PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70
  1. Color Scheme for SE
  2. Glass wrap one piece wings?
  3. Best Chipmunk?
  4. Lanier Shrike 10-20 Size
  5. Ace Bingo Series
  6. WOT 4 wing joining
  7. P-38
  8. To Glass Or Not To Glass?
  9. Modeltech Giles 202
  10. pica duelist
  11. Anyone know where to get a large size Roadrunner Kit?
  12. PP Convertable Questions
  13. Maratuka Kits
  14. Online plans ?
  15. 3" Wide Aileron Stock
  16. Painting then Covering
  17. Solartex
  18. Tell me about your Top Flight Contender
  19. Mentor T34B
  20. Covering Designs
  21. goldberg chipmunk wing kit
  22. Big Stick 40, Tail dragger ?
  23. How do you cover your tail surfaces?
  24. Covering and Canopies
  25. GP Extra 300 60 size Building Hints
  26. Do you have stories of missing parts?
  27. Bridi Kits
  28. Foam wing building
  29. Great Planes 60 size 300S kit
  30. Balsa USA Eindecker
  31. Buidling for survivability
  32. Get edge 540 plans
  33. AK Models not MK Models 3D Freedom
  34. MK Models 3D Freedom Kit, any experience?
  35. The future of coverings???
  36. new kit, GP Slowpoke .25
  37. 4 star and 4 stroke throttle set up?
  38. Where Do They Come From
  39. Covering question
  40. camouflage covering
  41. GeeBee Dreamer Bipe?
  42. Need mods for building Stinger 120 Gas
  43. HELP !! Flat-Side Bowed Elevator
  44. Dymond Giles
  45. Taylor Craft again
  46. Taylor Craft Kit
  47. Guillow's Balsa F4U-4 Corsair Question
  48. Top Flite P-47 cockpit
  49. Butyrate
  50. Moved
  51. need wing kit
  52. good kit for a .30 OR .52 4-stroke
  53. white glue
  54. what did santa bring
  55. Sig Hog Bipe mods & tips.
  56. Great Plains Ultra Sport 1000 Vrs. RCM Ultra Sport 1000
  57. Need CG for Sig Four Star 120
  58. HIDDEN CONTROL HORNS/CABLE vs PUSHROD?
  59. color scheme
  60. Warped stab, how to correct? pre covering stage.
  61. Great Planes Super Sky Bolt
  62. CA smear removal
  63. Hello and suggestions for 4* 60
  64. so far so good
  65. West Systems Epoxy
  66. senior telemaster diehedral
  67. 21st Century Fabric
  68. Please close post Ultra Stick 40 Question
  69. Super Coverite Availability
  70. Lazy Bee Kit Good Or Bad
  71. jkaerotech T52
  72. Ak Models Mig-29, Anyone Install Retracts?
  73. B&D Retracts on a GP Patriot?
  74. Warped four star elevator
  75. WIng and Fuse Jigs?
  76. difference ultracote and ultracote light
  77. Sig Somethin' Extra
  78. clear paint?
  79. Phaeton 90 Engine mount, how
  80. Kadet LT 40
  81. 4*40 servo tray mounting issue
  82. B & D retracts
  83. Beaver trim schemes
  84. Warped Ply Doublers
  85. looking for a "Robinhood"
  86. Bill Evans Simitar
  87. GP F-4 incident problems
  88. ohio rc extra 300L CG
  89. Painting Fiberglass Cowls?
  90. Do you sand laser cut edges?
  91. Lainer 33% extra 300s
  92. Great Planes P-51D wing fillets
  93. Tower FUN 51 First Kit ... Recommended?
  94. Crusader II kit - who makes one?
  95. Making a Cowl???
  96. GP Ultra Sport 1000
  97. Top-Flite Corsair or Thunderbolt
  98. Main Gear for Super Sportster
  99. HOB extra 300L with dual aileron servos
  100. Wings strong enough?
  101. Epoxy - 5 min vs. 30 min
  102. Sealing Decals - Hog Bipe
  103. Big Beaver Update
  104. Wing Ding?
  105. P47 Ziroli ..a lot of questions....
  106. duraplane aerobat 40 engine mount
  107. Plastic turtle deck finishing question.
  108. I see what yall mean!
  109. fabric covering question
  110. fiberglass cowl
  111. GP Adjustable Engine Mount
  112. Big Beaver
  113. camouflage covering
  114. Monokote & Econocote
  115. Twisted Patriot Fuselage
  116. 4* 120 wing joiner question.
