- GP Super Skybolt suggestions
- Berkley B-26 Maurader
- Topp Mini Camp
- Building Contracts: Kits and ARF's
- Help! Goop attacks!
- What's the longest sanding bar I need ?
- Gee Bee R2
- Columbo Anderson 300L - Tips
- Can someone describe the monocote process for me please?
- Applying Ultracote to Ultracote
- White Monokote Won't Stick!
- Carl Glodberg Ultimate 10-300
- P-51
- Turbo Bee
- Read Before Buying!!
- GP Ultimate Bipe .40
- Antenna Route 4 Star 60
- Aileron Servos For Hog Bipe
- Dumb Question
- Sig Astro Hog
- Tiger 40
- GP Old Timer 40
- Gp Us +
- Small razor planes
- lazy bee building
- Balsa USA enforcer
- Looking For Sig Hog Bipe Cowling
- 4*60 Mods - Wheel pants and bomb
- control surface connectors
- Help with Balsa USA Thunderbug 40
- Jack Stafford Bird Dog
- Glass parts
- Aileron linkage on G.P Ultimate 40
- Q How do you thin Epoxy?
- help covering dorsal fin.
- fusco aircraft long EZ questions...
- My TF cessna 182 PICS
- plans for 64" Stearman by Sterling
- Gluing the Canopy
- Cutting covering with a vinyl cutter
- Mounting The Ignition Box On A Decathlon?
- Beechcraft Staggerwing Bipe
- drywall building board point to remember!
- sherlock 727 planes
- Byron Christen Eagle
- Ly-25 Question
- taking a warp out
- When pinning things to your surface, do you pin through the plane part?? Pls Help
- Finishing Resin Vs. Epoxy
- P38 Lightning Kits - Which one?
- CG Tiger 40 fuel tank position
- Aeromaster Too
- Gb ultimate almost done!!
- Freezing aliphatic???
- Have a silly question about kit building
- Was somebody looking for a set of these plans?
- X-Acto 2000
- Sheeting foam fuselage
- What do you use to cut Balsa Wood Perfectly
- Build up my courage!
- 21st Century Coverite
- Need a cowl for a Sig Smith Mini Plane
- Need help from the covering pro's
- GP Super Kaos vintage 1984
- P-81 Ligthning Kit - recommendations
- WIK Modelle Fournier RF4D "HELP"
- Need HELP!!!!
- civilian canard kits?
- Jerry Bates Yak-3?
- Tower Hobbies Extra Special construction pics
- Hog Bipe Flies!
- New toy!!!!!
- SIG SE antenna routing - how far out?
- Sig Astro Hog CG?
- Another 4*60 question!
- Look what I got!
- Sig Fazer - Wing strong enough?
- avatar?
- sanding wing tips
- TF P-39 Construction
- Metal hinges
- Auto paint
- Having Plans Kitted
- Cessna Fuel tank ..I think I made a mistake
- Good kits no longer in production!!
- Any Sugestions
- Installing clear Canopies?? HELP
- jack stafford air coupe
- Sig SE - Antenna wire
- some tips on silkspan and dope process please!!!
- Lanier Ultimate Pitts
- 4 Star 40 contol throws and CG Question
- Does anyone know who kits a V-tail Bonanza
- Engine mount ?
- Book request...
- 1/4 Spacewalker Servos
- Which Extra Should I build???
- Please post Ultimate 10-300 three view
- H9 Edge CG
- Basswood or Plywood?
- Plans for a Kyosho Skyraider Kit
- cap stripping
- Right trust on Hog Bipe?
- AK-Models 3D Freedom build...Help!
- Professional builder?
- Great Planes Ultra Sport + "In Stock"
- Sig Cub 1/6 kit, acceptable engines?
- Need help on sealing a fuel hatch!!
- Global Corsair II
- Top Flite 108 Gallon Tank
- Kit bashing the Sig Hog Bipe.
- Flyguy1791 is alright!
- Topflite Elder Biplane
- Good thread
- Need SIG Wonder CG Info
- Top-Flite P-51 and Corsair 60 size
- Super Sportster Color Schemes
- Trainer with Flaps
- what retracts should i use in my topflight p39
- Which 108" cub? why?
- Running Twins from Main tank with header
- Thinner for Balsarite ?
- carl goldberg ultimate?
- wing warp, how do I fix it??
