Connection? Crimps?
  137. why can't they give you a decent cowl?
  138. Microballoons
  139. Superchipmunk radio setup
  140. Plywood fuse screw-up fix
  141. Any plans for Miss San Bernardino ???
  142. How to- covering with fiberglass
  143. Top Flite P-40 cockpit
  144. What a mess!
  145. Which epoxy for wing joint fiberglassing?
  146. how many ounces does one can of lustrecote add?
  147. CG Anniversary Cub
  148. any comments please on the protech Onyx F3A kit.
  149. 4*60 LG fiberglass reinforcement
  150. BUSA Phaeton (not II or 90)
  151. Decal sources?
  152. Aileron warped?
  153. Sig LT40 Help**Done-Thanks
  154. GP extra 300?
  155. Glue for ABS Plastic
  156. Nib files for removing ca glue spots
  157. robart hinges
  158. True Red Lustercote Help!!!
  159. Hinge Question
  160. Thank's Fellas,thank's Alot :)
  161. How do I modify a canopy shape?
  162. Looking for a good kit for My G-38
  163. Rit Dye - How long?
  164. Sheeting Foam wing
  165. G/P Extra 300S help PLEASE!!!!
  166. twins
  167. Great Planes 330l
  168. Acrylic Lacquer
  169. 2 stroke or 4 stroke for F4U Corsair
  170. Information Appreciated
  171. Building in, "Washout"
  172. ok so here the cap i'm talkin about!
  173. Solder help?
  174. Four * 60 - What motor to use???
  175. Canopy glue
  176. Dust Control?
  177. Two piece cowling - worth the trouble?
  178. Butane torch
  179. Splitting a cowl for mounting a twin cylinder engine
  180. Show me your mess
  181. Gp F-4 Pictures
  182. Best adhesive for plywood fuselage
  183. Hog-Bipe vs. Pica 1/6 Waco
  184. Come On Now Sombody Has To Have Built This Kit
  185. Hobbico retract modification
  186. Line drawings for Color Scemes?
  187. !/4 scale cub-Saito 150 mount..HELP!
  188. building frame for glass topped table
  189. Threading 1/8" dia piano wire
  190. Super-Thin CA Fails
  191. wing tip help
  192. 4 Star 120 w/G38
  193. Bates SBD Dauntless 85"
  194. TF Elder Bipe CG
  195. Fiberglass cowls
  196. Senior Telemaster Bomb Bay
  197. Senior Telemaster reincarnation
  198. Wax Paper sticking
  199. Profile sheeting adhesive
  200. D& L Designs kit need help
  201. Altech Stearman model
  202. wing alignment on profile
  203. wheel pants for a 4 Star 60?
  204. CG Bucker Jungmann Update
  205. GP 40 Corsair Kit
  206. Fiberglassing the Great Planes RV4 Good idea or bad idea?
  207. 4 * 60 Gc
  208. Fiberglass Cowling Source
  209. 4 * 60 Gc
  210. Chrome Monokote
  211. Sanding trailing edge angle accurately
  212. Carbon copy landing gear and Sig SE?
  213. Question on adhesives?
  214. My Something Extra
  215. Lanier Stinger 10...what engine?
  216. Carl Goldberg Sukhoi - shipping date?
  217. Cutting small balsa
  218. aite
  219. how about this?
  220. Experience with a BTE Flyin' King ?
  221. Enya .80 Giles 202 Combination?
  222. engine location
  223. Four * 60 bipe
  224. BALSA USA Thunderbug 40
  225. Epoxy or Ca for sheeting?
  226. Sealing Hinge Gap...
  227. Fiberglassing a P-51
  228. CA Hinge Removal?
  229. Help with Giant Extra 330L GP kit
  230. Ultra sport 1000 with OS 140RX
  231. Construction Manual for a Sig Kiwi
  232. Flames
  233. Where can I get a DH 88 Comet kit
  234. Lowes/Home Depot table
  235. Four Star 60 Wing
  236. How much fuel line is needed from firewall?
  237. How to Prepare for painting??
  238. building wing tubes
  239. Ultimate Setup
  240. GP Cub 40 questions
  241. 2nd Build 4 * 60
  242. Covering?
  243. Contender Kit
  244. Band Saw-Scroll Saw????
  245. Building a Lynch's Hanger combat 2.7.
  246. Have you used Robart hinge points?
  247. Searching for Super Chipmunk plans
  248. scratch built acrobat
  249. Great Planes Patriot...Hobbico Retracts??
  250. Xmas