  117. PAINT vs COVERING ON BALSA?
  118. 4*40 kit bashing
  119. Robart 605s
  120. Robart Hinge Points - what size??
  121. Great Planes Cap 232 40
  122. CGB Super Chipmunk
  123. Great Planes Cap 232 40
  124. Fiberglass Parts
  125. Scroll or band saw?-which one for most uses?
  126. Pica or TF 1/6th scale Spitfires
  127. CG Skylark ... COG and Info?
  128. Top Flite AT-6
  129. Topflite Spitfire???
  130. Surface prep prior to covering
  131. Help on 8' beaver
  132. GP Cub 40 Ailerons Servos
  133. Does sheeting increase strength?
  134. Wing MFG Kits
  135. 4 Star 40 - Clipping one wing bay?
  136. Somethin' Extra Gear...
  137. 4*40 Cg
  138. Contender...the original
  139. clear coat lustrekote
  140. Great planes corsair
  141. 40 size warbirds
  142. Monokote sags only in winter
  143. Top Flite paint question
  144. How do I glue CA hinges?
  145. T.F. Cessna 182/Robart Strut ?
  146. aeromaster CG?
  147. wing help?
  148. Covring with silk span
  149. Flying wires for a Byron Christen Eagle?
  150. Zero side or right side thrust
  151. Spirit Elite
  152. How to fuelproof?
  153. Soldering vs. J.B. Weld?
  154. Fiberglass Specialties site?
  155. Landing gear for 60- size GP Aeromaster
  156. Landing gear for 60- size GP Aeromaster
  157. retracts GP AT-6
  158. Watch Your great-plains order.
  159. 40 sized retracts
  160. Sig Four Star 40 Instruction Manual
  161. Muffler Clearence?
  162. Pete-N-Poke Sport 40
  163. Sanding elevator to shape
  164. Filling Hinge Gaps
  165. Greetings all.
  166. 1/3 scale WACO
  167. Foam Wings
  168. Unionville kits
  169. pull pull
  170. Hog Bipe and OS 61FX?
  171. wing incidence
  172. D&L Designs kits?
  173. What R All These Saws We R Talkign About???
  174. Another dern covering question
  175. Dry wall seam tape (fiber glass)
  176. 4 * 60 wing attachment
  177. WANTED, Model builder
  178. Need Help Completing...
  179. covering materials
  180. firberglass cowl
  181. Oooops!
  182. Rocket City still around ?
  183. JU-52 (Bahuer)
  184. making scale rivets
  185. what's the smallest plane you've ever fiberglassed?
  186. Fiberglass Reinforcemet
  187. SIG Kadet Senior ailerons & flaps
  188. Recovering an ARF. Everythings already hinged, can I still do it?
  189. Need Airplane For Saito 120
  190. Carl Goldberg "Gentle Lady"
  191. mounting the motor
  192. What happened to the Great Planes .40 size Spitfire?
  193. My GP F-4
  194. Century Jet Retracts
  195. cowl installed and more....
  196. an alternative cowl idea.
  197. DB Sopwith pub 1/4 scale,wing spars?
  198. Great Planes die cutting
  199. Fiberglassing a Wing Joint
  200. fenesse pattern ?
  201. Which Cub
  202. DynaFlite Decathalon?? Suggestions
  203. Carl Goldberg Super Chipmunk still available?
  204. CG Bucker mods??
  205. AKM models...OK!
  206. 4 star wing covering
  207. hog bipe
  208. new goldberg ultimate
  209. Generix Predator: No instructions!
  210. midstar 40: seperate aileron servos??
  211. Kanata RV-4 good, bad, ugly?
  212. Close Post please..
  213. Spring Air Retracts
  214. Great Planes Patriot Kit
  215. HOB Extra 300L Cowl?
  216. Robart Retracts
  217. Goldberg Sukhoi
  218. Sig vs Great Planes
  219. Started my SE last night
  220. MonoKote and Paint??
  221. HELP! I need a canopy for a Pilot Christen Eagle
  222. OS 70 - which 4*?
  223. vacuum bagging wings
  224. Has anyone built or know anyone that has built an American Eagle P-51
  225. Questions on covering.
  226. Need: MIDWEST Cap 232 Airfoil Tail
  227. Think this will 3D?
  228. Top Flite
  229. CA hinges, or Robart super point hinges?
  230. Tips on building a Telemaster 150 Kit
  231. 1/4 scale cub engine
  232. Top Flight Corsair questions
  233. Removing Monokote Film, Help!
  234. Looking for plans For a Marks Model or Jemco P-51 D
  235. LT-40 Dihedral question???
  236. GP .40 Extra vs GP .40 Cap232?
  237. Great Planes Piper Cub
  238. sig hog bipe
  239. Spinner for Top Flite AT-6 Texan?
  240. 30's racing plane kits
  241. U.S. Aircore Colt 40 information
  242. Another newbie question
  243. 1/5 Scale Cessna 170 - Ikon West Kit
  244. Need information for Goldberg Extra 300
  245. Bridi Sun Fly V
  246. need input/light 4 star
  247. Sig Kadet LT-40 assembly question
  248. sig skybolt
  249. Filling the gap
