PDA
View Full Version : Kit Building
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70
  1. Cowling. How do you do it?
  2. Bridi Dirty Birdy
  3. Gizmo Kit :)
  4. Please close thread-moved to fun fly forum
  5. Removing dihedral from wing
  6. Fulton's Hobbies - "The Nibbler"
  7. CG Ultimate
  8. Deviation from thrust line
  9. Dihedral on a 4*60
  10. cockpits
  11. Perfectionist Building
  12. Servo / Torque rod hookup ?
  13. Incedence on bipe wings??
  14. GP Super Sport 40 or 4 Star 40?
  15. anyone build a Split 280 before?
  16. What size wire to use for 4-40 threading die
  17. APC compatible spinner
  18. GP Aeromaster 60
  19. Pneumatic Retracts or Servo? Your two cents, please!
  20. Pica Duellist 2/40
  21. ouch
  22. thinking winter project already!!!
  23. First Kit - Sig Something Extra - Wish me luck!
  24. Has anyone built a Sig Rascal Electric kit?
  25. stripping cloth and dope
  26. how many PIPER "?" kits are available
  27. Pica Duellist Instructions
  28. Starfire
  29. TF P-47 flaps
  30. hinge pin
  31. F8F2 Bearcat Retracts
  32. fiberglass cowls
  33. Anyone have an old Dynaflight Fun scale p51 mustang .60??
  34. Hobby Hanger kit quality
  35. Career Opportunity- Research and Development Technician
  36. monokote
  37. PBY kit without foam wings??
  38. How do you cover in camo???
  39. Lanier Laser
  40. build the wing of Brian Taylor 83" Spitfire IX
  41. Piper cub wheels
  42. Please Help
  43. Kwik Poly
  44. Skyfire 40 - Delta - any info would be great!
  45. Gp Skybolt Kit
  46. Wing AT-6 Spar location?
  47. G23 Kit?? Gasoline or Bust!
  48. Midwest .40 sport scale kits
  49. Lack of customer service at DP Models
  50. Pull Pull Systems
  51. Recent VMAR Kit?
  52. World Engines Robinhood 99 Kit
  53. Sig 1/4 scale clipped wing cub - Control Throws?
  54. Sig 1/4 scale clipped wing cub - Control Throws?
  55. Top Flite Nobler
  56. RC America Cap 232
  57. Whats a First Good Kit?
  58. Slotting Ailerons / TE ???
  59. Looking for a kit for a 1.20 4s
  60. Coloer Schemes
  61. 4*120 set up question
  62. Cyber Bond Glue?
  63. Beta kit builders wanted
  64. Morris gee-whiz b CofG
  65. Sig 4*60 - Where to glue APG part ??????
  66. LT40 Wing Kit Includes Plans?
  67. Engine size for a piper cub 71" WS
  68. Need (2) 6-32 eye bolts
  69. Servo wires to Bipe Top Wing
  70. Ohio R/c
  71. Any idea how to take some of the bounce out of wire gear?
  72. decals
  73. Sullivan Gold-N-Rods
  74. Monokote web site/article
  75. left turn ... which aerilon goes up ?
  76. Monokote is history
  77. How to get smooth finish?
  78. Help w/ Metallic Monokote
  79. Bud Nosen Trainer
  80. Covering Ailerons and Rudder?
  81. Sig Kadet MK I
  82. Anybody try Dave Brown Skyloft?
  83. How to put two servo's in Ultimate Bipe wing...?
  84. re cover
  85. Perfect paint not so perfect
  86. Ace 4-120 kit from 15(?) years ago?
  87. Dumb Question?
  88. Chevron Perfect Paint Matches Monokote?
  89. Lanier Ultimate Pitts
  90. Anyone have a new Goldberg Ultimate Bipe on the shelf?
  91. Jack Stafford Models
  92. Spacewalker II wing with fabric covering-rigid enough?
  93. Tail Brace Wires
  94. Great Plains Trainner 40 CG
  95. GP ultra sport 40 retracts
  96. Finishing Wood Wing Struts
  97. Help on Aresti Arf and Wheel Pants
  98. Covering Shelf Life
  99. replacements foam wings
  100. Heat gun?
  101. Balance question
  102. Need Recommendation on Dremel Tool Set
  103. Listen to the expert
  104. Bevel on Control Surfaces?
  105. Home Made Jig
  106. setting the rudder... vertical ?
  107. Help with wheel pants (GP skybolt)
  108. How do YOU do iron on fabric undercambered wings ?
  109. Sig 4 star 40 or 60 ... that is the question
  110. Best Glow Fuel Valve ???
  111. Great Planes 40 size spitfire
  112. Storch Kit
  113. Piainting my first airplane
  114. Stinger 10
  115. Sig Somethin Extra
  116. Sig or Dynaflite Cub
  117. Sig Somethin Extra Engine
  118. Bud Nosen Cessna 310
  119. GP Skybolt builders
  120. painting balsa
  121. retracts
  122. Lanier Taylorcraft on floats...power????
  123. Uproar .90 kit, where?
  124. Sig Cubs
  125. sig 1/4 scale cub...
