PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70
  1. Sheeting a wing - step by step, Please!
  2. Basic Areonautic Terms and Meaning
  3. Glue differences and sagging stabs
  4. rudder
  5. My First Kit - 4*60 - How tight for Pull Pull
  6. Ryan Sta Kit?
  7. Spirit Of Yesteryear Gee Bee
  8. Best Source for GIANT CANOPYS
  9. Midwest Super Stearman
  10. Scroll saw or Band saw?
  11. Painting and covering material
  12. Wing Tips
  13. Profiling control surfaces
  14. Army green (olive drab) fabric
  15. Doesn't anybody make 10 Size Kits
  16. Sig Fazer Motor Mount Help!!
  17. MonoKote tips
  18. To pant or not to pant
  19. Balsa USA DR-1 engine set up
  20. My First Kit - 4 * 60 - how much weight is to much for CG
  21. sig senor CG
  22. Midwest srvo mounting idea, midwest's email in reply of the crash, a must read.
  23. 4*60 Question
  24. Bomb bay doors ???? Mechanism
  25. Need Help Tinting
  26. sig Racal 110
  27. Great Planes CAP-232
  28. Homemade Struts On A Decathlon
  29. Converting Guillow's P40 HELP!!!
  30. Question on dual aileron servo's on a 4*40
  31. HELP!! Kaos wing.
  32. master airscrew razor plane ??
  33. Joining foam wings with dihedral
  34. Trim Schemes
  35. Two planes, One trim scheme?
  36. Extra 300S Help
  37. Help In Finishing
  38. Hobby Dynamics Sportee 40
  39. Windshield for B-24 (JS)
  40. CA Hinge tools
  41. Kit building services
  42. Advice for throttle control linkage?
  43. What is your favorite kit building task?... your least favorite?
  44. Short Kit & Regular Kit
  45. 4 * 60 Solo Today, Yeah Baby!
  46. Can a TE be removed with debonder ?
  47. Leading Edges
  48. Kits
  49. plane balance
  50. How critical is the accuracy of the wings
  51. TopFlite P51D .60 Robart, Century, or Bob V. retracts ?
  52. Foam to Balsa glue???
  53. Servo in wing
  54. Celing tile(which kind?) or sheet rock on top?
  55. Best glue for big scale
  56. Killer Kaos wing instructions?
  57. Monocote Shelf-life
  58. 4 star 40, cowl??
  59. What's the perfect engine for the 4*60?
  60. A-6 or AE 6b Kit?
  61. Good first kit recommendation???
  62. Plan Protector ??????
  63. Smooth paint finish over balsa
  64. trailing edge.. to round off, or not to round off??
  65. Die cut parts in Slow Poke 40 kit
  66. Major Stab Mod Finished!
  67. need help finding correct size pilot.
  68. hobby hangar one design
  69. G/P Extra 300s vs 4* 40
  70. Yellow P-47 Ailerons
  71. Joining Wings
  72. Balsa USA Pheaton 40
  73. Built-up or Foam Wing?
  74. My removable 4*60 tank floor for 14oz GP
  75. New Fun Fly
  76. Flatness...
  77. Balsa USA Phaeton ll opinions
  78. Aeromasteritis
  79. Offset Hinges
  80. need to fill gap - what to use?
  81. SIG Somethin Extra
  82. I Need Decals
  83. Silverfish/woodworm attack !!
  84. Scrapper
  85. Adhering Cockpit Combing
  86. Spitfire Cowl
  87. cg ultimate fiber cowl?
  88. Eurokit Yak 18
  89. Kits, the demise of!
  90. Glassing technique?
  91. Help!
  92. painting blue foam.
  93. Fuel-proof clear coat. Which one to use???
  94. SKYWAY Red Admiral ( Heard of it?)
  95. Super Sportster 40
  96. Flite metal experiences?
  97. Latex Paint ?
  98. lazybee disscusion , about anything about the lazybee.
  99. H9 US 40 ultra stick wanted
  100. In flight saito problems
  101. Maratuka Stuka
  102. 14oz Tank in 4*60
  103. GP Patriot Tail Surface Help!
  104. where to find woodscrews #1 & smaller?
  105. Warp Wing
  106. Sealing Balsa for paint
  107. 4 Star and fuel tank set up?
  108. .60 size Aeromaster /Jungmeister
  109. ColorFab
  110. graphics.
  111. Sig Hog Bipe (Set up and configuration)
  112. covering woes
  113. worped wing
  114. Ever do this?
  115. Monocote and Ultracote compatibility?
  116. Looking For Someone In The Nyc Area Close To Brooklyn To Finshed Up A Few Models For
  117. BalsaNova 40
  118. Which one? Monokote or 21st century fabric???
  119. Glass Cowl manufacturer choice ?
  120. My First Kit - Also a Four Star 60
  121. stangel technologies hornet 60 bipe... any comments?