- Top Flite P-47 or Sea Fury? Can't decide which to build
- Cloud Dancer 40/ cowl
- Sliding canopy
- CA Hinge Material
- Need CG on Carl Goldberg Extra 300
- Parts List - Hollywood Zero
- GP Tracer, .40 sized
- Sig Four Star 40 throws and balance
- No room for a wheel collar!!!!!
- Advice on TF Zero kit.
- Cessna 182 top flite
- Painted Fiberglass Cutting
- Balsa Cutting Tools
- GP F-4 Phantom InstuctionBook?
- regarding your F16 miniE- Fan Kit
- Top Flite DC-3
- 4*60 So far
- 4-40 Thu-hole drill bit size?????
- Tiger 2 Construction question
- Super Decathalon w/OS40LA
- Fiberglass specialtys 4* cowl
- DPM Ultimate + Saito 180
- Anybody seen thier Ultrasport 40+ yet?
- Iron Temp. ?
- F8F-2 Bearcat ( Old TopFlite Kit) Manual
- Fuel Proof, or...
- US. Aircore Colt .40 Question
- SIG WONDER manual needed FOUND
- Venture 60 Cowl
- Aeroworks 25% EDGE
- Ultra Sport 1000 wing sheeting
- Super Kaos
- Balancing a Sig Hog Bipe
- 4* 120.......post weight?
- mounting on a cub scale wheel
- engine? 4 a Cloud Dancer kit
- help needed
- Looking For Someone In The Nyc Area Close To Brooklyn To Recover A Large Bipe For Me
- Easy to build bipe
- right tools for the job?
- my 4* 60 kit build with retracts UPDATE: CRASHED
- Need CG location on Sig 60 size King Kobra
- Thrust Line & Stabilizer Incidence
- Guillows kits RC compatible???
- Dummy Engine
- GP PT-ELECTRIC CONVERSION
- Home made decals
- 4* Canopy Tint..?
- Light weight wing for CAP 232
- where to buy fiberglass cowls
- use ca or aliphatic glues ??
- Sig Hog Bipe
- Pete N' Poke Sport 40
- Lion Models arf
- CG Balance
- 53 1/2 inch WS Piper J3 Cub
- Will silk and dope work?
- gear door hinge & spring
- SIG Kobra
- Wow
- What is MonoKote Trim Solvent?
- Sterling Fledgling
- RV-4 Great Planes
- Ace ultimate bipe... what engine?
- Yellow Aircraft P-47
- Ughhh!!!
- 33% tail wheel assembly
- Tips On A 727
- Lainer Ultimate Pitts.
- GP Ultra SPort 40+ Status???
- Monokote over Glass ???
- fuel proofing model masters paint
- Servo Trays
- Balsa Usa Laker Questions
- Paint for a warbird
- I got the covering on BUTT???
- Tips on drilling wing hold down on 4*40
- Hurky bird
- 4 star 40 and Wheel Pants
- .40-.60 biplane?
- How do you cover a plane?
- First Kit??
- Sig Somethin' Extra Help
- What Building Board
- 4*60 questions - I'm confused
- Help with nosen aeronca kit
- Four Star 40 or 60?
- cowl attachment
- Decals?
- 4* 60 with fiberglass specialties inc. cap-21 cowl
- Model/engine question
- Pica 1/5 YMF Waco top wing attach
- What twin with MDS 148 engines?
- 1/2 A Lanier Stinger 10 Kit ???
- Fusco Long Eeze
- Anyone flying the "NewBee" by Adrain Page?
- WM Frontier Senior ARF assembly help
- Washout
- Needed: Plans for GP T-Craft
- Question for 4* 60 builders/flyers
- manual please
- CA shelf life ?
- Profilm available in the US?
- Robart hinge questions...
- 4 Star 40 engine size?
- Urovitch OV-10 Kit
- Flaperons in a AreoMaster
- flair puppeteer kit
- need a cowling four star 120 or how to build.....
- Carl Goldberg Sukhoi
- Wing fitting on 4 * 60
- Larger 4*
- Midwest Sukhoi 40
- Four * 60 Prop size
- Goldberg Freedon 20
- Four Star 60 - Are Mechanical Retracts Possible....
- CA hinges
- Elevator and rudder counter-balances
- RIB template for CG Ultimate
- Goldberg Ultimate setup
- Warped vertical stabilizer?
- am I over glueing
- 4 Star Fuel Tank Installation
- Yellow Aircraft Kits
- Want to get into it but want advicce