  126. Storch kit
  127. how do you stop 4 stroke slobber from going through firewall?
  128. Easy building , Nice flying scale kit
  129. Gp Ultimate Bipe
  130. "Rules" For Wing Tube Installation in a built up wing
  131. Engine Box?
  132. Finishing up my Tiger 2
  133. Proctor/VK 1/2 Strutter
  134. .25 Size Kits?
  135. Help me decide on skybolt final bits of skybolt color scheme
  136. HOB Extra 300L
  137. midwest citabria vertical stab flapped like a bird!
  138. What Hitec servos to use??
  139. Another CA hinge question
  140. p-47 retracts
  141. My workbench
  142. HOB Laser
  143. DynaFlite Fun Scale Corsair
  144. balance
  145. Four Most Window Flange- Large
  146. Second kit after an LT-40?
  147. Wing Balancing
  148. Funtana S needs building help, lots and lots and lots of help!
  149. Telemaster Senior or Sig Kadet Senior
  150. Sig 4 * 60 idea's and tips?
  151. Tail unit off vertical axis slightly - what will happen in the sky?
  152. Astral Hog
  153. redimensioning .25 plans to .46 engine size
  154. Weeks Solution
  155. First covering job.
  156. Clost thread
  157. Sr. Telemaster - Candy Drop
  158. TBM Avenger/Heritage RC
  159. Regarding Shear Webs
  160. Servos for Midwest Extra 300XS
  161. Reparing Foam Core Wings
  162. kit availability of Grumman F3F
  163. advise on sealing hinge gap
  164. Covering the Somethin' Extra ?
  165. Wing Mfg. AT-6
  166. BTE Venture .60 and Saito .80?
  167. What do you buy right away with kit?
  168. Need giant scale builder in Northern CA - Minor Repairs
  169. Flair DR 1 kit
  170. How many X-Acto # 11 knives do you have in YOUR workroom?
  171. wood pecker on monokote
  172. covering iron
  173. Lanier Stinger 40?
  174. Pica P-40 1/5 scale kit
  175. Painting fiberglass?
  176. Questions - I'm building my 1st kit
  177. Wing sheeting here's another question
  178. foam wing repair
  179. Sig Clipped Wing Cub
  180. Royal P-38 pain in the tail?
  181. Hellcat
  182. Biscuits?
  183. 4*120 wing building,sheet or caps
  184. How to sheet a foam core wing?
  185. any suggestions on IMAA kit
  186. Questiong for GP SKYBOLT owners
  187. Best CA ?
  188. 21st Century covering
  189. Stephens AKRO kit from PILOT
  190. Stinson Reliant and YS-140?
  191. Wagner power painter? CBMf16
  192. Any comments on 1/4 scale CITABRIA kit by Bud Nosen?
  193. Building a TF-Spitfire, any advice?
  194. Finished Uproar 60
  195. Laser 200 Fron Lanier Review ?
  196. MidWest "StarDuster" questions
  197. EZ-VAC Vacum Bagging System
  198. Shrike Question???
  199. help with 21st Century paint
  200. Show me your LT-40! (or similar high wing)
  201. Forming landing gear with music wire?
  202. Twin Shrike .10s?..Almost done!!!!!
  203. DH2 instruction manual
  204. best spray paint for foam?
  205. Sig Somethin' Extra questions
  206. Wing twisting?
  207. Wing / Fuse building jig
  208. What Paint to use for Canopy Base?
  209. Looking for GeeBee kit
  210. Lanier Taylorcraft building question
  211. Tapered checkerboard, How?
  212. covering material compatability?
  213. CG Extra 300 Landing gear?
  214. Midwest extra 300
  215. Two Piece Wing for Sr. Telemaster
  216. Help with a color scheme
  217. Everything I wanted to know about kit building but was too scared to ask!
  218. midwest cap color scheme
  219. ultracote
  220. pete n poke
  221. Need Help
  222. Fabric or Plastic
  223. EXTREME DogHouse Extreme
  224. GP Extra 300 40size cowl
  225. Poll: Which is more popular -- Kit Building or Float Planes?
  226. cowl and canopy attachment
  227. Plans for Forty-sized Ultimate Bipe
  228. Covering Sig 4* wing
  229. GP Cap232 up thrust
  230. Great Planes Dazzler kit
  231. Pica 1/5 Scale Bucker Jungmeister
  232. Starting a Tiger 60
  233. Top-Flite AT-6 Almost Finished
  234. Flutter problem....exhaust deflector?
  235. Dehavilland twin otter kit
  236. Latest Project MK Laser 200 kit
  237. glass epoxy fuselage spare
  238. Top Flite 182
  239. Sig Kobra
  240. Something Extra wing gap
  241. Herr Engineering AT-6 Texan
  242. First time building
  243. Help covering & painting
  244. helpful tip of the week!
  245. Edge 540
  246. 4 stroke muffler heat and cowls
  247. What weight Fiberglass?
  248. Carl Goldberg Ultimate Bipe instructions
  249. House of Balsa
  250. Kit with easy to follow instructions