  122. Top-Flite Cessna
  123. Ugly graphics
  124. How do I deal with warped wood?
  125. Bibe kit for a YS 91?
  126. GP Super Skybolt suggestions
  127. Berkley B-26 Maurader
  128. Topp Mini Camp
  129. Building Contracts: Kits and ARF's
  130. Help! Goop attacks!
  131. What's the longest sanding bar I need ?
  132. Gee Bee R2
  133. Columbo Anderson 300L - Tips
  134. Can someone describe the monocote process for me please?
  135. Applying Ultracote to Ultracote
  136. White Monokote Won't Stick!
  137. Carl Glodberg Ultimate 10-300
  138. P-51
  139. Turbo Bee
  140. Read Before Buying!!
  141. GP Ultimate Bipe .40
  142. Antenna Route 4 Star 60
  143. Aileron Servos For Hog Bipe
  144. Dumb Question
  145. Sig Astro Hog
  146. Tiger 40
  147. GP Old Timer 40
  148. Gp Us +
  149. Small razor planes
  150. lazy bee building
  151. Balsa USA enforcer
  152. Looking For Sig Hog Bipe Cowling
  153. 4*60 Mods - Wheel pants and bomb
  154. control surface connectors
  155. Help with Balsa USA Thunderbug 40
  156. Jack Stafford Bird Dog
  157. Glass parts
  158. Aileron linkage on G.P Ultimate 40
  159. Q How do you thin Epoxy?
  160. help covering dorsal fin.
  161. fusco aircraft long EZ questions...
  162. My TF cessna 182 PICS
  163. plans for 64" Stearman by Sterling
  164. Gluing the Canopy
  165. Cutting covering with a vinyl cutter
  166. Mounting The Ignition Box On A Decathlon?
  167. Beechcraft Staggerwing Bipe
  168. drywall building board point to remember!
  169. sherlock 727 planes
  170. Byron Christen Eagle
  171. Ly-25 Question
  172. taking a warp out
  173. When pinning things to your surface, do you pin through the plane part?? Pls Help
  174. Finishing Resin Vs. Epoxy
  175. P38 Lightning Kits - Which one?
  176. CG Tiger 40 fuel tank position
  177. Aeromaster Too
  178. Gb ultimate almost done!!
  179. Freezing aliphatic???
  180. Have a silly question about kit building
  181. Was somebody looking for a set of these plans?
  182. X-Acto 2000
  183. Sheeting foam fuselage
  184. What do you use to cut Balsa Wood Perfectly
  185. Build up my courage!
  186. 21st Century Coverite
  187. Need a cowl for a Sig Smith Mini Plane
  188. Need help from the covering pro's
  189. GP Super Kaos vintage 1984
  190. P-81 Ligthning Kit - recommendations
  191. WIK Modelle Fournier RF4D "HELP"
  192. Need HELP!!!!
  193. civilian canard kits?
  194. Jerry Bates Yak-3?
  195. Tower Hobbies Extra Special construction pics
  196. Hog Bipe Flies!
  197. New toy!!!!!
  198. SIG SE antenna routing - how far out?
  199. Sig Astro Hog CG?
  200. Another 4*60 question!
  201. Look what I got!
  202. Sig Fazer - Wing strong enough?
  203. avatar?
  204. sanding wing tips
  205. TF P-39 Construction
  206. Metal hinges
  207. Auto paint
  208. Having Plans Kitted
  209. Cessna Fuel tank ..I think I made a mistake
  210. Good kits no longer in production!!
  211. Any Sugestions
  212. Installing clear Canopies?? HELP
  213. jack stafford air coupe
  214. Sig SE - Antenna wire
  215. some tips on silkspan and dope process please!!!
  216. Lanier Ultimate Pitts
  217. 4 Star 40 contol throws and CG Question
  218. Does anyone know who kits a V-tail Bonanza
  219. Engine mount ?
  220. Book request...
  221. 1/4 Spacewalker Servos
  222. Which Extra Should I build???
  223. Please post Ultimate 10-300 three view
  224. H9 Edge CG
  225. Basswood or Plywood?
  226. Plans for a Kyosho Skyraider Kit
  227. cap stripping
  228. Right trust on Hog Bipe?
  229. AK-Models 3D Freedom build...Help!
  230. Professional builder?
  231. Great Planes Ultra Sport + "In Stock"
  232. Sig Cub 1/6 kit, acceptable engines?
  233. Need help on sealing a fuel hatch!!
  234. Global Corsair II
  235. Top Flite 108 Gallon Tank
  236. Kit bashing the Sig Hog Bipe.
  237. Flyguy1791 is alright!
  238. Topflite Elder Biplane
  239. Good thread
  240. Need SIG Wonder CG Info
  241. Top-Flite P-51 and Corsair 60 size
  242. Super Sportster Color Schemes
  243. Trainer with Flaps
  244. what retracts should i use in my topflight p39
  245. Which 108" cub? why?
  246. Running Twins from Main tank with header
  247. Thinner for Balsarite ?
  248. carl goldberg ultimate?
  249. wing warp, how do I fix it??
  250. Top Flite P-47 or Sea Fury? Can't decide which to build
